Implementing a Daily Analytics Export Job for Genesys Cloud to S3 Using Python
  • You will build a Python script that queries Genesys Cloud Conversation Analytics for the previous 24 hours and uploads the resulting CSV data to an Amazon S3 bucket.
  • This solution uses the Genesys Cloud Python SDK (genesyscloud) for data retrieval and boto3 for AWS S3 operations.
  • The tutorial covers Python 3.9+ with type hints, error handling for rate limits, and pagination logic.
  • Genesys Cloud OAuth Client: A Service Account with the following scopes:
    • analytics:conversation:read
    • analytics:queue:read (if using queue-based queries)
  • AWS Credentials: An IAM user or role with s3:PutObject permissions on the target bucket.
  • Python Environment: Python 3.9 or higher.
  • Dependencies:
    • genesyscloud>=2.0.0 (Official Genesys Cloud Python SDK)
    • boto3>=1.28.0 (AWS SDK for Python)
    • pandas>=2.0.0 (For efficient CSV generation from JSON responses)
Install dependencies via pip:
pip install genesyscloud boto3 pandas
Genesys Cloud uses OAuth 2.0. For server-side jobs like this, you should use a Service Account with Client Credentials grant. The Genesys Cloud Python SDK handles token refresh automatically if configured correctly.
You must store your credentials securely. For this tutorial, we assume environment variables are set:
  • GENESYS_CLOUD_REGION (e.g., mypurecloud.ie)
  • GENESYS_CLOUD_CLIENT_ID
  • GENESYS_CLOUD_CLIENT_SECRET
  • AWS_ACCESS_KEY_ID
  • AWS_SECRET_ACCESS_KEY
  • AWS_S3_BUCKET_NAME
Initialize the Genesys Cloud client:
import os
from genesyscloud.platform.client import PlatformClient
from genesyscloud.authentication.client import AuthenticationClient
def init_genesys_client() -> PlatformClient:
    Initializes the Genesys Cloud Platform Client using Client Credentials grant.
    region = os.getenv("GENESYS_CLOUD_REGION")
    client_id = os.getenv("GENESYS_CLOUD_CLIENT_ID")
    client_secret = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
    if not all([region, client_id, client_secret]):
        raise EnvironmentError("Missing Genesys Cloud environment variables.")
    # The SDK automatically handles token acquisition and refresh
    platform_client = PlatformClient(
        host=f"https://{region}",
        oauth_client_id=client_id,
        oauth_client_secret=client_secret
    return platform_client
Step 1: Define the Analytics Query
Genesys Cloud Analytics uses a query-based model. You do not pull raw logs; you submit a query definition. For a daily export, we typically want conversation details grouped by time intervals.
We will use the /api/v2/analytics/conversations/details/query endpoint. This endpoint supports pagination via the pageSize parameter and returns a nextPage token if more data exists.
Define the query payload. Note the use of interval to bucket data into hourly chunks, which reduces payload size compared to per-conversation granularity if you only need aggregates. If you need individual conversation transcripts or metrics, remove the groupings field.
import datetime
from typing import Dict, Any
def build_daily_query() -> Dict[str, Any]:
    Constructs a query for the last 24 hours of conversation data.
    Groups by hour to manage payload size.
    now = datetime.datetime.now(datetime.timezone.utc)
    start_time = (now - datetime.timedelta(hours=24)).isoformat()
    end_time = now.isoformat()
    query = {
        "view": "summary",
        "dateFrom": start_time,
        "dateTo": end_time,
        "interval": "PT1H",  # Hourly buckets
        "select": [
            "conversationId",
            "channel",
            "queueId",
            "startTime",
            "endTime",
            "holdTime",
            "talkTime",
            "wrapUpTime"
        "groupings": [
            "time"
        "filters": {
            "type": "and",
            "clauses": [
                    "type": "dimension",
                    "dimension": "channel",
                    "operator": "eq",
                    "value": "voice"
    return query
Step 2: Execute Query with Pagination and Retry Logic
The analytics API can return large datasets. You must handle pagination using the nextPage token. Additionally, Genesys Cloud enforces rate limits. A 429 status code requires an exponential backoff strategy.
The Genesys Cloud Python SDK provides ConversationAnalyticsApi. We will iterate until nextPage is None.
import json
from genesyscloud.analytics.conversations.client import ConversationAnalyticsClient
from genesyscloud.rest import Exception as GenesysRestException
def fetch_analytics_data(
    conversation_client: ConversationAnalyticsClient,
    query: Dict[str, Any],
    max_retries: int = 5
) -> list:
    Fetches paginated analytics data with retry logic for 429 errors.
