Implementing a custom Genesys Cloud routing script that evaluates caller attributes and updates queue assignments using the Routing API and a NestJS microservice
  • A NestJS microservice that accepts incoming caller attributes, evaluates them against business rules, and programmatically updates agent queue assignments and routing script conditions.
  • The implementation uses the Genesys Cloud Routing API endpoints (/api/v2/routing/queues, /api/v2/routing/users/{userId}/queues, /api/v2/routing/scripts/{scriptId}) via a custom HTTP client.
  • The tutorial covers TypeScript with NestJS, including production-grade retry logic, pagination handling, and explicit error mapping.
  • OAuth 2.0 Client Credentials grant type with scopes: routing:queue:write, routing:user:write, routing:script:write, routing:queue:read
  • Genesys Cloud API version: v2
  • Runtime: Node.js 18+
  • Dependencies: @nestjs/common, @nestjs/core, @nestjs/platform-express, axios, class-validator, class-transformer
  • Environment variables: GENESYS_DOMAIN, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET
Genesys Cloud requires OAuth 2.0 Client Credentials for machine-to-machine communication. The microservice must fetch an access token, cache it, and refresh it before expiration. The following service manages token lifecycle and attaches it to every outbound request.
import { Injectable, Logger } from '@nestjs/common';
import axios, { AxiosInstance, InternalAxiosRequestConfig } from 'axios';
@Injectable()
export class GenesysAuthService {
  private readonly logger = new Logger(GenesysAuthService.name);
  private readonly axiosInstance: AxiosInstance;
  private tokenCache: { accessToken: string; expiresAt: number } | null = null;
  constructor() {
    this.axiosInstance = axios.create({
      baseURL: `https://${process.env.GENESYS_DOMAIN}`,
      timeout: 10000,
    this.axiosInstance.interceptors.request.use(async (config: InternalAxiosRequestConfig) => {
      if (!this.tokenCache || Date.now() >= this.tokenCache.expiresAt - 60000) {
        await this.refreshToken();
      if (this.tokenCache?.accessToken) {
        config.headers.Authorization = `Bearer ${this.tokenCache.accessToken}`;
      return config;
  private async refreshToken(): Promise<void> {
      const response = await axios.post(
        `https://${process.env.GENESYS_DOMAIN}/oauth/token`,
        new URLSearchParams({
          client_id: process.env.GENESYS_CLIENT_ID || '',
          client_secret: process.env.GENESYS_CLIENT_SECRET || '',
        { headers: { 'Content-Type': 'application/x-www-form-urlencoded' } }
      this.tokenCache = {
        accessToken: response.data.access_token,
        expiresAt: Date.now() + (response.data.expires_in * 1000),
      this.logger.log('OAuth token refreshed successfully');
    } catch (error) {
      this.logger.error('Failed to refresh OAuth token', error);
      throw new Error('Authentication failed: unable to retrieve access token');
  getClient(): AxiosInstance {
    return this.axiosInstance;
The interceptor checks the expiration window sixty seconds before actual expiry to prevent mid-request token failures. The refreshToken method uses application/x-www-form-urlencoded as required by the OAuth 2.0 specification.
Step 1: Configure the Genesys Cloud HTTP Client with Retry Logic
Rate limiting (HTTP 429) is common when batch-updating routing assignments. The client must implement exponential backoff with jitter. The following interceptor handles transient failures automatically.
import axios, { AxiosError, InternalAxiosRequestConfig } from 'axios';
@Injectable()
export class GenesysHttpClient {
  private readonly logger = new Logger(GenesysHttpClient.name);
  private readonly client: any;
  constructor(private readonly authService: GenesysAuthService) {
    this.client = this.authService.getClient();
    this.client.interceptors.response.use(
      (response) => response,
      async (error: AxiosError) => {
        const originalRequest = error.config as InternalAxiosRequestConfig & { _retryCount?: number };
        if (!originalRequest) return Promise.reject(error);
        if (error.response?.status === 429 && (originalRequest._retryCount || 0) < 3) {
          const retryCount = (originalRequest._retryCount || 0) + 1;
          originalRequest._retryCount = retryCount;
          const retryAfter = error.response.headers['retry-after']
            ? parseInt(error.response.headers['retry-after'] as string, 10)
            : Math.pow(2, retryCount) * 1000 + Math.random() * 500;
          this.logger.warn(`Rate limited. Retrying in ${retryAfter}ms (attempt ${retryCount})`);
          await new Promise((resolve) => setTimeout(resolve, retryAfter));
          return this.client(originalRequest);
        this.logger.error(`Genesys API error: ${error.response?.status} - ${error.message}`);
  getInstance() {
    return this.client;
The interceptor reads the Retry-After header when present. If the header is absent, it falls back to exponential backoff with random jitter to prevent thundering herd scenarios. Requests exceeding three retries fail fast to avoid indefinite blocking.
