Implementing a Custom Skill-Based Routing Decision Engine via Genesys Cloud Queue Assignment Events
A Node.js microservice that intercepts Genesys Cloud queue assignment events, evaluates agent skill proficiencies against a Redis cache, and programmatically approves or re-routes conversations based on custom business logic. This tutorial uses the Genesys Cloud Node.js SDK, the Routing Events WebSocket API, and the Queue Assignment REST API. The programming language covered is JavaScript (Node.js 18+).
  • OAuth client credentials with the following scopes: routing:events:read, routing:queue:read, routing:user:read, routing:assignment:write, view:users
  • Genesys Cloud Node.js SDK version 4.14.0 or higher
  • Node.js runtime version 18.0 or higher
  • Redis server running on localhost:6379 (or accessible via network)
  • External dependencies: @genesyscloud/node-js-client, ioredis, ws
Genesys Cloud requires OAuth 2.0 client credentials flow for server-to-server communication. The Node.js SDK includes a built-in token manager that handles initial acquisition and automatic refresh. You must configure the base URL, client ID, and client secret before invoking any API methods.
const { PureCloudPlatformClientV2 } = require('@genesyscloud/node-js-client');
const genesys = new PureCloudPlatformClientV2();
async function configureOAuth() {
  const grantOptions = {
    clientId: process.env.GENESYS_CLIENT_ID,
    clientSecret: process.env.GENESYS_CLIENT_SECRET,
    grantType: 'client_credentials',
    scope: [
      'routing:events:read',
      'routing:queue:read',
      'routing:user:read',
      'routing:assignment:write',
      'view:users'
    ].join(' ')
    await genesys.loginClientCredentials(grantOptions);
    console.log('OAuth authentication successful. Token cached.');
  } catch (error) {
    console.error('OAuth authentication failed:', error.response?.data || error.message);
    process.exit(1);
module.exports = { genesys, configureOAuth };
The SDK stores the access token in memory and automatically appends it to subsequent requests. When the token approaches expiration, the SDK invokes the refresh endpoint transparently. You do not need to implement manual token rotation logic unless you require cross-process token sharing.
Step 1: Initialize Redis Cache and WebSocket Event Subscription
The routing decision engine requires fast lookup of agent proficiency scores to avoid API latency during peak routing windows. Redis stores precomputed skill matrices keyed by agent and queue identifiers. The Routing Events WebSocket stream delivers real-time assignment payloads. You must subscribe to the WebSocket, parse incoming messages, and filter for QUEUE_MEMBER_ASSIGNED events.
const Redis = require('ioredis');
const { genesys, configureOAuth } = require('./auth');
const redis = new Redis({
  host: process.env.REDIS_HOST || '127.0.0.1',
  port: process.env.REDIS_PORT || 6379,
  retryStrategy: (times) => Math.min(times * 200, 2000)
async function subscribeToRoutingEvents() {
  await configureOAuth();
  const eventsApi = genesys.RoutingEventsApi;
  // Subscribe to routing events with specific event types
  const eventFilter = {
    eventType: ['QUEUE_MEMBER_ASSIGNED'],
    queueId: null, // null listens to all queues
    userId: null
  const websocket = await eventsApi.getRoutingEventsWebsocket(eventFilter);
  websocket.on('message', async (data) => {
    const event = JSON.parse(data.toString());
    if (event.eventType === 'QUEUE_MEMBER_ASSIGNED') {
      await processAssignmentEvent(event);
  websocket.on('error', (error) => {
    console.error('Routing events WebSocket error:', error.message);
  websocket.on('close', () => {
    console.warn('Routing events WebSocket disconnected. Reconnecting in 5 seconds...');
    setTimeout(subscribeToRoutingEvents, 5000);
  console.log('Listening to routing events...');
The getRoutingEventsWebsocket method establishes a persistent connection to wss://api.mypurecloud.com/api/v2/routing/events. The SDK handles heartbeat packets and automatic reconnection for transient network failures. You must explicitly handle the close event to trigger manual re-subscription when the connection drops permanently.
Step 2: Intercept Assignment and Evaluate Proficiency Against Cache
When a QUEUE_MEMBER_ASSIGNED event arrives, the payload contains queueId, memberId (agent user ID), and conversationId. The microservice checks Redis for a cached proficiency score. If the cache misses, the service fetches the agent routing profile from Genesys Cloud, evaluates the custom skill matrix, and stores the result in Redis with a time-to-live (TTL) of 300 seconds.
async function processAssignmentEvent(event) {
  const { queueId, memberId, conversationId } = event.data;
  const cacheKey = `routing:skill:${memberId}:${queueId}`;
    let proficiency = await redis.get(cacheKey);
    let score = proficiency ? parseFloat(proficiency) : null;
    if (score === null) {
      score = await fetchAndCacheProficiency(queueId, memberId);
    const decision = evaluateSkillThreshold(score);
    console.log(`Agent ${memberId} score: ${score}, Decision: ${decision}`);
    if (decision === 'reject') {
      await rejectAndReRouteAssignment(queueId, conversationId, memberId);
    } else {
      console.log(`Assignment approved for conversation ${conversationId}`);
  } catch (error) {
    console.error(`Failed to process assignment for ${conversationId}:`, error.message);
async function fetchAndCacheProficiency(queueId, userId) {
  const routingUsersApi = genesys.RoutingUsersApi;
    const profile = await routingUsersApi.getRoutingUserProfile(userId);
    const skillEntry = profile.skills?.find(s => s.queueId === queueId);
    if (!skillEntry) {
      return 0;
    const score = skillEntry.proficiency || 0;
    await redis.set(cacheKeyFor(userId, queueId), score, 'EX', 300);
    return score;
  } catch (error) {
    if (error.code === 429) {
      await exponentialBackoff(error);
      return fetchAndCacheProficiency(queueId, userId);
    throw error;
function cacheKeyFor(userId, queueId) {
  return `routing:skill:${userId}:${queueId}`;
The getRoutingUserProfile endpoint returns /api/v2/routing/users/{userId}/routing/profile. The response includes a skills array containing queue-specific proficiency values. You must handle HTTP 429 rate limit responses explicitly. The Genesys Cloud API returns a Retry-After header on 429 responses. The exponentialBackoff function parses this header and delays the retry accordingly.
