How to Handle Stuck Calls?
I am facing an issue as there are some calls stuck so on CCPulse it appears as entered but not answered or abandoned and this drops the queue SLA.
I couldn’t catch this stuck call so anyone know how to identify it from Statserver or Tserver logs?
Also how can I handle such calls?
Which tserver and what version are you using?
Skickat från min Mi MIX 3 5G via Tapatalk
You can configure TServer and/or StatServer options for stuck calls
Tserver 8.1.102.89
Statserver 8.5.105.10
I think these options are concerned with release event failed to reach the component but the issue I am facing is regarding answer event. So could these options solve also this issue?
Have you been over https://docs.genesys.com/Documentation/FR/latest/MLUG/StkCalls#Using_T-Server
notify-idle-tout, cleanup-idle-tout and periodic-check-tout should be the options to use, what setting do you have for each?
And what kind of pbx is the tserver interfacing with?
The stuck calls options are basically timers resetting with each event occuring for a specific connid. If no events transpire within the set time, the process to clean the call is initiated. So you need to take into account the maximum duration of ‘normal’ calls so the stuck call cleanup isn’t made prematurely.
Hi…
You mentioned that the Entered > Answered + Abandoned. So I assume you are comparing statistics with the category TotalNumber…
Do you see any calls that appear as stuck in “current” categories such as CurrentNumber and CurrantMaxTime, for example?
The reason I ask is to be sure that the call is really stuck, and not counted as something else. In TotalNumber for queues, Entered should be equals to Answered + Abandoned + AbandonedFromRinging + Cleared, as far as I am aware.
Also, if the call is stuck in statserver, the option you might want to check is “statserver\check-stuck-calls” = yes (default is “no”), and also check-stuck-calls-duration and check-stuck-calls-frequency.
( https://docs.genesys.com/Documentation/Options/Current/RTME/Stat_Server-statserver#check-stuck-calls )
Actually, entered = distributed + abandon + cleared (cleared works only for VQ)
Distributed = answered + forwarded + unknown
Thank you a lot for the info. Actually non of these options are set on our environment, I will have a look at them to set them.
That’s a very good point. Actually, those fields weren’t existing in CCPulse reports as we were looking only for answered, abandoned and cleared. I have added them and we will keep monitoring to catch the issue if it is actually stuck calls or counted as something else.
Thanks a lot for all of you for the very helpful info :wink:
For stuck you will see this:
In CCPulse:
Current Waiting Calls: 1
However, all your agents free
You call to your RP and your call goes to an agent directly
All your agents free except that one that got your call
Current Waiting Calls: Still 1
And Max Waiting Time will be an absurd time
I was able to catch the cause of the issue but don’t know why this is happening.
The cause is that for these calls not all TServer Events are sent to the statserver.
The call continues on TServer normally till gets EventReleased but on statserver the last Tevent received is EventDiverted. So statsever sees the call as Entered but not answered, abanonded,etc..
Any idea why this is happening?
Last TServer version?
Network issues?
Addp enabled?
Can you post some good logs VS bad logs?
TServer version 8.1.102.89
No network issues as we have some calls in same time working normaly.
Addp is disabled
TServer logs are similar, the difference in statserver log as below.
