How to Control Agent Microphone State via Genesys Cloud Web Chat and WebSocket APIs
  • A functional JavaScript module that sends WebSocket commands to the Genesys Cloud Edge to mute and unmute an agent’s microphone during an active conversation.
  • This tutorial utilizes the Genesys Cloud WebSocket Client API, specifically the send method on the active connection, rather than REST endpoints.
  • The implementation covers JavaScript/TypeScript using the official @genesyscloud/purecloud-platform-client-v2 SDK for authentication and raw WebSocket handling for real-time control.
  • OAuth Client Type: Public or Confidential client with the webchat:client scope. Note that traditional REST scopes like conversation:view are insufficient for WebSocket client-side actions.
  • SDK Version: @genesyscloud/purecloud-platform-client-v2 v4.0.0 or higher.
  • Runtime: Node.js 18+ or a modern browser environment (Chrome, Firefox, Edge).
  • Dependencies:
    • @genesyscloud/purecloud-platform-client-v2
    • dotenv (for local environment variable management)
The Genesys Cloud WebSocket client does not authenticate via HTTP headers in the same way REST APIs do. Instead, it authenticates via an initial auth message sent over the WebSocket connection. This message requires a valid OAuth access token.
First, you must generate an OAuth token. For this tutorial, we assume a Confidential Client flow (Client Credentials) for service-to-service testing, or a Public Client flow (Authorization Code) for end-user agent applications.
// auth-helper.js
const { PlatformClient } = require('@genesyscloud/purecloud-platform-client-v2');
 * Generates an OAuth Access Token using Client Credentials Flow.
 * Replace these values with your actual Genesys Cloud API credentials.
async function getAccessToken() {
  const platformClient = PlatformClient.create();
  const config = {
    clientId: process.env.GENESYS_CLIENT_ID,
    clientSecret: process.env.GENESYS_CLIENT_SECRET,
    environment: process.env.GENESYS_ENVIRONMENT || 'mypurecloud.com' // e.g., euw2.pure.cloud
    const response = await platformClient.login(config);
    return response.body.access_token;
  } catch (error) {
    console.error('Failed to authenticate:', error.message);
    throw error;
module.exports = { getAccessToken };
Critical Note: The token must have the webchat:client scope. If you are using a client registered for standard REST API access, you may need to add this scope in the Developer Console under your API Client settings. Without this scope, the WebSocket handshake will succeed, but the server will reject your auth message with an unauthorized error.
Step 1: Establish the WebSocket Connection
The Genesys Cloud Edge provides a WebSocket endpoint. The URL structure is wss://webchat-edge.genesiscloud.com/ws?environment={env}. You must construct the URL correctly based on your environment.
We will create a wrapper class that manages the connection lifecycle and handles the initial authentication handshake.
// websocket-client.js
const { getAccessToken } = require('./auth-helper');
class GenesysWebSocketClient {
  constructor(environment) {
    this.environment = environment;
    this.ws = null;
    this.isConnected = false;
    this.isAuthorized = false;
    // Construct the WebSocket URL
    // For US: wss://webchat-edge.genesiscloud.com/ws?environment=us-east-1
    // For EU: wss://webchat-edge.euw2.genesiscloud.com/ws?environment=euw2
    const edgeHost = environment === 'euw2'
      ? 'webchat-edge.euw2.genesiscloud.com'
      : 'webchat-edge.genesiscloud.com';
    this.wsUrl = `wss://${edgeHost}/ws?environment=${environment}`;
  async connect() {
    return new Promise((resolve, reject) => {
      this.ws = new WebSocket(this.wsUrl);
      this.ws.onopen = () => {
        console.log('WebSocket connection established.');
        this.isConnected = true;
        this.authenticate().then(resolve).catch(reject);
      this.ws.onmessage = (event) => {
        this.handleMessage(event.data);
      this.ws.onerror = (error) => {
        console.error('WebSocket error:', error);
        reject(error);
      this.ws.onclose = (event) => {
        console.log(`WebSocket closed. Code: ${event.code}, Reason: ${event.reason}`);
  async authenticate() {
      const token = await getAccessToken();
