Implement Cross-Channel Session Persistence in Cognigy.AI with Go, Protobuf, and DynamoDB
- A Go microservice that captures Cognigy.AI webhook events, serializes intent and slot data via Protocol Buffers, and writes versioned session snapshots to DynamoDB.
- The service uses conditional writes to prevent concurrent session overwrites and restores context across channels through the Cognigy REST API with strict version locking.
- This tutorial covers Go 1.21, AWS SDK v2, and the Cognigy.AI v2.0 REST API.
- OAuth 2.0 Client Credentials grant with
cognigy:context:readandcognigy:context:writescopes - Cognigy.AI Server v2.0+ REST API
- Go 1.21+ runtime
- AWS SDK for Go v2 (
github.com/aws/aws-sdk-go-v2/...) - Protocol Buffers Go runtime (
google.golang.org/protobuf/...) - DynamoDB table named
CognigySessionswith partition keyConversationId(String) and sort keySessionVersion(Number)
Cognigy.AI server-to-server integrations use OAuth 2.0 Client Credentials. The following manager caches tokens, checks expiration, and refreshes automatically. It returns a bearer token string for downstream API calls.
package auth
import (
"context"
"crypto/rand"
"encoding/base64"
"encoding/json"
"fmt"
"net/http"
"sync"
"time"
type Config struct {
ClientID string
ClientSecret string
TokenURL string
type TokenResponse struct {
ExpiresIn int64 `json:"expires_in"`
type Manager struct {
mu sync.Mutex
cfg Config
token string
expires time.Time
func New(cfg Config) *Manager {
return &Manager{cfg: cfg}
func (m *Manager) GetToken(ctx context.Context) (string, error) {
m.mu.Lock()
defer m.mu.Unlock()
if time.Until(m.expires) > 5*time.Minute {
return m.token, nil
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s",
m.cfg.ClientID, m.cfg.ClientSecret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, m.cfg.TokenURL, nil)
if err != nil {
return "", fmt.Errorf("failed to create token request: %w", err)
req.SetBasicAuth(base64.URLEncoding.EncodeToString([]byte(m.cfg.ClientID)),
base64.URLEncoding.EncodeToString([]byte(m.cfg.ClientSecret)))
resp, err := client.Do(req)
if err != nil {
return "", fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("token endpoint returned %d", resp.StatusCode)
var tr TokenResponse
if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
return "", fmt.Errorf("failed to decode token response: %w", err)
m.token = tr.AccessToken
m.expires = time.Now().Add(time.Duration(tr.ExpiresIn) * time.Second)
return m.token, nil
OAuth scope required for token acquisition: cognigy:context:read, cognigy:context:write
Step 1: Define Protobuf Schema and Intercept Webhook Events
Cognigy.AI sends dialog events as JSON to your webhook endpoint. You will deserialize the JSON into a Protobuf message to enforce strict typing and reduce payload size before storage.
Define dialog.proto:
syntax = "proto3";
package dialog;
option go_package = "github.com/example/cognigy-session/proto";
message DialogEvent {
string conversation_id = 1;
string channel = 2;
string intent = 3;
map<string, string> slots = 4;
int64 timestamp = 5;
Generate Go code with protoc --go_out=. dialog.proto. The webhook handler reads the request body, unmarshals JSON to Protobuf, and forwards it to the persistence layer.
package handler
import (
"encoding/json"
"io"
"net/http"
"time"
"google.golang.org/protobuf/encoding/protojson"
func WebhookHandler(next func(proto.DialogEvent) error) http.HandlerFunc {
return func(w http.ResponseWriter, r *http.Request) {
if r.Method != http.MethodPost {
http.Error(w, "Method Not Allowed", http.StatusMethodNotAllowed)
return
body, err := io.ReadAll(r.Body)
if err != nil {
http.Error(w, "Failed to read request body", http.StatusBadRequest)
return
var event proto.DialogEvent
if err := protojson.Unmarshal(body, &event); err != nil {
http.Error(w, "Invalid protobuf JSON payload", http.StatusBadRequest)
return
if event.ConversationId == "" || event.Channel == "" {
http.Error(w, "Missing required fields", http.StatusBadRequest)
return
if err := next(event); err != nil {
http.Error(w, "Internal processing error", http.StatusInternalServerError)
return
w.WriteHeader(http.StatusOK)
json.NewEncoder(w).Encode(map[string]string{"status": "processed"})
Expected webhook request body:
"conversationId": "conv-88a2c1f9",
"channel": "web-chat",
"intent": "book_flight",
"slots": {
"origin": "JFK",
"destination": "LHR",
"date": "2024-06-15"
"timestamp": 1718409600
Step 2: Extract Intent and Slots for DynamoDB Serialization
You must transform the Protobuf map into DynamoDB attribute values. AWS SDK v2 requires explicit type conversion. You will also increment the session version to enforce ordering.
