help! confserv and confserv_bkp both in primary mode and not starting
Hi guys, I need your help.
My confserv stopped abnormally and now when I try o start it is detects that another confserv is primary it it cannot find it. The backup server is also stopped and when I try to start it it detests the first confserv as primary but cannot find it.
so : confserv stopped
confserv_bkp stopped both detect the other server as primary and would not start.
from confserv_bkp log:
12:47:49.896 Std 22102 Server application name is set to [confserv_BCK]
12:47:49.896 Std 22915 Server mode is set to [PRIMARY]
12:47:56.381 Std 04502 Cannot connect to ConfigurationServer ‘’ at host ‘buc-srv05’, port 9000, reason ‘CFGServerNotFound’
on_dbsync_violated executed when server is not fully loaded
12:47:56.381 Std 22300 Another Configuration Server is detected
12:47:56.381 Std 22905 Objectset [main-cfgset] failed to load
refresh stopped because of unhandled violation of access to cfg_refresh table
Main loop has ended
12:47:56.381 Std 05063 Normal termination
from confserv log:
12:49:04.243 Std 22102 Server application name is set to [confserv]
12:49:04.244 Std 22915 Server mode is set to [PRIMARY]
12:49:09.659 Std 04502 Cannot connect to ConfigurationServer ‘’ at host ‘buc-vm16’, port 9000, reason ‘CFGServerNotFound’
12:49:09.659 Std 22300 Another Configuration Server is detected
12:49:09.659 Std 22905 Objectset [main-cfgset] failed to load
Main loop has ended
12:49:09.659 Std 05063 Normal termination
Is there a way to set directly from the config database the mode to Backup ( a safe way )?
Thank you!
What Release of confserv do you have?It’s may be a bug of certainly version - I think,that in R8.0 was similiar issue or same issue.
confserv vers: 7.6.0.20
I’m afraid that the only solution is to upgrade confserv to R8.0 - 8.0.300.27 and above. In this version/patch has been fixed same issue.
[i]Release Number 8.0.300.27 [09/22/10] – Hot Fix
In a redundant configuration, the primary and backup Configuration Servers can start simultaneously. Previously, one or both of the two servers in the redundant pair sometimes stopped executing. [/i]