      const authMessage = {
        type: 'auth',
        payload: {
          token: token
      this.send(JSON.stringify(authMessage));
      // Wait for the 'authed' response from the server
        const timeout = setTimeout(() => {
          reject(new Error('Authentication timed out.'));
        }, 5000);
        const originalHandler = this.ws.onmessage;
          const data = JSON.parse(event.data);
          if (data.type === 'authed') {
            clearTimeout(timeout);
            this.isAuthorized = true;
            console.log('Successfully authenticated with Genesys Cloud.');
            this.ws.onmessage = originalHandler; // Restore handler
            resolve();
          } else if (data.type === 'error') {
            reject(new Error(`Auth failed: ${data.payload.message}`));
    } catch (error) {
      throw new Error('Failed to retrieve or send auth token: ' + error.message);
  send(message) {
    if (!this.isConnected || this.ws.readyState !== WebSocket.OPEN) {
      throw new Error('WebSocket is not connected.');
    this.ws.send(message);
  handleMessage(data) {
      const message = JSON.parse(data);
      console.log('Received:', JSON.stringify(message, null, 2));
      // Handle specific response types if needed
      if (message.type === 'error') {
        console.error('Server Error:', message.payload);
    } catch (e) {
      console.error('Failed to parse message:', data);
  disconnect() {
    if (this.ws) {
      this.ws.close();
module.exports = { GenesysWebSocketClient };
Step 2: Implement Mute/Unmute Logic
Once authenticated, you can send control messages. To mute or unmute an agent, you send a media event with the mute action.
The payload structure depends on whether you are controlling audio or video. For microphone control, we target the audio stream.
Key Payload Fields:
  • type: Must be 'media'.
  • action: Must be 'mute' or 'unmute'.
  • streamId: Optional but recommended. If omitted, it applies to the default stream. For precise control in multi-stream scenarios, identify the stream ID from the media events received during call setup.
  • direction: 'outbound' (what the agent sends) or 'inbound' (what the agent hears). To mute the microphone, you are muting the outbound audio.
// media-controller.js
const { GenesysWebSocketClient } = require('./websocket-client');
class MediaController {
    this.client = new GenesysWebSocketClient(environment);
  async initialize() {
    await this.client.connect();
   * Mutes the agent's microphone (outbound audio).
   * @param {string} [conversationId] - Optional conversation ID for logging/tracking.
  async muteMicrophone(conversationId = 'unknown') {
    if (!this.client.isAuthorized) {
      throw new Error('Client is not authenticated.');
    const payload = {
      type: 'media',
      action: 'mute',
      streamId: 'default', // Use specific streamId if known
      direction: 'outbound', // Muting what we send
      mediaType: 'audio'
    console.log(`[Mute] Sending mute command for conversation: ${conversationId}`);
    this.client.send(JSON.stringify(payload));
    // Note: The server may acknowledge this with a 'media' event of type 'mute'
    // or it may be fire-and-forget depending on the edge configuration.
   * Unmutes the agent's microphone (restores outbound audio).
  async unmuteMicrophone(conversationId = 'unknown') {
    const payload = {
      type: 'media',
      action: 'unmute',
      mediaType: 'audio'
    console.log(`[Unmute] Sending unmute command for conversation: ${conversationId}`);
   * Toggles the microphone state.
   * Requires tracking current state externally.
  async toggleMicrophone(isMuted, conversationId = 'unknown') {
    if (isMuted) {
      await this.muteMicrophone(conversationId);
    } else {
      await this.unmuteMicrophone(conversationId);
  disconnect() {
    this.client.disconnect();
module.exports = { MediaController };
Step 3: Processing Results and State Sync
The Genesys Cloud WebSocket protocol is event-driven. When you send a mute command, the server might respond with a confirmation event. More importantly, if the mute state changes on the server side (e.g., by a supervisor or another client), you will receive a media event.
You must handle these incoming events to keep your UI in sync.
