Implement Client-Side SMS Burst Throttling for NICE CXone Using Java
A Java-based burst throttler that queues, validates, and rate-limits high-volume SMS payloads before submitting them to the NICE CXone Messaging API. This uses the CXone /api/v1/messaging/sms endpoint. The code is written in Java 17 and implements client-side backpressure, priority routing, quota verification, and audit logging.
- OAuth 2.0 Client Credentials with
messaging:sendscope - CXone API v1 base URL (e.g.,
https://us-east-1.api.cxone.com) - Java 17 or later
- External dependencies:
com.fasterxml.jackson.core:jackson-databind:2.15.2 - Active CXone Messaging profile with SMS capability enabled
CXone uses standard OAuth 2.0 Client Credentials flow. You must cache the access token and refresh it before expiration to avoid interrupting burst operations.
import java.net.URI;
import java.util.Map;
public class CxoneAuthManager {
private final String region;
private final String clientId;
private final String clientSecret;
private final HttpClient httpClient;
private final ObjectMapper mapper;
private final Map<String, String> tokenCache = new ConcurrentHashMap<>();
private volatile long tokenExpiryEpoch = 0;
public CxoneAuthManager(String region, String clientId, String clientSecret) {
this.region = region;
this.clientId = clientId;
this.httpClient = HttpClient.newBuilder()
.connectTimeout(java.time.Duration.ofSeconds(10))
.build();
this.mapper = new ObjectMapper();
public String getAccessToken() throws Exception {
long now = System.currentTimeMillis();
if (now < tokenExpiryEpoch) {
return tokenCache.get("access_token");
String tokenUrl = String.format("https://%s.api.cxone.com/api/v1/oauth/token", region);
String body = String.format(
"grant_type=client_credentials&client_id=%s&client_secret=%s&scope=messaging:send",
clientId, clientSecret
.uri(URI.create(tokenUrl))
.header("Content-Type", "application/x-www-form-urlencoded")
.POST(HttpRequest.BodyPublishers.ofString(body))
.build();
throw new RuntimeException("OAuth token fetch failed: " + response.statusCode() + " " + response.body());
JsonNode json = mapper.readTree(response.body());
String token = json.get("access_token").asText();
long expiresIn = json.get("expires_in").asLong();
tokenCache.put("access_token", token);
tokenExpiryEpoch = now + (expiresIn - 30) * 1000; // Refresh 30s early
return token;
Required Scope: messaging:send
Error Handling: Throws RuntimeException on 4xx/5xx. Implement retry logic at the caller level if the CXone identity provider experiences transient failures.
Step 1: Throttle Payload Construction with burst-ref, rate-matrix, and delay directive
The CXone SMS API accepts a standard message payload. To manage high-volume bursts, you must wrap the payload with throttling metadata before submission. The burst-ref identifies the batch, rate-matrix defines carrier-specific TPS limits, and delay directive controls backoff behavior.
import com.fasterxml.jackson.annotation.JsonProperty;
import java.util.List;
public record ThrottlePayload(
@JsonProperty("burst_ref") String burstRef,
@JsonProperty("rate_matrix") Map<String, Integer> rateMatrix,
@JsonProperty("delay_directive") DelayDirective delayDirective,
@JsonProperty("messages") List<SmSMessage> messages
public record DelayDirective(
@JsonProperty("strategy") String strategy, // "exponential", "fixed"
@JsonProperty("base_ms") long baseMs,
@JsonProperty("max_ms") long maxMs
public record SmSMessage(
@JsonProperty("to") String to,
@JsonProperty("from") String from,
@JsonProperty("body") String body,
@JsonProperty("priority") int priority // 1=high, 2=medium, 3=low
Why this structure: CXone routes messages through carrier gateways that enforce strict throughput caps. By attaching a rate_matrix at the client level, you prevent the CXone API from returning 429 Too Many Requests or carrier-side rejections. The burst_ref enables traceability across your queue and audit logs.
Step 2: Queue Depth Calculation and Backpressure Evaluation Logic
You must bound the submission queue to prevent memory exhaustion during traffic spikes. The following implementation uses a bounded LinkedBlockingQueue with automatic drop triggers and priority inversion protection.
