Handling Webhook Delivery Failures: Implementing a Dead Letter Queue with Genesys Cloud
  • You will build a Python-based microservice that receives failed webhook payloads from Genesys Cloud and routes them to a persistent dead letter queue for analysis and manual retry.
  • This solution utilizes the Genesys Cloud Webhooks API and the Python requests library to configure the webhook endpoint and the AWS SQS API for queue management.
  • The tutorial covers Python and JavaScript for the receiving endpoint and queue consumer.
  • OAuth Client: A Genesys Cloud OAuth client with the scope webhooks:write to configure webhooks and webhooks:read to inspect them.
  • SDK Version: Genesys Cloud Python SDK (genesys-cloud-sdk) version 150.0.0 or higher.
  • Runtime: Python 3.9+ for the configuration script and consumer; Node.js 18+ for the example webhook receiver.
  • Dependencies:
    • Python: pip install genesys-cloud-sdk requests boto3
    • Node.js: npm install express aws-sdk
  • AWS Account: An active AWS account with permissions to create SQS queues (sqs:CreateQueue, sqs:SendMessage).
Genesys Cloud APIs require OAuth 2.0 Client Credentials grant flow. You must generate an access token before making any configuration changes.
Python Token Generation
import requests
import base64
import json
def get_genesys_token(client_id: str, client_env: str, client_secret: str) -> dict:
    Authenticates with Genesys Cloud and returns a token dictionary.
    url = f"https://api.{client_env}.mypurecloud.com/oauth/token"
    # Combine client ID and secret for Basic Auth header
    credentials = f"{client_id}:{client_secret}"
    encoded_credentials = base64.b64encode(credentials.encode()).decode()
    headers = {
        "Authorization": f"Basic {encoded_credentials}",
    data = {
        "scope": "webhooks:write webhooks:read"
    response = requests.post(url, headers=headers, data=data)
    if response.status_code != 200:
        raise Exception(f"Authentication failed: {response.status_code} - {response.text}")
    return response.json()
# Usage example
# token_data = get_genesys_token("YOUR_CLIENT_ID", "us", "YOUR_CLIENT_SECRET")
# access_token = token_data['access_token']
Note: Access tokens expire after 3600 seconds. In a production service, implement a cache that checks the expires_in field and refreshes the token before expiration.
Step 1: Configure the Dead Letter Webhook in Genesys Cloud
Genesys Cloud allows you to specify a deadLetterUrl in the webhook configuration. When your primary endpoint returns a 5xx error or times out, Genesys sends the payload to this secondary URL. This URL must be publicly accessible via HTTPS.
We will use the SDK to create or update a webhook with this setting.
from purecloudplatformclientv2 import Webhook, WebhookConfig, WebhookDeadLetterConfig
from purecloudplatformclientv2.platform_client import PlatformClient
def setup_dlq_webhook(platform_client: PlatformClient, webhook_name: str, primary_url: str, dlq_url: str) -> str:
    Creates a webhook with a configured Dead Letter Queue URL.
    Args:
        platform_client: Initialized Genesys Cloud PlatformClient.
        webhook_name: Name of the webhook.
        primary_url: The main endpoint receiving events.
        dlq_url: The endpoint that receives failed payloads.
    Returns:
        The ID of the created webhook.
    # Define the Dead Letter Configuration
    dlq_config = WebhookDeadLetterConfig(
        url=dlq_url
    # Define the Webhook Configuration
    config = WebhookConfig(
        name=webhook_name,
        url=primary_url,
        deadletterconfig=dlq_config,
        event_filter="type='conversation' and conversation.type='voice'", # Example filter
        request_headers={"Content-Type": "application/json"},
        request_body_type="application/json"
    # Create the Webhook object
    webhook = Webhook(config=config)
    # Call the API
        response = platform_client.webhooks_api.post_webhooks(webhook=webhook)
        print(f"Webhook created successfully. ID: {response.id}")
        return response.id
        print(f"Failed to create webhook: {e}")
        raise e
# To run this, you must initialize the PlatformClient with the token from Step 0
# from purecloudplatformclientv2 import AuthClient
# auth_client = AuthClient(client_id, client_secret, environment="us")
# platform_client = PlatformClient(auth_client)
# setup_dlq_webhook(platform_client, "Voice DLQ Test", "https://my-app.example.com/primary", "https://my-app.example.com/dlq")
Required Scope: webhooks:write
Critical Parameter: The deadletterconfig object. If omitted, Genesys Cloud will simply drop the message after retries. By providing a URL, you ensure no data is lost.
