How to Audit OAuth Clients and Validate Scope Assignments in Genesys Cloud
- You will build a Python script that enumerates every OAuth client within a Genesys Cloud organization.
- You will use the Genesys Cloud REST API v2 to retrieve client details and map assigned OAuth scopes to their definitions.
- You will write Python code using the
httpxlibrary to handle authentication, pagination, and error resilience.
- OAuth Client Type: You must use a Service Account or Application OAuth client. Public clients cannot access organizational administrative data.
- Required Scopes: The client must have the
admin:oauthclient:readscope to list clients and view their scope assignments. To resolve scope IDs to human-readable names, you also needadmin:oauthscope:read. - SDK Version: This tutorial uses direct REST API calls via
httpx, which is version-agnostic but relies on the current/api/v2endpoints. - Language/Runtime: Python 3.8+ is required.
- External Dependencies:
pip install httpx pydantic
Genesys Cloud uses OAuth 2.0 for all API access. For a service account integration, you will use the Client Credentials Grant flow. This flow exchanges your client ID and client secret for an access token. This token is valid for a limited duration (typically 30 minutes) and must be refreshed before expiration.
The following code establishes a robust authentication helper. It caches the token and handles the refresh logic automatically when the token expires.
import httpx
import logging
from typing import Optional
# Configure logging for debugging
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, env: str = "mypurecloud.com"):
self.client_id = client_id
self.env = env
self.base_url = f"https://api.{env}"
self.token_url = f"{self.base_url}/oauth/token"
self.token_expiry_time: float = 0
# Using httpx.Client for synchronous requests for simplicity in this script
self.http_client = httpx.Client(timeout=30.0)
def _get_token(self) -> None:
Requests a new OAuth token from the Genesys Cloud authorization server.
logger.info("Requesting new OAuth token...")
payload = {
"client_id": self.client_id,
response = self.http_client.post(
self.token_url,
data=payload,
headers={"Content-Type": "application/x-www-form-urlencoded"}
response.raise_for_status()
logger.error(f"Authentication failed: {e.response.status_code} - {e.response.text}")
raise
logger.error(f"Network error during authentication: {e}")
raise
data = response.json()
self.access_token = data.get("access_token")
# Token expires in seconds, convert to absolute timestamp
expires_in = data.get("expires_in", 1800)
self.token_expiry_time = time.time() + expires_in - 10 # Subtract 10s buffer
logger.info("OAuth token acquired successfully.")
def get_valid_token(self) -> str:
Returns a valid access token. Refreshes if the current token is expired.
if not self.access_token or time.time() >= self.token_expiry_time:
self._get_token()
return self.access_token
def close(self):
"""Closes the underlying HTTP connection pool."""
self.http_client.close()
Step 1: Retrieving the List of OAuth Clients
The Genesys Cloud API endpoint for listing OAuth clients is GET /api/v2/oauth/clients. This endpoint supports pagination. To ensure you capture every client in large organizations, you must implement pagination logic using the afterId parameter.
Endpoint: GET /api/v2/oauth/clients
Required Scope: admin:oauthclient:read
The response contains an array of client objects. Each object includes an id, name, type, and a scopes array. The scopes array contains the IDs of the OAuth scopes assigned to that client.
def fetch_all_oauth_clients(auth_manager: GenesysAuthManager) -> List[Dict[str, Any]]:
Fetches all OAuth clients from the organization, handling pagination.
all_clients = []
after_id = None
page_size = 250
url = f"{auth_manager.base_url}/api/v2/oauth/clients"
while True:
headers = {
"Authorization": f"Bearer {auth_manager.get_valid_token()}",
params = {
"pageSize": page_size
if after_id:
params["afterId"] = after_id
response = auth_manager.http_client.get(url, headers=headers, params=params)
if e.response.status_code == 401:
logger.warning("Token expired during fetch, refreshing...")
continue # Retry the request
elif e.response.status_code == 403:
logger.error("403 Forbidden: Ensure the client has 'admin:oauthclient:read' scope.")
raise
else:
logger.error(f"HTTP Error: {e.response.status_code} - {e.response.text}")
raise
entities = data.get("entities", [])
if not entities:
break
all_clients.extend(entities)
# Check if there are more pages
after_id = data.get("afterId")
if not after_id:
break
logger.info(f"Fetched {len(all_clients)} OAuth clients.")
return all_clients
Step 2: Resolving Scope IDs to Definitions
The client objects returned in Step 1 only contain scope IDs (e.g., "admin:agent:read"), not the full definition. To perform a meaningful audit, you need to know what each scope actually permits. You must fetch the global list of OAuth scopes using GET /api/v2/oauth/scopes.