Step 3: Implement Custom Skill Evaluation and Assignment Rejection
The decision engine applies a threshold-based rule. Agents with a proficiency score below 0.75 are considered unqualified for the target queue. When a rejection occurs, the microservice calls the Queue Assignment API to terminate the current assignment and optionally create a new assignment to a qualified agent. You must construct a valid assignment payload with status: "rejected" or status: "completed" to clear the routing state.
function evaluateSkillThreshold(score) {
  const MINIMUM_PROFICIENCY = 0.75;
  return score >= MINIMUM_PROFICIENCY ? 'approve' : 'reject';
async function rejectAndReRouteAssignment(queueId, conversationId, rejectedUserId) {
  const routingQueuesApi = genesys.RoutingQueuesApi;
  const rejectionPayload = {
    conversationId: conversationId,
    userId: rejectedUserId,
    status: 'rejected',
    reason: 'Skill proficiency below threshold'
    await routingQueuesApi.postRoutingQueueAssignment(queueId, rejectionPayload);
    console.log(`Assignment rejected for ${rejectedUserId} on queue ${queueId}`);
    // Optional: Trigger re-routing by posting a new assignment to a qualified agent
    // await routingQueuesApi.postRoutingQueueAssignment(queueId, {
    //   conversationId: conversationId,
    //   userId: process.env.FALLBACK_AGENT_ID,
    //   status: 'assigned'
  } catch (error) {
      return rejectAndReRouteAssignment(queueId, conversationId, rejectedUserId);
    throw error;
async function exponentialBackoff(error) {
  const retryAfter = error.response?.headers?.['retry-after'] || 1;
  const delay = Math.min(retryAfter * 1000, 10000);
  console.warn(`Rate limited. Retrying in ${delay}ms...`);
  return new Promise(resolve => setTimeout(resolve, delay));
The postRoutingQueueAssignment endpoint maps to /api/v2/routing/queues/{queueId}/assignments. The request body must include conversationId, userId, and status. The status field accepts assigned, rejected, or completed. Rejecting an assignment removes the agent from the active routing queue for that conversation, allowing the Genesys Cloud routing engine to evaluate the next available agent. You must implement retry logic for 429 responses because assignment endpoints are heavily throttled during high-volume routing windows.
require('dotenv').config();
    } else {
  } catch (error) {
    if (!skillEntry) {
      return 0;
    await redis.set(`routing:skill:${userId}:${queueId}`, score, 'EX', 300);
    return score;
  } catch (error) {
    throw error;
    status: 'rejected',
  } catch (error) {
    throw error;
    queueId: null,
    userId: null
subscribeToRoutingEvents().catch(console.error);
Save this file as routing-engine.js. Create a .env file with GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, and optionally REDIS_HOST and REDIS_PORT. Run the service using node routing-engine.js. The microservice maintains a persistent WebSocket connection, caches proficiency scores, and evaluates every assignment event in real time.
Error: HTTP 401 Unauthorized
  • What causes it: The OAuth token is expired, invalid, or the client credentials lack the required scopes.
  • How to fix it: Verify that the .env file contains valid client credentials. Ensure the OAuth client in Genesys Cloud is configured with routing:events:read and routing:user:read scopes. Restart the service to trigger a fresh token acquisition.
  • Code showing the fix:
} catch (error) {
  if (error.code === 401) {
    console.error('Invalid credentials or missing scopes. Check .env and Genesys OAuth client configuration.');
    process.exit(1);
  throw error;
Error: HTTP 403 Forbidden
  • What causes it: The OAuth client lacks permissions to read routing profiles or write queue assignments.
  • How to fix it: Navigate to the Genesys Cloud Admin console, locate the OAuth client, and add routing:assignment:write and view:users to the scope list. Save the configuration and restart the microservice.
  scope: 'routing:events:read routing:queue:read routing:user:read routing:assignment:write view:users'
  • What causes it: The Genesys Cloud API enforces rate limits per endpoint. High-volume routing windows trigger 429 responses when the microservice polls profiles or posts assignments too frequently.
  • How to fix it: Implement exponential backoff with jitter. Parse the Retry-After header from the 429 response. Cache proficiency scores in Redis to reduce API calls.
  const jitter = Math.random() * 500;
  const delay = Math.min(retryAfter * 1000 + jitter, 10000);
Error: WebSocket Connection Refused or Stale
  • What causes it: Network instability, firewall restrictions, or Genesys Cloud platform maintenance disconnects the event stream.
  • How to fix it: Implement automatic reconnection logic on the close event. Verify that outbound WebSocket traffic to api.mypurecloud.com port 443 is allowed. Add health check endpoints to monitor connection status.
websocket.on('close', (code, reason) => {
  console.warn(`WebSocket closed. Code: ${code}, Reason: ${reason}`);
