Implement automatic JWT token rotation and refresh logic for long-running Genesys Cloud API consumers
  • You will build a token manager that fetches, caches, and rotates Genesys Cloud JWT access tokens before expiration using a scheduled validation job.
  • You will integrate this manager with the @genesyscloud/purecloud-platform-client-v2 Node.js SDK to execute authenticated API calls without manual token intervention.
  • You will implement this solution using Node.js 18 LTS with axios, node-cron, and standard asynchronous patterns.
  • OAuth client type and required scopes: Machine-to-machine (Client Credentials) grant with user:read and analytics:query
  • SDK version or API version: @genesyscloud/purecloud-platform-client-v2 v3.1.0 or higher
  • Language/runtime requirements: Node.js 18.0.0 LTS or higher
  • Any external dependencies: axios, node-cron, dotenv, uuid
Genesys Cloud issues JWT access tokens with a fixed lifetime of 3600 seconds. The SDK contains an internal refresh mechanism, but long-running consumers (queue workers, batch exporters, event listeners) benefit from explicit token lifecycle control. Explicit rotation prevents silent authentication failures during peak load, allows predictable cache invalidation, and gives you direct visibility into token health metrics.
The Client Credentials flow requires a POST request to the OAuth endpoint. The request body must contain the client identifier, client secret, and requested scopes. The response returns the access token, token type, scope, and expiration window in seconds.
You will store the token and its absolute expiration timestamp in memory. A background cron job will evaluate the remaining lifetime every sixty seconds. If the remaining lifetime falls below a configured buffer threshold, the manager triggers a rotation request. This approach guarantees that API calls always use a token with at least the buffer duration remaining.
import axios from 'axios';
import dotenv from 'dotenv';
dotenv.config();
const ENVIRONMENT = process.env.GENESYS_ENVIRONMENT || 'mypurecloud.com';
const CLIENT_ID = process.env.GENESYS_CLIENT_ID;
const CLIENT_SECRET = process.env.GENESYS_CLIENT_SECRET;
const SCOPES = process.env.GENESYS_SCOPES || 'user:read analytics:query';
const BASE_URL = `https://${ENVIRONMENT}`;
export class TokenManager {
  constructor() {
    this.accessToken = null;
    this.expiresAt = null;
    this.rotationBufferSeconds = 300;
    this.isRefreshing = false;
    this.refreshQueue = [];
  async fetchToken() {
    const url = `${BASE_URL}/api/v2/oauth/token`;
    const params = new URLSearchParams({
      client_id: CLIENT_ID,
      client_secret: CLIENT_SECRET,
      scope: SCOPES
      const response = await axios.post(url, params, {
        headers: {
          'Content-Type': 'application/x-www-form-urlencoded',
          'Accept': 'application/json'
      const data = response.data;
      this.accessToken = data.access_token;
      this.expiresAt = Date.now() + (data.expires_in * 1000);
      console.log(`Token acquired. Expires at: ${new Date(this.expiresAt).toISOString()}`);
      return this.accessToken;
    } catch (error) {
      if (error.response) {
        const status = error.response.status;
        if (status === 401) {
          throw new Error('OAuth 401: Invalid client_id or client_secret. Verify credentials in the Genesys Cloud security profile.');
        if (status === 403) {
          throw new Error('OAuth 403: Client lacks permission to request scopes. Check the OAuth client configuration.');
        if (status === 429) {
          throw new Error('OAuth 429: Rate limit exceeded on token endpoint. Implement backoff before retrying.');
        throw new Error(`OAuth ${status}: ${error.response.data?.error_description || 'Unknown OAuth error'}`);
      throw new Error(`Network error during token fetch: ${error.message}`);
The request payload uses application/x-www-form-urlencoded encoding. Genesys Cloud rejects JSON payloads for the OAuth token endpoint. The response body contains the JWT string and the expires_in field measured in seconds. You convert that value to a millisecond timestamp for reliable comparison in JavaScript.
Step 1: Configure the OAuth client and initial token fetch
The token manager requires an initial bootstrap sequence. You call fetchToken() once at application startup. The method handles network failures, parses the JSON response, and stores the token alongside its expiration boundary. You must handle transient HTTP errors gracefully because OAuth endpoints enforce strict rate limits.
  async initialize() {
    if (this.accessToken && !this.isExpired()) {
      console.log('Valid token already cached. Skipping initialization fetch.');
    return await this.fetchToken();
  isExpired() {
    return !this.expiresAt || Date.now() >= this.expiresAt;
Expected response structure from /api/v2/oauth/token:
  "token_type": "Bearer",
  "expires_in": 3600,
  "scope": "user:read analytics:query"
The isExpired() method checks the current timestamp against the stored boundary. You will use this method in the cron job to determine rotation necessity. The initialize() method prevents redundant network calls during container restarts or cluster node scaling events.