Step 2: Resolve Queue Identifiers via Pagination
Queue names are human-readable but the Routing API requires UUIDs. The GET /api/v2/routing/queues endpoint returns paginated results. The following method fetches all matching queues and caches them by name.
import { GenesysHttpClient } from './genesys-http-client.service';
export interface QueueEntity {
@Injectable()
export class GenesysRoutingService {
  private readonly logger = new Logger(GenesysRoutingService.name);
  private queueCache: Map<string, string> = new Map();
  constructor(private readonly httpClient: GenesysHttpClient) {}
  async resolveQueueIds(queueNames: string[]): Promise<Record<string, string>> {
    if (queueNames.length === 0) return {};
    const mapping: Record<string, string> = {};
    const encodedNames = queueNames.map((name) => encodeURIComponent(name)).join('&name=');
    const endpoint = `/api/v2/routing/queues?name=${encodedNames}&pageSize=100`;
    let nextPage = endpoint;
    while (nextPage) {
      const response = await this.httpClient.getInstance().get(nextPage);
      const data = response.data;
      for (const queue of data.entities || []) {
        if (!mapping[queue.name]) {
          mapping[queue.name] = queue.id;
      nextPage = data.nextPage || null;
    this.logger.log(`Resolved ${Object.keys(mapping).length} queue identifiers`);
    return mapping;
The loop continues until nextPage is null. The pageSize=100 parameter maximizes throughput while staying within default API limits. The method returns a name-to-ID mapping for downstream assignment logic.
Step 3: Evaluate Caller Attributes and Update Queue Assignments
Caller attributes arrive as key-value pairs. The service evaluates them against routing rules and updates the target user via PATCH /api/v2/routing/users/{userId}/queues. This endpoint requires the routing:user:write scope.
  async updateQueueAssignment(
    userId: string,
    callerAttributes: Record<string, string>,
    queueMapping: Record<string, string>
  ): Promise<void> {
    const targetQueue = this.evaluateRoutingRules(callerAttributes);
    const queueId = queueMapping[targetQueue];
    if (!queueId) {
      throw new Error(`Queue "${targetQueue}" not found in resolved mapping`);
    const payload = [
        rank: 1,
        status: 'available',
        wrapUpTime: 0,
      await this.httpClient.getInstance().patch(
        `/api/v2/routing/users/${userId}/queues`,
        payload,
        { headers: { 'Content-Type': 'application/json' } }
      this.logger.log(`Updated queue assignment for user ${userId} to ${targetQueue}`);
    } catch (error) {
      this.logger.error(`Failed to update queue assignment for ${userId}`, error);
      throw error;
  private evaluateRoutingRules(attributes: Record<string, string>): string {
    const tier = attributes.tier?.toLowerCase();
    const language = attributes.language?.toLowerCase();
    if (tier === 'vip') return 'Premium Support';
    if (language === 'es') return 'Spanish Support';
    return 'Standard Support';
The PATCH request replaces the user’s current queue assignment array. The rank field determines routing priority across multiple queues. The status field must be available, unavailable, or busy. The evaluation method demonstrates attribute-based branching. Extend it with regex or threshold checks as required.
Step 4: Modify Routing Script Conditions
Routing scripts control conversation flow. The PUT /api/v2/routing/scripts/{scriptId} endpoint replaces the entire script definition. The following method updates a specific condition to route VIP callers to a dedicated queue.
  async updateRoutingScriptCondition(
    scriptId: string,
    targetQueueId: string,
    conditionIndex: number
  ): Promise<void> {
    const scriptResponse = await this.httpClient.getInstance().get(`/api/v2/routing/scripts/${scriptId}`);
    const script = scriptResponse.data;
    if (!script.conditions || !script.conditions[conditionIndex]) {
      throw new Error(`Condition index ${conditionIndex} does not exist in script ${scriptId}`);
    script.conditions[conditionIndex].actions = [
        type: 'queue',
        queueId: targetQueueId,
        defaultAction: {
          type: 'queue',
    script.conditions[conditionIndex].label = `Route to ${targetQueueId}`;
      await this.httpClient.getInstance().put(
        `/api/v2/routing/scripts/${scriptId}`,
        script,
      this.logger.log(`Updated condition ${conditionIndex} in script ${scriptId}`);
    } catch (error) {
      this.logger.error(`Failed to update routing script ${scriptId}`, error);
      throw error;
The PUT operation is destructive. It requires the full script payload. The method fetches the current definition, mutates the specified condition, and pushes the complete object back. The routing:script:write scope is mandatory. Always validate scriptId before mutation to prevent accidental overwrites.
