How to Integrate ServiceNow with Genesys Cloud CX for Incident Management and Workflow Automation
This guide details the configuration required to integrate ServiceNow with Genesys Cloud CX, enabling automatic incident ticket creation and enrichment based on call details. Upon completion, when a caller interacts with a Genesys Cloud CX IVR and triggers an incident escalation, a ServiceNow incident ticket will be automatically created with relevant data such as caller ID, IVR selections, and agent notes.
  • Genesys Cloud CX: CX 2 or higher is recommended for robust API usage. Requires the Data Actions license.
  • ServiceNow: Instance with the IntegrationHub subscription and appropriate roles for API access.
  • Genesys Cloud Permissions: Data Actions > Data Actions > View and Data Actions > Data Action Execution > View. Additionally, Workforce Engagement > Recording > View if recording details are to be included in the ServiceNow ticket.
  • ServiceNow Permissions: incident_create permission on the relevant ServiceNow instance. A dedicated integration user with scoped access is highly recommended.
  • OAuth Scopes (Genesys Cloud): data_action scope.
  • External Dependencies: A stable internet connection and valid credentials for both platforms.
1. Configuring the ServiceNow Integration User and Credentials
First, within ServiceNow, create a dedicated user specifically for the Genesys Cloud CX integration. This user should be granted the incident_create role and potentially others based on the desired level of ticket modification. Do not use a personal user account. The Trap: Using a personal account exposes your ServiceNow instance to potential security breaches if the Genesys Cloud CX integration is compromised.
Next, generate a ServiceNow OAuth application. Configure the following:
  • Client ID: Record this value; it will be used in Genesys Cloud CX.
  • Client Secret: Record this value; it will be used in Genesys Cloud CX.
  • Redirect URL: https://<your_genesys_cloud_instance_name>.mypurecloud.com/oauth/callback (Replace <your_genesys_cloud_instance_name>)
  • Scopes: incident_create, incident_read, incident_update (adjust as needed)
2. Creating the Genesys Cloud CX Data Action
Within Genesys Cloud CX, navigate to Admin → Data Actions and create a new Data Action.
  • Name: ServiceNow Incident Creation
  • Data Action Type: REST
  • Method: POST
  • Endpoint URL: https://<your_servicenow_instance>.service-now.com/api/now/table/incident (Replace <your_servicenow_instance>)
  • Request Headers:
    • Content-Type: application/json
    • Accept: application/json
    • Authorization: Basic <Base64 encoded Client ID:Client Secret> (Encode the Client ID and Client Secret from ServiceNow using Base64 encoding. Use a Base64 encoder tool - readily available online - and ensure no line breaks are added to the encoded string).
  • Request Body: This is where we define the data to be sent to ServiceNow. Use the following JSON payload as a starting point, customizing fields as required:
  "short_description": "Incident created from Genesys Cloud CX",
  "description": "Caller reported: ${call.variable.IVRSelection}. Agent notes: ${agent.notes}",
  "caller_id": "${call.callerId}",
  "category": "Network",
  "urgency": "4",
  "impact": "1",
  "contact_type": "phone",
  "phone": "${call.callerId}",
  "comments": "Genesys Cloud CX Interaction ID: ${call.interactionId}",
  "sys_created_by": "Genesys Cloud Integration",
  "sys_created_on": "${date.now()}"
The Trap: Incorrect Base64 encoding of the Client ID and Client Secret will result in authentication failures. Double-check the encoding process and ensure there are no extra characters or line breaks. Also, hardcoding values in the request body prevents dynamic data from being passed, rendering the integration less useful.
3. Configuring the Genesys Cloud CX IVR Workflow
Within the Genesys Cloud CX Architect flow, identify the point where incident escalation is triggered. This could be a specific IVR menu option, a transfer to a support group, or a timeout condition.
  • Add a Data Action node to the flow.
  • Select the “ServiceNow Incident Creation” Data Action created in the previous step.
  • Map data from the Genesys Cloud CX call context to the ServiceNow incident fields. This is done using the expression builder. For example, map ${call.variable.IVRSelection} to the description field in the ServiceNow incident.
  • Add an Error node connected to the Data Action node to handle potential integration failures. This Error node should log the error details and potentially notify an administrator.
4. Handling Authentication and Rate Limiting
The OAuth authentication method provides secure access to ServiceNow. However, ServiceNow has rate limits. The Trap: Exceeding ServiceNow’s rate limits will cause the Data Action to fail. Implement error handling within Genesys Cloud CX to retry the Data Action with exponential backoff. Consider batching requests if high call volumes are expected. Monitor the Data Action execution logs for rate limit errors.
Edge Case 1: Invalid ServiceNow Credentials
  • Failure Condition: The Data Action fails with a 401 Unauthorized error.
  • Root Cause: Incorrect Client ID or Client Secret in Genesys Cloud CX, or the OAuth application in ServiceNow is inactive.
  • Solution: Verify the Client ID and Client Secret in Genesys Cloud CX against the ServiceNow OAuth application. Ensure the application is active and the Redirect URL is correctly configured.
Edge Case 2: ServiceNow Field Mapping Errors
  • Failure Condition: The ServiceNow incident is created, but some fields are missing or contain incorrect data.
  • Root Cause: Incorrect mapping of Genesys Cloud CX call context variables to ServiceNow fields in the Data Action request body.
  • Solution: Carefully review the Data Action request body and the mapping of each variable. Use the Genesys Cloud CX Interaction Diagnostics tool to inspect the available call context variables.
Edge Case 3: ServiceNow Rate Limit Exceeded
  • Failure Condition: The Data Action fails with a 429 Too Many Requests error.
  • Root Cause: The Genesys Cloud CX integration is sending requests to ServiceNow faster than the configured rate limit allows.
  • Solution: Implement exponential backoff and retry logic in the Genesys Cloud CX workflow. Consider batching requests or adjusting the call volume to reduce the request rate.
