Handling Webhook Delivery Failures with a Dead Letter Queue in Genesys Cloud
- You will build a Python service that intercepts failed webhook deliveries from Genesys Cloud by polling the Webhook Delivery Log API.
- You will implement a retry mechanism that attempts to redeliver the payload to your endpoint, and a Dead Letter Queue (DLQ) pattern that persists permanently failed messages to a local JSON file for manual inspection.
- This tutorial uses the Genesys Cloud Python SDK (
genesyscloud) and therequestslibrary for HTTP operations.
- OAuth Client: A Genesys Cloud OAuth client with the scope
webhook:readandwebhook:write(if you intend to update webhook status, though this tutorial focuses on reading logs and retrying). - SDK Version:
genesyscloud>= 13.0.0. - Language/Runtime: Python 3.9+.
- Dependencies: Install the required packages via pip:
pip install genesyscloud requests python-dotenv - Environment: A
.envfile containing your Genesys Cloud credentials:GENESYS_CLOUD_REGION=us-east-1 GENESYS_CLOUD_CLIENT_ID=your_client_id GENESYS_CLOUD_CLIENT_SECRET=your_client_secret WEBHOOK_ID=your_webhook_id
Genesys Cloud APIs require an OAuth 2.0 Bearer token. The Python SDK handles the token acquisition and refresh automatically when you initialize the PlatformClient. You must configure the client with your region, client ID, and client secret.
import os
from genesyscloud.platform.client import PlatformClient
from genesyscloud.api.webhooks import WebhooksApi
# Load environment variables
load_dotenv()
def get_webhooks_api() -> WebhooksApi:
Initializes and returns the WebhooksApi instance with OAuth authentication.
platform_client = PlatformClient()
# Configure OAuth credentials
platform_client.set_environment(os.getenv("GENESYS_CLOUD_REGION"))
platform_client.set_client_id(os.getenv("GENESYS_CLOUD_CLIENT_ID"))
platform_client.set_client_secret(os.getenv("GENESYS_CLOUD_CLIENT_SECRET"))
# Return the Webhooks API object
return WebhooksApi(platform_client)
This setup ensures that every subsequent API call includes a valid Authorization: Bearer <token> header. The SDK caches the token and refreshes it silently before expiration, preventing 401 Unauthorized errors during long-running processes.
Step 1: Polling for Failed Webhook Deliveries
Genesys Cloud maintains a delivery log for each webhook. When your endpoint returns a 5xx error, Genesys Cloud records the failure. You can query these failures using the get_webhook_deliveries endpoint.
The key parameter here is filter_status. You must set this to failed to retrieve only the deliveries that did not succeed. You should also specify a time window to avoid processing historical data indefinitely.
from genesyscloud.models import WebhookDeliveryQuery
def fetch_failed_deliveries(api: WebhooksApi, webhook_id: str, lookback_hours: int = 1) -> list:
Queries Genesys Cloud for failed webhook deliveries within the last N hours.
Args:
api: The initialized WebhooksApi instance.
webhook_id: The UUID of the specific webhook.
lookback_hours: How many hours back to search for failures.
Returns:
A list of WebhookDelivery objects that have failed.
now = datetime.utcnow()
start_time = now - timedelta(hours=lookback_hours)
# Format dates as ISO 8601 strings required by the API
start_time_str = start_time.isoformat() + "Z"
end_time_str = now.isoformat() + "Z"
# Construct the query body
# The 'filter_status' field is critical for filtering only failed attempts
query_body = WebhookDeliveryQuery(
filter_status="failed",
start_date=start_time_str,
end_date=end_time_str
# Call the API
# Scope required: webhook:read
response = api.get_webhook_deliveries(
webhook_id=webhook_id,
body=query_body
# The response contains a list of deliveries in the 'entities' field
if response and response.entities:
return response.entities
else:
return []
print(f"Error fetching deliveries: {e}")
return []
Expected Response Structure:
The response.entities list contains objects with fields like:
id: Unique ID for this specific delivery attempt.webhookId: The ID of the webhook.status: “failed”.httpStatusCode: The status code returned by your server (e.g., 500, 502, 503).body: The original JSON payload that Genesys Cloud tried to send.headers: The headers included in the request.
