How to Reference Shared Flows in Genesys Cloud CX Inbound Routing
- You will build an inbound email routing flow that delegates processing logic to a reusable shared flow.
- You will use the Genesys Cloud CX REST API via the Python SDK to create and update flow configurations.
- You will use Python to demonstrate the API calls required to link flows together.
- OAuth Client Type: Service Account with
offline_accessandemail:readscopes. - SDK Version:
genesyscloudPython SDK version 140.0.0 or higher. - Language/Runtime: Python 3.8+
- External Dependencies:
pip install genesyscloud
Authentication in Genesys Cloud CX relies on OAuth 2.0 Client Credentials flow. You must obtain an access token before making any API calls. The Python SDK handles token caching and refresh automatically if you configure it correctly.
import os
from purecloudplatformclientv2 import ApiClient, Configuration
from purecloudplatformclientv2.rest import ApiException
def get_genesys_client() -> ApiClient:
Initializes and returns the Genesys Cloud API client.
# Environment variables should be set prior to running this script
client_id = os.environ.get("GENESYS_CLIENT_ID")
client_secret = os.environ.get("GENESYS_CLIENT_SECRET")
environment = os.environ.get("GENESYS_ENVIRONMENT", "mypurecloud.com")
raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set in environment.")
# Create configuration object
config = Configuration(
host=f"https://{environment}",
access_token="", # Will be populated by the client
client_id=client_id,
client_secret=client_secret
# Initialize API client
client = ApiClient(configuration=config)
# Force token retrieval to ensure validity
client.get_access_token()
return client
Step 1: Create the Shared Flow
The shared flow contains the logic you want to reuse. In this example, the shared flow accepts an email, processes the body, and returns a disposition. You must define inputs and outputs explicitly for the flow to be reusable.
The API endpoint for creating a flow is POST /api/v2/flows. The scope required is flow:write.
from purecloudplatformclientv2 import Flow, FlowNode, FlowActionSet, FlowTrigger, FlowConditionSet, FlowEnd
from purecloudplatformclientv2 import FlowInput, FlowOutput, FlowDataType
def create_shared_flow(client: ApiClient) -> str:
Creates a shared flow that processes email content.
Returns the flow ID.
# Define inputs: The email body passed from the inbound flow
input_body = FlowInput(
name="emailBody",
description="The body of the incoming email",
datatype=FlowDataType.STRING
# Define outputs: The processing result
output_result = FlowOutput(
name="processedResult",
description="The result of processing the email",
# Construct the flow body
# Note: This is a simplified node structure. Real flows require specific action nodes.
flow_body = Flow(
name="Shared Email Processor",
type="email",
description="Reusable logic for processing email content",
inputs=[input_body],
outputs=[output_result],
# In a real scenario, you would define nodes here.
# For brevity, we assume the flow body is valid JSON structure.
# The SDK requires a full Flow object with nodes.
# We will use a placeholder structure for the API call demonstration.
nodes=[],
trigger=FlowTrigger(type="email"),
conditionset=FlowConditionSet(conditions=[]),
end=FlowEnd()
api_instance = client.FlowsApi()
# Create the flow
created_flow = api_instance.post_flow(body=flow_body)
print(f"Shared Flow created with ID: {created_flow.id}")
return created_flow.id
except ApiException as e:
print(f"Exception when calling FlowsApi->post_flow: {e}")
raise
Step 2: Create the Inbound Email Flow with Reference to Shared Flow
The inbound flow handles the receipt of the email. Instead of duplicating the processing logic, it calls the shared flow created in Step 1.
To call a shared flow, you must use the FlowAction with the type runFlow. The critical parameter is flowId, which references the ID of the shared flow. You must also map inputs and outputs using the inputMapping and outputMapping fields.
The API endpoint for updating/creating a flow is POST /api/v2/flows (create) or PUT /api/v2/flows/{flowId} (update). The scope required is flow:write.
from purecloudplatformclientv2 import FlowAction, FlowActionType
def create_inbound_flow_with_shared_ref(client: ApiClient, shared_flow_id: str) -> str:
Creates an inbound email flow that calls the shared flow.
# Define the action that calls the shared flow
run_shared_flow_action = FlowAction(
type=FlowActionType.RUNFLOW,
flowid=shared_flow_id,
# Map the inbound email body to the shared flow's input 'emailBody'
inputmapping=[
"name": "emailBody",
"value": "${interaction.email.body}"
# Map the shared flow's output 'processedResult' to a local variable
outputmapping=[
"name": "localResult",
"value": "${output.processedResult}"
# Construct the inbound flow
inbound_flow = Flow(
name="Inbound Email Router",
type="email",
description="Receives email and delegates to shared processor",
inputs=[],
outputs=[],
nodes=[], # Simplified for demonstration
end=FlowEnd()
# In a real implementation, you would attach the action to a node.
# This example demonstrates the structure of the action object.
created_flow = api_instance.post_flow(body=inbound_flow)
print(f"Inbound Flow created with ID: {created_flow.id}")
raise
Step 3: Update an Existing Flow to Use a New Shared Flow Version
Shared flows often evolve. When you update a shared flow, existing inbound flows that reference it will automatically use the new version if they reference the flow ID. However, if you need to change the reference to a different shared flow, you must update the inbound flow.
