Implementing a custom queue routing strategy by manipulating queue positions and agent availability through the Routing API using a Java client with optimistic locking
- This tutorial builds a Java service that programmatically updates agent availability states and routing skills to enforce a custom queue routing strategy.
- It uses the Genesys Cloud CX Routing API (
/api/v2/routing/users/{userId}/availability) and the officialplatform-client-javaSDK. - The implementation demonstrates optimistic locking using the
diversionfield to prevent race conditions during concurrent routing updates.
- OAuth 2.0 Client Credentials flow configured in Genesys Cloud Admin with
routing:availability:writeandrouting:availability:readscopes. - Genesys Cloud CX Java SDK version 19.5.0 or higher.
- Java 17+ runtime environment.
- Maven dependencies for
platform-client-javaandjackson-databindfor JSON processing.
<dependency>
<groupId>com.mendix.core.client</groupId>
<artifactId>platform-client-java</artifactId>
<version>19.5.0</version>
</dependency>
<dependency>
<groupId>com.fasterxml.jackson.core</groupId>
<artifactId>jackson-databind</artifactId>
<version>2.15.2</version>
</dependency>
Genesys Cloud CX uses OAuth 2.0 for all API authentication. The Java SDK does not manage token lifecycles automatically, so you must implement a token fetcher and inject the access token into the ApiClient instance. The following code demonstrates a production-ready token acquisition method using Java 17 HttpClient.
import java.net.URI;
import java.net.URLEncoder;
import java.nio.charset.StandardCharsets;
public class GenesysAuth {
private static final String TOKEN_URL = "https://api.myspotinstance.com/api/v2/oauth/token";
private static final ObjectMapper MAPPER = new ObjectMapper();
public static String fetchAccessToken(String clientId, String clientSecret, String grantType) throws Exception {
String body = String.format(
"client_id=%s&client_secret=%s&grant_type=%s",
URLEncoder.encode(clientId, StandardCharsets.UTF_8),
URLEncoder.encode(clientSecret, StandardCharsets.UTF_8),
URLEncoder.encode(grantType, StandardCharsets.UTF_8)
.uri(URI.create(TOKEN_URL))
.header("Content-Type", "application/x-www-form-urlencoded")
.POST(HttpRequest.BodyPublishers.ofString(body))
.build();
HttpResponse<String> response = HttpClient.newHttpClient().send(request, HttpResponse.BodyHandlers.ofString());
throw new RuntimeException("OAuth token request failed with status: " + response.statusCode());
JsonNode json = MAPPER.readTree(response.body());
return json.get("access_token").asText();
Step 1: Initialize Client and Fetch Current Availability
Before manipulating routing behavior, you must retrieve the current availability state to obtain the diversion value. The diversion field acts as a version stamp for optimistic locking. Genesys Cloud rejects any availability update that does not include the current diversion value, preventing lost updates when multiple systems modify the same agent state simultaneously.
Required OAuth scope: routing:availability:read
import com.mendix.core.client.gen.client.ApiClient;
import com.mendix.core.client.gen.client.ApiException;
import com.mendix.core.client.gen.client.RoutingApi;
import com.mendix.core.client.gen.model.UserAvailability;
public class AvailabilityFetcher {
private final RoutingApi routingApi;
public AvailabilityFetcher(ApiClient apiClient) {
this.routingApi = new RoutingApi(apiClient);
public UserAvailability getCurrentAvailability(String userId) throws ApiException {
// GET /api/v2/routing/users/{userId}/availability
UserAvailability current = routingApi.getRoutingUserAvailability(userId);
if (current.getDiversion() == null) {
throw new IllegalStateException("Diversion field is null. The user may not be provisioned for routing.");
return current;
} catch (ApiException e) {
if (e.getCode() == 404) {
throw new RuntimeException("User " + userId + " not found in routing system.", e);
throw e;
Step 2: Apply Custom Routing Logic with Optimistic Locking
To enforce a custom routing strategy, you modify the state and wrapUpCode fields. For example, setting a specific wrap code can trigger post-interaction routing rules, while changing the state to Available or Busy directly impacts queue position calculations. You must copy the diversion value from Step 1 into the payload before submission.
Required OAuth scope: routing:availability:write
Raw HTTP equivalent:
POST /api/v2/routing/users/12345678-1234-1234-1234-123456789012/availability HTTP/1.1
Host: api.myspotinstance.com
"diversion": "3",
"state": "Available",
"wrapUpCode": "routing:wrapupcode:custom_routing_trigger",
"reason": "System-driven routing adjustment"
public class RoutingStrategyApplier {
public RoutingStrategyApplier(ApiClient apiClient) {
public UserAvailability applyCustomStrategy(String userId, UserAvailability baseAvailability, String targetState, String targetWrapCode) throws ApiException {
// Clone or create new availability object to preserve diversion
UserAvailability updated = new UserAvailability();
updated.setDiversion(baseAvailability.getDiversion()); // Critical for optimistic locking
updated.setState(targetState);
updated.setWrapUpCode(targetWrapCode);
updated.setReason("Automated routing strategy adjustment");
// POST /api/v2/routing/users/{userId}/availability
UserAvailability result = routingApi.postRoutingUserAvailability(userId, updated);
return result;
Step 3: Handle 409 Conflicts and Implement Retry Logic
When two processes update the same agent availability concurrently, the second submission receives a 409 Conflict response because the diversion value has changed. You must implement a retry loop that re-fetches the latest state, recalculates the routing strategy, and resubmits. The following implementation caps retries at three attempts to prevent infinite loops during network partitions.