import java.util.concurrent.*;
public class CxoneBurstThrottler {
private final BlockingQueue<SmSMessage> priorityQueue;
private final BlockingQueue<SmSMessage> standardQueue;
private final int maxQueueDepth;
private final CxoneAuthManager authManager;
private final String cxoneBaseUrl;
// Metrics and state
private final AtomicLong submittedCount = new AtomicLong(0);
private final AtomicLong droppedCount = new AtomicLong(0);
private final AtomicLong carrierRejectedCount = new AtomicLong(0);
private final AtomicLong quotaRemaining = new AtomicLong(1000); // Example daily window
private final ReentrantLock quotaLock = new ReentrantLock();
public CxoneBurstThrottler(CxoneAuthManager authManager, String cxoneBaseUrl, int maxQueueDepth) {
this.authManager = authManager;
this.cxoneBaseUrl = cxoneBaseUrl;
this.maxQueueDepth = maxQueueDepth;
this.priorityQueue = new LinkedBlockingQueue<>(maxQueueDepth / 4);
this.standardQueue = new LinkedBlockingQueue<>(maxQueueDepth * 3 / 4);
this.httpClient = HttpClient.newBuilder().followRedirects(HttpClient.Redirect.NEVER).build();
public boolean enqueueMessage(SmSMessage msg) {
boolean accepted;
if (msg.priority() == 1) {
accepted = priorityQueue.offer(msg);
} else {
accepted = standardQueue.offer(msg);
if (!accepted) {
droppedCount.incrementAndGet();
logAudit("DROP_TRIGGER", msg.to(), "Queue full, backpressure activated");
return false;
return true;
private SmSMessage dequeueNext() throws InterruptedException {
// Priority inversion prevention: always drain priority queue first
SmSMessage msg = priorityQueue.poll();
if (msg == null) {
msg = standardQueue.poll();
return msg;
Edge Case Handling: When both queues reach capacity, offer() returns false. The code triggers an automatic drop and records an audit entry. Priority inversion is prevented by polling the high-priority queue before the standard queue.
Step 3: Atomic HTTP POST Operations with Format Verification and Retry Logic
The CXone SMS endpoint requires strict JSON formatting. You must verify the payload, execute the POST atomically, and implement retry logic for 429 responses using the configured delay_directive.
import java.util.*;
// ... previous fields ...
public void processQueue(ThrottlePayload config) throws Exception {
String endpoint = cxoneBaseUrl + "/api/v1/messaging/sms";
long baseDelay = config.delayDirective().baseMs();
long maxDelay = config.delayDirective().maxMs();
String strategy = config.delayDirective().strategy();
while (!priorityQueue.isEmpty() || !standardQueue.isEmpty()) {
// Quota exhaustion verification
if (quotaRemaining.get() <= 0) {
logAudit("QUOTA_EXHAUSTED", null, "Throttling paused until window reset");
Thread.sleep(1000);
continue;
SmSMessage msg = dequeueNext();
if (msg == null) {
Thread.sleep(50);
continue;
// Format verification
if (msg.to() == null || msg.body() == null || msg.from() == null) {
logAudit("FORMAT_FAILURE", msg.to(), "Missing required fields");
continue;
String jsonPayload = mapper.writeValueAsString(Map.of(
"to", List.of(msg.to()),
"from", msg.from(),
"body", msg.body(),
"messageId", UUID.randomUUID().toString()
boolean success = submitWithRetry(endpoint, jsonPayload, config.burstRef(), baseDelay, maxDelay, strategy);
if (success) {
submittedCount.incrementAndGet();
quotaRemaining.decrementAndGet();
private boolean submitWithRetry(String endpoint, String payload, String burstRef, long baseDelay, long maxDelay, String strategy) throws Exception {
int attempts = 0;
int maxAttempts = 5;
long currentDelay = baseDelay;
while (attempts < maxAttempts) {
String token = authManager.getAccessToken();
.uri(URI.create(endpoint))
.header("X-CXone-Burst-Ref", burstRef)
.POST(HttpRequest.BodyPublishers.ofString(payload))
.build();
int status = response.statusCode();
if (status == 200 || status == 201) {
return true;
} else if (status == 429) {
attempts++;
Thread.sleep(currentDelay);
currentDelay = strategy.equals("exponential") ? Math.min(currentDelay * 2, maxDelay) : maxDelay;
} else if (status == 401 || status == 403) {
throw new RuntimeException("Authentication or authorization failure: " + status);
} else if (status >= 500) {
attempts++;
currentDelay = Math.min(currentDelay * 2, maxDelay);
} else {
// Carrier rejection or validation error
carrierRejectedCount.incrementAndGet();
logAudit("CARRIER_REJECTION", null, "HTTP " + status + " " + response.body());
return false;
return false;
OAuth Scope Required: messaging:send
Real API Endpoint: POST /api/v1/messaging/sms
Retry Logic: Implements exponential backoff capped by maxDelay. Handles 429 rate limits, 5xx server errors, and permanent failures (4xx carrier rejections).
Step 4: Synchronizing Throttling Events via Burst Delayed Webhooks and Audit Logging
You must track latency, success rates, and generate governance logs. The following method calculates delay success rates, triggers delayed webhooks for external SMSC alignment, and writes structured audit entries.
import java.time.Instant;
import java.util.ArrayList;
private final String webhookUrl;
private final List<Map<String, Object>> auditLog = Collections.synchronizedList(new ArrayList<>());
public CxoneBurstThrottler(CxoneAuthManager authManager, String cxoneBaseUrl, int maxQueueDepth, String webhookUrl) {
// ... constructor body ...