    Args:
        conversation_client: Genesys Cloud ConversationAnalyticsClient instance
        query: The query definition dictionary
        max_retries: Maximum number of retries for rate limit errors
    Returns:
        A list of all result objects from the query
    all_results = []
    next_page_token = None
    retries = 0
    while True:
            # Prepare request parameters
            request_kwargs = {
                "body": query,
                "page_size": 1000,  # Max allowed page size
                "expand": ["metrics"] # Expand metrics for detailed data
            if next_page_token:
                request_kwargs["next_page"] = next_page_token
            # Execute the query
            response = conversation_client.post_analytics_conversations_details_query(**request_kwargs)
            # Reset retries on success
            retries = 0
            # Accumulate results
            if response.entities:
                all_results.extend(response.entities)
            # Check for next page
            if response.next_page:
                next_page_token = response.next_page
            else:
                break
        except GenesysRestException as e:
            if e.status == 429:
                # Rate Limit Hit
                if retries < max_retries:
                    wait_time = 2 ** retries  # Exponential backoff: 1, 2, 4, 8, 16 seconds
                    print(f"Rate limited. Retrying in {wait_time} seconds...")
                    time.sleep(wait_time)
                    retries += 1
                else:
                    raise Exception(f"Max retries exceeded for 429 error: {e.message}")
            elif e.status in [401, 403]:
                raise Exception(f"Authentication/Authorization error: {e.message}")
            else:
                raise e
    return all_results
Step 3: Process Results and Generate CSV
Raw JSON from Genesys Cloud is nested. To write a clean CSV for S3, we need to flatten the structure. We will use pandas for this, as it handles nested JSON expansion and CSV writing efficiently.
import pandas as pd
import io
def process_results_to_csv(results: list) -> io.BytesIO:
    Converts a list of Genesys Cloud analytics entities into a CSV byte stream.
    Flattens nested objects for easier downstream processing.
    Args:
        results: List of analytics entity objects
    Returns:
        BytesIO object containing the CSV data
    if not results:
        raise ValueError("No analytics data returned to process.")
    # Convert SDK objects to dictionaries
    # The SDK objects are dataclasses or similar, we need to serialize them.
    # Depending on SDK version, you may need to use .to_dict() or json.dumps
    # Here we assume the entities have a method or attribute to convert to dict.
    # In recent genesyscloud SDKs, entities are often serializable via json.
    import json
    data_dicts = []
    for entity in results:
        # Serialize the entity to JSON string then back to dict to ensure flat structure
        # This handles nested objects like 'metrics' or 'groupings'
        entity_json = json.loads(json.dumps(entity.to_dict() if hasattr(entity, 'to_dict') else entity))
        data_dicts.append(entity_json)
    # Create DataFrame
    df = pd.json_normalize(data_dicts)
    # Flatten specific nested structures if necessary
    # For example, if 'groupings' contains a list of time buckets, we might want to explode it
    # However, for a simple export, the normalized structure is usually sufficient.
    # Write to BytesIO
    csv_buffer = io.BytesIO()
    df.to_csv(csv_buffer, index=False)
    csv_buffer.seek(0)
    return csv_buffer
Step 4: Upload to Amazon S3
Use boto3 to upload the CSV buffer to S3. We will generate a timestamped filename to ensure idempotency (if the job runs twice, it creates a new file rather than overwriting).
import boto3
from botocore.exceptions import ClientError as BotoClientError
import os
def upload_to_s3(
    csv_data: io.BytesIO,
    bucket_name: str,
    key_prefix: str = "analytics/"
) -> str:
    Uploads CSV data to an S3 bucket.
    Args:
        csv_data: BytesIO object containing CSV content
        bucket_name: Target S3 bucket name
        key_prefix: Prefix for the S3 object key
    Returns:
        The S3 object key (path) where the file was uploaded
    s3_client = boto3.client('s3')
    # Generate unique filename based on current timestamp
    timestamp = datetime.datetime.now(datetime.timezone.utc).strftime("%Y%m%d_%H%M%S")
    filename = f"genesys_conversations_{timestamp}.csv"
    s3_key = f"{key_prefix}{filename}"
        s3_client.put_object(
            Bucket=bucket_name,
            Key=s3_key,
            Body=csv_data.getvalue(),
            ContentType='text/csv'
        print(f"Successfully uploaded to s3://{bucket_name}/{s3_key}")
        return s3_key
    except BotoClientError as e:
        raise Exception(f"Failed to upload to S3: {e.response['Error']['Message']}")
This script combines all steps into a single executable module. Save this as daily_analytics_export.py.
