Identifying a call from remote switch - Intercommunication Strategy
So here’s another curly problem I’ve come across today.
I have a situation where a client has a Genesys BCP setup with 2 sites running active / active mode. Agents log in to one site predominantly but inbound calls are load balanced to both sites equally.
When a call arrives on site 2 and delivers to an agent on site 1 and that agent needs to transfer the call externally I need to perform some logic in IRD in order to specify a prefix on the outbound call, but only on these cross site calls. With a normal inbound call I’m able to do this easily using user data, however with an intercommunication call I don’t get all the original call data.
Anyone got any ideas on what I could use to identify the calls?
Here is a sample EventRouteRequest:
received from 65354(sipserver_a)host.domain:3000(fd=) message EventRouteRequest
AttributeCallState 0
AttributeCallType 4
AttributeLocalCallType 4
AttributeCallID 19748596
AttributeConnID 076f02f79f7f7a05
AttributeCallUUID ‘01R3GJ2L9SF8196HICIH4PTAES02IG2R’
AttributeTransferConnID 0771030cd0d02e4c
AttributeUserData [1788] 00 1c 00 00..
‘IW_CaseUid’ ‘1d625d70-f5e0-4e06-b914-8990d146a31b’
‘ContactId’ ‘0000XaGCGK319BTT’
‘DisplayContact’ ‘’
‘IWAttachedDataInformation’(list) ‘ToastCaseDataBusinessAttribute’ ‘ViewAttachedData’
‘CaseDataBusinessAttribute’ ‘ViewAttachedData’
‘Option.interaction.case-data.frame-color’ ‘#FF17849D’
‘Option.interaction.case-data.header-foreground-color’ ‘#FFFFFFFF’
‘Option.expression.url’ ‘(?#Protocol)(?:(?:ht|f)tp(?:s?)://|~/|/)?(?#Username:Password)(?:\w+:\w+@)?(?#Subdomains)(?:(?:[-\w]+.)+(?#TopLevel Domains)(?:com|org|net|gov|mil|biz|info|mobi|name|aero|jobs|museum|travel|[a-z]{2}))(?#Port)(?::[\d]{1,5})?(?#Directories)(?:(?:(?:/(?:[-\w~!$+|.,=]|%[a-f\d]{2})+)+|/)+|?|#)?(?#Query)(?:(?:?(?:[-\w~!$+|.,:]|%[a-f\d{2}])+=(?:[-\w~!$+|.,:=]|%[a-f\d]{2}))(?:&(?:[-\w~!$+|.,:]|%[a-f\d{2}])+=(?:[-\w~!$+|.,:=]|%[a-f\d]{2})))(?#Anchor)(?:#(?:[-\w~!$+|.,:=]|%[a-f\d]{2}))?’
‘GCS_TransferringDate’ ‘7/8/2021 10:47:35 PM’
‘GCS_TransferringAgentName’ ‘user@company’
‘GCS_TransferringReason’ ‘’
‘GCS_TransferringEmployeeId’ ‘user@company’
‘GCS_TransferringNotepad’ ‘’
‘RVQDBID’ ‘’
‘RTargetAgSelDBID’ ‘19430’
‘RTargetPlSelDBID’ ‘12132’
‘RTenantDBID’ ‘169’
‘CustomerSegment’ ‘default’
‘ServiceType’ ‘default’
‘ServiceObjective’ ‘’
‘IWS_CallUuid’ ‘01R3GJ2L9SF8196HICIH4PTAES02IG2Q’
‘IWS_ConnID’ ‘0771030CD0D02E4C’
‘IWS_ANI’ ‘9876543210’
‘IWS_DNIS’ ‘169EXRP0053’
‘IWS_ThisDN’ ‘1699300’
‘NT_LOGIN’ ‘user’
‘BusinessResult’ ‘[“none”]’
‘BusinessResultDisplay’ ‘none’
‘Outcome_1’ ‘none’
‘Outcome_2’ ‘none’
‘Outcome_3’ ‘none’
‘Outcome_4’ ‘none’
‘IW_RoutingBasedOriginalEmployeeId’ ‘user@company’
‘IW_RoutingBasedTargetType’ ‘TypeDestination’
‘IW_RoutingBasedTargetId’ ‘123456’
‘IW_RoutingBasedRequestType’ ‘InitTransfer’
‘IW_BundleUid’ ‘68136d13-693b-4bf1-b347-8205db674fa4’
AttributeDNIS ‘1699998’
AttributeCustomerID ‘Tenant’
AttributeThisDN ‘1699998’
AttributeThisDNRole 2
AttributeThisQueue ‘1699998’
AttributePartyUUID ‘00BI36ILA0F8196HICIH4PTAES2U0QM9’
AttributeOtherDN ‘1699300’
AttributeOtherDNRole 1
AttributeExtensions [23] 00 01 01 00..
‘BusinessCall’ 2
AttributeTimeinSecs 1625748459 (22:47:39)
AttributeTimeinuSecs 122138
AttributeEventSequenceNumber 000000001b195983
As far as I can tell there is no meaningful difference between difference with these EventRouteRequests for cross site or same site calls.
You have one URS for each site?
Yes, separate pairs of URS’s per site.
There are some TServer options to preserve attach data on consult transfer calls. Have you checked those?
I should have updated this yesterday, I realised that my test calls weren’t using the normal strategy, once I changed that I had all the attached data I needed and resolved the issue.
That’ll teach me for throwing together a test strategy rather than using a copy of production.
Hehehe happens a lot ;D ;D