package persistence
import (
"context"
"fmt"
"strconv"
"github.com/aws/aws-sdk-go-v2/aws"
"github.com/aws/aws-sdk-go-v2/service/dynamodb"
"github.com/aws/aws-sdk-go-v2/service/dynamodb/types"
type SessionStore struct {
client *dynamodb.Client
table string
func NewSessionStore(client *dynamodb.Client, tableName string) *SessionStore {
return &SessionStore{client: client, table: tableName}
func (s *SessionStore) buildAttributes(event proto.DialogEvent, version int64) (map[string]types.AttributeValue, error) {
slotsMap := make(map[string]types.AttributeValue)
for k, v := range event.Slots {
slotsMap[k] = &types.AttributeValueMemberS{Value: v}
return map[string]types.AttributeValue{
"ConversationId": &types.AttributeValueMemberS{Value: event.ConversationId},
"SessionVersion": &types.AttributeValueMemberN{Value: strconv.FormatInt(version, 10)},
"Channel": &types.AttributeValueMemberS{Value: event.Channel},
"Intent": &types.AttributeValueMemberS{Value: event.Intent},
"Slots": &types.AttributeValueMemberM{Value: slotsMap},
"Timestamp": &types.AttributeValueMemberN{Value: strconv.FormatInt(event.Timestamp, 10)},
}, nil
Step 3: Store Session Snapshot with Conditional Writes
Race conditions occur when multiple channels emit events for the same conversation simultaneously. You will use a conditional expression that allows writes only if the item does not exist or matches the expected version. This guarantees strict version locking.
func (s *SessionStore) SaveSnapshot(ctx context.Context, event proto.DialogEvent, expectedVersion int64) error {
attrs, err := s.buildAttributes(event, expectedVersion+1)
if err != nil {
return fmt.Errorf("failed to build DynamoDB attributes: %w", err)
_, err = s.client.PutItem(ctx, &dynamodb.PutItemInput{
TableName: aws.String(s.table),
Item: attrs,
ConditionExpression: aws.String("attribute_not_exists(ConversationId) OR SessionVersion = :expected"),
ExpressionAttributeValues: map[string]types.AttributeValue{
":expected": &types.AttributeValueMemberN{Value: strconv.FormatInt(expectedVersion, 10)},
if err != nil {
return fmt.Errorf("DynamoDB PutItem failed: %w", err)
return nil
OAuth scope required for DynamoDB operations: AWS IAM policy dynamodb:PutItem on arn:aws:dynamodb:region:account:table/CognigySessions
Step 4: Restore Context on Channel Switch via Cognigy API
When a user switches channels, you read the latest snapshot and push it back to Cognigy.AI. The REST endpoint accepts a JSON payload with the conversation ID, target channel, and context key-value pairs. You will implement retry logic for 429 responses.
package cognigy
import (
"bytes"
"context"
"encoding/json"
"fmt"
"math/rand"
"net/http"
"time"
"github.com/example/cognigy-session/auth"
type Client struct {
baseURL string
authMgr *auth.Manager
httpCli *http.Client
type ContextPayload struct {
ConversationId string `json:"conversationId"`
Channel string `json:"channel"`
Context map[string]interface{} `json:"context"`
func NewClient(baseURL string, authMgr *auth.Manager) *Client {
return &Client{
baseURL: baseURL,
authMgr: authMgr,
httpCli: &http.Client{Timeout: 15 * time.Second},
func (c *Client) RestoreContext(ctx context.Context, payload ContextPayload) error {
token, err := c.authMgr.GetToken(ctx)
if err != nil {
return fmt.Errorf("failed to acquire OAuth token: %w", err)
body, err := json.Marshal(payload)
if err != nil {
return fmt.Errorf("failed to marshal context payload: %w", err)
url := fmt.Sprintf("%s/api/v2.0/cognigy/context", c.baseURL)
return c.doWithRetry(ctx, url, token, body)
func (c *Client) doWithRetry(ctx context.Context, url, token string, body []byte) error {
retryCount := 0
maxRetries := 3
for retryCount <= maxRetries {
req, err := http.NewRequestWithContext(ctx, http.MethodPost, url, bytes.NewReader(body))
if err != nil {
return fmt.Errorf("failed to create request: %w", err)
resp, err := c.httpCli.Do(req)
if err != nil {
return fmt.Errorf("HTTP request failed: %w", err)
switch resp.StatusCode {
case http.StatusOK, http.StatusCreated:
return nil
case http.StatusUnauthorized:
return fmt.Errorf("401 Unauthorized: token invalid or missing scopes")
case http.StatusForbidden:
return fmt.Errorf("403 Forbidden: insufficient permissions")
case http.StatusTooManyRequests:
retryCount++
if retryCount > maxRetries {
return fmt.Errorf("429 Too Many Requests exceeded retry limit")
jitter := time.Duration(rand.Intn(500)) * time.Millisecond
backoff := time.Duration(1<<uint(retryCount-1)) * time.Second
time.Sleep(backoff + jitter)
default:
return fmt.Errorf("Cognigy API returned %d", resp.StatusCode)
return nil
OAuth scope required for context restoration: cognigy:context:write
The following module combines authentication, protobuf handling, DynamoDB persistence, and Cognigy API restoration into a single runnable microservice.