Step 2: Implementing the Retry Logic
When a delivery fails with a 5xx error, it is often transient (server overload, temporary network glitch). Your service should attempt to redeliver the payload. You will use the requests library to send the original payload to the original destination URL.
You must reconstruct the HTTP request using the data from the WebhookDelivery object. Note that Genesys Cloud includes the original headers in the delivery log. You should forward these headers (minus sensitive ones like Authorization if you are acting as a proxy, but typically you forward them to preserve the original context).
import requests
def retry_delivery(delivery: object, max_retries: int = 3, delay_seconds: int = 5) -> bool:
Attempts to resend the webhook payload to the original URL.
Args:
delivery: The WebhookDelivery object containing payload and metadata.
max_retries: Maximum number of retry attempts.
delay_seconds: Seconds to wait between retries.
Returns:
True if the delivery succeeds, False otherwise.
# Extract necessary data from the delivery object
target_url = delivery.webhook_url # The URL the webhook is configured to hit
payload = delivery.body # The JSON body sent originally
headers = delivery.headers or {} # Original headers
# Remove Genesys-specific headers that might confuse the target if they are not expected
# Usually safe to keep Content-Type, etc.
for attempt in range(1, max_retries + 1):
print(f"Retry attempt {attempt}/{max_retries} for delivery ID: {delivery.id}")
# Send the POST request
# Use timeout to prevent hanging indefinitely
response = requests.post(
target_url,
json=payload, # Automatically serializes dict/list to JSON
headers=headers,
timeout=10
# Check if the response is successful (2xx)
if response.status_code >= 200 and response.status_code < 300:
print(f"Successfully redelivered delivery ID: {delivery.id} with status {response.status_code}")
return True
else:
print(f"Retry failed with status code: {response.status_code}")
# If it's still a 5xx, we might want to retry again
# If it's a 4xx, it's likely a permanent error, so we should stop retrying
if response.status_code >= 400 and response.status_code < 500:
print("Received 4xx error. Stopping retries.")
return False
print(f"Network error during retry: {e}")
# Wait before next retry, unless it was the last attempt
if attempt < max_retries:
time.sleep(delay_seconds)
return False
Step 3: Processing Results and the Dead Letter Queue
If the retry logic fails after all attempts, the message is considered “dead.” You must persist this data so it can be investigated later. This is the Dead Letter Queue (DLQ). For this tutorial, we will implement a simple file-based DLQ using JSON. In a production environment, you would write to Kafka, RabbitMQ, or an AWS SQS queue.
The DLQ entry must contain all context: the original payload, the error reason, the timestamp of failure, and the delivery ID.
import json
def save_to_dlq(delivery: object, error_reason: str, dlq_file: str = "dlq.json"):
Saves a permanently failed delivery to a Dead Letter Queue file.
Args:
delivery: The WebhookDelivery object.
error_reason: A string describing why the retries failed.
dlq_file: The path to the JSON file acting as the DLQ.
dlq_entry = {
"deliveryId": delivery.id,
"webhookId": delivery.webhook_id,
"timestamp": datetime.utcnow().isoformat() + "Z",
"originalPayload": delivery.body,
"originalHeaders": delivery.headers,
"httpStatusCode": delivery.http_status_code,
"errorReason": error_reason,
"targetUrl": delivery.webhook_url
# Read existing DLQ entries
existing_entries = []
if os.path.exists(dlq_file):
with open(dlq_file, 'r') as f:
existing_entries = json.load(f)
except json.JSONDecodeError:
print(f"Error reading DLQ file: {e}")
# Append new entry
existing_entries.append(dlq_entry)
# Write back to file
with open(dlq_file, 'w') as f:
json.dump(existing_entries, f, indent=2)
print(f"Saved failed delivery {delivery.id} to DLQ.")
print(f"CRITICAL: Failed to write to DLQ: {e}")
The following script combines all steps into a single runnable module. It polls Genesys Cloud every 60 seconds for failed webhooks, attempts to retry them, and moves permanently failed ones to the DLQ.