import java.time.Instant;
public class OptimisticLockHandler {
private final AvailabilityFetcher fetcher;
private final RoutingStrategyApplier applier;
private static final int MAX_RETRIES = 3;
private static final long RETRY_DELAY_MS = 500;
public OptimisticLockHandler(ApiClient apiClient) {
this.fetcher = new AvailabilityFetcher(apiClient);
this.applier = new RoutingStrategyApplier(apiClient);
public UserAvailability updateWithLocking(String userId, String targetState, String targetWrapCode) throws Exception {
int attempts = 0;
while (attempts < MAX_RETRIES) {
UserAvailability current = fetcher.getCurrentAvailability(userId);
UserAvailability result = applier.applyCustomStrategy(userId, current, targetState, targetWrapCode);
return result;
if (e.getCode() == 409 && attempts < MAX_RETRIES - 1) {
attempts++;
System.out.println("Optimistic lock conflict detected. Retry " + attempts + " after backoff.");
TimeUnit.MILLISECONDS.sleep(RETRY_DELAY_MS * attempts); // Linear backoff
} else {
throw e;
throw new RuntimeException("Max retries exceeded for user " + userId);
The following class integrates authentication, optimistic locking, and error handling into a single executable service. Replace the placeholder credentials and instance URL before execution.
public class CustomRoutingStrategyService {
private static final String INSTANCE_URL = "https://api.myspotinstance.com";
private static final String CLIENT_ID = "your_client_id";
private static final String CLIENT_SECRET = "your_client_secret";
private static final String TARGET_USER_ID = "12345678-1234-1234-1234-123456789012";
String accessToken = GenesysAuth.fetchAccessToken(CLIENT_ID, CLIENT_SECRET, "client_credentials");
ApiClient apiClient = new ApiClient();
apiClient.setBasePath(INSTANCE_URL);
apiClient.setAccessToken(accessToken);
CustomRoutingStrategyService service = new CustomRoutingStrategyService(apiClient);
service.executeRoutingUpdate(TARGET_USER_ID, "Available", "routing:wrapupcode:priority_queue_access");
} catch (Exception e) {
e.printStackTrace();
private final ApiClient apiClient;
public CustomRoutingStrategyService(ApiClient apiClient) {
this.apiClient = apiClient;
public void executeRoutingUpdate(String userId, String targetState, String targetWrapCode) throws Exception {
int attempts = 0;
// Step 1: Fetch current availability to retrieve diversion
UserAvailability current = apiClient.getApiClient().getApiClient()
.getRoutingApi().getRoutingUserAvailability(userId);
throw new IllegalStateException("User availability diversion is null. Routing system not initialized.");
// Step 2: Prepare update payload with optimistic lock
updated.setDiversion(current.getDiversion());
updated.setReason("Custom routing strategy enforcement");
// Step 3: Submit update
UserAvailability result = apiClient.getApiClient().getRoutingApi()
System.out.println("Routing update successful. New diversion: " + result.getDiversion());
return;
attempts++;
System.out.println("409 Conflict: Diversion mismatch. Retry " + attempts + " in " + (RETRY_DELAY_MS * attempts) + "ms");
} else if (e.getCode() == 429) {
String retryAfter = e.getResponseHeaders().getOrDefault("Retry-After", "5");
long delay = Long.parseLong(retryAfter) * 1000;
System.out.println("429 Rate Limited. Waiting " + delay + "ms");
TimeUnit.MILLISECONDS.sleep(delay);
} else {
throw e;
throw new RuntimeException("Failed to update routing strategy after " + MAX_RETRIES + " attempts.");
- Cause: The access token has expired, been revoked, or contains incorrect scopes. Genesys Cloud OAuth tokens expire after one hour.
- Fix: Implement token caching with a TTL buffer (e.g., refresh at 55 minutes). Verify the OAuth client in Genesys Cloud Admin has the
routing:availability:writescope enabled. - Code Fix: Wrap the token fetcher in a scheduler or use a token provider interface that checks
Instant.now().isBefore(tokenExpiry.minusSeconds(300))before reuse.
Error: 403 Forbidden
- Cause: The authenticated OAuth client lacks permission to modify routing states, or the target user ID belongs to a different organization.
- Fix: Confirm the client credentials match the organization hosting the target user. Check the OAuth client settings for the
routing:availability:writescope. Verify the user ID format matches UUID standards.
Error: 409 Conflict
- Cause: Optimistic locking failure. The
diversionvalue submitted does not match the current server state. This occurs when Genesys Cloud internal processes, the admin console, or another integration updates the agent state concurrently. - Fix: Always re-fetch the availability state before retrying. Never reuse a cached
diversionvalue across multiple update attempts. The retry loop in the complete example handles this by fetching fresh state on each attempt.
- Cause: Exceeding the Genesys Cloud CX rate limits. The Routing API enforces per-organization and per-endpoint throttling.
- Fix: Read the
Retry-Afterheader from the response. Implement exponential backoff with jitter. For bulk routing updates, queue requests and process them at a controlled throughput (e.g., 10 requests per second per user batch).
