You may also want to check your Access Groups in CME to make sure you have full R/W access, as well as your Rank for IRD, to ensure you are (still) an Administrator, rather than just a User…
I am adding a picture of the problem I have. to clarify the situation, and try to reinstall the IRD but continues the same fault,
Reinstall it on another pc and this problem does not happen so I guess it must be something on my pc, but do not know the reason
Clarification: I have full R / W access … and administrator permissions.
I had that problem and solved it, but I am not sure what was the solution. I suppose it was something with different versions of IRD.
Is it possible that this strategy was edited by someone that has a different version of IRD than you? Or your IRD is in the different version than IRD that other people use?
This issue is described in Genesys Knowledge base - strategy was edited by higher version of IRD (7.6?) and opened with older release (7.5 based on your screenshot). It’s necessary to save it in compatibility mode to fix the issue.
You can find more details in mentioned Knowledge base - search using following keywords “IRD block icon grey”.