The following NestJS module and controller wire the services together. The endpoint accepts caller attributes, resolves queues, updates assignments, and modifies the routing script.
import { Module } from '@nestjs/common';
import { GenesysAuthService } from './genesys-auth.service';
import { GenesysRoutingService } from './genesys-routing.service';
import { RoutingController } from './routing.controller';
@Module({
  imports: [],
  controllers: [RoutingController],
  providers: [GenesysAuthService, GenesysHttpClient, GenesysRoutingService],
  exports: [GenesysRoutingService],
export class RoutingModule {}
import { Controller, Post, Body, BadRequestException, Logger } from '@nestjs/common';
export interface CallerPayload {
  userId: string;
  scriptId: string;
  conditionIndex: number;
  attributes: Record<string, string>;
  queueNames: string[];
@Controller('routing')
export class RoutingController {
  private readonly logger = new Logger(RoutingController.name);
  constructor(private readonly routingService: GenesysRoutingService) {}
  @Post('evaluate-and-route')
  async evaluateAndRoute(@Body() payload: CallerPayload) {
    if (!payload.userId || !payload.scriptId || !payload.attributes) {
      throw new BadRequestException('Missing required fields: userId, scriptId, attributes');
      const queueMapping = await this.routingService.resolveQueueIds(payload.queueNames);
      await this.routingService.updateQueueAssignment(payload.userId, payload.attributes, queueMapping);
      const targetQueueName = this.routingService['evaluateRoutingRules'](payload.attributes);
      const targetQueueId = queueMapping[targetQueueName];
      if (targetQueueId) {
        await this.routingService.updateRoutingScriptCondition(
          payload.scriptId,
          targetQueueId,
          payload.conditionIndex || 0
      return { status: 'success', message: 'Routing configuration updated' };
    } catch (error) {
      this.logger.error('Routing evaluation failed', error);
      throw error;
The controller validates input, delegates to the service layer, and returns a structured response. The private method access in the example assumes TypeScript compilation preserves accessibility. In production, extract evaluateRoutingRules to a public method or a dedicated rule engine.
Error: HTTP 401 Unauthorized
  • Cause: Expired or invalid OAuth token. The interceptor failed to refresh before the request.
  • Fix: Verify GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET match the Genesys Cloud integration. Check the /oauth/token response for error or error_description fields. Ensure the client credentials grant type is enabled in the Genesys Cloud admin console.
  • Code fix: Add explicit token validation before batch operations:
    if (!this.tokenCache || Date.now() >= this.tokenCache.expiresAt) {
Error: HTTP 403 Forbidden
  • Cause: Missing OAuth scope. The client lacks routing:user:write, routing:queue:write, or routing:script:write.
  • Fix: Navigate to Genesys Cloud Admin > Security > Integrations > OAuth. Select the client and add the required scopes. Restart the microservice to trigger a fresh token request.
  • Verification: Log the token response and inspect the scope claim in the JWT payload.
  • Cause: Exceeded Genesys Cloud rate limits (typically 10 requests per second per client for routing endpoints).
  • Fix: The retry interceptor handles automatic backoff. For high-volume workloads, implement request queuing with a token bucket algorithm. Spread mutations across multiple client credentials if available.
  • Code fix: Add a global request limiter:
    import PQueue from 'p-queue';
    const queue = new PQueue({ concurrency: 8, interval: 100, intervalCap: 10 });
    // Wrap API calls: await queue.add(() => this.client.patch(...))
Error: HTTP 400 Bad Request
  • Cause: Invalid JSON structure or missing required fields in the script payload. The PUT /api/v2/routing/scripts/{scriptId} endpoint rejects partial updates.
  • Fix: Validate the script schema before submission. Ensure conditions, actions, and defaultAction match the Genesys Cloud routing script schema. Use the application/json content type explicitly.
  • Debugging: Enable Axios debug logging to inspect the exact request body:
    axios.defaults.debug = true;
