Implement Queue Fallback Routing and Overflow Management via Genesys Cloud Routing API with Python
- The code detects queue saturation, validates capacity constraints, and atomically applies fallback routing configurations to redirect overflow interactions to a target matrix.
- This tutorial uses the Genesys Cloud Routing API (
/api/v2/routing/queues), Analytics API (/api/v2/analytics/queues/summary/query), and Webhook API (/api/v2/platform/webhooks). - The implementation is written in Python 3.9+ using
httpxfor HTTP transport andpydanticfor schema validation.
- OAuth client type: Service Account with Client Credentials flow
- Required scopes:
routing:queue:write,routing:queue:read,analytics:query:read,webhook:write - SDK/API version: Genesys Cloud CX REST API v2
- Runtime requirements: Python 3.9 or higher
- External dependencies:
httpx>=0.25.0,pydantic>=2.5.0,tenacity>=8.2.0,purecloud-platform-client>=2.0.0
Genesys Cloud uses OAuth 2.0 Client Credentials for service-to-service authentication. You must cache the access token and handle expiration gracefully. The following implementation uses httpx to fetch the token, stores it with a time-to-live buffer, and refreshes automatically before expiration.
import os
import httpx
from typing import Optional
from pydantic import BaseModel
class OAuthToken(BaseModel):
access_token: str
expires_in: int
issued_at: float
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
self.client_id = client_id
self.base_url = base_url
self.token: Optional[OAuthToken] = None
self.client = httpx.Client(timeout=15.0)
if self.token and time.time() < (self.token.issued_at + self.token.expires_in - 60):
return self.token.access_token
url = f"{self.base_url}/oauth/token"
data = {
"client_id": self.client_id,
"scope": "routing:queue:write routing:queue:read analytics:query:read webhook:write"
response = self.client.post(url, headers=headers, data=data)
response.raise_for_status()
payload = response.json()
self.token = OAuthToken(
access_token=payload["access_token"],
expires_in=payload["expires_in"],
issued_at=time.time()
def close(self):
self.client.close()
The token endpoint returns a JWT valid for one hour. The buffer subtracts sixty seconds from the expiration window to prevent race conditions during concurrent API calls. A 401 Unauthorized response typically indicates an expired token or invalid client credentials. The get_access_token method throws an httpx.HTTPStatusError on failure, which downstream code must catch.
Step 1: Detect Queue Saturation and Validate Capacity Constraints
Before applying fallback routing, you must verify that the primary queue exceeds capacity thresholds and that the fallback target has available agents. The Analytics API provides real-time queue metrics. You must also enforce a maximum cascade depth to prevent infinite routing loops.
import json
from typing import Dict, Any
class QueueCapacityValidator:
def __init__(self, auth: GenesysAuthManager, base_url: str):
self.auth = auth
self.max_cascade_depth = 3
def check_saturation(self, queue_id: str, fallback_queue_id: str, current_depth: int = 0) -> Dict[str, Any]:
if current_depth >= self.max_cascade_depth:
raise ValueError(f"Maximum cascade depth {self.max_cascade_depth} exceeded. Aborting fallback routing.")
now = datetime.now(timezone.utc).isoformat()
one_hour_ago = (datetime.now(timezone.utc).replace(second=0, microsecond=0) - timedelta(hours=1)).isoformat()
query_payload = {
"dateFrom": one_hour_ago,
"dateTo": now,
"groupBy": ["queueId"],
"metrics": ["activeconversations", "waittime", "abandonedconversations"],
"filter": {
"filterType": "and",
"clauses": [
{"type": "eq", "field": "queueId", "value": queue_id},
{"type": "eq", "field": "queueId", "value": fallback_queue_id}
# OAuth scope required: analytics:query:read
headers = {
"Authorization": f"Bearer {self.auth.get_access_token()}",
f"{self.base_url}/api/v2/analytics/queues/summary/query",
headers=headers,
json=query_payload
metrics = response.json().get("summary", [])
primary_metrics = next((m for m in metrics if m["id"] == queue_id), None)
fallback_metrics = next((m for m in metrics if m["id"] == fallback_queue_id), None)
if not primary_metrics or not fallback_metrics:
raise RuntimeError("Queue metrics not found. Verify queue IDs and analytics retention settings.")
is_saturated = (
primary_metrics["metrics"]["activeconversations"]["value"] > 50 and
primary_metrics["metrics"]["waittime"]["value"] > 300000 # 5 minutes in ms
has_capacity = fallback_metrics["metrics"]["activeconversations"]["value"] < 20
"primary_saturated": is_saturated,
"fallback_has_capacity": has_capacity,
"primary_active": primary_metrics["metrics"]["activeconversations"]["value"],
"fallback_active": fallback_metrics["metrics"]["activeconversations"]["value"],
"current_depth": current_depth
The timedelta import is required at the module level. The analytics query groups by queueId and returns millisecond wait times. The saturation threshold uses active conversation count and wait time. The cascade depth check prevents routing loops where Queue A falls back to Queue B, which falls back to Queue A.
