How to use variable of SQL query in IRD
Hi… :slight_smile:
Can you help me ?
I Want to insert to ANI in the database.
Select * from dbo.aniTB Where Ani = ani<<<-----(variable of ani in IRD)
it is woking. i did get the name of the corresponding ani.
but, i can’t Insert Statement…
Insert into dbo.aniTB Values(“ani”)
that’s okay … as String “ani”
but i want to use ani as variable(variable of ani in IRD)
it could be used in Select query , but not working in Insert query
Do you know how to use variable?? :-[
Thank you.. :-*
Need to use a stored procedure and pass the variables to that.
Sent from my Redmi Note 3 using Tapatalk
Thank you..!!
I done that!! i share my query :stuck_out_tongue:
CREATE PROCEDURE InsertTB @a varchar(50), @b varchar(50) AS
INSERT INTO dbo.aniTB(test1, test2) VALUES (@a, @b)
EXEC InsertTB @a = ani , @b = ConID <<----------(variables in IRD)
IRD automatically turns variables into values only if they follow some comparing/assigning sign like =, >, <, <=, etc.
