Hot-Swapping Cognigy.AI Model Versions via REST API with Java
  • The code executes a zero-downtime model version swap by constructing a validated traffic directive payload, verifying schema compatibility against runtime engine constraints, and executing an atomic PATCH cutover operation.
  • This uses the Cognigy.AI REST API v2 model management, deployment routing, and audit endpoints.
  • The implementation is written in Java 17 using the standard java.net.http client with built-in retry logic, latency tracking, and webhook synchronization.
  • OAuth client type: Confidential client registered in Cognigy.AI with model:read, model:write, deployment:write, routing:read, audit:write scopes.
  • API version: Cognigy.AI REST API v2.
  • Language/runtime: Java 17 or higher.
  • External dependencies: None. The tutorial uses only JDK standard libraries (java.net.http, java.time, java.util, java.util.logging).
Cognigy.AI uses standard OAuth 2.0 client credentials flow. You must cache the access token and refresh it before expiration to avoid 401 interruptions during swap operations.
import java.net.URI;
import java.time.Instant;
import java.util.Map;
public class CognigyAuth {
    private final HttpClient httpClient;
    private final String clientId;
    private final String clientSecret;
    private final String tokenEndpoint;
    private String cachedToken;
    private Instant tokenExpiry;
    public CognigyAuth(String clientId, String clientSecret, String baseUrl) {
        this.httpClient = HttpClient.newHttpClient();
        this.clientId = clientId;
        this.tokenEndpoint = baseUrl + "/oauth/token";
        this.tokenExpiry = Instant.now().minusSeconds(1);
    public String getAccessToken() throws Exception {
        if (cachedToken != null && Instant.now().isBefore(tokenExpiry)) {
            return cachedToken;
        String body = "grant_type=client_credentials&client_id=" + clientId + "&client_secret=" + clientSecret;
                .uri(URI.create(tokenEndpoint))
                .header("Content-Type", "application/x-www-form-urlencoded")
                .POST(HttpRequest.BodyPublishers.ofString(body))
                .build();
            throw new RuntimeException("OAuth token request failed with status " + response.statusCode() + ": " + response.body());
        Map<String, Object> tokenMap = parseSimpleJson(response.body());
        this.cachedToken = (String) tokenMap.get("access_token");
        long expiresIn = ((Number) tokenMap.get("expires_in")).longValue();
        this.tokenExpiry = Instant.now().plusSeconds(expiresIn - 30); // 30s buffer
        return cachedToken;
    // Minimal JSON parser for token response to avoid external dependencies
    private static Map<String, Object> parseSimpleJson(String json) {
        // In production, use Jackson/Gson. This is a simplified extractor for tutorial clarity.
        return Map.of(
            "access_token", extractJsonValue(json, "access_token"),
            "expires_in", extractJsonLong(json, "expires_in")
    private static String extractJsonValue(String json, String key) {
        int start = json.indexOf("\"" + key + "\":\"") + key.length() + 3;
        int end = json.indexOf("\"", start);
        return json.substring(start, end);
    private static long extractJsonLong(String json, String key) {
        int start = json.indexOf("\"" + key + "\":") + key.length() + 2;
        int end = start;
        while (end < json.length() && Character.isDigit(json.charAt(end))) end++;
        return Long.parseLong(json.substring(start, end));
Required OAuth Scopes for Authentication: model:read, model:write, deployment:write, routing:read, audit:write
Step 1: Construct Swap Payload and Validate Runtime Constraints
Before initiating a swap, you must verify that the target model version exists, that the deployment has not exceeded the maximum concurrent version limit, and that the schema is compatible with the runtime engine. Cognigy.AI enforces a default limit of five active versions per deployment.
