How to get Userdata from INFO Body
Dear all,
Anybody please help me to know how to get Userdata from INFO boday message using GVP Composer?
User Data is sent to MCP via SIP INFO body.
From: sip:809123@10.84.9.166:5060;tag=98565000-C48C-13E2-B94E-3969BE14E195
To: sip:1001@10.84.9.166;tag=00875D0C-0704-1438-B204-A409540AAA77-202175
Max-Forwards: 70
CSeq: 1 INFO
Call-ID: 00875CDA-0704-1438-B204-A409540AAA77-197868@10.84.9.166
Content-Length: 15
Content-Type: application/x-www-form-urlencoded;charset=utf-8
Route: sip:0x1bb33b60@10.84.9.167:5068;transport=TCP;lr;gvp.rm.datanodes=1;idtag=00000110
X-Genesys-GVP-Session-ID: 98565000-AC36-ED39-1AEC-61656C42E536;gvp.rm.datanodes=1;gvp.rm.tenant-id=1_Tranfer_test
User-Agent: eyeBeam release 1100z stamp 47739
Min-SE: 90
X-Genesys-GVP-Session-Data: callsession=98565000-AC36-ED39-1AEC-61656C42E536;1;0;;;;Environment;Tranfer_test;
Supported: timer, uui
Text=0613777001
Thank you so much.
You mean you want to get in Composer data you have attached to the call?
Z
Yes, Gzooby.
Can you help me!
Scenario:
  1. GVP use Interaction Data block send infomation to Routing Point with Userdata - key name ‘Text’=‘0613777001’
  2. Routing Point make call out with destination number in ‘Text’. and when route call failed, send call back GVP, still keep all User Data.
    (Routing Point can get UserData successfully)
  3. GVP use Interaction Data block again to get User Data - key name ‘Text’.
    Problem: GVP cannot get Userdata using Interaction Data block.
MCP logs:
Max-Forwards: 70
CSeq: 1 INFO
Content-Length: 15
Min-SE: 90
Text=0613777001
Errro logs:
fetch_end Done (revalidated):http://10.84.9.154:8080/testTransfer/include/common.js
2014-10-14T11:08:23.646 Int 50043 00B90143-100053E5 1187371904 fetch_end Done (revalidated):http://10.84.9.154:8080/testTransfer/include/ctic.js
2014-10-14T11:08:23.664 Int 50043 00B90143-100053E5 1188375424 fetch_end Done (revalidated):http://10.84.9.154:8080/testTransfer/include/json.js
2014-10-14T11:08:23.680 Int 50043 00B90143-100053E5 1189378944 fetch_end Done (revalidated):http://10.84.9.154:8080/testTransfer/include/DataAccess.js
2014-10-14T11:08:23.695 Int 50043 00B90143-100053E5 1190382464 fetch_end Done (revalidated):http://10.84.9.154:8080/testTransfer/Resources/Prompts/PromptSwitch.js
2014-10-14T11:08:23.710 Int 50043 00B90143-100053E5 1184361344 fetch_end Done (revalidated):http://10.84.9.154:8080/testTransfer/Resources/Prompts/en-US/en-US.js
2014-10-14T11:08:23.720 Int 50041 00B90143-100053E5 1184361344 compile_done :http://10.84.9.154:8080/testTransfer/src-gen/BackFromRP.vxml
2014-10-14T11:08:23.724 Int 50028 00B90143-100053E5 1184361344 form_enter
2014-10-14T11:08:23.724 Int 50029 00B90143-100053E5 1184361344 form_select :_FORMITEM_NAME$326$:BLOCK
2014-10-14T11:08:23.724 Int 50033 00B90143-100053E5 1184361344 goto :#Entry1
2014-10-14T11:08:23.724 Int 50030 00B90143-100053E5 1184361344 form_exit normal
2014-10-14T11:08:23.724 Int 50028 00B90143-100053E5 1184361344 form_enter :Entry1
2014-10-14T11:08:23.724 Int 50029 00B90143-100053E5 1184361344 form_select :Entry:BLOCK
2014-10-14T11:08:23.724 Int 50033 00B90143-100053E5 1184361344 goto :#InteractionData1
2014-10-14T11:08:23.724 Int 50028 00B90143-100053E5 1184361344 form_enter :InteractionData1
2014-10-14T11:08:23.724 Int 50029 00B90143-100053E5 1184361344 form_select :_FORMITEM_NAME$329$
:BLOCK
2014-10-14T11:08:23.724 Int 50034 00B90143-100053E5 1184361344 event error.com.genesyslab.composer.invalidkey:1|Missing InteractionData key ‘Text’
2014-10-14T11:08:23.724 Int 50080 00B90143-100053E5 1184361344 event_handler_enter :error .|http://10.84.9.154:8080/testTransfer/src-gen/BackFromRP.vxml
2014-10-14T11:08:23.725 Int 50035 00B90143-100053E5 1184361344 log com.genesyslab.quality.failure:error event terminated session
2014-10-14T11:08:23.725 Int 50018 00B90143-100053E5 1191385984 prompt
2014-10-14T11:08:23.726 Int 50043 00B90143-100053E5 1191385984 fetch_end Done (file):file:///opt/gcti/mcp/audio/alaw/default_audio/sorry_there_has_been_an_error.vox
2014-10-14T11:08:23.726 Int 50134 00B90143-100053E5 1191385984 prompt_play audio|builtin:default_audio/sorry_there_has_been_an_error.vox
2014-10-14T11:08:25.815 Int 50019 00B90143-100053E5 1191385984 prompt_end done
2014-10-14T11:08:25.816 Int 50081 00B90143-100053E5 1183357824 event_handler_exit :error .