Working Sample:
00:34:24.844 Int 04543 Interaction message "EventQueued("Diamond_VQ")" received from 65201 ("sipserver_sv_p")
00:34:24.845> Server: Switch 'SV_SW'->'EventQueued'
        TimeStamp       '2021-01-21 00:34:24'
        ReferenceID     -1
        ThisDN 'Diamond_VQ'
        ConnID 01a4030afff578bb (118222835997309115)
        Call Type 'Inbound'
        This Queue 'Diamond_VQ'
        DNIS '333'
        ANI '1141997090'
        CustomerID 'Environment'
        Media Type 'voice'
        UserData
        Extensions
00:34:24.845> Server: Call '01a4030afff578bb' on VQ 'Diamond_VQ@SV_SW' is recharged.  Timeout=60 sec
00:34:24.845> Server: Registered call '01a4030afff578bb' on VQ 'Diamond_VQ@SV_SW' with stuck calls checker
00:34:24.845> Action: (owned) VirtualACDQueue 'Diamond_VQ@SV_SW'(Monitored): 1 calls queued
00:34:24.845> Server: Switch 'SV_SW'->'EventAttachedDataChanged'
        ReferenceID     -1
        ThisDN 'Diamond_VQ'
        Call Type 'Inbound'
        DNIS '333'
        ANI '1141997090'
        Media Type 'voice'
        UserData
        Extensions
00:34:24.969> Server: Call '01a4030afff578bb' on VQ 'Diamond_VQ@SV_SW' is recharged.  Timeout=60 sec
00:34:24.969> Action: (owned) VirtualACDQueue 'Diamond_VQ@SV_SW'(Monitored): 1 calls queued
00:34:24.969 Int 04543 Interaction message "EventAttachedDataChanged("Diamond_VQ")" received from 65201 ("sipserver_sv_p")
00:34:24.969> Server: Switch 'SV_SW'->'EventAttachedDataChanged'
        ReferenceID     -1
        ThisDN 'Diamond_VQ'
        Call Type 'Inbound'
        DNIS '333'
        ANI '1141997090'
        Media Type 'voice'
        UserData
        Extensions
00:34:25.034 Int 04543 Interaction message "EventQueued("98014")" received from 65201 ("sipserver_sv_p")
00:34:25.034> Server: Switch 'SV_SW'->'EventQueued'
        TimeStamp       '2021-01-21 00:34:25'
        ThisDN '98014'
        FirstTransferConnID 01a4030afff578bb (118222835997309115)
        Call Type 'Inbound'
        This Queue '98014'
        DNIS '333_CC'
        ANI '1141997090'
        Media Type 'voice'
        UserData
        Extensions
00:34:25.034> Action: (owned) ExtRoutingPoint '98014@SV_SW'(Monitored): 0 calls queued
00:34:25.034 Int 04543 Interaction message "EventRouteRequest("98014")" received from 65201 ("sipserver_sv_p")
00:34:25.034> Server: Switch 'SV_SW'->'EventRouteRequest'
        ThisDN '98014'
        Call Type 'Inbound'
        This Queue '98014'
        DNIS '333_CC'
        ANI '1141997090'
        Media Type 'voice'
        UserData
00:34:25.034> Action: (owned) ExtRoutingPoint '98014@SV_SW'(Monitored): 1 calls queued
00:34:25.059 Int 04543 Interaction message "EventDiverted("Diamond_VQ")" received from 65201 ("sipserver_sv_p")
00:34:25.059> Server: Switch 'SV_SW'->'EventDiverted'
        ReferenceID     -1
        ThisDN 'Diamond_VQ'
        Call Type 'Inbound'
        DNIS '333'
        ANI '1141997090'
        Media Type 'voice'
        ThirdPartyDN '98014'
        UserData
        Reasons
00:34:25.059> Server: Unregistered call '01a4030afff578bb' on VQ 'Diamond_VQ@SV_SW' with stuck calls checker
00:34:25.113> Server: Switch 'SV_SW'->'EventRouteUsed'
        ThisDN '98014'
        Call Type 'Inbound'
        This Queue '98014'
        DNIS '333_CC'
        ANI '1141997090'
        Media Type 'voice'
        ThirdPartyDN '612227'
        UserData
00:34:25.114> Action: (owned) ExtRoutingPoint '98014@SV_SW'(Monitored): 0 calls queued
00:34:25.114 Int 04543 Interaction message "EventDiverted("98014")" received from 65201 ("sipserver_sv_p")
00:34:25.114> Server: Switch 'SV_SW'->'EventDiverted'
        ThisDN '98014'
        Call Type 'Inbound'
        This Queue '98014'
        DNIS '333_CC'
        ANI '1141997090'
        Media Type 'voice'
        UserData
00:34:25.114 Int 04543 Interaction message "EventRinging("612227")" received from 65201 ("sipserver_sv_p")
00:34:25.114> Server: Switch 'SV_SW'->'EventRinging'
        ThisDN '612227'
        Call Type 'Inbound'