Endpoint: GET /api/v2/oauth/scopes
Required Scope: admin:oauthscope:read
This endpoint returns a dictionary-like structure where keys are scope IDs and values are scope objects containing name, description, and category.
def fetch_all_oauth_scopes(auth_manager: GenesysAuthManager) -> Dict[str, Dict[str, Any]]:
Fetches all available OAuth scopes and returns them as a dictionary keyed by scope ID.
url = f"{auth_manager.base_url}/api/v2/oauth/scopes"
headers = {
response = auth_manager.http_client.get(url, headers=headers)
logger.error("403 Forbidden: Ensure the client has 'admin:oauthscope:read' scope.")
raise
else:
raise
# The API returns a flat dictionary of scopes
scopes_map = data.get("entities", {})
logger.info(f"Fetched {len(scopes_map)} OAuth scope definitions.")
return scopes_map
Step 3: Auditing and Validating Assignments
Now that you have the list of clients and the map of scope definitions, you can cross-reference them. This step is critical for security audits. You will check for:
- Orphaned Scopes: Scopes assigned to a client that no longer exist in the system (rare, but possible during migrations).
- High-Risk Scopes: Identification of clients with administrative scopes like
admin:organization:writeoradmin:oauthclient:write. - Unused Clients: Clients that have not been used recently (based on
lastUsedtimestamp if available, though the basic client list may not always expose detailed usage metrics without additional analytics queries).
We will create a data structure that normalizes this information for reporting.
from dataclasses import dataclass
from typing import List, Dict, Any, Optional
from datetime import datetime
@dataclass
class OAuthClientAuditRecord:
client_id: str
client_name: str
client_type: str
assigned_scope_ids: List[str]
resolved_scopes: List[Dict[str, Any]]
orphaned_scopes: List[str]
has_admin_write: bool
def audit_clients(
clients: List[Dict[str, Any]],
scopes_map: Dict[str, Dict[str, Any]]
) -> List[OAuthClientAuditRecord]:
Cross-references clients with scope definitions to create audit records.
audit_records = []
# Define high-risk scopes for flagging
high_risk_prefixes = ["admin:", "impersonation:"]
for client in clients:
client_id = client.get("id")
client_name = client.get("name")
client_type = client.get("type")
assigned_scope_ids = client.get("scopes", [])
resolved_scopes = []
orphaned_scopes = []
has_admin_write = False
for scope_id in assigned_scope_ids:
if scope_id in scopes_map:
scope_def = scopes_map[scope_id]
resolved_scopes.append({
"id": scope_id,
"name": scope_def.get("name"),
"category": scope_def.get("category")
# Check for high-risk scopes
if any(scope_id.startswith(prefix) for prefix in high_risk_prefixes):
# Specifically check for write/modify/delete capabilities if possible
# For this tutorial, we flag any admin scope as potentially high risk
has_admin_write = True
else:
# Scope ID exists on client but not in global definition
orphaned_scopes.append(scope_id)
record = OAuthClientAuditRecord(
client_id=client_id,
client_name=client_name,
client_type=client_type,
assigned_scope_ids=assigned_scope_ids,
resolved_scopes=resolved_scopes,
orphaned_scopes=orphaned_scopes,
has_admin_write=has_admin_write
audit_records.append(record)
return audit_records
This is the full, copy-pasteable script. Save this as audit_oauth_clients.py. You will need to set your CLIENT_ID and CLIENT_SECRET in the environment variables or directly in the code (for testing only).
#!/usr/bin/env python3
Genesys Cloud OAuth Client Auditor
Lists all OAuth clients and validates their scope assignments against global definitions.
import httpx
import logging
import json
import os
# --- Configuration ---
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID", "YOUR_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET", "YOUR_CLIENT_SECRET")
GENESYS_ENV = os.getenv("GENESYS_ENV", "mypurecloud.com")
# --- Logging Setup ---
level=logging.INFO,
format="%(asctime)s [%(levelname)s] %(message)s",
handlers=[logging.StreamHandler()]
# --- Data Models ---
@dataclass
client_id: str
client_name: str
client_type: str
# --- Authentication Manager ---
self.env = env
payload = {
self.token_url,
data=payload,
raise
raise
self._get_token()
def close(self):
# --- API Helpers ---
all_clients = []
after_id = None
page_size = 250
while True:
headers = {
params = {"pageSize": page_size}
if after_id:
logger.warning("Token expired, refreshing...")