2014-10-14T11:08:25.816 Int 50030 00B90143-100053E5 1183357824 form_exit normal
2014-10-14T11:08:25.816 Int 50036 00B90143-100053E5 1183357824 appl_end
2014-10-14T11:08:25.825 Int 50001 00B90143-100053E5 1155259264 incall_end aplend
Its because data is not there, check URS logs
No, we got Userdata ‘Text’=‘0613777001’ in URS logs.
received from 65204(HanoiIvrSIP)hniivrsip01:3000(fd=) message EventDiverted
AttributeCallState 0
AttributeCallType 1
AttributePropagatedCallType 1
AttributeCallID 630
AttributeConnID 00a702531a639276
AttributeCallUUID ‘028GJJG70GA3HCG4KG4L82LAES0000JM’
AttributeUserData [731] 00 18 00 00..
‘CallUUID’ ‘01J1G8JPJGA3B2D6HC4L82LAES0000KQ’
‘Text’ ‘0613777001’
‘GVP-Session-ID’ ‘98565000-AC36-6EAC-6D6C-F6F53E7B3B76;gvp.rm.datanodes=1;gvp.rm.tenant-id=1_Tranfer_test’
‘GVP-Session-Data’ ‘callsession=98565000-AC36-6EAC-6D6C-F6F53E7B3B76;1;0;;;;Environment;Tranfer_test;’
‘RRequestedSkills’(list)
‘CustomerSegment’ ‘default’
‘ServiceType’ ‘default’
‘ServiceObjective’ ‘’
‘RVQID’ ‘’
‘RVQDBID’ ‘’
‘RTargetTypeSelected’ ‘100’
‘RTargetRuleSelected’ ‘’
‘RTargetObjectSelected’ ‘’
‘RTargetObjSelDBID’ ‘’
‘RTargetAgentSelected’ ‘’
‘RTargetPlaceSelected’ ‘’
‘RTenant’ ‘Environment’
‘RStrategyName’ ‘Force’
‘RStrategyDBID’ ‘535’
‘CBR-actual_volume’ ‘’
‘CBR-Interaction_cost’ ‘’
‘CBR-contract_DBIDs’ ‘’
‘CBR-IT-path_DBIDs’ ‘’
‘RRequestedSkillCombination’ ‘’
AttributeDNIS ‘809123’
AttributeThisDN ‘99999’
AttributeThisDNRole 2
AttributeThisQueue ‘99999’
AttributeThirdPartyDN ‘1089@10.84.9.166:5060’
AttributeThirdPartyDNRole 2
AttributeOtherDN ‘1001’
AttributeOtherDNRole 1
AttributeExtensions [23] 00 01 01 00..
‘BusinessCall’ 1
AttributeTimeinSecs 1413400051 (02:07:31)
AttributeTimeinuSecs 435354
AttributeEventSequenceNumber 000000000002ef75
02:07:32.369 Trc 20012 current number of interactions per second - 0.20
02:07:32.369 Trc 20013 current number of entries: for longest queue 0, for all queues 0
G_I Version: 8.1.200.16
Ok now check MCP logs and see if attached
Why did you never read the documentation or search for other topics with similiar title? This problematic has been solved for many times here and within docs is entire section describing that funcionality.
May be little hint - User data prefix (X-Genesys)
I thought the same Kubig, but according to his description GVP does send the KVPs as URS with a strategy can handle it and do something with it. The problem would be the return to GVP.
Is CTI enabled for that second application?