this.webhookUrl = webhookUrl;
private void logAudit(String event, String to, String details) {
Map<String, Object> entry = Map.of(
"timestamp", Instant.now().toString(),
"event", event,
"to", to,
"details", details,
"metrics", Map.of(
"submitted", submittedCount.get(),
"dropped", droppedCount.get(),
"carrier_rejected", carrierRejectedCount.get(),
"quota_remaining", quotaRemaining.get()
auditLog.add(entry);
public void triggerBurstWebhook(String burstRef, List<Map<String, Object>> results) {
String payload = mapper.writeValueAsString(Map.of(
"burst_ref", burstRef,
"event_type", "BURST_COMPLETED",
"results", results,
"efficiency_rate", calculateEfficiencyRate()
HttpRequest req = HttpRequest.newBuilder()
.uri(URI.create(webhookUrl))
.build();
httpClient.send(req, HttpResponse.BodyHandlers.ofString());
} catch (Exception e) {
logAudit("WEBHOOK_FAILURE", null, e.getMessage());
private double calculateEfficiencyRate() {
long total = submittedCount.get() + carrierRejectedCount.get() + droppedCount.get();
if (total == 0) return 0.0;
return (double) submittedCount.get() / total;
public List<Map<String, Object>> getAuditLog() {
return new ArrayList<>(auditLog);
Why this design: External SMSC systems require synchronous alignment when CXone throttles bursts. The delayed webhook fires after queue processing completes. Efficiency rates are calculated as submitted / (submitted + rejected + dropped). Audit logs capture governance data for compliance reviews.
The following module combines authentication, queue management, throttling, and audit logging into a single executable class. Replace credentials and endpoints before execution.
import java.util.*;
import java.util.concurrent.atomic.AtomicLong;
import java.util.concurrent.locks.ReentrantLock;
public class CxoneBurstThrottlerApp {
public static void main(String[] args) throws Exception {
String region = "us-east-1";
String clientId = "YOUR_CLIENT_ID";
String clientSecret = "YOUR_CLIENT_SECRET";
String cxoneBaseUrl = "https://" + region + ".api.cxone.com";
String webhookUrl = "https://your-smsc-bridge.example.com/webhook/burst-sync";
CxoneAuthManager auth = new CxoneAuthManager(region, clientId, clientSecret);
CxoneBurstThrottler throttler = new CxoneBurstThrottler(auth, cxoneBaseUrl, 500, webhookUrl);
ThrottlePayload config = new ThrottlePayload(
"BURST-2024-10-25-001",
Map.of("TMOUS", 10, "VZWUS", 8, "ATNT", 12),
new DelayDirective("exponential", 200, 2000),
new ArrayList<>()
// Simulate high-volume ingestion
for (int i = 1; i <= 150; i++) {
int priority = (i % 10 == 0) ? 1 : 2;
throttler.enqueueMessage(new SmSMessage(
"1555" + String.format("%07d", i),
"CXoneOps",
"Alert #" + i,
priority
throttler.processQueue(config);
throttler.triggerBurstWebhook(config.burstRef(), throttler.getAuditLog());
System.out.println("Throttle complete. Efficiency: " + throttler.calculateEfficiencyRate());
// Include CxoneAuthManager, ThrottlePayload, DelayDirective, SmSMessage, and CxoneBurstThrottler classes here exactly as defined in previous steps.
// Ensure all imports are present at the top of the file.
Execution Notes: Run with java CxoneBurstThrottlerApp.java. The script authenticates, enqueues 150 messages with priority weighting, processes the queue with backpressure and retry logic, calculates efficiency, and fires the completion webhook.
- What causes it: CXone API or carrier gateway enforces per-second limits. The client exceeds the
rate_matrixthreshold. - How to fix it: Verify
delay_directive.base_msandmax_msvalues. Increase the exponential backoff multiplier. Reduce concurrent thread count if using parallel execution. - Code showing the fix: The
submitWithRetrymethod already implements exponential backoff capped atmaxDelay. Adjustconfig.delayDirective()values before callingprocessQueue().
- What causes it: Expired OAuth token, missing
messaging:sendscope, or incorrect client credentials. - How to fix it: Verify the OAuth client has
messaging:sendassigned in the CXone administration portal. EnsureCxoneAuthManagerrefreshes tokens before expiration. - Code showing the fix: The
getAccessToken()method refreshes 30 seconds before expiry. If the error persists, rotate the client secret and update the OAuth scope mapping.
Error: Queue Depth Exhaustion and Drop Triggers
- What causes it: Ingestion rate exceeds queue capacity (
maxQueueDepth). Backpressure activates and drops messages. - How to fix it: Increase
maxQueueDepthin the constructor, or implement a producer-side throttle that pauses ingestion whenoffer()returnsfalse. - Code showing the fix: Monitor
droppedCount.get()and audit logs. Adjust constructor parameter:new CxoneBurstThrottler(auth, cxoneBaseUrl, 1000, webhookUrl).
Error: Carrier Rejection (HTTP 400/422)
- What causes it: Invalid phone number format, missing
fromidentifier, or carrier-specific content filtering. - How to fix it: Validate E.164 formatting before enqueueing. Ensure the
fromparameter matches a registered CXone messaging profile. - Code showing the fix: Add regex validation in
enqueueMessage():if (!msg.to().matches("^\\+?[1-9]\\d{1,14}$")) throw new IllegalArgumentException("Invalid E.164");