#!/usr/bin/env python3
Daily Genesys Cloud Analytics Export to S3
import os
import sys
import io
import json
import datetime
import pandas as pd
import boto3
    return PlatformClient(
def build_daily_query() -> dict:
        "view": "summary",
        "dateTo": end_time,
        "interval": "PT1H",
        "select": [
            "conversationId", "channel", "queueId",
            "startTime", "endTime", "holdTime", "talkTime", "wrapUpTime"
        "groupings": ["time"],
        "filters": {
            "type": "and",
            "clauses": [
                {"type": "dimension", "dimension": "channel", "operator": "eq", "value": "voice"}
def fetch_analytics_data(conversation_client: ConversationAnalyticsClient, query: dict) -> list:
    all_results = []
    retries = 0
    max_retries = 5
    while True:
            request_kwargs = {
                "body": query,
                "page_size": 1000,
            if next_page_token:
            retries = 0
            else:
                break
            if e.status == 429:
                    retries += 1
                else:
                raise Exception(f"Auth error: {e.message}")
            else:
                raise e
    return all_results
    if not results:
        raise ValueError("No analytics data returned.")
    data_dicts = []
        # Handle serialization based on SDK object type
        if hasattr(entity, 'to_dict'):
            entity_dict = entity.to_dict()
        else:
            # Fallback for different SDK versions
            entity_dict = json.loads(json.dumps(entity))
        data_dicts.append(entity_dict)
    csv_buffer.seek(0)
    return csv_buffer
def upload_to_s3(csv_data: io.BytesIO, bucket_name: str) -> str:
    filename = f"genesys_voice_{timestamp}.csv"
    s3_key = f"analytics/{filename}"
            Bucket=bucket_name,
            Key=s3_key,
        return s3_key
        raise Exception(f"S3 Upload failed: {str(e)}")
def main():
        print("Initializing Genesys Cloud Client...")
        platform_client = init_genesys_client()
        conversation_client = ConversationAnalyticsClient(platform_client)
        print("Building query for last 24 hours...")
        query = build_daily_query()
        print("Fetching analytics data...")
        results = fetch_analytics_data(conversation_client, query)
        print(f"Fetched {len(results)} data points.")
        if not results:
            print("No data found. Exiting.")
            return
        print("Processing data to CSV...")
        csv_data = process_results_to_csv(results)
        bucket_name = os.getenv("AWS_S3_BUCKET_NAME")
        if not bucket_name:
            raise EnvironmentError("Missing AWS_S3_BUCKET_NAME environment variable.")
        print(f"Uploading to S3 bucket: {bucket_name}...")
        s3_key = upload_to_s3(csv_data, bucket_name)
        print(f"Export complete. File location: s3://{bucket_name}/{s3_key}")
        print(f"Error: {str(e)}", file=sys.stderr)
        sys.exit(1)
    main()
  • Cause: The Genesys Cloud Analytics API has strict rate limits, especially for high-volume queries. The default retry logic in the SDK may not be sufficient for bulk exports.
  • Fix: Implement exponential backoff as shown in fetch_analytics_data. Ensure you are not making parallel requests from multiple threads without respecting the global rate limit.
  • Code Fix: The provided code includes a while loop with time.sleep(2 ** retries) to handle this automatically.
Error: 400 Bad Request - “Query is too complex”
  • Cause: The query exceeds the maximum execution time or resource limit. This often happens with wide date ranges or too many groupings.
  • Fix: Reduce the dateFrom to dateTo range. Process data in smaller chunks (e.g., 6-hour windows instead of 24 hours). Remove unnecessary select fields.
  • Debug: Check the x-correlation-id header in the response to trace the specific query failure in Genesys Cloud logs.
Error: 403 Forbidden - “Insufficient permissions”
  • Cause: The Service Account lacks the analytics:conversation:read scope.
  • Fix: Go to Genesys Cloud Admin > Security > OAuth Clients. Edit your client and ensure analytics:conversation:read is selected. Restart the script to pick up the new token.
Error: Pandas Serialization Error
  • Cause: The Genesys Cloud SDK returns complex objects that pandas.json_normalize cannot flatten directly if nested lists contain non-dict objects.
  • Fix: Ensure you convert SDK entities to plain dictionaries using json.dumps and json.loads before passing to pandas. The process_results_to_csv function handles this via json.loads(json.dumps(entity)).
