help in parsing conf server datas
Hello Everybody,
I am sorry for posting something that is perhaps stupid but I am new with genesys SDK (and in fact c# - I am coming from cisco call manager world and I have been working with php and python mostly) and I have a big problem.
I have the following code to ask some config to genesys conf server.
This is working but I get crazy to extract result datas.
If I would like to get, for example, the “lastname” of all returning objects, does someone knows what I should do or have a link with some examples of something that is working ?
Thanks in advance and happy new year :smiley:
CODE THAT GIVE A RESULT
        PropertyConfiguration config = new PropertyConfiguration();
        ConfServerProtocol protocol =
            new ConfServerProtocol(new Endpoint("default", "10.32.1.11", 2020));
        protocol.ClientApplicationType = (int)CfgAppType.CFGSCE;
        protocol.ClientName=("aaa");
        protocol.UserName="aaa";
        protocol.UserPassword=("aaa");
        protocol.Open();
        RequestReadObjects2 requestXpathQuery =
             RequestReadObjects2.Create(
                 (int)CfgObjectType.CFGPerson,
                 "CfgPerson[@emailAddress='*com' and firstName='*']");
        protocol.Send(requestXpathQuery);
        //remove this to be non blocking
        IMessage respondingEvent =
            protocol.Receive();
        Console.WriteLine("[We got something]");
        Console.WriteLine("** test 0 **");
        foreach (var x in objectsRead.ConfObject.Elements())
            Console.WriteLine(">#test0#"+x);
WHAT I GOT :
** test 0 **
#test0#
What are you doing is sending a request to the conf server, and receiving XML response. Inside tags of XML you have whatever you want. You must read innerXml to see the data.
If you are not used to work with xml and you don´t want to parse it…
Try to use config services… IConfService service = ConfServiceFactory.CreateConfService(protocol);
Regards.
