HELP! HOW TO GET IP ADDRESS??
HI ~~ I use COMPOSER 8.1.5 , how to get IP ADDRESS?
i find this -->get_SIPHeadValue(‘X-Genesys-Gani’)
IP address of what?
Enviado de meu SM-G9650 usando o Tapatalk
I want get SIP SERVER ip,
i find example like this:
session.connection.protocol.sip.requesturi.voicexml
Why you need SIP Server IP in composer ? Usually we have static IP address in Genesys environment so your IP of SIP Server will be same always (unless you change for some reason) .. If its multi site environment and your target to get switch then you should get switch in composer instead SIP Server IP .. and based on switch information you can decide which SIP Server got this call.