Step 2: Build the Dead Letter Receiver Endpoint
This endpoint receives the failed payload. It must return a 200 OK status immediately to acknowledge receipt. It should not process the business logic here; it should only persist the data.
We will use a simple Node.js/Express server for this receiver, as it is common for webhook endpoints.
const express = require('express');
const AWS = require('aws-sdk');
const app = express();
app.use(express.json());
// Initialize SQS Client
const sqs = new AWS.SQS({ region: 'us-east-1' });
const DLQ_QUEUE_URL = 'https://sqs.us-east-1.amazonaws.com/123456789012/genesys-dlq';
// Endpoint that Genesys Cloud calls when the primary webhook fails
app.post('/dlq', async (req, res) => {
    const payload = req.body;
    const headers = req.headers;
    console.log('Received DLQ payload:', payload);
        // Validate payload structure
        if (!payload || !payload.type) {
            throw new Error('Invalid payload structure');
        // Send to SQS with metadata for debugging
        const messageData = {
            originalPayload: payload,
            receivedAt: new Date().toISOString(),
            genesysHeaders: {
                'x-genesis-id': headers['x-genesis-id'],
                'x-webhook-id': headers['x-webhook-id'],
                'x-webhook-name': headers['x-webhook-name']
        const params = {
            MessageBody: JSON.stringify(messageData),
            QueueUrl: DLQ_QUEUE_URL,
            MessageAttributes: {
                'eventType': {
                    DataType: 'String',
                    StringValue: payload.type
        await sqs.sendMessage(params).promise();
        // Acknowledge receipt to Genesys Cloud immediately
        res.status(200).json({ success: true });
    } catch (error) {
        console.error('Error processing DLQ message:', error);
        // Return 500 to indicate the DLQ itself failed.
        // Genesys will stop retrying the DLQ URL if it fails repeatedly.
        res.status(500).json({ error: 'DLQ processing failed' });
const PORT = process.env.PORT || 3000;
app.listen(PORT, () => {
    console.log(`DLQ Receiver listening on port ${PORT}`);
Important: The DLQ endpoint must be resilient. If the DLQ endpoint returns a 5xx, Genesys Cloud will not retry the DLQ URL indefinitely. It will log the failure internally. Ensure your DLQ receiver has high availability.
Step 3: Implement the Retry Logic Consumer
The dead letter queue stores the failed messages. You need a consumer that reads these messages, analyzes why they failed, and optionally retries them against the primary endpoint.
import boto3
import json
import requests
from typing import Dict, Any
class DLQConsumer:
    def __init__(self, region: str, queue_url: str, primary_endpoint: str):
        self.sqs = boto3.client('sqs', region_name=region)
        self.queue_url = queue_url
        self.primary_endpoint = primary_endpoint
        self.max_retries = 3
        self.retry_delay = 5 # seconds
    def receive_messages(self) -> list:
        """Polls SQS for new messages."""
        response = self.sqs.receive_message(
            QueueUrl=self.queue_url,
            MaxNumberOfMessages=10,
            WaitTimeSeconds=5,
            VisibilityTimeout=30
        return response.get('Messages', [])
    def process_message(self, message: Dict[str, Any]) -> bool:
        """Processes a single DLQ message."""
        receipt_handle = message['ReceiptHandle']
        body = json.loads(message['Body'])
        original_payload = body.get('originalPayload')
        event_type = body.get('eventType')
        print(f"Processing DLQ message for event type: {event_type}")
        retry_success = False
        for attempt in range(self.max_retries):
                # Attempt to resend to the primary endpoint
                    self.primary_endpoint,
                    json=original_payload,
                    timeout=10
                if response.status_code == 200:
                    print("Retry successful.")
                    retry_success = True
                    break
                else:
                    print(f"Retry attempt {attempt + 1} failed with status {response.status_code}")
                print(f"Network error during retry: {e}")
            if attempt < self.max_retries - 1:
                time.sleep(self.retry_delay)
        # Delete message from SQS regardless of retry success
        # (In production, you might move failed retries to a different queue)
        self.sqs.delete_message(
            ReceiptHandle=receipt_handle
        return retry_success
    def run(self):
        """Main loop to consume messages."""
        print("Starting DLQ Consumer...")
        while True:
            messages = self.receive_messages()
            for msg in messages:
                self.process_message(msg)
            time.sleep(2)
# Usage
# consumer = DLQConsumer('us-east-1', 'https://sqs.us-east-1.amazonaws.com/123456789012/genesys-dlq', 'https://my-app.example.com/primary')
# consumer.run()
Error Handling Strategy:
  1. Visibility Timeout: Set to 30 seconds. If the consumer crashes while processing, the message becomes visible again after 30 seconds.