import java.util.List;
import java.util.logging.Logger;
import java.util.logging.Level;
public class CognigyModelValidator {
    private static final Logger logger = Logger.getLogger(CognigyModelValidator.class.getName());
    private final String baseUrl;
    private final CognigyAuth auth;
    public CognigyModelValidator(HttpClient httpClient, String baseUrl, CognigyAuth auth) {
        this.httpClient = httpClient;
        this.baseUrl = baseUrl;
        this.auth = auth;
    public Map<String, Object> validateSwap(String modelId, String targetVersion, String deploymentId) throws Exception {
        String token = auth.getAccessToken();
        // Fetch active versions to enforce max version count limit
        String versionsUrl = baseUrl + "/api/v2/models/" + modelId + "/versions?status=active";
        HttpRequest versionsReq = HttpRequest.newBuilder()
                .uri(URI.create(versionsUrl))
                .header("Accept", "application/json")
                .GET()
                .build();
        HttpResponse<String> versionsResp = httpClient.send(versionsReq, HttpResponse.BodyHandlers.ofString());
        if (versionsResp.statusCode() == 429) {
            throw new RuntimeException("Rate limited on version fetch. Implement exponential backoff.");
        if (versionsResp.statusCode() != 200) {
            throw new RuntimeException("Version fetch failed: " + versionsResp.statusCode());
        int activeCount = parseActiveVersionCount(versionsResp.body());
        if (activeCount >= 5) {
            throw new IllegalStateException("Maximum version count limit (5) reached. Cannot hot-swap until older versions are pruned.");
        // Validate schema compatibility against runtime engine
        String schemaUrl = baseUrl + "/api/v2/models/" + modelId + "/versions/" + targetVersion + "/schema/validate";
        HttpRequest schemaReq = HttpRequest.newBuilder()
                .uri(URI.create(schemaUrl))
                .POST(HttpRequest.BodyPublishers.ofString("{\"runtimeEngine\": \"cognigy-runtime-v2\", \"strictMode\": true}"))
                .build();
        HttpResponse<String> schemaResp = httpClient.send(schemaReq, HttpResponse.BodyHandlers.ofString());
        if (schemaResp.statusCode() != 200) {
            throw new RuntimeException("Schema validation failed for version " + targetVersion + ": " + schemaResp.body());
        // Construct atomic swap payload with traffic directive and canary routing
        String swapPayload = """
                "modelId": "%s",
                "targetVersion": "%s",
                "deploymentId": "%s",
                "trafficDirective": {
                    "type": "canary",
                    "initialWeight": 0.1,
                    "rampUpIntervalSeconds": 60,
                    "maxWeight": 1.0
                "fallbackModelId": "%s",
                "validateBeforeCutover": true,
                "auditMetadata": {
                    "initiatedBy": "automated-pipeline",
                    "pipelineRunId": "run-%d"
            """.formatted(modelId, targetVersion, deploymentId, modelId + "_v1.0.0", System.currentTimeMillis());
        return Map.of(
            "payload", swapPayload,
            "activeVersionCount", activeCount,
            "schemaValid", true
    private static int parseActiveVersionCount(String json) {
        // Simplified parser for tutorial. Extracts "count" or array length.
        int countIdx = json.indexOf("\"count\":");
        if (countIdx != -1) {
            int start = countIdx + 7;
            int end = start;
            return Integer.parseInt(json.substring(start, end));
        return 0;
Required OAuth Scopes: model:read, routing:read
Expected Response for Schema Validation:
  "valid": true,
  "compatible": true,
  "warnings": [],
  "engineConstraints": {
    "maxConcurrentVersions": 5,
    "supportedFormats": ["cognigy-json", "openapi-3.0"]
Step 2: Execute Atomic PATCH Operation with Retry and Latency Tracking
The cutover operation uses an atomic PATCH request. You must implement retry logic for 429 responses and track latency to measure swap efficiency. The request triggers automatic canary routing based on the traffic directive.
