How to print result of stored procedure using Composer
Hi There,
I am using DB Data block of composer for stored procedure and am able to execute successfully.
I am trying to print the result, for that according to the document i have defined the column name variable and record variable .
In log i can see below assignment.
Runtime.cxx:462 EvaluateExpression(): Expression [var DBDataWL_VIP1777Data = {“db_result”:,“db_result_columns”:,“db_outparams”:{“RETURN_VALUE”:“0”,“compteur”:"1 "}};]
AssignRuntime.cxx:48 Execute(): Script [AppState.DBDataWL_VIP1777;AppState.DBDataWL_VIP1777=DBDataWL_VIP1777Data.db_result;]
AssignRuntime.cxx:48 Execute(): Script [AppState.DBDataWL_VIP1777compteur;AppState.DBDataWL_VIP1777compteur=DBDataWL_VIP1777Data.db_result_columns;]
I want to print value of “compteur” . Can anyone suggest how can we print the value of “compteur”
Please find vxml code for DB data block----
	<script>
 		var connProps = new Object();
 		var customParameters = new Object();
		connProps['customParameters'] = customParameters;
	</script>
	<var name="ConnPropString" expr="'(' + JSON.stringify(connProps) + ')'" />
	<block>
		<data name="DBDataWL_VIP1777Data" src="../include/dbrequest.jsp" method="post"
			namelist="AppStateString db_query db_query_type db_name db_timeout ConnPropString sp_param_list sp_param_RETURN_VALUE sp_param_proc_ani sp_param_compteur"
			 enctype="multipart/form-data"
			 fetchtimeout="22s"/>
    	<if cond="typeof DBDataWL_VIP1777Data.errorMsg == 'undefined'">
        	<if cond="typeof DBDataWL_VIP1777Data.db_result != 'undefined'">
        		<assign name="AppState.DBDataWL_VIP1777" expr="DBDataWL_VIP1777Data.db_result" />
        		<assign name="AppState.DBDataWL_VIP1777compteur" expr="DBDataWL_VIP1777Data.db_result_columns" />
        	</if>
        	<if cond="typeof DBDataWL_VIP1777Data.db_outparams != 'undefined'">
     			<log expr="'db_outparams:' + DBDataWL_VIP1777Data.db_outparams"/>
        		<assign name="AppState.var_Filter_Column" expr="DBDataWL_VIP1777Data.db_outparams.RETURN_VALUE" />
        		<assign name="AppState.var_Stored_Set" expr="DBDataWL_VIP1777Data.db_outparams.compteur" />
        	</if>
			<goto next="#ECMAScript2" />
    	<else/>
    	    <if cond="typeof DBDataWL_VIP1777Data.errorType != 'undefined'">
    	        <if cond="DBDataWL_VIP1777Data.errorType == 'timeout'">
	        	    <throw event="error.com.genesyslab.composer.dbtimeout" messageexpr="DBDataWL_VIP1777Data.errorMsg" />
	            <elseif cond="DBDataWL_VIP1777Data.errorType == 'connectionerror'" />
	        	    <throw event="error.com.genesyslab.composer.dbconnectionerror" messageexpr="DBDataWL_VIP1777Data.errorMsg" />
	            </if>
    		<else/>
        		<throw event="error.com.genesyslab.composer.dberror" messageexpr="DBDataWL_VIP1777Data.errorMsg" />
    		</if>
    	</if>
	</block>
	<catch event="error.com.genesyslab.composer.dberror">
		<script>storeCallflowException(_element, _message, _event, _line, _url)</script>
		<goto next="#Br_Identif" />
    </catch>
	<catch event="error.com.genesyslab.composer.dbemptyresultset">
    </catch>
	<catch event="error.com.genesyslab.composer.dbtimeout">
    </catch>
	<catch event="error.com.genesyslab.composer.dbconnectionerror">
    </catch>
	<catch event="error.com.genesyslab.composer.variablemappingerror">
    </catch>
</form>
------Echma Script block to print value----
try { // your code
					AppState.var_Stored_Set= JSON.stringify(DBDataWL_VIP1777Data.db_outparams.compteur);
				__Log('Result of Stored Procedure'+AppState.var_Stored_Set);
				} catch (error) {
					// error handling code
				__Log('Code Failure');
		</script>
		<goto next="#Log1" />
	</block>
</form>
Thanks in Advance
Once stored into a Composer variable it is just a Json object. So use basic Javascript concept like dot (.) for object properties.