logger.error("403 Forbidden: Check 'admin:oauthclient:read' scope.")
raise
else:
raise
if not entities:
break
if not after_id:
break
return all_clients
headers = {
logger.error("403 Forbidden: Check 'admin:oauthscope:read' scope.")
raise
else:
raise
return data.get("entities", {})
def audit_clients(
audit_records = []
"id": scope_id,
else:
audit_records.append(OAuthClientAuditRecord(
# --- Main Execution ---
def main():
if CLIENT_ID == "YOUR_CLIENT_ID" or CLIENT_SECRET == "YOUR_CLIENT_SECRET":
logger.error("Please set GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables.")
return
auth_manager = None
auth_manager = GenesysAuthManager(CLIENT_ID, CLIENT_SECRET, GENESYS_ENV)
# Step 1: Fetch Clients
logger.info("Fetching OAuth clients...")
clients = fetch_all_oauth_clients(auth_manager)
# Step 2: Fetch Scopes
logger.info("Fetching OAuth scopes...")
scopes_map = fetch_all_oauth_scopes(auth_manager)
# Step 3: Audit
logger.info("Auditing client scope assignments...")
audit_records = audit_clients(clients, scopes_map)
# Output Results
high_risk_clients = [r for r in audit_records if r.has_admin_write]
clients_with_orphans = [r for r in audit_records if r.orphaned_scopes]
logger.info(f"Total Clients: {len(audit_records)}")
logger.info(f"Clients with Admin/High-Risk Scopes: {len(high_risk_clients)}")
logger.info(f"Clients with Orphaned Scopes: {len(clients_with_orphans)}")
# Save detailed report to JSON
report = []
for record in audit_records:
report.append({
"client_id": record.client_id,
"client_name": record.client_name,
"client_type": record.client_type,
"has_admin_write": record.has_admin_write,
"orphaned_scopes": record.orphaned_scopes,
"assigned_scopes": record.resolved_scopes
with open("oauth_audit_report.json", "w") as f:
json.dump(report, f, indent=2)
logger.info("Report saved to oauth_audit_report.json")
logger.error(f"An error occurred: {e}")
finally:
if auth_manager:
auth_manager.close()
main()
Error: 403 Forbidden
Cause: The OAuth client used for authentication does not have the required scopes.
Fix:
- Log in to the Genesys Cloud Admin portal.
- Navigate to Admin > Security > OAuth.
- Select the client you are using for this script.
- Ensure the following scopes are checked:
admin:oauthclient:readadmin:oauthscope:read
- Save the changes. The token must be refreshed after scope changes.
Cause: The access token has expired, or the Client ID/Secret is invalid.
Fix:
- Verify the
CLIENT_IDandCLIENT_SECRETare correct. - Ensure your
GenesysAuthManageris correctly refreshing the token. The provided code handles automatic refresh, but if you are debugging manually, delete the cached token or restart the script. - Check that the client is not disabled in the Genesys Cloud admin console.
Error: Orphaned Scopes Detected
Cause: The audit script finds scope IDs on a client that do not exist in the global scope definition list.
Fix:
- This is rare and usually indicates a data inconsistency or a custom scope that was deleted.
- Review the
orphaned_scopeslist in the audit record. - If the scope is no longer needed, you can remove it from the client using the
PUT /api/v2/oauth/clients/{id}endpoint. - If the scope is required, ensure it exists globally. If it is a custom scope, verify it was not accidentally deleted.
Error: Rate Limiting (429 Too Many Requests)
Cause: You are making too many requests in a short period.
Fix:
- The
fetch_all_oauth_clientsfunction uses pagination with a page size of 250. This is efficient. - If you still hit 429s, implement exponential backoff.
- Check the
Retry-Afterheader in the 429 response.
# Example of adding simple retry logic for 429s
def get_with_retry(client, url, headers, params=None, max_retries=3):
response = client.get(url, headers=headers, params=params)
retry_after = int(response.headers.get("Retry-After", 5))
logger.warning(f"Rate limited. Waiting {retry_after}s...")
time.sleep(retry_after)
return response
raise Exception("Max retries exceeded for 429")
