How to set ANI in my specific attach data key in routing strategy
Dear All,
How to set ANI(call number) in my specific attach data key in routing strategy.
Thanks in advance :slight_smile:
Not sure what you mean, do you want to change the AttributeANI, or attach the ANI as a specific user data key?
I’m fairly certain you can’t change the ANI attribute, or at least not easily. If attaching the ANI as a specific user data key then:
Update[‘some-key’,ANI]
Update[‘some-key’,ANI] is exactly i wanted thank you very much :slight_smile:
Is there any document or reference where i can learn this.
https://docs.genesys.com - of course, you have to have own access login to the Genesys site.
This type of thing you can learn within IRD itself though, all you need to do is use the function builder to create the functions you need.
Thank you
There is a function in the Fx block…just populate it and then attach
