we have a Alcatel 4400 (TServer 7.0.201.05) and try to play busy treatments in a loop.
In the routing target object we set as busy treatments:
1: Music 30sec
2: Waiting Announcemet
The URS execute both treatments.
After the second event “EventTreatmentEnd” the URS fails to take any action. And does not start to play the first treatment (music) again. The customer only hear silence.
Is there any TServer or URS option to force Genesys play busy treatments in a loop??
Ideally, the same strategy should be working no matter what type of PBX you are using.
Have you checked if the call is routed to default?
Would it be possible for you to paste URS log starting EventRouteRequest and ending with RequestRouteCall or whenever the strategy ends and calls leaves the route point?
(PLEASE PLEASE REMOVE ANY OTHER CALLS THAT HAPPEN IN BETWEEN)