public class CognigyModelSwapper {
    private static final Logger logger = Logger.getLogger(CognigyModelSwapper.class.getName());
    public CognigyModelSwapper(HttpClient httpClient, String baseUrl, CognigyAuth auth) {
        this.auth = auth;
    public Map<String, Object> executeCutover(String deploymentId, String payload) throws Exception {
        String cutoverUrl = baseUrl + "/api/v2/deployments/" + deploymentId + "/cutover";
        long startNanos = System.nanoTime();
        int maxRetries = 3;
        long baseDelayMs = 1000;
        for (int attempt = 1; attempt <= maxRetries; attempt++) {
                    .uri(URI.create(cutoverUrl))
                    .header("X-Request-Id", "swap-" + System.currentTimeMillis())
                    .header("Idempotency-Key", "idemp-" + deploymentId + "-" + payload.hashCode())
                    .method("PATCH", HttpRequest.BodyPublishers.ofString(payload))
                    .build();
            long elapsedMs = TimeUnit.NANOSECONDS.toMillis(System.nanoTime() - startNanos);
            if (response.statusCode() == 200 || response.statusCode() == 202) {
                logger.info("Cutover successful. Status: " + response.statusCode() + " | Latency: " + elapsedMs + "ms");
                return Map.of(
                    "success", true,
                    "statusCode", response.statusCode(),
                    "responseBody", response.body(),
                    "latencyMs", elapsedMs,
                    "attempts", attempt
            if (response.statusCode() == 429) {
                long delay = baseDelayMs * (long) Math.pow(2, attempt - 1);
                logger.warning("Rate limited (429). Retrying in " + delay + "ms (attempt " + attempt + ")");
                Thread.sleep(delay);
                continue;
            throw new RuntimeException("Cutover failed with status " + response.statusCode() + ": " + response.body());
        throw new RuntimeException("Max retries exceeded for cutover operation.");
Required OAuth Scopes: deployment:write, routing:read
Expected Response for PATCH Cutover:
  "deploymentId": "dep-88a7c2",
  "status": "cutover_initiated",
  "cutoverId": "cut-99f1d4",
    "type": "canary",
    "currentWeight": 0.1,
    "nextAdjustmentAt": "2024-05-20T14:35:00Z"
  "estimatedCompletionSeconds": 120,
  "auditTrail": {
    "timestamp": "2024-05-20T14:34:00Z",
    "action": "model_hot_swap",
    "operator": "automated-pipeline"
Step 3: Verify Fallback Model and Synchronize Webhooks
After the atomic PATCH succeeds, you must verify that the fallback model is healthy and trigger webhooks to align external deployment pipelines (including NICE CXone routing configuration). This step ensures continuous service availability and generates governance audit logs.
public class CognigySwapOrchestrator {
    private static final Logger logger = Logger.getLogger(CognigySwapOrchestrator.class.getName());
    public CognigySwapOrchestrator(HttpClient httpClient, String baseUrl, CognigyAuth auth) {
        this.auth = auth;
    public void postSwapVerificationAndSync(String deploymentId, String modelId, Map<String, Object> cutoverResult) throws Exception {
        // 1. Verify fallback model health
        String fallbackUrl = baseUrl + "/api/v2/models/" + modelId + "/versions/fallback/health";
        HttpRequest fallbackReq = HttpRequest.newBuilder()
                .uri(URI.create(fallbackUrl))
                .GET()
                .build();
        HttpResponse<String> fallbackResp = httpClient.send(fallbackReq, HttpResponse.BodyHandlers.ofString());
        if (fallbackResp.statusCode() != 200) {
            throw new RuntimeException("Fallback model verification failed: " + fallbackResp.body());
        logger.info("Fallback model verified. Status: " + fallbackResp.body());
        // 2. Generate audit log entry
        String auditPayload = """
                "event": "MODEL_HOT_SWAP_COMPLETED",
                "modelId": "%s",
                "cutoverId": "%s",
                "latencyMs": %d,
                "successRate": %s,
                "timestamp": "%s"
            """.formatted(
                deploymentId,
                modelId,
                extractValue(cutoverResult, "responseBody", "cutoverId"),
                cutoverResult.get("latencyMs"),
                cutoverResult.get("success"),
                java.time.Instant.now().toString()
        // 3. Trigger webhook for external pipeline sync (CXone alignment)
        String webhookUrl = baseUrl + "/api/v2/webhooks/deployments/sync";
        String webhookPayload = """
                "source": "cognigy-ai",
                "action": "routing_update",
                "targetPlatform": "nice-cxone",
                "cxoneRoutingConfig": {
                    "queueId": "queue-ai-fallback",
                    "priority": 1,
                    "enable": true
                "swapAudit": %s
            """.formatted(auditPayload);
        HttpRequest webhookReq = HttpRequest.newBuilder()
                .uri(URI.create(webhookUrl))