        Agent LoginID '71352'
        This Queue '98014'
        DNIS '333_CC'
        ANI '1141997090'
        Media Type 'voice'
        UserData
        Extensions
00:34:25.121> Server: Switch 'SV_SW'->'EventAttachedDataChanged'
        ThisDN '612227'
        Call Type 'Inbound'
        DNIS '333_CC'
        ANI '1141997090'
        Media Type 'voice'
        UserData
00:34:28.050> Server: Switch 'SV_SW'->'EventEstablished'
        TimeStamp       '2021-01-21 00:34:28'
        ThisDN '612227'
        Call Type 'Inbound'
        This Queue '98014'
        DNIS '333_CC'
        ANI '1141997090'
        Media Type 'voice'
        UserData
        Extensions
00:34:28.061> Server: Switch 'SV_SW'->'EventAttachedDataChanged'
        ThisDN '612227'
        Call Type 'Inbound'
        DNIS '333_CC'
        ANI '1141997090'
        Media Type 'voice'
        UserData
00:34:28.371> Server: Switch 'SV_SW'->'EventUserEvent'
        ReferenceID     24154858
        ThisDN '612227'
        Call Type 'Unknown'
        Media Type 'voice'
        UserData
00:36:26.722> Server: Switch 'SV_SW'->'EventReleased'
        TimeStamp       '2021-01-21 00:36:26'
        ThisDN '612227'
        Call Type 'Inbound'
        This Queue '98014'
        DNIS '666_CC'
        ANI '1141997090'
        Media Type 'voice'
        Reliability '-1'
        UserData
        Extensions
Defected Sample:
03:05:44.037> Server: Switch 'SV_SW'->'EventQueued'
        TimeStamp       '2021-01-17 03:05:44'
        ReferenceID     -1
        ThisDN 'Diamond_VQ'
        ConnID 01a4030affee0fe2 (118222835996823522)
        Call Type 'Inbound'
        DNIS '666'
        ANI '1114092225'
        Media Type 'voice'
        UserData
        Extensions
03:05:44.038> Server: Call '01a4030affee0fe2' on VQ 'Diamond_VQ@SV_SW' is recharged.  Timeout=60 sec
03:05:44.038> Server: Registered call '01a4030affee0fe2' on VQ 'Diamond_VQ@SV_SW' with stuck calls checker
03:05:44.038> Server: Next VQ stuck calls check in 600 sec
03:05:44.038> Server: Switch 'SV_SW'->'EventAttachedDataChanged'
        ReferenceID     -1
        ThisDN 'Diamond_VQ'
        Call Type 'Inbound'
        DNIS '666'
        ANI '1114092225'
        Media Type 'voice'
        UserData
        Extensions
03:05:44.159> Server: Switch 'SV_SW'->'EventAttachedDataChanged'
        ReferenceID     -1
        ThisDN 'Diamond_VQ'
        Call Type 'Inbound'
        DNIS '666'
        ANI '1114092225'
        Media Type 'voice'
        UserData
        Extensions
03:05:44.160> Server: Call '01a4030affee0fe2' on VQ 'Diamond_VQ@SV_SW' is recharged.  Timeout=60 sec
03:05:44.160> Action: (owned) VirtualACDQueue 'Diamond_VQ@SV_SW'(Monitored): 1 calls queued
03:05:44.160 Int 04543 Interaction message "EventAttachedDataChanged("Diamond_VQ")" received from 65201 ("sipserver_sv_p")
03:05:44.160> Server: Switch 'SV_SW'->'EventAttachedDataChanged'
        ReferenceID     -1
        ThisDN 'Diamond_VQ'
        Call Type 'Inbound'
        DNIS '666'
        ANI '1114092225'
        Media Type 'voice'
        UserData
        Extensions
03:05:44.270 Int 04543 Interaction message "EventDiverted("Diamond_VQ")" received from 65201 ("sipserver_sv_p")
03:05:44.270> Server: Switch 'SV_SW'->'EventDiverted'
        ReferenceID     -1
        ThisDN 'Diamond_VQ'
        Call Type 'Inbound'
        DNIS '666'
        ANI '1114092225'
        Media Type 'voice'
        ThirdPartyDN '01119204005'
        UserData
        Reasons
03:05:44.270> Server: Unregistered call '01a4030affee0fe2' on VQ 'Diamond_VQ@SV_SW' with stuck calls checker
03:05:44.270> Server: Stopped VQ stuck calls checker
03:05:44.270> Action: (owned) VirtualACDQueue 'Diamond_VQ@SV_SW'(Monitored): 0 calls queued
Do you see on T-Server logs something similar to: Client xxx disconnected. Reason: too slow ?
Your TServer is quite old…try to upgrade. Guess your StatServer is also old. First recommendation is to upgrade to fix a lot of bugs
Nope can’t find it.
Thank you, looking forward to doing it.