package main
import (
"context"
"log"
"net/http"
"strconv"
"sync"
"github.com/aws/aws-sdk-go-v2/config"
"github.com/example/cognigy-session/cognigy"
"github.com/example/cognigy-session/handler"
"github.com/example/cognigy-session/persistence"
type App struct {
store *persistence.SessionStore
cognigy *cognigy.Client
mu sync.Mutex
version map[string]int64
func NewApp(ctx context.Context) (*App, error) {
cfg, err := config.LoadDefaultConfig(ctx)
if err != nil {
return nil, err
dynamo := dynamodb.NewFromConfig(cfg)
store := persistence.NewSessionStore(dynamo, "CognigySessions")
authMgr := auth.New(auth.Config{
ClientID: "YOUR_CLIENT_ID",
ClientSecret: "YOUR_CLIENT_SECRET",
TokenURL: "https://your-cognigy-instance.com/oauth/token",
cognigyClient := cognigy.NewClient("https://your-cognigy-instance.com", authMgr)
return &App{
store: store,
cognigy: cognigyClient,
version: make(map[string]int64),
}, nil
func (a *App) processEvent(event proto.DialogEvent) error {
a.mu.Lock()
currentVersion := a.version[event.ConversationId]
a.version[event.ConversationId] = currentVersion + 1
a.mu.Unlock()
if err := a.store.SaveSnapshot(context.Background(), event, currentVersion); err != nil {
return err
slots := make(map[string]interface{})
slots[k] = v
slots["intent"] = event.Intent
slots["sessionVersion"] = currentVersion + 1
payload := cognigy.ContextPayload{
ConversationId: event.ConversationId,
Channel: event.Channel,
Context: slots,
return a.cognigy.RestoreContext(context.Background(), payload)
func main() {
ctx := context.Background()
app, err := NewApp(ctx)
if err != nil {
log.Fatalf("Failed to initialize application: %v", err)
http.HandleFunc("/webhook/dialog", handler.WebhookHandler(app.processEvent))
http.HandleFunc("/health", func(w http.ResponseWriter, r *http.Request) {
w.Write([]byte("OK"))
log.Println("Starting Cognigy session persistence service on :8080")
if err := http.ListenAndServe(":8080", nil); err != nil {
log.Fatalf("Server failed: %v", err)
Error: ConditionalCheckFailedException
- What causes it: Two webhook events arrive for the same
ConversationIdwith mismatchedSessionVersionvalues. The DynamoDB condition rejects the stale write. - How to fix it: Implement a retry loop that fetches the current version, increments it, and retries the
PutItemcall. The version map in memory prevents local drift. - Code showing the fix:
func (a *App) saveWithRetry(ctx context.Context, event proto.DialogEvent) error {
maxRetries := 3
for i := 0; i < maxRetries; i++ {
a.mu.Lock()
current := a.version[event.ConversationId]
a.version[event.ConversationId] = current + 1
a.mu.Unlock()
err := a.store.SaveSnapshot(ctx, event, current)
if err == nil {
return nil
if i < maxRetries-1 {
time.Sleep(time.Duration(1<<i) * 100 * time.Millisecond)
return fmt.Errorf("failed to save snapshot after %d retries", maxRetries)
- What causes it: The OAuth token expired or the client credentials lack the required scopes.
- How to fix it: Verify the
cognigy:context:readandcognigy:context:writescopes are attached to the OAuth client. Ensure the token manager refreshes before theexpires_inwindow closes. - Code showing the fix: The
auth.Manager.GetTokenfunction already checkstime.Until(m.expires) > 5*time.Minuteand refreshes proactively.
- What causes it: Cognigy.AI enforces rate limits on the
/api/v2.0/cognigy/contextendpoint during high-volume channel switches. - How to fix it: Use exponential backoff with jitter. The
doWithRetrymethod implements this pattern and aborts after three attempts to prevent cascading failures. - Code showing the fix: Already implemented in
cognigy.Client.doWithRetry.
- What causes it: DynamoDB provisioned throughput exhaustion or transient service degradation.
- How to fix it: Switch to on-demand capacity mode for the DynamoDB table. Add client-side retries with jitter for 5xx responses from AWS SDK.