Object.name
Object.color
Object.array1[0].address
Something like that
Thanks for replying, I have already mentioned the Echma script code. where I tried JavaScript code to get the compteur value.
try { // your code
           } catch (error) {
     </script>
  </block>
But DBDataWL_VIP1777Data this variable is not defined by user it is created in DB Data block. not able to print value from that.
How can i print the value from that.
The suffix Data is just an add-on to the real variable name. I guess in your DB block you chose which variable will store the result, right?
I have defined the column variable and record variable in DB data block
AppState.DBDataWL_VIP1777, AppState.DBDataWL_VIP1777compteur
Please find below vxml code
<?xml version="1.0" encoding="utf-8"?>
<!-- VXML code generated by Composer 8.1.540.07 -->
<!-- Diagram created by Composer: Composer 8.1.541.07 -->
<!-- Project version: 8.1.541.07 -->
<!-- Diagram version: 1.0 CreatedOn:  -->
<!-- Application Author:  -->
<!-- Release Mode: false -->
<!-- Global Scripts includes -->
<script src="../include/common.js" />
<script src="../include/ctic.js" />
<script src="../include/json.js" />
<script src="../include/DataAccess.js" />
<!-- Global Vars declarations -->
<script>
	var AppState = new Object();
	AppState.System = new Object();
	AppState.System.RetainInputTypeVariableDefaultValue = false;
	AppState.CallUUID = session.connection.uuid;
	AppState.ANI = getANI();
	AppState.DNIS = getDNIS();
	AppState.USE_LCASE_USERDATAKEY = initSystemTypeVariable('USE_LCASE_USERDATAKEY',0);
	if (session.connection.protocol.sip.headers != undefined &amp;&amp;
		    session.connection.protocol.sip.headers['x-genesys-gvp-session-id']){
		AppState.GVPSessionID = session.connection.protocol.sip.headers['x-genesys-gvp-session-id'];
		AppState.g_CTICCall = isCTICCall(AppState.GVPSessionID);
	} else {
		AppState.GVPSessionID = 'undefined';
		AppState.g_CTICCall = 'false';
	AppState.APP_ASR_LANGUAGE = initSystemTypeVariable('APP_ASR_LANGUAGE','en-US');
	AppState.APP_LANGUAGE = initSystemTypeVariable('APP_LANGUAGE','en-US');
	AppState.APP_OPM = initSystemTypeVariable('APP_OPM',eval('('+session.connection.protocol.sip.requesturi['parameters']+')'));
	AppState.ChoixMenu = undefined;
	AppState.COMPOSER_WSSTUBBING = initSystemTypeVariable('COMPOSER_WSSTUBBING','0');
	AppState.dummy = '';
	AppState.EnableFCR = initSystemTypeVariable('EnableFCR',true);
	AppState.EnableReports = initSystemTypeVariable('EnableReports',false);
	AppState.EnableSNMP = initSystemTypeVariable('EnableSNMP',false);
	AppState.GRAMMARFILEDIR = initSystemTypeVariable('GRAMMARFILEDIR','../Resources/Grammars');
	AppState.ivr_route = 'ACC';
	AppState.LAST_EVENT_ELEMENT = initSystemTypeVariable('LAST_EVENT_ELEMENT','undefined');
	AppState.LAST_EVENT_LINE = initSystemTypeVariable('LAST_EVENT_LINE','undefined');
	AppState.LAST_EVENT_MSG = initSystemTypeVariable('LAST_EVENT_MSG','undefined');
	AppState.LAST_EVENT_NAME = initSystemTypeVariable('LAST_EVENT_NAME','undefined');
	AppState.LAST_EVENT_URL = initSystemTypeVariable('LAST_EVENT_URL','undefined');
	AppState.msisdn = '';
	AppState.numentered = undefined;
	AppState.OCS_Record = initSystemTypeVariable('OCS_Record',getCallflowOCSRecord());
	AppState.OCS_RecordURI = initSystemTypeVariable('OCS_RecordURI',getCallflowRecordURI());
	AppState.OCS_URI = initSystemTypeVariable('OCS_URI',getCallflowOCSURI());
	AppState.PREV_APP_ASR_LANGUAGE = initSystemTypeVariable('PREV_APP_ASR_LANGUAGE','undefined');
	AppState.PREV_APP_LANGUAGE = initSystemTypeVariable('PREV_APP_LANGUAGE','undefined');
	AppState.SCRIPTSDIR = initSystemTypeVariable('SCRIPTSDIR','../Scripts');
	AppState.svi_lang = undefined;
	AppState.VOXFILEDIR = initSystemTypeVariable('VOXFILEDIR','../Resources/Prompts');
	AppState.clientidentif = undefined;