Step 2: Build the cron-based expiration validator and rotation trigger
You will use node-cron to schedule a validation job that runs every minute. The job calculates the remaining lifetime and compares it against the rotation buffer. If the remaining lifetime is less than the buffer, the manager triggers a refresh. Multiple concurrent API calls might trigger the refresh simultaneously, so you implement a queue-based synchronization pattern to prevent thundering herd requests to the OAuth endpoint.
import cron from 'node-cron';
  startCronValidator() {
    cron.schedule('*/1 * * * *', async () => {
      if (this.isRefreshing) return;
      const remainingSeconds = Math.max(0, Math.floor((this.expiresAt - Date.now()) / 1000));
      if (remainingSeconds < this.rotationBufferSeconds) {
        console.log(`Token expires in ${remainingSeconds}s. Triggering rotation.`);
        await this.refreshToken();
  async refreshToken() {
    this.isRefreshing = true;
      const resolved = this.refreshQueue.shift();
      while (resolved) {
        resolved(this.accessToken);
    } catch (error) {
      const rejected = this.refreshQueue.shift();
      while (rejected) {
        rejected(error);
      throw error;
    } finally {
  async getAccessToken() {
    if (!this.accessToken || this.isExpired()) {
      return await this.refreshToken();
    if (this.isRefreshing) {
      return new Promise((resolve, reject) => {
        this.refreshQueue.push((token) => resolve(token));
        this.refreshQueue.push((err) => reject(err));
The refreshToken() method sets a lock flag to prevent parallel OAuth requests. Pending calls push resolve and reject handlers onto a queue. Once the new token arrives, the manager distributes it to all waiting promises. This pattern ensures thread-safe token distribution in a single-threaded Node.js event loop.
Step 3: Integrate with the Genesys Cloud SDK for API calls with retry logic
The Node.js SDK accepts a custom access token configuration. You will wire the TokenManager into the SDK client so every outgoing request automatically attaches a fresh bearer token. You will also wrap API calls in a retry function that handles 429 rate limit responses with exponential backoff and randomized jitter.
import PureCloudPlatformClientV2 from '@genesyscloud/purecloud-platform-client-v2';
export class GenesysApiClient {
  constructor(tokenManager) {
    this.tokenManager = tokenManager;
    this.sdk = new PureCloudPlatformClientV2();
    this.sdk.setEnvironment(`https://${ENVIRONMENT}`);
    this.sdk.setAccessToken(async () => await this.tokenManager.getAccessToken());
    this.maxRetries = 3;
    this.baseDelayMs = 1000;
  async executeWithRetry(apiCall, operationName) {
    let attempt = 0;
    while (attempt < this.maxRetries) {
        const result = await apiCall();
        return result;
      } catch (error) {
        const status = error?.statusCode || error?.status;
          const retryAfter = parseInt(error.headers?.['retry-after'] || '5', 10);
          const jitter = Math.random() * 1000;
          const delay = (retryAfter * 1000) + jitter;
          console.warn(`${operationName} hit 429. Retrying in ${Math.floor(delay / 1000)}s (attempt ${attempt + 1}/${this.maxRetries})`);
          attempt++;
          continue;
        if (status === 401 || status === 403) {
          console.error(`${operationName} failed with ${status}. Token may be invalid or scopes insufficient.`);
          throw error;
        throw error;
    throw new Error(`${operationName} failed after ${this.maxRetries} retries due to 429 rate limiting.`);
The SDK’s setAccessToken() method accepts an asynchronous function. The SDK calls this function before each request, which triggers your token manager’s validation logic. If the token is fresh, the manager returns it immediately. If the token is near expiration, the manager rotates it synchronously from the caller’s perspective.
You will use the retry wrapper for endpoints that enforce strict request quotas. The 429 response includes a Retry-After header. You parse that header, add randomized jitter to prevent synchronized retry storms, and delay the next attempt. You abort retries for 401 and 403 errors because those indicate credential or scope misconfiguration, not transient load.
Step 4: Execute a paginated API call using the configured client
You will query the /api/v2/users endpoint to demonstrate pagination handling. The endpoint requires the user:read scope. You will iterate through pages until the nextPageUri is null. You will accumulate results in a single array and handle empty pages gracefully.
  async listAllUsers(pageSize = 25) {
    const usersApi = this.sdk.UsersApi;
    let allUsers = [];
    let nextPageUri = null;
    let pageCounter = 0;
    do {
      pageCounter++;
      const queryParams = {
        pageSize,
        nextPageUri: nextPageUri || undefined,
        expand: ['routing', 'skills']
      const response = await this.executeWithRetry(
        () => usersApi.postUsersQuery(queryParams),
        `UsersQuery-Page-${pageCounter}`
      if (response.body?.entities?.length > 0) {
        allUsers = allUsers.concat(response.body.entities);
      nextPageUri = response.body?.nextPageUri || null;
      console.log(`Fetched page ${pageCounter}. Total users: ${allUsers.length}. Next page: ${nextPageUri ? 'available' : 'none'}`);
    } while (nextPageUri);
    return allUsers;
The postUsersQuery method maps to POST /api/v2/users/query. You pass pageSize and nextPageUri in the request body. The response contains an entities array and a nextPageUri string. You loop until nextPageUri resolves to null. The retry wrapper catches 429 responses on any page and delays the next request automatically.
