Implementing a Custom Dialer Pattern with Pause and Retry Logic Using the CXone Call Control API in Java
A Java application that programmatically initiates outbound voice calls via the CXone Call Control API, monitors call state with configurable pause intervals, and automatically retries failed attempts based on specific termination codes. This tutorial uses the CXone REST API surface with Java 17 built-in HTTP client components. The language covered is Java.
- CXone OAuth client credentials with
calls:writeandcalls:readscopes - CXone Call Control API v2
- Java 17 or higher
com.fasterxml.jackson.core:jackson-databind(version 2.15.0 or higher) for JSON serialization and deserialization- Access to a CXone sandbox or production environment with outbound calling enabled
CXone uses OAuth 2.0 client credentials flow for machine-to-machine API access. The Call Control API requires explicit scope declaration. Token caching is mandatory because CXone enforces strict rate limits on the /oauth/token endpoint and reusing a valid token prevents unnecessary authentication overhead.
import java.net.URI;
import java.time.Instant;
import java.util.Base64;
public class CxoneAuthClient {
private final HttpClient httpClient;
private final ObjectMapper mapper;
private final String baseUrl;
private final String clientId;
private final String clientSecret;
private String accessToken;
private Instant tokenExpiry;
public CxoneAuthClient(String subdomain, String clientId, String clientSecret) {
this.baseUrl = String.format("https://%s.api.cxone.com", subdomain);
this.clientId = clientId;
this.httpClient = HttpClient.newBuilder()
.followRedirects(HttpClient.Redirect.NEVER)
.build();
this.mapper = new ObjectMapper();
this.tokenExpiry = Instant.now();
public String getAccessToken() throws Exception {
if (accessToken != null && Instant.now().isBefore(tokenExpiry)) {
return accessToken;
String authHeader = Base64.getEncoder().encodeToString(
String.format("%s:%s", clientId, clientSecret).getBytes()
.uri(URI.create(baseUrl + "/oauth/token"))
.header("Authorization", "Basic " + authHeader)
.header("Content-Type", "application/x-www-form-urlencoded")
.POST(HttpRequest.BodyPublishers.ofString("grant_type=client_credentials&scope=calls:write%20calls:read"))
.build();
throw new RuntimeException("OAuth token request failed with status " + response.statusCode() + ": " + response.body());
JsonNode json = mapper.readTree(response.body());
accessToken = json.get("access_token").asText();
long expiresIn = json.get("expires_in").asLong();
tokenExpiry = Instant.now().plusSeconds(expiresIn - 60); // Buffer 60 seconds for clock skew
return accessToken;
The token cache checks Instant.now() against tokenExpiry before issuing a network request. The buffer accounts for server-client clock drift. The scope parameter explicitly requests calls:write and calls:read, which CXone evaluates at the token issuance level. Missing scopes will result in a 403 Forbidden on subsequent API calls rather than at authentication time.
Step 1: Initialize HTTP Client and OAuth Token Management
The dialer requires a persistent HTTP client that respects connection pooling and TLS settings. Java 17 HttpClient handles connection reuse automatically. You must attach the bearer token to every request. CXone validates the token on every call, and expired tokens return 401 Unauthorized.
import java.time.Duration;
public class CxoneDialerClient {
private final CxoneAuthClient authClient;
public CxoneDialerClient(CxoneAuthClient authClient, String subdomain) {
this.authClient = authClient;
.connectTimeout(Duration.ofSeconds(10))
.build();
private HttpRequest.Builder baseRequestBuilder() throws Exception {
String token = authClient.getAccessToken();
return HttpRequest.newBuilder()
.uri(URI.create(baseUrl))
.header("Accept", "application/json");
Step 2: Initiate Outbound Call
CXone provisions outbound calls asynchronously. The POST /api/v2/calls endpoint returns immediately with a 201 Created status and a provisional call object. The API design separates call initiation from media routing to prevent request timeouts during carrier negotiation.
// ... previous code ...
private final ObjectMapper mapper = new ObjectMapper();
public String initiateCall(String fromNumber, String toNumber) throws Exception {
String requestBody = String.format(
"{\"from\":{\"phoneNumber\":\"%s\"},\"to\":[{\"phoneNumber\":\"%s\"}],\"type\":\"voice\"}",
fromNumber, toNumber
HttpRequest request = baseRequestBuilder()
.uri(URI.create(baseUrl + "/api/v2/calls"))
.POST(HttpRequest.BodyPublishers.ofString(requestBody))
.build();
if (response.statusCode() != 201) {
throw new RuntimeException("Call initiation failed with status " + response.statusCode() + ": " + response.body());
String callId = mapper.readTree(response.body()).get("id").asText();
return callId;
The request body uses E.164 formatted phone numbers. CXone validates number formatting at the application layer. Invalid formats return a 400 Bad Request with a detailed error object. The response contains the id field, which you must store for subsequent status polling.
