request = RequestAgentReady.create(thisDN, workMode, thisQueue, reason_kvc, ext_kvc);
reason_kvc is String or int or structure ??
Please teach me, How to set parameter in reasonCode.
Dim ReasonPair As New CTKVPair
Dim ReasonList As New CTKVList
'Create the NotReady ReasonCode KVPair
ReasonPair.Type = CKVTypeNum
ReasonPair.Key = "ReasonCode"
ReasonPair.NumValue = 3 'Where 3 is what you created on CME for example as Action Codes
'Add the NotReady ReasonCode to the KVList
ReasonList.AddHead ReasonPair
'Attach the KVList to the AttributeReason List
TExtension1.TSetReason ReasonList
'Change Agent's state to AuxWork mode, and go NotReady.
TExtension1.TAgentWorkMode = AuxWork
TExtension1.TNotReady
'Clear the NotReady ReasonCode Extension, and Reason list.
ReasonList.Clear
TExtension1.TSetExtensions ReasonList
Hi Tom,
the parameter “reasons” is an object of type “KeyValueCollection”. You have to create an instance of this object, add some key-value pair and pass it as a parameter to “create” method. The standard KV for reason code is “ReasonCode” (surprise ;)) but I would suggest you to check TServer documentation for your PBX for correct name of key-value pair.
Genesyslab.Platform.Commons.Collections.KeyValueCollection reasons;
reasons = new Genesyslab.Platform.Commons.Collections.KeyValueCollection();
reasons.Add(“ReasonCode”,“1”);
René
Ok,
Seems i posted a total different thing, what language is that?
I am using JAVA language.
Now I did crear my problem.
Thank you very mutch.