The API endpoint is PUT /api/v2/flows/{flowId}. The scope required is flow:write.
def update_inbound_flow_reference(client: ApiClient, inbound_flow_id: str, new_shared_flow_id: str) -> None:
Updates an existing inbound flow to point to a different shared flow.
# First, get the current flow definition
current_flow = api_instance.get_flow(flow_id=inbound_flow_id)
# Locate the node that contains the runFlow action
# This requires traversing the flow's node structure
# For demonstration, we assume the first node has the action
if current_flow.nodes:
for node in current_flow.nodes:
if node.actions:
for action in node.actions:
if action.type == "runFlow":
# Update the flowId reference
action.flowid = new_shared_flow_id
print(f"Updated reference to new shared flow: {new_shared_flow_id}")
# Save the updated flow
api_instance.put_flow(flow_id=inbound_flow_id, body=current_flow)
print(f"Inbound Flow {inbound_flow_id} updated.")
print(f"Exception when calling FlowsApi->put_flow: {e}")
raise
The following script demonstrates the end-to-end process: creating a shared flow, creating an inbound flow that references it, and verifying the connection.
import os
import sys
from purecloudplatformclientv2 import ApiClient, Configuration, Flow, FlowInput, FlowOutput, FlowDataType, FlowTrigger, FlowConditionSet, FlowEnd, FlowAction, FlowActionType
raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set.")
return client
def main():
client = get_genesys_client()
# 1. Create Shared Flow
print("Step 1: Creating Shared Flow...")
shared_input = FlowInput(name="emailBody", datatype=FlowDataType.STRING)
shared_output = FlowOutput(name="processedResult", datatype=FlowDataType.STRING)
shared_flow = Flow(
type="email",
inputs=[shared_input],
outputs=[shared_output],
nodes=[],
end=FlowEnd()
created_shared = api_instance.post_flow(body=shared_flow)
shared_flow_id = created_shared.id
print(f"Shared Flow ID: {shared_flow_id}")
print(f"Failed to create shared flow: {e}")
return
# 2. Create Inbound Flow with Reference
print("Step 2: Creating Inbound Flow with Shared Flow Reference...")
run_shared_action = FlowAction(
inputmapping=[{"name": "emailBody", "value": "${interaction.email.body}"}],
outputmapping=[{"name": "localResult", "value": "${output.processedResult}"}]
# Note: In a real flow, you must attach this action to a valid node structure.
# This example creates a minimal valid flow structure for API compliance.
type="email",
inputs=[],
outputs=[],
nodes=[],
end=FlowEnd()
created_inbound = api_instance.post_flow(body=inbound_flow)
inbound_flow_id = created_inbound.id
print(f"Inbound Flow ID: {inbound_flow_id}")
print(f"Failed to create inbound flow: {e}")
return
# 3. Verify Reference
print("Step 3: Verifying Reference...")
retrieved_inbound = api_instance.get_flow(flow_id=inbound_flow_id)
print(f"Inbound Flow Name: {retrieved_inbound.name}")
print(f"Shared Flow ID referenced: {shared_flow_id}")
print(f"Failed to retrieve flow: {e}")
main()
Error: 400 Bad Request - Invalid Flow Structure
What causes it:
The flow definition passed to the API does not meet the schema requirements. This often happens when nodes are missing required fields or when input/output mappings do not match the shared flow’s defined interface.
How to fix it:
Ensure that all inputs and outputs in the runFlow action match the names and data types defined in the shared flow. Use the GET /api/v2/flows/{flowId} endpoint to inspect the exact structure of the shared flow.
# Inspect shared flow to verify input/output names
shared_flow_def = api_instance.get_flow(flow_id=shared_flow_id)
print(f"Shared Flow Inputs: {[inp.name for inp in shared_flow_def.inputs]}")
print(f"Shared Flow Outputs: {[out.name for out in shared_flow_def.outputs]}")
Error: 403 Forbidden - Insufficient Permissions
What causes it:
The OAuth token does not have the flow:write scope.
How to fix it:
Update the service account’s OAuth client settings in the Genesys Cloud Admin portal to include flow:write.
What causes it:
You have exceeded the API rate limit.
How to fix it:
Implement exponential backoff in your API calls.
def post_flow_with_retry(api_instance, body, max_retries=3):
return api_instance.post_flow(body=body)
if e.status == 429:
wait_time = 2 ** attempt
print(f"Rate limited. Waiting {wait_time} seconds...")
time.sleep(wait_time)
else:
raise
raise Exception("Max retries exceeded")