  2. Retry Logic: The consumer retries the primary endpoint up to 3 times. This handles transient network issues between your service and the primary endpoint.
  3. Persistence: If retries fail, you should log the originalPayload to a database or S3 for manual investigation. Deleting the message from SQS immediately after retry attempts prevents infinite loops.
Below is a consolidated Python script that sets up the webhook configuration and a minimal DLQ receiver using Flask (for Python consistency) and a simulated SQS sender.
File: dlq_setup_and_receiver.py
import os
import json
import requests
from flask import Flask, request, jsonify
from purecloudplatformclientv2 import Webhook, WebhookConfig, WebhookDeadLetterConfig, PlatformClient, AuthClient
# Configuration
CLIENT_ID = os.getenv('GENESYS_CLIENT_ID')
CLIENT_SECRET = os.getenv('GENESYS_CLIENT_SECRET')
ENVIRONMENT = os.getenv('GENESYS_ENV', 'us')
PRIMARY_URL = os.getenv('PRIMARY_WEBHOOK_URL', 'https://primary.example.com/webhook')
DLQ_URL = os.getenv('DLQ_WEBHOOK_URL', 'https://dlq.example.com/dlq')
app = Flask(__name__)
def setup_genesys_webhook():
    """Configures the webhook with DLQ in Genesys Cloud."""
    print("Setting up Genesys Cloud Webhook...")
        auth_client = AuthClient(CLIENT_ID, CLIENT_SECRET, environment=ENVIRONMENT)
        dlq_config = WebhookDeadLetterConfig(url=DLQ_URL)
            name="Python DLQ Example",
            url=PRIMARY_URL,
        print(f"Webhook created. ID: {response.id}")
        print(f"Error setting up webhook: {e}")
        raise e
@app.route('/dlq', methods=['POST'])
def handle_dlq():
    """Receives failed payloads from Genesys Cloud."""
        payload = request.get_json()
        if not payload:
            return jsonify({"error": "Empty payload"}), 400
        # In production, send to SQS, DB, or S3
        print(f"DLQ Received: {json.dumps(payload, indent=2)}")
        # Simulate processing time
        time.sleep(0.1)
        return jsonify({"status": "accepted"}), 200
        print(f"DLQ Handler Error: {e}")
        return jsonify({"error": "Internal Server Error"}), 500
if __name__ == '__main__':
    # 1. Setup Webhook (Run this once via CLI or separate script)
    # setup_genesys_webhook()
    # 2. Start DLQ Receiver
    print("Starting DLQ Receiver on port 5000...")
    app.run(host='0.0.0.0', port=5000)
To Run:
  1. Install dependencies: pip install flask genesys-cloud-sdk requests
  2. Set environment variables:
    export GENESYS_CLIENT_ID="your_client_id"
    export GENESYS_CLIENT_SECRET="your_client_secret"
    export PRIMARY_WEBHOOK_URL="https://your-primary-endpoint.com/webhook"
    export DLQ_WEBHOOK_URL="https://your-dlq-endpoint.com/dlq"
  3. Run the script: python dlq_setup_and_receiver.py
  4. Comment out setup_genesys_webhook() after the first run to avoid duplicate webhooks.
Error: 403 Forbidden on Webhook Creation
  • Cause: The OAuth token lacks the webhooks:write scope.
  • Fix: Update the scope parameter in the get_genesys_token function to include webhooks:write.
Error: DLQ URL Returns 404
  • Cause: The DLQ endpoint is not publicly accessible or the path is incorrect.
  • Fix: Ensure the URL is HTTPS and accessible from the internet. Genesys Cloud cannot reach internal IPs. Use a tunneling service like ngrok for testing: ngrok http 5000.
Error: Webhook Payload Missing Fields
  • Cause: The event_filter is too broad or the event type does not support the requested data.
  • Fix: Check the Genesys Cloud Webhook Events documentation for the specific event structure. Ensure the request_body_type matches the expected format.
Error: SQS Queue Not Found
  • Cause: Incorrect AWS region or queue URL.
  • Fix: Verify the QueueUrl in the Node.js/Python consumer matches the actual SQS queue URL. Check AWS IAM permissions for the role executing the code.