                .POST(HttpRequest.BodyPublishers.ofString(webhookPayload))
                .build();
        HttpResponse<String> webhookResp = httpClient.send(webhookReq, HttpResponse.BodyHandlers.ofString());
        if (webhookResp.statusCode() >= 400) {
            logger.warning("Webhook sync returned " + webhookResp.statusCode() + ": " + webhookResp.body());
        } else {
            logger.info("External pipeline synchronized successfully.");
    private static String extractValue(Map<String, Object> map, String key, String jsonPath) {
        String body = (String) map.get(key);
        int start = body.indexOf("\"" + jsonPath + "\":\"") + jsonPath.length() + 3;
        int end = body.indexOf("\"", start);
        return body.substring(start, end);
Required OAuth Scopes: model:read, audit:write, webhook:write
Expected Webhook Response:
  "webhookId": "wh-77b3e1",
  "status": "dispatched",
  "targets": ["nice-cxone-routing-sync"],
  "deliveryLatencyMs": 142,
  "syncConfirmation": true
public class CognigyHotSwapRunner {
    public static void main(String[] args) throws Exception {
        if (args.length < 3) {
            throw new IllegalArgumentException("Usage: java CognigyHotSwapRunner <clientId> <clientSecret> <baseUrl>");
        String clientId = args[0];
        String clientSecret = args[1];
        String baseUrl = args[2].replace("https://", "").replace("http://", "");
        String fullBaseUrl = "https://" + baseUrl;
        String modelId = "mdl-44a9c1";
        String deploymentId = "dep-88a7c2";
        String targetVersion = "2.4.1";
        HttpClient client = HttpClient.newBuilder()
                .followRedirects(HttpClient.Redirect.NORMAL)
                .build();
        CognigyAuth auth = new CognigyAuth(clientId, clientSecret, fullBaseUrl);
        CognigyModelValidator validator = new CognigyModelValidator(client, fullBaseUrl, auth);
        CognigyModelSwapper swapper = new CognigyModelSwapper(client, fullBaseUrl, auth);
        CognigySwapOrchestrator orchestrator = new CognigySwapOrchestrator(client, fullBaseUrl, auth);
            System.out.println("Validating model swap constraints...");
            Map<String, Object> validation = validator.validateSwap(modelId, targetVersion, deploymentId);
            System.out.println("Active versions: " + validation.get("activeVersionCount"));
            System.out.println("Schema valid: " + validation.get("schemaValid"));
            System.out.println("Executing atomic cutover...");
            Map<String, Object> cutoverResult = swapper.executeCutover(deploymentId, (String) validation.get("payload"));
            System.out.println("Cutover latency: " + cutoverResult.get("latencyMs") + "ms");
            System.out.println("Response: " + cutoverResult.get("responseBody"));
            System.out.println("Verifying fallback and synchronizing pipelines...");
            orchestrator.postSwapVerificationAndSync(deploymentId, modelId, cutoverResult);
            System.out.println("Hot-swap completed successfully.");
        } catch (Exception e) {
            System.err.println("Swap operation failed: " + e.getMessage());
            e.printStackTrace();
Error: 409 Conflict - Version Limit or Schema Mismatch
  • What causes it: The deployment already contains five active versions, or the target version schema contains incompatible node definitions that violate runtime engine constraints.
  • How to fix it: Prune older versions via DELETE /api/v2/models/{modelId}/versions/{versionId} or update the model schema to match the runtime specification.
  • Code showing the fix:
// Prune oldest version before swap
HttpRequest pruneReq = HttpRequest.newBuilder()
    .uri(URI.create(baseUrl + "/api/v2/models/" + modelId + "/versions/v1.0.0"))
    .DELETE()
    .build();
httpClient.send(pruneReq, HttpResponse.BodyHandlers.ofString());
Error: 422 Unprocessable Entity - Invalid Traffic Directive Format
  • What causes it: The trafficDirective JSON object contains invalid weight values (outside 0.0 to 1.0) or missing required fields like rampUpIntervalSeconds.
  • How to fix it: Validate the payload structure against the Cognigy.AI routing schema before sending. Ensure initialWeight and maxWeight are decimal numbers.
// Validate weight bounds before constructing payload
if (initialWeight < 0.0 || initialWeight > 1.0) {
    throw new IllegalArgumentException("Traffic directive weight must be between 0.0 and 1.0");
Error: 503 Service Unavailable - Runtime Engine Busy
  • What causes it: The inference cluster is undergoing internal scaling or garbage collection. The atomic PATCH cannot acquire a write lock on the routing table.
  • How to fix it: Implement exponential backoff with jitter. The provided executeCutover method already handles 429 retries. For 503, wrap the call in a retry loop with a longer base delay.
if (response.statusCode() == 503) {
    long delay = 5000 * (long) Math.pow(2, attempt - 1);
    Thread.sleep(delay + (long)(Math.random() * 1000)); // Add jitter
    continue;
