How to Pass Custom Variables Through an IVR Flow Using Set Participant Data
- You will build a Node.js application that programmatically updates the
participantDatafor an active conversation in Genesys Cloud CX, allowing you to pass custom key-value pairs from an external system into the IVR flow. - This tutorial utilizes the Genesys Cloud Platform API v2, specifically the Conversations API endpoint for modifying participant data.
- The implementation uses JavaScript (Node.js) with the
axioslibrary for HTTP requests and the Genesys Cloud Node.js SDK for authentication.
- OAuth Client Type: An OAuth Client with the
client_credentialsgrant type. - Required Scopes: The client must have the following scopes assigned in the Genesys Cloud Admin Portal:
conversation:updateconversation:viewuser:read(if you need to resolve user IDs for routing, though not strictly required for basic participant data updates)
- SDK Version:
@genesyscloud/genesyscloud-node-sdkversion 150.0.0 or higher. - Runtime: Node.js version 18 or higher.
- External Dependencies:
@genesyscloud/genesyscloud-node-sdkaxios
Before you can modify participant data, you must obtain a valid access token. The Genesys Cloud API uses OAuth 2.0. For server-to-server communication, the client_credentials flow is standard. You must cache this token and handle expiration (typically 1 hour) by requesting a new one.
The following code demonstrates how to initialize the Genesys Cloud SDK and retrieve a token. In a production environment, you would implement a token cache with TTL (Time-To-Live) logic.
const { platformClient, PureCloudPlatformClientV2 } = require('@genesyscloud/genesyscloud-node-sdk');
// Configuration
const CONFIG = {
environment: 'mypurecloud.com', // Change to your specific environment (e.g., usw2.pure.cloud)
clientId: process.env.GENESYS_CLIENT_ID,
clientSecret: process.env.GENESYS_CLIENT_SECRET
* Initializes the Genesys Cloud Platform Client and retrieves an access token.
* @returns {Promise<PureCloudPlatformClientV2>} The configured platform client.
async function initPlatformClient() {
const client = new PureCloudPlatformClientV2();
// Configure the client
client.setEnvironment(CONFIG.environment);
client.setClientId(CONFIG.clientId);
client.setClientSecret(CONFIG.clientSecret);
// Authenticate using client credentials
await client.auth.login('client_credentials');
console.log('Authentication successful.');
return client;
} catch (error) {
console.error('Authentication failed:', error.response?.data || error.message);
throw error;
Important: The client.auth.login('client_credentials') call performs the POST request to /api/v2/oauth/token. If this fails, check your Client ID, Secret, and ensure the client has the required scopes.
Step 1: Identify the Conversation and Participant
To update participant data, you need two specific identifiers:
conversationId: The unique ID of the active conversation.participantId: The unique ID of the specific participant (usually the customer or agent) within that conversation.
If you are triggering this update from an external event (e.g., a webhook from a CRM), you likely already have the conversationId. However, you must identify the correct participantId. In a voice or webchat IVR context, the “participant” is typically the entity interacting with the flow.
You can retrieve the list of participants in a conversation using the getConversation endpoint.
* Retrieves the participant ID for a specific conversation.
* This example assumes the first participant is the one we want to update.
* In production, you should filter by participant type (e.g., 'customer', 'agent').
* @param {PureCloudPlatformClientV2} client - The authenticated platform client.
* @param {string} conversationId - The ID of the conversation.
* @returns {Promise<string>} The participant ID.
async function getParticipantId(client, conversationId) {
// Get the full conversation object
const conversation = await client.conversationsApi.getConversation(conversationId);
if (!conversation.participants || conversation.participants.length === 0) {
throw new Error('No participants found in the conversation.');
// For IVR flows, we typically target the customer participant.
// You may need to iterate to find the correct type.
const customerParticipant = conversation.participants.find(p => p.type === 'customer');
if (!customerParticipant) {
console.warn('No customer participant found. Using the first available participant.');
return conversation.participants[0].id;
return customerParticipant.id;
} catch (error) {
console.error('Error retrieving conversation participants:', error.response?.data || error.message);
throw error;
OAuth Scope Required: conversation:view
Step 2: Construct the Participant Data Payload
The setConversationParticipantData endpoint expects a JSON body containing the new data. The structure is straightforward: an object containing key-value pairs. These keys must be strings, and values can be strings, numbers, booleans, or null.
Critical Constraint: The total size of the participantData object is limited. Avoid storing large JSON blobs. Use this for routing keys, CRM IDs, or preference flags.
Here is the structure of the request body:
"data": {
"crmAccountId": "ACC-12345",
"priorityLevel": "high",
"preferredLanguage": "en-US",
"hasPremiumSupport": true
Step 3: Update Participant Data
Now, you combine the authentication, participant lookup, and the actual update call. The core API endpoint is POST /api/v2/conversations/{conversationId}/participants/{participantId}/data.
The following function performs the update. It includes robust error handling for common HTTP status codes.
* Updates the participant data for a specific conversation participant.
* @param {string} participantId - The ID of the participant.
* @param {Object} customData - An object containing key-value pairs to set.
* @returns {Promise<void>}
async function updateParticipantData(client, conversationId, participantId, customData) {
const url = `/api/v2/conversations/${conversationId}/participants/${participantId}/data`;
// The SDK method expects the body to match the API definition.
// We wrap our customData in the 'data' property as required by the schema.
const requestBody = {
data: customData
// Call the SDK method
// Note: The SDK handles the HTTP method (POST) and headers automatically.
const response = await client.conversationsApi.postConversationParticipantData(
conversationId,
participantId,
requestBody
console.log('Participant data updated successfully.');
console.log('Response status:', response.status);
// In some SDK versions, the response body might be empty (204 No Content).
