How to Configure Routing Point to handle inbound calls through SIP trunk
Hello all!
Since I am not so much familiar with URS & IRD, I would like to know how to quickly configure a Routing Point (RP) to handle inbound calls through a SIP trunk.
URS strategy is ready, which simply diverts all inbound/internal calls to an ACD queue – it works! No problem here.
What I want is to associate this RP with a SIP trunk, so all inbound calls generated by my Asterisk can be routed by my strategy.
Could you please explain me how to do this step by step?
Thank you in advance.
emm just make up a route point under switch then load strategy onto it in IRD
Match the route point to the number asterisk passes or setup a dial plan.
Sent from my SM-N9005 using Tapatalk
Dial Plan for SIP Trunk?
Incoming call → SIP Trunk → (x) → Routing Point
I created a new Trunk with the following Annex:
[TServer]
“Contact” = “:”
“prefix” = “”
“record” = “false”
“refer-enabled” = “false”
In General tab, Register set to “true”
Well, should I create a dial-plan and add it into Annex/TServer section?
Trunk is for Outgoing calls
Asterisk will send a number to Genesys, lets say 9000, then you create a RP 9000 and load a strategy on it
If you don’t want 9000 configure your Asterisk properly
Cavagnaro,
Thank you for your reply.
Like I said, I created RP 8999 (tested. It works).
On Asterisk, in /etc/asterisk/sip.conf, the configuration is as follows:
  1. register to 8999:8999@
  2. created context
[8999]
type = friend
callerid = genesys
fromuser = 8999
context = callcenter
nat = yes
qualify = yes
username = 8999
secred = 8999
insecure = invite,port
host =
dtmfmode = rfc2833
canreinvite = no
qualify = yes
disallow = all
allow = ulaw
allow = alaw
allow = gsm
usereqphone = yes
fromdomain =
transport = tcp
So,
  1. Asterisk cannot register to 8999 at (will check if it is really necessary)
  2. When Asterisk places a call to 8999@, the call will be automatically diverted to this RP, right?
Thank you
So you want to route all calls from 8xxx to a single Genesys RP?
On Genesys there is no way to do that, you will have to create a DID (8000-8999) range on your Asterisk and all those calls route to a single RP with a unique DID identifier.
How to do that is more an Asterisk config question.
I, personally have no clue
Whatever Asterisk sends to Genesys SIP Server, it must be a DN on Genesys, can be a RP or an extension. RP will execute the strategy, Extension will be like any agent set
I already created the dial-plan on Asterisk side.
What I want is to place a call to sip/8999@, which I can. However, Genesys SIP Server returns me “SIP 403 Forbidden” error (The Genesys SIP server understood the request, but is refusing to fulfil it).
I think this is kind of codec-related issue. Will figure out.
I will ask if I have further question.
Thank you.
I think, this is caused by Genesys SIP server by default, in case your GW/Asterisk is not configured as Trunk object within Genesys configuration. For Genesys it is unknown gateway, which are declined by default. So, do following:
  • enable unknown gateway by SIP application option
or
  • create the trunk which will identify your GW by IP address/host (better solution)
Thank you, Kubig.
Since I am not that familiar with IRD/URS, I have some more newbie questions regarding what you told:
  1. Is “unknown gateway” in Annex section of the SIP Server?
  2. Is this trunk for Asterisk, or for RP (if for RP, how to associate it?)
[ol]- It is an option “enable-unknown-gateway” under section “TServer” on SIP server application object
  • It is a trunk, associated with Asterisk (IP/host, prefix, etc.)[/ol]
I defined enable-unknown-gateway (true) in Annex/TServer.
The message Genesys SIP Server returns is SIP/genesys-0123f9d0 is circuit-busy.
I will also configure the trunk for Asterisk
Try to post logs covering the incoming call
Logs are
01:55:38.295: $+NET:SIP::0:0
01:55:38.296: SIPS:LOGBLOCK:BEGIN:SIPMSG:[
01:55:38.296: SIPTR: Received [648,TCP] 865 bytes from 192.168.2.34:41202 <<<<<
INVITE sip:8999@192.168.2.247 SIP/2.0
Via: SIP/2.0/TCP 192.168.2.34:5060;branch=z9hG4bK7f4b0e25;rport
Max-Forwards: 70
To: sip:8999@192.168.2.247
Contact: sip:8999@192.168.2.34:5060;transport=TCP
Call-ID: 168c89514e2bfafe7a82966e0b971615@192.168.2.247
CSeq: 102 INVITE
User-Agent: Asterisk PBX 1.6.0.1
Date: Mon, 22 Aug 2016 22:18:51 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces, timer
Content-Type: application/sdp
Content-Length: 310
v=0
o=root 1975435331 1975435331 IN IP4 192.168.2.34
s=Asterisk PBX 1.6.0.1
c=IN IP4 192.168.2.34
t=0 0
m=audio 18602 RTP/AVP 0 8 3 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
01:55:38.297: CallMatcher: no call match attributes found
01:55:38.297: call to itself is rejected
01:55:38.298: Sending [648,TCP] 334 bytes to 192.168.2.34:41202 >>>>>
SIP/2.0 403 Forbidden
Via: SIP/2.0/TCP 192.168.2.34:5060;branch=z9hG4bK7f4b0e25;rport;received=192.168.2.34
To: sip:8999@192.168.2.247;tag=303A7051-50FE-446C-8801-CFA78988A5A0-30
CSeq: 102 INVITE
Content-Length: 0
Where 8999 is Routing Point that diverts all incoming calls to the Agent Group.
The From part of SIP INVITE message is incorrect:
You cannot call to itself, the from address should be address of asterisk, not of Genesys.
From my point of view, the configuration on Asterisk level is not correct, the RP should not be configured as Extension/User. Follow the existing document which describes how properly deploy and integrate the Asterisk with Genesys SIP.
Can you please give the URL of this document?
You can follow for example this http://www.voip-info.org/wiki/view/Asterisk+Genesys+SIP+Server+Integration
Solved!
Thank you all for your support.
Configuration is as follows:
On Genesys side;
SIP Server Application
Annex/TServer/enable-unknown-gateway=true
Trunk
  1. Created trunk for Asterisk, where Annex/TServer is
“contact” = “:5060”
“prefix” = “”
“record” = “false”
  1. Created trunk for Routing Point (RP) with following AnnexTServer:
“contact” = “:5060”
“prefix” = “”
“record” = “false”
On Asterisk side;
sip.conf
[genesys]
type = friend
callerid = genesys
nat = yes
qualify = yes
host =
dtmfmode = rfc2833
canreinvite = no
qualify = yes
disallow = all
allow = ulaw
allow = alaw
allow = gsm
usereqphone = yes
transport = tcp
extensions.conf
[incoming]
include = default
[callcenter]
include = incoming
include = default
exten = _00.,1,NoOP(“Outbound Call”)
exten = _00.,2,Dial(SIP/${EXTEN:2}@genesys)
Using your soft phone application, which already registered to the Asterisk server, when you dial 00, your call goes to RP over Genesys SIP Server.
P.S. You need to reload SIP and Extension settings in Asterisk after having sip.conf and extensions.conf modified.
There is no need for having trunk for RP