Step 2: Construct Fallback Routing Payload and Validate Schema
Genesys Cloud queue configuration uses the Queue object schema. You must construct a PATCH payload that defines the skill matrix, outbound fallback target, and routing directives. The payload must pass schema validation before transmission.
class RoutingSkill(BaseModel):
skill: Dict[str, str]
matchCriteria: Dict[str, Any]
class OutboundQueue(BaseModel):
class FallbackRoutingPayload(BaseModel):
skills: List[RoutingSkill] = Field(default_factory=list)
outboundQueue: Optional[OutboundQueue] = None
routingQueue: Optional[Dict[str, Any]] = None
def to_patch_json(self) -> Dict[str, Any]:
return self.model_dump(exclude_none=True)
def build_fallback_payload(
primary_skill_id: str,
fallback_queue_name: str
) -> FallbackRoutingPayload:
return FallbackRoutingPayload(
skills=[
"skill": {"id": primary_skill_id, "name": "PrimarySupport"},
"matchCriteria": {
"routingType": "skills",
"fallbackRouting": {
"routingType": "outboundQueue",
"outboundQueue": {"id": fallback_queue_id}
outboundQueue={"id": fallback_queue_id, "name": fallback_queue_name}
The fallbackRouting directive inside matchCriteria tells the routing engine to redirect unmatched or saturated interactions to the specified outboundQueue. The pydantic model enforces type safety and strips null values before serialization. Genesys Cloud rejects payloads with undefined or mismatched skill IDs.
Step 3: Execute Atomic PATCH with Retry and Capacity Release Triggers
Queue configuration updates must be atomic. You must handle 429 Too Many Requests responses with exponential backoff. The implementation also simulates a capacity release trigger that validates the fallback queue before committing the PATCH.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import httpx
class QueueFallbackRouter:
self.auth = auth
@retry(
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10),
retry=retry_if_exception_type(httpx.HTTPStatusError)
def apply_fallback_routing(self, queue_id: str, payload: FallbackRoutingPayload) -> Dict[str, Any]:
# OAuth scope required: routing:queue:write
headers = {
"Accept": "application/json"
patch_body = payload.to_patch_json()
# Capacity release trigger: verify fallback queue is writable
if not patch_body.get("outboundQueue"):
raise ValueError("Fallback routing requires a valid outboundQueue target.")
response = self.client.patch(
f"{self.base_url}/api/v2/routing/queues/{queue_id}",
headers=headers,
json=patch_body
if response.status_code == 422:
raise RuntimeError(f"Schema validation failed: {response.text}")
return response.json()
The tenacity decorator automatically retries on 429 and 5xx errors. The PATCH endpoint expects a partial Queue object. Genesys Cloud returns 422 Unprocessable Entity when skill IDs do not exist or when fallbackRouting references an invalid queue. The capacity release trigger ensures the outbound queue is explicitly defined before the routing engine processes the update.
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
Fallback routing events must synchronize with external workforce schedulers. You register a webhook for queue state changes, measure redirect latency, and persist audit logs for governance.
import uuid
class FallbackEventTracker:
self.auth = auth
self.audit_log: List[Dict[str, Any]] = []
def register_queue_webhook(self, webhook_name: str, callback_url: str) -> Dict[str, Any]:
# OAuth scope required: webhook:write
headers = {
webhook_config = {
"name": webhook_name,
"enabled": True,
"events": ["queue.updated", "queue.member.added", "queue.member.removed"],
"address": callback_url,
"transportType": "HTTPS",
"eventFilters": [{"field": "queue.id", "operator": "eq", "value": "dynamic"}]
f"{self.base_url}/api/v2/platform/webhooks",
headers=headers,
json=webhook_config
def record_fallback_event(self, queue_id: str, latency_ms: float, success: bool) -> None:
event = {
"id": str(uuid.uuid4()),
"queueId": queue_id,
"latencyMs": latency_ms,
"success": success,
"action": "fallback_routing_applied"
self.audit_log.append(event)
print(f"Audit logged: {json.dumps(event, indent=2)}")
def get_success_rate(self) -> float:
if not self.audit_log:
return 0.0
successful = sum(1 for e in self.audit_log if e["success"])
return (successful / len(self.audit_log)) * 100
The webhook listens to queue.updated events to notify external schedulers. The tracker records latency and success status for each fallback operation. Governance teams query the audit log to verify routing compliance and measure redirect efficiency.
The following script integrates authentication, capacity validation, payload construction, atomic PATCH execution, and audit tracking into a single executable module. Replace the placeholder credentials with your service account values.
import os
import httpx
import json
import uuid
from datetime import datetime, timezone, timedelta
from typing import Dict, Any, List, Optional
access_token: str
expires_in: int
issued_at: float
data = {
self.token = OAuthToken(access_token=payload["access_token"], expires_in=payload["expires_in"], issued_at=time.time())
def close(self):
self.client.close()
self.auth = auth
if current_depth >= 3:
raise ValueError("Maximum cascade depth exceeded. Aborting fallback routing.")
query_payload = {
"dateTo": now,
"metrics": ["activeconversations", "waittime"],
"filter": {"filterType": "and", "clauses": [{"type": "eq", "field": "queueId", "value": queue_id}, {"type": "eq", "field": "queueId", "value": fallback_queue_id}]}
headers = {"Authorization": f"Bearer {self.auth.get_access_token()}", "Content-Type": "application/json"}
response = self.client.post(f"{self.base_url}/api/v2/analytics/queues/summary/query", headers=headers, json=query_payload)
primary = next((m for m in metrics if m["id"] == queue_id), None)
fallback = next((m for m in metrics if m["id"] == fallback_queue_id), None)
if not primary or not fallback:
raise RuntimeError("Queue metrics not found.")
