mProtocolManager[tServerName].Send(requestMakeCall);
TServer Log
— Evt::Ready —
link (link-tcp) S->H: (0[0 / 0] requests pending)
@12/23/10@04:16:41.874 **** PBX::SystemStatus ****
link (link-tcp) S->H: System status request (id=228 [2]) from PBX (0[0 / 0] requests pending)
04:16:55.343 Trc 04521 New client 396 connected from ‘192.168.0.9’
04:16:55.343 {connection {accepted} {socket 396} {remote-host 192.168.0.9} {remote-port 3830} {listener {port-id default} {socket 336}}}
04:16:55.406 Trc 04541 RequestRegisterClient received from [396]
message RequestRegisterClient
AttributeApplicationPassword ‘’
AttributeApplicationName ‘test’
AttributeSessionID 0
AttributeProtocolVersion ‘tserver protocol 4.2’
04:16:55.406 Trc 04522 Client [396] authorized, name ‘test’, id=0000000a
12/23/10@04:16:55.406 +++ RqHandler::RequestRegisterClient +++
got message from client
@04:16:55.4060 [0] 7.6.002.00 send_to_client: message EventLinkConnected
AttributeApplicationName ‘Tserver’
AttributeSessionID 7995401
AttributeUserData [2] 00 00..
AttributeRegistrationCode 0
AttributeEventSequenceNumber 0000000000000058
AttributeServerStartTime 4d125df400003a98 (03:22:12.015000)
AttributeTimeinuSecs 406000
AttributeTimeinSecs 1293052615 (04:16:55)
04:16:55.406 Trc 04542 EventLinkConnected sent to [396] (0000000a test 192.168.0.9:3830)
— RqHandler::RequestRegisterClient —
04:16:57.437 Trc 04541 RequestMakeCall received from [396] (0000000a test 192.168.0.9:3830)
message RequestMakeCall
AttributeExtensions [20] 00 01 00 00..
‘CPNDigits’ ‘2503’
AttributeReferenceID 2
AttributeMakeCallType 1 (MakeCallDirectAgent)
AttributeOtherDN ‘765002’
AttributeThisDN ‘765001’
04:16:57.437 Int 04543 Interaction message “RequestMakeCall” received from 396 (“test”)
@04:16:57.4370 [ISCC] Client location test:0000000a@ added
@04:16:57.4370 [0] 7.6.002.00 send_to_client: message EventError
(DN is not registered)
AttributeEventSequenceNumber 0000000000000059
AttributeTimeinuSecs 437000
AttributeTimeinSecs 1293052617 (04:16:57)
AttributeErrorCode 41
04:16:57.437 Int 04545 Interaction message “EventError” sent to 396 (“test”)
04:16:57.437 Trc 04542 EventError sent to [396] (0000000a test 192.168.0.9:3830)
@12/23/10@04:17:10.890 **** PBX::SystemStatus ****
link (link-tcp) S->H: System status request (id=22a [2]) from PBX (0[0 / 0] requests pending)
This source code
private void button2_Click(object sender, EventArgs e)
//Makecall
//MakeCallButton.Enabled = false;
RequestMakeCall requestMakeCall =
RequestMakeCall.Create(
thisDn,
SingleTargetTextField.Text,
MakeCallType.DirectAgent);
int uniqueId = GenerateUniqueId();
//requestMakeCall.ReferenceID = uniqueId;
RequestHash.Add(uniqueId, "RequestMakeCall");
try
requestMakeCall.OtherDN = SingleTargetTextField.Text;
requestMakeCall.ThisDN = thisDn;
//requestMakeCall.Extensions = new KeyValueCollection();
//requestMakeCall.Extensions["CPNDigits"] = "2503";
catch (ProtocolException protocolException)
MessageBox.Show("Protocol Exception!/n" + protocolException);
MakeCallButton.Enabled = true;
On your code you are sending the dial order but don’t the register/monitor, is it done on another function?
Hi onizerga,
You must register DN you’d like to control using RequestRegisterAddress request before issuing RequestMakeCall.