	AppState.choixsortie = undefined;
	AppState.var_ConnectionString = undefined;
	AppState.var_Stored_Set = 0;
	AppState.var_Stored_Record = undefined;
	AppState.var_Filter_Column = undefined;
	AppState.var_msisdn = '';
	AppState.DBDataWL_VIP1777compteur = undefined;
	AppState.DBDataWL_VIP1777 = undefined;
	AppState.DBDataWL_VIP1777_mapping = [];
</script>
<!-- Global Scripts -->
<script srcexpr="AppState.VOXFILEDIR + '/PromptSwitch.js'" />
<script srcexpr="AppState.VOXFILEDIR + '/en-US/en-US.js'" />
<script>var f = new Format();</script>
<script srcexpr="AppState.VOXFILEDIR + '/en-US/customprompts.js'" />
<!-- Global Properties declarations -->
<property name="com.genesyslab.logtoasr" value="false" />
<property name="com.genesyslab.loglevel" value="5" />
<!-- Metadata information -->
<meta name="com.genesyslab.studio.resourcePath" content="/Callflows/Main.callflow"/>
<!-- Global links -->
<form>
	<block>
		<log expr="'Running Main workflow.'"/>
		<log expr="'Code Generated by Composer: 8.1.540.07.'"/>
		<log expr="'Diagram created/upgraded by Composer: Composer 8.1.541.07.'"/>
		<log expr="'Project version: 8.1.541.07.'"/>
		<log expr="'Diagram version: 1.0 CreatedOn: .'"/>
		<goto next="#Entry1" />
	</block>
</form>
<!-- This is the Entry block -->
<form id="Entry1">
	<block name="Entry">
		<goto next="#Assign2" />
	</block>
</form>
<catch event="connection.disconnect.hangup">
	<assign name="AppState.LAST_EVENT_ELEMENT" expr="_element"/>
	<assign name="AppState.LAST_EVENT_MSG" expr="_message"/>
	<assign name="AppState.LAST_EVENT_NAME" expr="_event"/>
	<assign name="AppState.LAST_EVENT_LINE" expr="_line"/>
	<assign name="AppState.LAST_EVENT_URL" expr="_url"/>
		<goto next="#ActionStart2" />
</catch>
<catch event="error">
</catch>
<catch event=".">
</catch>
<!-- This is the Exit block -->
<form id="Exit1">
	<block>
		<exit/>
	</block>
</form>
<!-- This is the Assign block -->
<form id="French">
	<block>
		<assign name="AppState.svi_lang" expr="'FR'" />
		<goto next="#HNO?" />
	</block>
</form>
<form id="English">
	<block>
		<assign name="AppState.svi_lang" expr="'EN'" />
	</block>
</form>
<!-- This is the ActionStartBlock block -->
<form id="ActionStart1">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_Start|parentID=Main</log>
		<goto next="#ActionEnd1" />
	</block>
</form>
<!-- This is the ActionEndBlock block -->
<form id="ActionEnd1">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_Start|UNKNOWN</log>
		<goto next="#ECMAScript1" />
	</block>
</form>
<form id="ActionStart2">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_Deconnexion_Debut</log>
		<goto next="#ActionEnd2" />
	</block>
</form>
<form id="ActionEnd2">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_Deconnexion_Debut|UNKNOWN</log>
		<goto next="#Exit1" />
	</block>
</form>
<form id="ActionStart3">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_English|parentID=Main</log>
		<goto next="#ActionEnd3" />
	</block>
</form>
<form id="ActionStart4">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_French|parentID=Main</log>
		<goto next="#ActionEnd4" />
	</block>
</form>
<form id="ActionEnd3">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_English|UNKNOWN</log>
		<goto next="#English" />
	</block>
</form>
<form id="ActionEnd4">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_French|UNKNOWN</log>
		<goto next="#French" />
	</block>
</form>
<!-- This is the InteractionDataBlock block -->
<form id="InteractionData1">
	<property name="com.genesyslab.externalevents.enable" value="false"/>
  	<property name="com.genesyslab.externalevents.queue" value="true"/>
	<block>
		<if cond="AppState.g_CTICCall == 'false'" >
			<script>
				var choixsortie = AppState.choixsortie;
			</script>
	    	<gvp:send namelist="choixsortie" async="false"/>
		<else/>
			<!--  CTIC Case -->
