How to Enable G729 Codec in MCP
I need to enable G729 codec in MCP.
If I add G729 mcp.Codecs option it is giving me an error.
Logs
2012-08-04T15:28:17.328 Std 46001 WARN 00DB0101-10006E29 4872 0B400BBA Cannot transcode from 5 (g729) to 13 (l16)
2012-08-04T15:28:17.328 Std 38001 EROR 00DB0101-10006E29 2428 02F007D1 A Connection Error has occurred:
2012-08-04T15:28:17.328 Std 33008 EROR 00DB0101-10006E29 2768 028007D2 Media error detected; terminating call
Hi
you need also check you gate side config and disable unsuported l16 on it.
HIH
WBR Tim
Thanks for your reply. Avaya Team told that Genesys side need to enable ,it has been enabled on Avaya side.
Be aware of the issues G723 can bring…more compression means more CPU, less accurate DTMF, noise increase…not very good for IVR
Thanks for your valuable input. any idea how to enable g729 in MCP. if i simple add g729 under mpc it is not allowing me to reach IVR.
I guess somthing i am missing in MCP option.
Thanks in advance.
Erm..check your logs…SIP ones, check the codec negotiation and analyze it