Thank you
I will try solve from suggestion
Hi I try register DN from source code as below but my softphone not register
private void button1_Click(object sender, EventArgs e)
//Login
try
LoginButton.Enabled = false;
RequestRegisterAddress requestRegisterAddress =
RequestRegisterAddress.Create(
thisDn,
RegisterMode.ModeShare,
ControlMode.RegisterDefault,
AddressType.DN);
requestRegisterAddress.ReferenceID = uniqueId;
requestRegisterAddress.Extensions = new KeyValueCollection();
//requestRegisterAddress.Extensions["CPNDigits"] = "2503";
requestRegisterAddress.Extensions["CPNDigits"] = "761001";
mProtocolManager[tServerName].Send(requestRegisterAddress);
RequestHash.Add(uniqueId, "RequestRegisterAddress");
LogoutButton.Enabled = true;
MessageBox.Show("Login complete ");
MessageBox.Show("Protocol Exception!\n" + protocolException);
TServer Log
@12/26/10@20:30:42.936 **** PBX::SystemStatus ****
12/26/10@20:30:42.952 link (link-tcp) S->H: System status request (id=899 [2]) from PBX (0[0 / 0] requests pending)
20:30:55.139 Trc 04521 New client 368 connected from ‘192.168.0.9’
20:30:55.139 {connection {accepted} {socket 368} {remote-host 192.168.0.9} {remote-port 2811} {listener {port-id default} {socket 336}}}
20:30:55.264 Trc 04541 RequestRegisterClient received from [368]
20:30:55.264 Trc 04522 Client [368] authorized, name ‘test’, id=00000004
12/26/10@20:30:55.264 +++ RqHandler::RequestRegisterClient +++
got message from client <4>
@20:30:55.2640 [0] 7.6.002.00 send_to_client: message EventLinkConnected
AttributeSessionID 7995395
AttributeEventSequenceNumber 0000000000000034
AttributeServerStartTime 4d16d114000a3d18 (12:22:28.671000)
AttributeTimeinuSecs 264000
AttributeTimeinSecs 1293370255 (20:30:55)
20:30:55.264 Trc 04542 EventLinkConnected sent to [368] (00000004 test 192.168.0.9:2811)
20:31:04.499 Trc 04541 RequestRegisterAddress received from [368] (00000004 test 192.168.0.9:2811)
message RequestRegisterAddress
AttributeExtensions [22] 00 01 00 00..
‘CPNDigits’ ‘761001’
AttributeAddressType 1 (DN)
AttributeControlMode 0
AttributeRegisterMode 0
@20:31:04.4990 [ISCC] Client location test:00000004@ added
20:31:04.499 Trc 20006 Number of seat licenses in use 3 out of 9999 available
(tservice_proc) AddressType changed to 2 for 765001 based on CME
(tservice_proc) ControlMode set to 1 for 765001
12/26/10@20:31:04.499 +++ RqHandler::RequestRegisterAddress +++
device <765001> cannot be monitored - could be a real agent
@20:31:04.4990 [0] 7.6.002.00 send_to_client: message EventError
(Bad DN type for DN registration)
AttributeEventSequenceNumber 0000000000000035
AttributeTimeinuSecs 499000
AttributeTimeinSecs 1293370264 (20:31:04)
AttributeErrorMessage ‘Bad DN type for DN registration’
AttributeErrorCode 128
AttributeUserEvent RequestRegisterAddress
AttributeClientID 4
AttributeControlMode 1
AttributeAddressType 2 (Position)
20:31:04.499 Int 04545 Interaction message “EventError” sent to 368 (“test”)
20:31:04.499 Trc 04542 EventError sent to [368] (00000004 test 192.168.0.9:2811)
— RqHandler::RequestRegisterAddress —
@12/26/10@20:31:13.030 **** PBX::SystemStatus ****
link (link-tcp) S->H: System status request (id=89b [2]) from PBX (0[0 / 0] requests pending)
What type of DN is the number 765001 in Genesys configuration (CME)?
What switch do you have?
