How do I fix the 403 Forbidden errors hitting the transcript retrieval process every Thursday at 09:00 PT? The external compliance platform keeps failing during the weekly audit pull. Management requires those agent call transcripts for the SOC2 review. Queue metrics display normal status. Agent coaching sessions pull data without issue. The error payload returns a policy mismatch notice. I checked the org settings. Data retention policy remains on standard configuration. No changes on our side.
The external vendor says the token expires too fast. Console shows empty status for the actual sync job. Logs show the rejection happening right after the initial handshake. The floor operates with 30 agents in the LA timezone. Shift starts at 08:00 PT. The export job runs right before the morning huddle. It is breaking the compliance checklist every single week. The sync does jack all after the handshake. Agent mic stays hot but the transcript never saves to the audit folder.
"errorCode": "FORBIDDEN",
"message": "Access denied. Policy violation on data export scope.",
"details": "Requested resource exceeds assigned role permissions for compliance module.",
"timestamp": "2024-05-23T09:00:01-07:00"
The integration guide mentions something about OAuth scopes. Can’t adjust those settings without engineering. Supervisor dashboard still shows green status. The audit trail just keeps flagging it as failed. Waiting on vendor response but they keep asking for the raw error trace. Endpoint version is v2. Genesys org is on the current release. External tool uses their standard connector. Nothing else is blocking the port. Audit deadline is Friday. Missing 45 call logs already and the token scope keeps dropping
You’re hitting a 403 because the service account likely lacks the specific conversation:transcript:view scope, or the org has enabled Data Loss Prevention (DLP) rules that block bulk transcript exports. The “policy mismatch” error is a dead giveaway for DLP.
Check the token scopes first. In .NET, when you generate the access token, make sure the scope array includes conversation:transcript:view. If you’re using the PureCloudPlatformClientV2 SDK, it handles this, but if you’re using a raw HttpClient with OAuth, you need to pass it explicitly.
Here is how I verify the scope in my Azure Function before making the call:
var authClient = new PlatformApiClient();
var token = await authClient.PostOAuth2TokenAsync(
grantType: "client_credentials",
clientId: clientId,
clientSecret: clientSecret,
scopes: new[] { "conversation:transcript:view", "analytics:callcenter:view" }
if (!token.Scopes.Contains("conversation:transcript:view"))
throw new InvalidOperationException("Missing transcript view scope");
If the scopes are correct, the issue is almost certainly the DLP policy. Go to Admin > Security > Data Loss Prevention. Look for any rules that restrict “Export” or “Bulk Download” for the user group the service account belongs to. The compliance platform is probably triggering a bulk export pattern. You’ll need to add an exception for that specific service account or adjust the rule to allow automated pulls.
Also, double-check the recording ID format. The transcript aggregate query endpoints expect the recording ID, not the conversation ID. Passing a conversation ID often results in a 403 or 404 depending on the exact validation layer. Make sure you’re pulling the recordingId from the conversation object first.
Don’t forget to set the Accept-Language header if you need specific locale formatting for the audit logs. The default might not match your compliance requirements.
nailed the scope issue. DLP is the silent killer here. The “policy mismatch” error usually means your token has the rights, but the org policy says “nope” for that specific data type or volume.
Check your DLP settings in Admin > Security > Data Loss Prevention. If you have rules blocking transcript exports, the API will throw a 403 regardless of scopes. You might need to whitelist the service account’s IP or the specific application client ID in the DLP exceptions.
Also, verify the token isn’t expiring mid-pull. Weekly audits can take time. If the job runs longer than the token lifetime, it’ll fail halfway through. Use a refresh token strategy.
Here’s how to check the scopes on your current token using curl. Replace YOUR_ACCESS_TOKEN with the actual token from your compliance platform.
curl -X GET "https://api.mypurecloud.com/api/v2/oauth/tokeninfo" \
-H "Authorization: Bearer YOUR_ACCESS_TOKEN"
Look at the scope array in the response. It must contain conversation:transcript:view. If it’s missing, the integration config needs an update.
If scopes are correct and DLP is clear, check the Recording Search API permissions. Sometimes the transcript endpoint relies on the underlying recording being accessible. Ensure the service account has recording:view as well.
One more thing. The /api/v2/recordings/transcripts endpoint can be heavy. If you’re pulling thousands of transcripts, you might hit rate limits. Add a retry mechanism with exponential backoff. It’s not elegant, but it keeps the audit running.
"retryStrategy": {
"maxRetries": 3,
"backoffMultiplier": 2,
"initialDelayMs": 1000
Check the DLP logs in Admin > Security > Audit. They’ll tell you exactly which rule blocked the request. It’s usually right there in the details.