"primary_saturated": primary["metrics"]["activeconversations"]["value"] > 50 and primary["metrics"]["waittime"]["value"] > 300000,
"fallback_has_capacity": fallback["metrics"]["activeconversations"]["value"] < 20,
@retry(stop=stop_after_attempt(3), wait=wait_exponential(multiplier=1, min=2, max=10), retry=retry_if_exception_type(httpx.HTTPStatusError))
def apply_fallback(self, queue_id: str, payload: FallbackRoutingPayload) -> Dict[str, Any]:
headers = {"Authorization": f"Bearer {self.auth.get_access_token()}", "Content-Type": "application/json", "Accept": "application/json"}
start_time = time.time()
response = self.client.patch(f"{self.base_url}/api/v2/routing/queues/{queue_id}", headers=headers, json=payload.to_patch_json())
self.audit_log.append({
"success": True,
def register_webhook(self, webhook_name: str, callback_url: str) -> Dict[str, Any]:
webhook_config = {"name": webhook_name, "enabled": True, "events": ["queue.updated"], "address": callback_url, "transportType": "HTTPS"}
response = self.client.post(f"{self.base_url}/api/v2/platform/webhooks", headers=headers, json=webhook_config)
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID", "your-client-id")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET", "your-client-secret")
PRIMARY_QUEUE_ID = os.getenv("PRIMARY_QUEUE_ID", "primary-queue-uuid")
FALLBACK_QUEUE_ID = os.getenv("FALLBACK_QUEUE_ID", "fallback-queue-uuid")
CALLBACK_URL = os.getenv("WEBHOOK_CALLBACK_URL", "https://your-scheduler.com/webhook")
auth = GenesysAuthManager(CLIENT_ID, CLIENT_SECRET)
router = QueueFallbackRouter(auth, "https://api.mypurecloud.com")
status = router.check_saturation(PRIMARY_QUEUE_ID, FALLBACK_QUEUE_ID)
print(f"Saturation check: {json.dumps(status, indent=2)}")
if status["primary_saturated"] and status["fallback_has_capacity"]:
payload = FallbackRoutingPayload(
skills=[{
"skill": {"id": "primary-skill-uuid", "name": "PrimarySupport"},
"matchCriteria": {"routingType": "skills", "fallbackRouting": {"routingType": "outboundQueue", "outboundQueue": {"id": FALLBACK_QUEUE_ID}}}
outboundQueue={"id": FALLBACK_QUEUE_ID, "name": "Overflow Queue"}
result = router.apply_fallback(PRIMARY_QUEUE_ID, payload)
print(f"Fallback applied: {json.dumps(result, indent=2)}")
router.register_webhook("FallbackSync", CALLBACK_URL)
else:
print("Conditions not met for fallback routing.")
print(f"Execution failed: {str(e)}")
finally:
auth.close()
router.client.close()
- What causes it: The OAuth token expired, the client credentials are invalid, or the scope list is malformed.
- How to fix it: Verify the
client_idandclient_secretmatch a service account in the Genesys Cloud admin console. Ensure thescopeparameter contains space-separated values. TheGenesysAuthManagerautomatically refreshes tokens, but initial handshake failures require credential correction. - Code showing the fix: The
get_access_tokenmethod callsresponse.raise_for_status(), which throwshttpx.HTTPStatusError. Wrap the initial call in a try-except block to log credential mismatches before retrying.
Error: 403 Forbidden
- What causes it: The service account lacks the required OAuth scopes or the user role does not have queue management permissions.
- How to fix it: Assign the
routing:queue:writeandrouting:queue:readscopes to the OAuth client. Verify the service account user has theRouting AdministratororQueue Administratorrole. - Code showing the fix: Add scope validation at startup:
required_scopes = {"routing:queue:write", "routing:queue:read"}
if not required_scopes.issubset(set(auth.token.scope.split())):
raise PermissionError("Service account missing required routing scopes.")
Error: 422 Unprocessable Entity
- What causes it: The PATCH payload violates the
Queueobject schema, references a non-existent skill ID, or creates a routing loop. - How to fix it: Validate all
skill.idandoutboundQueue.idvalues against the Genesys Cloud resource directory. EnsurefallbackRoutingdoes not point back to the primary queue. Use theFallbackRoutingPayload.to_patch_json()method to strip null fields before transmission. - Code showing the fix: The
apply_fallbackmethod checksresponse.status_code == 422and raises a descriptiveRuntimeErrorwith the server validation message.
