How to define a Genesys Cloud queue with skills in Terraform using the CX as Code provider
- You will create a Genesys Cloud queue with associated routing skills using the purecloudlabs/cx-as-code Terraform provider.
- This tutorial uses the Genesys Cloud CX as Code provider to manage configuration state declaratively.
- The implementation covers Terraform HCL configuration, state management, and error handling for dependency resolution.
- Terraform Version: 1.0+
- Provider:
purecloudlabs/cx-as-codeversion 1.18.0+ - OAuth Scopes:
queue:write(for creating/updating queues)routing:skill:readorrouting:skill:write(if creating skills dynamically, though this tutorial assumes pre-existing skills)
- External Dependencies:
- Terraform installed locally
- Access to a Genesys Cloud Organization with API credentials
The CX as Code provider uses OAuth2 Client Credentials flow. You must configure the provider block with your client ID, client secret, and environment.
Do not hardcode secrets in your Terraform files. Use environment variables or a secrets manager.
terraform {
required_providers {
gen = {
source = "purecloudlabs/cx-as-code"
version = "1.18.0"
provider "gen" {
# These values are expected in environment variables
# GEN_CLIENT_ID, GEN_CLIENT_SECRET, GEN_ENVIRONMENT
client_id = var.client_id
client_secret = var.client_secret
environment = var.environment
Set the environment variables before running terraform plan or terraform apply.
export GEN_CLIENT_ID="your-client-id"
export GEN_CLIENT_SECRET="your-client-secret"
export GEN_ENVIRONMENT="mypurecloud.com"
Step 1: Define Skills References
Queues require skills to route interactions. In Genesys Cloud, skills are global resources. You must know the skillId or skillName and the domainId (usually the org ID) to associate them with a queue.
If you do not have the skill IDs, you can use the gen_routing_skill data source to look them up by name. This is safer than hardcoding UUIDs.
data "gen_routing_skill" "support_skill" {
name = "General Support"
domain_id = var.org_id
data "gen_routing_skill" "billing_skill" {
name = "Billing"
Expected Response:
The data source returns an object containing the id and name of the skill. Terraform uses this id to build the queue configuration.
Error Handling:
If the skill does not exist, Terraform will fail during the plan phase with a 404 Not Found. Ensure the skill exists in the Genesys Cloud admin console before proceeding.
Step 2: Create the Queue Resource
The gen_queue resource is the core object. You must define the name, skill_requirements, and routing_skills.
The routing_skills block is critical. It maps a skill to a priority and a percentage of capacity. This defines how much of the queue’s capacity is reserved for that specific skill.
resource "gen_queue" "support_queue" {
name = "Customer Support Queue"
description = "Primary queue for general customer support inquiries"
enable_auto_answer = false
enable_callback = true
enable_customer_hold_music = true
empty_agent_hold_music_uri = "https://example.com/hold.mp3"
member_flow = "LongestIdleAgent"
wrap_up_policy = "Optional"
# Define the skills required for agents in this queue
skill_requirements {
required = true
skill {
id = data.gen_routing_skill.support_skill.id
name = data.gen_routing_skill.support_skill.name
# Define routing skills to allocate capacity
routing_skills {
skill {
priority = 1
percentage = 100
# Optional: Add a second skill with lower priority
routing_skills {
skill {
id = data.gen_routing_skill.billing_skill.id
name = data.gen_routing_skill.billing_skill.name
priority = 2
percentage = 50
Explanation of Parameters:
enable_auto_answer: Iftrue, the system will automatically answer calls. Set tofalsefor standard IVR routing.member_flow: Determines how agents are selected.LongestIdleAgentis common for fairness.routing_skills: This block can be repeated. Thepriorityfield determines which skill is checked first.percentagedefines the portion of the queue’s capacity reserved for that skill. The sum of percentages does not need to equal 100, but exceeding 100 can lead to over-allocation warnings.
Edge Cases:
- If you remove a
routing_skillsblock, Terraform will remove that skill from the queue in Genesys Cloud. - If you change the
percentage, Terraform will update the queue configuration. This may cause a brief moment of unavailability for that skill while the configuration propagates.
Step 3: Add Queue Members (Optional but Recommended)
A queue is useless without agents. You can add users to the queue using the gen_queue_member resource.
resource "gen_queue_member" "agent_member" {
queue_id = gen_queue.support_queue.id
# Reference a user by email or ID
user {
id = var.agent_user_id
# Set the agent's rank in the queue
rank = 1
# Set the maximum number of concurrent conversations
max_concurrent_conversations = 5
Error Handling:
If the user_id does not exist, Terraform will return a 400 Bad Request. Validate the user ID exists in the Genesys Cloud organization.
Below is a complete, copy-pasteable Terraform configuration. Save this as main.tf.
terraform {
gen = {
version = "1.18.0"
variable "client_id" {
description = "Genesys Cloud OAuth Client ID"
type = string
sensitive = true
variable "client_secret" {
description = "Genesys Cloud OAuth Client Secret"
type = string
sensitive = true
variable "environment" {
description = "Genesys Cloud Environment (e.g., mypurecloud.com)"
type = string
default = "mypurecloud.com"
variable "org_id" {
description = "Genesys Cloud Organization ID"
type = string
variable "agent_user_id" {
description = "User ID of the agent to add to the queue"
type = string
provider "gen" {
# Data sources to look up existing skills
name = "Billing"
# Create the Queue
required = true
skill {
routing_skills {
skill {
priority = 1
percentage = 100
routing_skills {
skill {
priority = 2
percentage = 50
# Add an agent to the queue
user {
rank = 1
Run the following commands to apply the configuration:
terraform init
terraform plan
terraform apply
Error: 404 Not Found on Skill Lookup
What causes it:
The gen_routing_skill data source cannot find a skill with the specified name in the domain_id.
How to fix it:
- Verify the skill name in the Genesys Cloud Admin Console.
- Ensure the
domain_idvariable matches your organization ID. - Check for typos in the skill name.
Code showing the fix:
# Corrected data source with exact name match
name = "General Support" # Exact match required
Error: 400 Bad Request on Queue Creation
What causes it:
The routing_skills block has invalid parameters. Common issues include:
percentagegreater than 100.prioritynot being a positive integer.- Referencing a skill that does not exist.
How to fix it:
- Ensure
percentageis between 0 and 100. - Ensure
priorityis a unique positive integer for eachrouting_skillsblock. - Verify the skill IDs are valid.
# Corrected routing_skills block
routing_skills {
skill {
priority = 1
percentage = 100 # Valid percentage
What causes it:
Genesys Cloud API rate limits are exceeded. This can happen if you are applying a large number of resources in parallel.
How to fix it:
- Reduce the number of parallel operations in Terraform by setting
parallelism = 1in the provider block. - Wait and retry the
terraform applycommand.
provider "gen" {
parallelism = 1 # Reduce parallelism to avoid rate limits