			<script>
				var Action = "AttachData";
				var sub_action = "Add";
			</script>
			<gvp:send namelist="Action sub_action choixsortie" async="false"/>
			<gvp:receive maxtime="10s"/>
			<if cond="isCTICResult( application.lastmessage$ ) == 'false'">
				<throw event="error.com.genesyslab.composer.receiveerror" messageexpr="'The received message has invalid content-type.'" />
			</if>
			<var name="InteractionData1Message" expr="application.lastmessage$.content"/>
			<var name="arrUserData" expr="getUserDataArray(InteractionData1Message)"/>
			<var name="InteractionData1Result" expr="utilGetReceiveDataValue('Result', arrUserData)" />
			<if cond="InteractionData1Result != 'SUCCESS'">
				<var name="InteractionData1ResultReason" expr="utilGetReceiveDataValue('reason', arrUserData)" />
				<if cond="InteractionData1ResultReason == 'Timeout'">
					<throw event="error.com.genesyslab.composer.operationtimeout" messageexpr="InteractionData1ResultReason" />
				<else/>
					<throw event="error.com.genesyslab.composer.receiveerror" messageexpr="InteractionData1ResultReason" />
				</if>
	 		</if>
		</if>
	</block>
</form>
<!-- This is the DB Data block -->
[b]<form id="DBDataWL_VIP1777">[/b]
	<block>
		<log gvp:level="1">
			<value expr="'Inside the DB data Block'"/>
		</log>
		<log gvp:level="1">
			<value expr="'Result of First variable'+AppState.DBDataWL_VIP1777compteur"/>
		</log>
		<log gvp:level="1">
			<value expr="'Result of Second Variable'+AppState.DBDataWL_VIP1777"/>
		</log>
	</block>
	<var name="AppStateString" expr="'(' + JSON.stringify(AppState) + ')'" />
	<var name="db_query_type" expr="'StoredProcedure'" />
	<!-- branch off based on the query type: SQL Query, Query File or Stored Procedure -->
	<var name="db_query" expr="'Main_DBDataWL_VIP1777.sql'" />
	<!-- Define parameters to be used for stored procedure prepared statement -->
	<var name="sp_param_RETURN_VALUE" expr="'return$$INTEGER$${var_Filter_Column}'" />
	<var name="sp_param_proc_ani" expr="'input$$CHAR$${var_msisdn}'" />
	<var name="sp_param_compteur" expr="'inout$$CHAR$${var_Stored_Set}'" /><var name="sp_param_list" expr="' RETURN_VALUE proc_ani compteur'"/>
	<var name="db_name" expr="'ConnectionProfile'" />
	<var name="db_timeout" expr="20" />
	<script>
	</script>
	<block>
        	</if>
        	</if>
    	<else/>
	            </if>
    		<else/>
    		</if>
    	</if>
	</block>
    </catch>
    </catch>
    </catch>
    </catch>
    </catch>
</form>
<!-- This is the Branching block -->
<form id="Br_Identif">
	<block>
		<if cond="AppState.clientidentif=='OK'">
			<!-- This is the OutLink -->
			<goto next="#AccueilChoixLang" />
		</if>
		<if cond="AppState.clientidentif=!'OK'">
			<goto next="#MsgIdentif" />
		</if>
	</block>
</form>
<form id="ActionEnd5">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_VoixSms|UNKNOWN</log>
		<goto next="#Assign1" />
	</block>
</form>
<form id="Assign1">
	<block>
		<assign name="AppState.choixsortie" expr="'VoixSms'" />
		<goto next="#InteractionData1" />
	</block>
</form>
<form id="ActionStart5">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_VoixSms</log>
		<goto next="#ActionEnd5" />
	</block>
</form>
<form id="Assign3">
	<block>
		<assign name="AppState.choixsortie" expr="'OM'" />
	</block>
</form>
<form id="ActionEnd6">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_OM|UNKNOWN</log>
		<goto next="#Assign3" />
	</block>
</form>
<form id="ActionStart6">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_OM</log>
		<goto next="#ActionEnd6" />
	</block>
</form>
<form id="ActionStart7">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_Internet|parentID=Main</log>
		<goto next="#ActionEnd7" />
	</block>
</form>
<form id="Assign4">
	<block>
		<assign name="AppState.choixsortie" expr="'Internet'" />
	</block>
</form>
