hold issue
I are facing some problem in extension/trunk on which record parameter is enable.When I call from extension on which recording parameter is enabled then a hold warning appears on yealink phone when we pick up the call.The hold appears for 1 second after that we can able to hear voice,but for that 1 second there is no voice.
Please help me to resolve with issue.
Regards
prem
So,it is so difficult to say what is the cause of issue when you did not posted any description about your troubleshooting. It caused by many reasons and it is necessary to check T-Server logs and logs of components at “way” of call.
I will not check your logs,this is your job :slight_smile: I am only asking if you do something in troubleshooting and if yes,what do you want discover? So,I do not know if the SIP logs covering the issue,I recommended to make a network sniff and do troubleshooting there.
Ok,the only troubleshooting is did is that when i disabled the recording on trunk or extension then no hold message is shown but when i enablete recording then hold message is appear on extension when we answer a call.
Actually i am new to genesys so i can’t able to find any errors in Logs.
I am using yealink phones and same hold msg comes in yealink phone but when i am using any another phone hold message is not showing but i hear voice after 1 sec delay.
So,suggest me any solution for this.
Recording on Trunk or on Agent DN? You must decide one of them, as recording acts a 3rd party on the conversation. Maybe this component is taking too long to answer…check you configuration and logs. Check deployment guide for both scenarios.
