But as per this thread http://genesysguru.com/blog/blog/2010/02/05/how-to-implement-an-esp-server/, it supports Voice interactions as well.
Abrar84,
I havenât found anything in linked article indicating that ESP is supported for voice interaction⊠And Genesys clearly states in the URS Reference Guide that ESP is for âuse in non-voice routing strategiesâ.
ESP Server is not supported handling of voice interactions.The link does not contain any such information
Rene and Kubig,
Please check following thread; specially part 5 and It clearly shows that the test call was made as Voice call.
https://forums.genesyslab.com/showthread.php?t=524
``` _I_I_007c01b03187e01e [14:33] strategy: *0x65*ESPFromVoice is attached to the call 02:42:51.838 Int 20001 interaction 007c01b03187e01e is started _I_I_007c01b03187e01e [01:14] current call classification: media=voice(100), service=default(200), segment=default(3 00) 02:42:51.838_I_I_007c01b03187e01e [09:06] >>>>>>>>>>>>start interpretator _I_I_007c01b03187e01e [09:04] ASSIGN: __Return(SCRIPT) <- STRING: _I_I_007c01b03187e01e [07:46] no error mode for this call _I_I_007c01b03187e01e [09:04] ASSIGN: __Return(SCRIPT) <- STRING: _I_I_007c01b03187e01e [09:04] ASSIGN: __DBReturn(SCRIPT) <- STRING: _I_I_007c01b03187e01e [09:04] ASSIGN: __DBStrReturn(SCRIPT) <- STRING: _I_I_007c01b03187e01e [09:04] ASSIGN: __TargetVar(SCRIPT) <- STRING: _I_I_007c01b03187e01e [09:04] ASSIGN: vEmployeeId(LOCAL) <- STRING: Analyst001 ```
Check your connections between URS<-> T-Server/IXN;IXN<-> ESP Server
These are perfectly working.
01:51:40.289_T_I_ [14:32] EventLinkConnected is received for ts InteractionServer_761, register all CDNs and IVRs again
request to 65201(--) message RequestQueryLocation
AttributeReferenceID 7
AttributeExtensions [2] 00 00..
AttributeLocationInfoType 4
..sent to TEST-dev02:7007(fd=544)
received from 65201(InteractionServer_761)TEST-dev02:7007(fd=) message EventError
(Bad message type)
AttributeErrorMessage 'Unsupported request'
AttributeErrorCode 102
AttributeReferenceID 5
01:51:40.291_T_E_ [14:0f] can not find tserver for event EventError, tenant
(Bad parameter passed to function)
AttributeErrorMessage 'CustomerID missing'
AttributeErrorCode 223
AttributeReferenceID 6
(Bad message type)
received from 65200(TserverAvayaCM)TEST-dev09:3000(fd=) message EventServerInfo
AttributeServerVersion '8.1.001.14'
AttributeServerRole 0
AttributeApplicationName 'TserverAvayaCM'
AttributeHomeLocation 'Avaya'
AttributeServerCapabilityMask [64] ff cf ff fd..
AttributeServerXCapabilities '(2=(56=524283),8=(16=31),10=(16=7),11=(16=25),14=(73=31),27=(66=3),34=(67=35),36=(60=7307),75=(16=6),76=(16=25),108=(74=3),121=(88=6),160=(146=1),161=(146=1),162=(146=1))'
AttributeExtensions [732] 00 05 00 00..
'T-Server' 'Tserver for Avaya Communication Manager, Version: 8.1.001.14 Compiled: May 2 2012 08:37:02
Genesys Telecommunications Laboratories, Inc., Copyright 1991 - 2012
'Features' '
Build with TServerCommonPart 8.1.001.42
High Availability feature: ON
ISCC feature support: ON
'TransactionMonitoring'(list) 'class' '029LK70N8SBO9F2B04000VTAESXX000F'
'object' '029LK70N8SBO9F2B04000VTAESXX000G'
'iscc.transaction' '029LK70N8SBO9F2B04000VTAESXX000J'
'iscc.direction' '029LK70N8SBO9F2B04000VTAESXX000L'
'iscc.is-link-creation' '029LK70N8SBO9F2B04000VTAESXX000M'
'iscc.call-operation' '029LK70N8SBO9F2B04000VTAESXX000R'
'iscc.resource' '029LK70N8SBO9F2B04000VTAESXX000U'
'sdn-licenses-in-use' 1
'sdn-licenses-available' 9998
AttributeReferenceID 1
AttributeTimeinSecs 1344502300 (01:51:40)
AttributeTimeinuSecs 318000
AttributeEventSequenceNumber 0000000000000047
Please look into this log. Right at the start there is an error âUnsupported requestâ. Do you think this is the reason?
Abrar
No,this is not a reason.The eServices/MCR docs say:
âą Interaction Server does not support the following requests:
Â
RequestQueryServer
ÂRequestQueryLocationÂ
RequestDeletePair (when URS sends this request after
RequestRouteCall)
This is the reasonwhy an EventError is returned
