I’m going to depoyment Framework 7.6 , Tserver will connect with AES via DLG .
Is there any testing tool which I can test the CTI link and AES connection ? how do I know the link is configured properly ?
Thanks in advance ??? ???
Well the first thing is to make sure it is configured on the tserver correctly and that you are getting an eventlinkconnected message back.
Its pretty easy to get a connection… once you get that there rest is all from Genesys side, except maybe depending on how you want to handle TACW and RONA.
Ian DS
