How do I fix 400 Bad Request on /api/v2/telephony/users/softphones for daily readiness sync?
How do I fix the 400 Bad Request errors hitting the softphone configuration endpoint every Tuesday at 09:00 PT? The external routing platform keeps failing when it tries to push ready states into the softphone controller. Queue monitor is doing jack all while the error keeps firing. Dashboard shows green status but agents report the mic stays hot and calls drop right after the ring. We’ve checked the supervisor view. All thirty seats run WebRTC release 2311 on Chrome 121. The WFM team says the auth token is valid but the endpoint doesn’t accept the payload. It’s throwing a mismatch error every single time. Softphone configuration in the admin panel shows default settings. Nothing in the flow designer matches this behavior. The integration log shows the request goes out at 09:00:12 PT and bounces back instantly. Agent wrap-up times are spiking because the system forces a silent disconnect. We need the readiness flag to stick. The vendor claims the payload format matches the documentation exactly.
{“code”: “invalid_request”, “message”: “Softphone session mismatch. Current state: ACTIVE, Requested state: NOT_READY”, “status”: 400}
It’s almost certainly the endpointId format or a missing status field in your payload. The softphone API is notoriously strict about the structure, especially when you’re trying to force a state change like “ready” from an external system.
Here is what I’d check:
  • Verify the Endpoint ID: The endpointId must match the exact ID of the softphone device for that user. If you’re pulling this from the User API, make sure you’re grabbing the softphone.endpoint.id specifically, not just the user ID. A mismatch here triggers a 400 immediately.
  • Check the JSON Structure: The body needs to include the status explicitly. If you omit it, the API might default to “not ready” or throw an error depending on your platform version. It should look something like this:
 "endpointId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
 "status": "ready",
 "capabilities": [
 "voice"
  • Scope Permissions: Ensure the OAuth token used for this call has the telephony:softphone:update scope. If the token only has read access, you’ll get a 403, but sometimes the error handling on older gateway versions misfires as a 400.
  • Rate Limiting: Since this happens daily at 09:00 PT for thirty seats, check if you’re hitting the API rate limit. If all thirty requests fire simultaneously, Genesys Cloud might drop the tail end. Add a small jitter to your request loop so they don’t all hit at the exact same millisecond.
The “mic stays hot” issue you mentioned sounds like the softphone client didn’t receive the state update, leaving it in a half-initialized state. Fixing the API call usually resolves that.