The following script combines the token manager, cron validator, SDK client, and paginated query into a single executable module. You must set environment variables before running.
import 'dotenv/config';
  constructor() {
      scope: SCOPES
        headers: {
    } catch (error) {
        if (status === 401) throw new Error('OAuth 401: Invalid client credentials.');
        if (status === 403) throw new Error('OAuth 403: Insufficient client permissions.');
        if (status === 429) throw new Error('OAuth 429: Rate limit exceeded.');
        throw new Error(`OAuth ${status}: ${error.response.data?.error_description || 'Unknown'}`);
      throw new Error(`Network error: ${error.message}`);
      console.log('Valid token cached. Skipping fetch.');
  isExpired() {
      const remaining = Math.max(0, Math.floor((this.expiresAt - Date.now()) / 1000));
      if (remaining < this.rotationBufferSeconds) {
        console.log(`Token expires in ${remaining}s. Rotating.`);
      while (resolved) {
    } catch (error) {
      while (rejected) {
        rejected(error);
      throw error;
    } finally {
    if (!this.accessToken || this.isExpired()) return await this.refreshToken();
        this.refreshQueue.push((t) => resolve(t));
        this.refreshQueue.push((e) => reject(e));
    this.sdk.setEnvironment(BASE_URL);
    let attempt = 0;
        return await apiCall();
      } catch (error) {
          await new Promise(r => setTimeout(r, (retryAfter * 1000) + jitter));
          attempt++;
          continue;
        throw error;
    throw new Error(`${operationName} failed after ${this.maxRetries} retries.`);
    let allUsers = [];
    do {
      pageCounter++;
        () => usersApi.postUsersQuery({ pageSize, nextPageUri: nextPageUri || undefined, expand: ['routing'] }),
    return allUsers;
async function main() {
  const tokenManager = new TokenManager();
  await tokenManager.initialize();
  tokenManager.startCronValidator();
  const client = new GenesysApiClient(tokenManager);
  console.log('Fetching users...');
  const users = await client.listAllUsers();
  console.log(`Successfully retrieved ${users.length} users.`);
  process.exit(0);
main().catch(err => {
  console.error('Fatal error:', err);
  process.exit(1);
Run the script with node --env-file=.env index.mjs. The script bootstraps the token, starts the cron validator, executes a paginated query, and exits cleanly. The cron job continues running in the background until the process terminates.
Error: OAuth 401 Unauthorized
  • What causes it: The client identifier or client secret is incorrect, expired, or revoked in the Genesys Cloud security profile.
  • How to fix it: Navigate to Admin > Security > OAuth Clients. Verify the client status is Active. Regenerate the secret if it was rotated. Ensure the environment URL matches the client registration environment.
  • Code showing the fix: The fetchToken() method explicitly catches 401 and throws a descriptive error. You must update environment variables before retrying.
Error: OAuth 429 Too Many Requests
  • What causes it: The OAuth endpoint enforces a strict request rate limit. Rapid restarts or cluster scaling events can trigger simultaneous token requests.
  • How to fix it: Implement the queue-based synchronization pattern shown in refreshToken(). Add exponential backoff with jitter to retry logic. Monitor the Retry-After header.
  • Code showing the fix: The executeWithRetry method parses Retry-After, adds random jitter, and delays the next attempt. The token manager queues concurrent refresh requests to prevent parallel OAuth calls.
Error: SDK 403 Forbidden
  • What causes it: The requested API endpoint requires scopes that were not included in the scope parameter during token acquisition.
  • How to fix it: Update the GENESYS_SCOPES environment variable to include the required permissions. Restart the application to fetch a new token with the expanded scope set.
  • Code showing the fix: The SCOPES constant is passed directly to the OAuth request body. Modifying it requires a fresh token fetch.
Error: SDK setAccessToken is deprecated or ignored
  • What causes it: Older SDK versions used configuration.setAccessToken(). The v3 SDK requires sdk.setAccessToken() with an async function signature.
  • How to fix it: Upgrade to @genesyscloud/purecloud-platform-client-v2 v3.1.0 or higher. Use the async arrow function pattern shown in the GenesysApiClient constructor.
  • Code showing the fix: this.sdk.setAccessToken(async () => await this.tokenManager.getAccessToken());
