how can monitor speak using tsinglestepconf
I use the API TSingleStepConference for adding the monitor to existing call. but i find the monitor only can listen the call instead of conference. how can make the monitor speak in this situation?
Usually it’s possible to change type of participation by attaching predefined key in Extensions. You can find that information in TServer’s manual.
What switch do you have?
René