// Check if response.data exists before logging.
if (response.data) {
console.log('Response body:', JSON.stringify(response.data));
} catch (error) {
// Handle specific HTTP errors
if (error.response) {
const status = error.response.status;
const message = error.response.data?.message || error.message;
if (status === 404) {
console.error(`Conversation or Participant not found. ID: ${conversationId}, Participant: ${participantId}`);
} else if (status === 409) {
console.error('Conflict: The participant data update may have conflicted with another concurrent update.');
} else if (status === 429) {
console.error('Rate Limit Exceeded. Implement retry logic with exponential backoff.');
} else if (status >= 500) {
console.error('Server Error. Genesys Cloud is experiencing issues.');
} else {
console.error(`API Error ${status}: ${message}`);
} else {
console.error('Network or unexpected error:', error.message);
throw error;
OAuth Scope Required: conversation:update
Step 4: Handling Rate Limits (429 Errors)
Genesys Cloud APIs enforce rate limits. If you are processing high-volume events (e.g., a webhook from a webchat session that triggers multiple data updates), you may hit a 429 status. The response header Retry-After indicates the number of seconds to wait before retrying.
You should wrap your API calls in a retry mechanism. Here is a simple helper function using axios interceptors or a wrapper around the SDK call. Since the SDK uses axios under the hood in Node.js, you can configure the SDK’s underlying axios instance or wrap the call manually.
* A simple retry wrapper for async functions that may throw 429 errors.
* @param {Function} fn - The async function to execute.
* @param {number} maxRetries - Maximum number of retries.
* @param {number} baseDelay - Base delay in milliseconds.
* @returns {Promise<any>} The result of the function.
async function withRetry(fn, maxRetries = 3, baseDelay = 1000) {
let attempt = 0;
while (attempt < maxRetries) {
return await fn();
} catch (error) {
// Check if it is a 429 error
if (error.response && error.response.status === 429) {
const retryAfter = error.response.headers['retry-after'] || (baseDelay * Math.pow(2, attempt)) / 1000;
const delayMs = retryAfter * 1000;
console.log(`Rate limited. Retrying in ${delayMs}ms... (Attempt ${attempt + 1}/${maxRetries})`);
await new Promise(resolve => setTimeout(resolve, delayMs));
attempt++;
} else {
// If it is not a 429, re-throw immediately
throw error;
throw new Error(`Max retries (${maxRetries}) exceeded.`);
The following script demonstrates the complete flow: authenticating, finding the participant, and updating their data. Replace the placeholder values with your actual credentials and a valid conversationId from an active test conversation.
const { PureCloudPlatformClientV2 } = require('@genesyscloud/genesyscloud-node-sdk');
// Configuration
const CONFIG = {
environment: 'mypurecloud.com', // Replace with your environment
clientSecret: process.env.GENESYS_CLIENT_SECRET,
conversationId: 'your-active-conversation-id-here' // Replace with a real conversation ID
* Main execution function
async function main() {
let client;
// 1. Initialize and Authenticate
console.log('Initializing Genesys Cloud Client...');
console.log('Authenticated successfully.');
// 2. Retrieve Participant ID
console.log(`Fetching participants for conversation: ${CONFIG.conversationId}`);
const conversation = await client.conversationsApi.getConversation(CONFIG.conversationId);
// Find the customer participant. Adjust logic if targeting an agent or other type.
const participant = conversation.participants.find(p => p.type === 'customer') || conversation.participants[0];
const participantId = participant.id;
console.log(`Target Participant ID: ${participantId}`);
// 3. Define Custom Data
const customData = {
"externalCustomerId": "CUST-98765",
"ivrsessionid": "sess_" + Date.now(),
"routingPriority": 1,
"hasOptedIn": true
// 4. Update Participant Data with Retry Logic
console.log('Updating participant data...');
// Wrap the update call in retry logic
await withRetry(async () => {
data: customData
CONFIG.conversationId,
participantId,
requestBody
} catch (error) {
console.error('Execution failed:', error.message);
console.error('Response Data:', error.response.data);
} finally {
// Cleanup if necessary
if (client) {
// Optionally logout, though not strictly required for server-to-server
// await client.auth.logout();
* Retry helper function (included for completeness)
let attempt = 0;
return await fn();
} catch (error) {
attempt++;
} else {
throw error;
// Run the main function
if (require.main === module) {
main();
module.exports = { main, withRetry };
Error: 404 Not Found
- Cause: The
conversationIddoes not exist, or theparticipantIdis invalid for that conversation. - Fix: Verify that the conversation is still active. Conversations are archived after a period of inactivity. If the conversation is archived, you cannot update participant data. Use the
getConversationendpoint first to confirm the ID is valid. - Debug Code:
const conv = await client.conversationsApi.getConversation(id); console.log('Conversation Status:', conv.state); // Should be 'active' or 'ringing'
Error: 403 Forbidden
- Cause: The OAuth token lacks the
conversation:updatescope. - Fix: Go to the Genesys Cloud Admin Portal > Admin > Security > OAuth Clients. Select your client and ensure
conversation:updateis checked in the Scopes list. Save and re-authenticate.
Error: 409 Conflict
- Cause: A concurrent update to the same participant data occurred. Genesys Cloud uses optimistic locking for some resources.
- Fix: Implement retry logic with a small delay (e.g., 500ms) and try the update again. This is rare for participant data but possible in high-concurrency scenarios.
Error: 422 Unprocessable Entity
- Cause: The JSON payload is malformed or exceeds size limits.
- Fix: Ensure the
dataobject is a flat JSON object. Do not pass nested objects if the downstream IVR logic cannot parse them. Keep the total payload under 1KB.