import os
import json
import requests
# Configuration
LOAD_ENV = True
POLL_INTERVAL_SECONDS = 60
LOOKBACK_HOURS = 1
MAX_RETRIES = 3
RETRY_DELAY_SECONDS = 5
DLQ_FILE = "dlq.json"
def get_webhooks_api():
def fetch_failed_deliveries(api, webhook_id, lookback_hours):
body=query_body
return []
return []
def retry_delivery(delivery, max_retries, delay_seconds):
print(f"[{datetime.utcnow().isoformat()}] Retry attempt {attempt}/{max_retries} for ID: {delivery.id}")
target_url,
json=payload,
headers=headers,
timeout=10
if 200 <= response.status_code < 300:
print(f"[{datetime.utcnow().isoformat()}] Success! ID: {delivery.id}, Status: {response.status_code}")
return True
else:
print(f"[{datetime.utcnow().isoformat()}] Failed retry. ID: {delivery.id}, Status: {response.status_code}")
if 400 <= response.status_code < 500:
return False
print(f"[{datetime.utcnow().isoformat()}] Network error: {e}")
return False
def save_to_dlq(delivery, error_reason, dlq_file):
dlq_entry = {
def main():
if LOAD_ENV:
load_dotenv()
webhook_id = os.getenv("WEBHOOK_ID")
if not webhook_id:
raise ValueError("WEBHOOK_ID environment variable is required.")
api = get_webhooks_api()
print(f"Starting Webhook Retry Service for Webhook ID: {webhook_id}")
print(f"Polling every {POLL_INTERVAL_SECONDS} seconds...")
while True:
# Step 1: Fetch failed deliveries
failed_deliveries = fetch_failed_deliveries(api, webhook_id, LOOKBACK_HOURS)
if not failed_deliveries:
print("No failed deliveries found.")
else:
print(f"Found {len(failed_deliveries)} failed delivery(ies).")
# Step 2 & 3: Process each failure
for delivery in failed_deliveries:
print(f"Processing delivery ID: {delivery.id}")
# Attempt retry
success = retry_delivery(delivery, MAX_RETRIES, RETRY_DELAY_SECONDS)
if not success:
# Move to DLQ
save_to_dlq(
delivery,
f"Failed after {MAX_RETRIES} retries",
DLQ_FILE
except KeyboardInterrupt:
print("Shutting down...")
break
print(f"Unexpected error in main loop: {e}")
# Wait before next poll
time.sleep(POLL_INTERVAL_SECONDS)
from datetime import timedelta
main()
Error: 403 Forbidden
Cause: The OAuth client used in the PlatformClient initialization lacks the webhook:read scope.
Fix:
- Go to the Genesys Cloud Admin Portal.
- Navigate to Admin > Security > OAuth Clients.
- Select your client.
- Ensure the scope
webhook:readis checked. - Regenerate the client secret if you suspect the token was issued before the scope change.
Cause: You are polling the get_webhook_deliveries endpoint too frequently. Genesys Cloud enforces rate limits per client ID.
Fix:
Increase the POLL_INTERVAL_SECONDS in the configuration. The default of 60 seconds is usually safe. If you have a high volume of webhooks, consider implementing exponential backoff in the fetch_failed_deliveries function when a 429 is caught.
# Example rate limit handling in fetch_failed_deliveries
if "429" in str(e):
print("Rate limited. Waiting 10 seconds...")
time.sleep(10)
return []
raise e
Error: Payload Mismatch on Retry
Cause: The delivery.body field in the Genesys Cloud log might be a stringified JSON string rather than a parsed dictionary, depending on the SDK version or how the webhook was configured.
Fix:
Before sending the retry request, ensure the payload is a valid JSON object.
import json
# Inside retry_delivery
if isinstance(payload, str):
payload = json.loads(payload)
# If it cannot be parsed, it might be a raw text payload
# In this case, send as text, not JSON
headers['Content-Type'] = 'text/plain'
# Use requests.post(url, data=payload, headers=headers)
Error: DLQ File Locking
Cause: If multiple instances of this script run simultaneously, they will race to write to dlq.json, causing data corruption or PermissionError.
Fix:
For production, replace the file-based DLQ with a message queue (e.g., RabbitMQ, AWS SQS). If you must use a file, use a file lock library like fcntl (Linux/Mac) or msvcrt (Windows) to ensure atomic writes.