// event-handler.js
 * Attaches a listener for media state changes to update local UI state.
function attachMediaStateListener(webSocketClient, onStateChange) {
  const originalHandler = webSocketClient.client.ws.onmessage;
  webSocketClient.client.ws.onmessage = (event) => {
    // Call original handler to ensure base logging happens
    if (originalHandler) originalHandler(event);
      // Listen for media events that indicate state changes
      if (data.type === 'media') {
        const payload = data.payload;
        if (payload.action === 'mute' && payload.direction === 'outbound' && payload.mediaType === 'audio') {
          console.log('State Sync: Microphone is now MUTED.');
          onStateChange(true, payload.streamId);
        else if (payload.action === 'unmute' && payload.direction === 'outbound' && payload.mediaType === 'audio') {
          console.log('State Sync: Microphone is now UNMUTED.');
          onStateChange(false, payload.streamId);
      // Handle errors specifically related to media actions
      if (data.type === 'error' && data.payload && data.payload.action === 'mute') {
        console.error('Failed to mute/unmute:', data.payload.message);
    } catch (e) {
      console.error('Error parsing media event:', e);
module.exports = { attachMediaStateListener };
Below is a complete, runnable Node.js script that initializes the connection, mutes the microphone, waits 5 seconds, unmutes it, and then disconnects.
// main.js
require('dotenv').config();
const { MediaController } = require('./media-controller');
const { attachMediaStateListener } = require('./event-handler');
async function main() {
  const ENVIRONMENT = process.env.GENESYS_ENVIRONMENT || 'us-east-1';
  const CONVERSATION_ID = 'test-conversation-123'; // Placeholder for demo
  const controller = new MediaController(ENVIRONMENT);
    // 1. Initialize and Authenticate
    console.log('Connecting to Genesys Cloud Edge...');
    await controller.initialize();
    console.log('Connection and Authentication successful.');
    // 2. Attach State Listener
    attachMediaStateListener(controller, (isMuted, streamId) => {
      console.log(`UI Update: Microphone state changed to ${isMuted ? 'MUTED' : 'UNMUTED'} on stream ${streamId}`);
    // 3. Mute Microphone
    await controller.muteMicrophone(CONVERSATION_ID);
    // Wait to observe the mute state
    await new Promise(resolve => setTimeout(resolve, 5000));
    // 4. Unmute Microphone
    await controller.unmuteMicrophone(CONVERSATION_ID);
    // Wait to observe the unmute state
  } catch (error) {
    console.error('Execution failed:', error.message);
    process.exit(1);
  } finally {
    // 5. Cleanup
    controller.disconnect();
    console.log('Disconnected.');
    process.exit(0);
main();
Error: WebSocket Connection Refused (403 or 503)
  • What causes it: The environment URL is incorrect, or the client IP is blocked by firewall rules.
  • How to fix it: Verify the GENESYS_ENVIRONMENT variable. Ensure you are using the correct edge host (webchat-edge.genesiscloud.com for US, webchat-edge.euw2.genesiscloud.com for EU). Check that your network allows outbound traffic on port 443 to these domains.
Error: Auth Failed: Invalid Token
  • What causes it: The OAuth token provided in the auth message is expired, invalid, or lacks the webchat:client scope.
  • How to fix it:
    1. Check your API Client settings in the Genesys Cloud Admin Console. Ensure the webchat:client scope is added.
    2. Verify that the getAccessToken function is retrieving a fresh token. Tokens expire after 1 hour by default.
    3. Log the raw token being sent to ensure it is not empty or malformed.
Error: Media Action Failed: Stream Not Found
  • What causes it: You specified a streamId that does not exist in the current session.
  • How to fix it: If you do not know the specific streamId, omit the streamId field from the payload. The server will apply the action to the default active stream. Alternatively, inspect the media events received at the start of the call to identify active stream IDs.
  • What causes it: You are sending media control messages too frequently. Genesys Cloud enforces rate limits on WebSocket messages.
  • How to fix it: Implement a debounce mechanism in your UI layer. Do not send a mute/unmute command if the current state matches the desired state. Cache the last known state locally and compare before sending.
// Debounce example
let lastMuteState = null;
function requestMute(isMuted) {
  if (lastMuteState === isMuted) {
    console.log('State unchanged, skipping send.');
    return;
  lastMuteState = isMuted;
  controller.toggleMicrophone(isMuted);
