I am new on this forum but not on Genesys. I had develop two months ago a softphone and now i have to implement also Rescheduling Outbound Call. I create a KeyValueCollection with the required parameters.
I don’t know two things.
How should i retreive the GSW_RECORD_HANDLE in order to attach it on the KeyValueCollection? From where can i find it? Does it exists on the AnswerCall and How should i found it?
Which Request should i use in order to fire the Request on T-Server in order to Reschedule the Call?
Any sample code would be very very helpfull.
Thomas
The record handle arrives on the Event_Ringing for example.
It will be a good idea that you add a eventlog object so you can see all what happens on your DN.
To reschedule just send the event any time with the required format.
Search here, there a couple of codes for examples
There is a sample VB application with source code that I have posted here a while back that will do just that. Take a look at it because it should cover most of your questions. Please tell me if you cannot find it and I will upload it again.
Needless to say, please ask questions about the source code, if something seems weird
(Please remember that I put it together in less than an hour, so please do not expect it to work perfectly in a full production environment!)
Best regards,
Thanks a lot for your replies. Victor i cannot find the sample VB application. Could you please upload it again and send me the url i can download it?
Best Regards,
Thomas
search for visual + basic + code it’s not a file, it’s plain text.
Ok, here we go - I put together something for you - I did not have time to play with date/time yet, but all you need to do is add the time field and you are set.
This application will let you login.logout, join/leave campaign, ask for the next record, enter the data, update the status of the record. So, what you need to do is just one more field for date
Needless to say, please re-write it to make it more useful for you - I only spent about 15 minutes on it.
I will try to play with the date tomorrow if you need more help
Best regards,
did you have any luck with GIS reschedule? I did not get a chance to install or play with it so far.
Did you manage to do it on your own?
