I cannot seem to get this working at all, can someone have a look at these log segments and try and give me some pointers please…
First off I’m not getting DNIS, I can live with that for now and have setup default DNIS (7192). Why is this call being rejected??
Popgateway log:
[2009/07/24 10:40:09.031] 17F8 HangupCall.cpp:157 C=12:L=2:U=321:D=W_12_93 CFC rejected the call [ ANI=$ani$ DID=7192 TollFreeNum=8888 Reseller=GVPOwner Customer=Admin Application=GVP_ACI SessionID={184B5835-40F6-4A54-8D76-8C77CAB8F11A} LastError=$last-error$ LastErrorString=$last-error-string$]
[2009/07/24 10:40:21.639] 17F8 ConversationController.cpp:1590 C=3:L=2:U=0:D=W_3_82 Informed CFC about Leg going down
GVPOwner_Admin_GQA log:
[2009/07/24 10:40:09.015] 10FC GetCallInfoAction.cpp:228 C=14:L=1:U=1413 Session ID[{184B5835-40F6-4A54-8D76-8C77CAB8F11A}] : Timeout waiting for Ringing event from IServer.
[2009/07/24 10:40:09.015] 10FC GetCallInfoAction.cpp:276 C=14:L=2:U=0 Ringing event did not received may be got ENDCAUSE as ‘FeatureNotSupported’
Your issue is caused by wrong GVP configuration in CME thus IVR T-Server rejects incoming calls. I can see in the snippet of IVR T-Server log that GVP ports are numbered 01,02,03… I think (99% - don’t have access to Avaya/GVP system now) it’s wrong as port number has to match extension number mapped to this GVP port (port 1234 = extension 1234).
Please i really aprecite if u can point what type of DN r u using for avaya.
For sure u r using VoiceTreatmentPorts … rigth?
Well, my problem is taht i want 2 implement autologin functionality, i only did this for( ACD Position on Nortel). Do u know if it is posible to implement something similar in Avaya?
You can create ACD Postion type for Avaya.
For the Auto-Login; create a AutoLogin section on the AnnexTab of your IVR Ports with these options (put your values)
