How to disable PlayApplication block in workflow changing original DNIS?
Hi, guys,
I have a URS centric workflow/callflow development.
In workflow, I use playApplication block to call IVR callflow. I created a voip over ip service DN in sipswitch, MSML_Service.
then I noticed DNIS is changed to MSML_Service from my original RP, where my workflow is loaded.
But I need this original DNIS in my workflow.
How to disable this DNIS replacement by MSML_Service?
thx.
Kevin
Hi Kevin,
I believe you can create a user data in the dnis workflow (thisdn) for input in the vxml.
I recommend, based on the business rule of your flow, to perform the deleteudata if the interaction returns to the beginning of the flow with another DNIS.
This is a suggestion. I already had this scenario where I could solve just this way.
Att,