Step 3: Implement Status Polling with Pause Logic
CXone does not push call state updates via WebSockets for the Call Control API. You must poll GET /api/v2/calls/{callId} until the call reaches a terminal state. Aggressive polling triggers 429 Too Many Requests because CXone enforces per-endpoint rate limits. Pause logic with exponential backoff prevents cascade failures.
public JsonNode pollCallStatus(String callId, int maxPolls, long initialPauseMs) throws Exception {
long pauseMs = initialPauseMs;
for (int attempt = 0; attempt < maxPolls; attempt++) {
.uri(URI.create(baseUrl + "/api/v2/calls/" + callId))
.GET()
.build();
if (response.statusCode() == 429) {
String retryAfter = response.headers().firstValue("Retry-After").orElse("5");
long waitMs = Long.parseLong(retryAfter) * 1000;
Thread.sleep(waitMs);
continue;
throw new RuntimeException("Status poll failed with status " + response.statusCode());
JsonNode statusNode = mapper.readTree(response.body());
String status = statusNode.get("status").asText();
if (status.equals("completed") || status.equals("failed") ||
status.equals("busy") || status.equals("no-answer") ||
status.equals("canceled")) {
return statusNode;
Thread.sleep(pauseMs);
pauseMs = Math.min(pauseMs * 2, 30000); // Cap at 30 seconds
throw new RuntimeException("Call status polling timed out after " + maxPolls + " attempts");
The pause interval doubles after each poll, capped at thirty seconds. This exponential backoff aligns with CXone carrier routing latency, which typically resolves within five to fifteen seconds. The Retry-After header handling ensures compliance with platform rate limits. Terminal states include completed, failed, busy, no-answer, and canceled. Non-terminal states like ringing or connected trigger the sleep loop.
Step 4: Implement Retry Logic and Error Handling
Telephony networks experience transient failures. A custom dialer must distinguish between permanent failures and retryable conditions. CXone returns busy and no-answer as terminal states, but your business logic may require retrying these specific outcomes. Network errors (5xx) and OAuth token expiration require immediate retry without incrementing the call attempt counter.
import java.util.Set;
private static final Set<String> RETRYABLE_STATUSES = Set.of("busy", "no-answer", "failed");
public JsonNode executeDialWithRetry(String fromNumber, String toNumber, int maxRetries) throws Exception {
int attempt = 0;
while (attempt < maxRetries) {
attempt++;
String callId = null;
callId = initiateCall(fromNumber, toNumber);
JsonNode result = pollCallStatus(callId, 20, 2000);
String status = result.get("status").asText();
if (!RETRYABLE_STATUSES.contains(status)) {
return result; // Success or non-retryable terminal state
if (attempt < maxRetries) {
long backoff = (long) Math.pow(2, attempt) * 1000;
Thread.sleep(backoff);
} catch (Exception e) {
if (e.getMessage().contains("401") || e.getMessage().contains("429")) {
Thread.sleep(5000);
continue;
throw e;
throw new RuntimeException("Dialer exhausted all retries for " + toNumber);
The retry loop evaluates the final call status against a predefined set. Successful connections or explicit cancellations exit immediately. The backoff calculation uses Math.pow(2, attempt) to create increasing delays between retries. OAuth 401 errors trigger a forced token refresh via authClient.getAccessToken() on the next iteration.
The following class combines authentication, call initiation, status polling, and retry logic into a single executable module. Replace the placeholder credentials with your CXone OAuth details.
public class CxoneCustomDialer {
public CxoneCustomDialer(String subdomain, String clientId, String clientSecret) {
.build();
private String getAccessToken() throws Exception {
return accessToken;
.build();
throw new RuntimeException("OAuth token request failed: " + response.body());
return accessToken;
String token = getAccessToken();
.build();
throw new RuntimeException("Call initiation failed: " + response.body());
return mapper.readTree(response.body()).get("id").asText();
.GET()
.build();
Thread.sleep(Long.parseLong(retryAfter) * 1000);
continue;
throw new RuntimeException("Status poll failed: " + response.body());
if (Set.of("completed", "failed", "busy", "no-answer", "canceled").contains(status)) {
return statusNode;
throw new RuntimeException("Polling timed out");
int attempt = 0;
attempt++;
String callId = initiateCall(fromNumber, toNumber);
return result;
Thread.sleep((long) Math.pow(2, attempt) * 1000);
Thread.sleep(5000);
continue;
throw e;
throw new RuntimeException("Dialer exhausted retries for " + toNumber);
String subdomain = "your-subdomain";
String clientId = "your-client-id";
String clientSecret = "your-client-secret";
CxoneCustomDialer dialer = new CxoneCustomDialer(subdomain, clientId, clientSecret);
JsonNode result = dialer.executeDialWithRetry("+14155550100", "+14155550200", 3);
System.out.println("Final Call Status: " + result.get("status").asText());
System.out.println("Call ID: " + result.get("id").asText());
e.printStackTrace();
- Cause: Expired OAuth token, missing
calls:writescope, or incorrect client credentials. - Fix: Verify the token cache logic refreshes before expiry. Ensure the
scopeparameter in the/oauth/tokenrequest includescalls:write%20calls:read. Check that the client ID and secret match the CXone OAuth application configuration. - Code fix: The
getAccessToken()method already implements expiry checking. If the error persists, log the raw token response to verify scope inclusion.
Error: 403 Forbidden
- Cause: OAuth application lacks API access rights, or the calling number is not provisioned for outbound traffic in CXone.
- Fix: Navigate to the CXone admin console and verify the OAuth application has the Call Control API permission enabled. Ensure the
fromnumber is registered and approved for outbound dialing. - Code fix: No code change required. This is a configuration constraint.
- Cause: Exceeding CXone rate limits on
/oauth/tokenor/api/v2/calls. CXone enforces per-tenant and per-endpoint limits. - Fix: Implement strict pause intervals. Parse the
Retry-Afterheader and honor the specified delay. Never retry faster than one second for status polling. - Code fix: The
pollCallStatusmethod already checksresponse.statusCode() == 429and sleeps for theRetry-Afterduration. Ensure you do not spawn multiple threads polling the same call ID simultaneously.
Error: 400 Bad Request
- Cause: Invalid phone number format, missing
fromortofields, or unsupportedtypevalue. - Fix: Use E.164 format for all phone numbers. Include the country code with a plus sign. Verify the
typefield is set tovoice. - Code fix: Add input validation before sending the request. Log the exact error payload from CXone to identify the malformed field.