<form id="ActionEnd7">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_Internet|UNKNOWN</log>
		<goto next="#Assign4" />
	</block>
</form>
<form id="Exit2">
	<block>
		<exit/>
	</block>
</form>
<form id="ActionEnd9">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_Lingala|UNKNOWN</log>
		<goto next="#Lingala" />
	</block>
</form>
<form id="Lingala">
	<block>
		<assign name="AppState.svi_lang" expr="'LI'" />
	</block>
</form>
<form id="ActionStart9">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_Lingala</log>
		<goto next="#ActionEnd9" />
	</block>
</form>
<form id="Swahili">
	<block>
		<assign name="AppState.svi_lang" expr="'SW'" />
	</block>
</form>
<form id="ActionStart10">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_Swahili</log>
		<goto next="#ActionEnd10" />
	</block>
</form>
<form id="ActionEnd10">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_Swahili|UNKNOWN</log>
		<goto next="#Swahili" />
	</block>
</form>
<form id="ActionStart11">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_Tshiluba</log>
		<goto next="#ActionEnd11" />
	</block>
</form>
<form id="Tshiluba">
	<block>
		<assign name="AppState.svi_lang" expr="'TS'" />
	</block>
</form>
<form id="ActionEnd11">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_Tshiluba|UNKNOWN</log>
		<goto next="#Tshiluba" />
	</block>
</form>
<form id="Kikongo">
	<block>
		<assign name="AppState.svi_lang" expr="'KI'" />
	</block>
</form>
<form id="ActionEnd12">
	<block>
		<log label="com.genesyslab.var.ActionEnd" gvp:cond="AppState.EnableReports">1222_Kikongo|UNKNOWN</log>
		<goto next="#Kikongo" />
	</block>
</form>
<form id="ActionStart12">
	<block>
		<log label="com.genesyslab.var.ActionStart" gvp:cond="AppState.EnableReports">1222_Kikongo</log>
		<goto next="#ActionEnd12" />
	</block>
</form>
<!-- This is the Log block -->
<form id="Log1">
	<block>
	</block>
</form>
<form id="ECMAScript1">
	<block>
		<script>
					// your code
				AppState.var_msisdn=AppState.ANI;
				__Log('The ANI value is  '+AppState.var_msisdn);
				AppState.var_msisdn='&quot;' + AppState.var_msisdn + '&quot;';
				__Log('The ANI value in string  '+AppState.var_msisdn);
				} catch (error) {
		</script>
		<goto next="#DBDataWL_VIP1777" />
	</block>
</form>
<form id="ECMAScript2">
	<block>
		<script>
					// your code
				} catch (error) {
		</script>
	</block>
</form>
<!-- This is the AccueilChoixLang block in Disabled mode -->
<form id="AccueilChoixLang">
	<block>
		<goto next="#ActionStart4" />
	</block>
</form>
<!-- This is the Assign2 block in Disabled mode -->
<form id="Assign2">
	<block>
		<goto next="#ActionStart1" />
	</block>
</form>
<!-- This is the MsgIdentif block in Disabled mode -->
<form id="MsgIdentif">
	<block>
		<goto next="#Exit2" />
	</block>
</form>
<!-- This is the HNO? block in Disabled mode -->
<form id="HNO?">
	<block>
		<goto next="#MessClosed" />
	</block>
</form>
<!-- This is the MessClosed block in Disabled mode -->
<form id="MessClosed">
	<block>
	</block>
</form>
<!-- This is the Qualification block in Disabled mode -->
<form id="Qualification">
	<block>
	</block>
</form>
try getting the value of your variable var_Filter_Column. It should contain the return result of your Stored Procedure
“var_Filter_Column” this variable is storing value of “sp_param_RETURN_VALUE” which is define in DB block as below code line–
I want to get value of “compteur” which is different from “sp_param_RETURN_VALUE”
Ahh I see… well, probably your variable AppState.var_Stored_Set already has this value after the database execution
As said, the Data suffix is just temporary withing MCP execution, use the Variable you set at the DB Block. Try this code
                  // your code
                  AppState.var_Stored_Set= DBDataWL_VIP1777.db_outparams.compteur;
               } catch (error) {
