Handling SCIM 2.0 bulk provisioning conflicts by implementing a retry-and-merge strategy using the Python SDK and exponential backoff with jitter
  • A Python script that submits SCIM 2.0 bulk provisioning requests to Genesys Cloud and automatically resolves 409 Conflict responses by fetching the current resource state, merging requested changes, and retrying the update.
  • The implementation uses the Genesys Cloud Python SDK for authentication and typing, combined with httpx for HTTP transport, and applies exponential backoff with jitter to prevent retry storms.
  • The tutorial covers Python 3.9+ with type hints, production error handling, and raw HTTP cycle visibility.
  • OAuth 2.0 Client Credentials grant with scopes: scim:user:read, scim:user:write, scim:bulk:write
  • Genesys Cloud Python SDK genesyscloud>=2.15.0
  • Runtime: Python 3.9 or higher
  • Dependencies: pip install genesyscloud httpx tenacity pydantic
  • A Genesys Cloud organization with SCIM provisioning enabled and a valid API key ID and secret
The Genesys Cloud Python SDK handles token acquisition and caching. You must initialize the platform configuration before making SCIM calls. The SDK uses a sliding window cache, but you must explicitly enable it for long-running scripts.
import os
from genesyscloud.platform_client_v2.configuration import PlatformConfiguration
from genesyscloud.auth.client_credentials_auth import ClientCredentialsAuth
from genesyscloud.platform_client_v2.apis.scim_api import ScimApi
def initialize_scim_client(
    base_url: str,
    client_id: str,
    client_secret: str
) -> ScimApi:
    """Initialize the Genesys Cloud SCIM API client with OAuth2 Client Credentials."""
    platform_config = PlatformConfiguration(
        base_url=base_url,
        client_id=client_id,
        client_secret=client_secret
    platform_config.enable_cache = True
    auth = ClientCredentialsAuth(platform_config)
    auth.login()
    return ScimApi(platform_config)
OAuth Scopes Required: scim:user:read, scim:user:write, scim:bulk:write
The SDK caches the access token and automatically refreshes it when the response contains a 401 Unauthorized status. You do not need to manually implement token rotation. The underlying token endpoint is https://login.mypurecloud.com/oauth/token with grant_type=client_credentials.
Step 1: Submit Bulk SCIM Operations and Parse Multi-Status Responses
SCIM 2.0 bulk endpoints return a 207 Multi-Status response. Each operation in the request receives an individual status code. You must parse the Operations array to identify conflicts (409), successes (200/201), and server errors (5xx).
import httpx
import json
from typing import Any, Dict, List
def submit_bulk_scim(
    client: ScimApi,
    operations: List[Dict[str, Any]]
) -> Dict[str, Any]:
    """Submit a bulk SCIM request and return the raw 207 response body."""
    bulk_payload = {"Operations": operations}
    # Construct the raw HTTP request to satisfy cycle visibility requirements
    url = f"{client._base_url}/api/v2/scim/v2/Bulk"
    headers = {
        "Authorization": f"Bearer {client._auth.get_access_token()}",
        "Content-Type": "application/json; charset=utf-8",
        "Accept": "application/json"
    with httpx.Client(timeout=30.0) as session:
        response = session.post(url, headers=headers, json=bulk_payload)
        raise httpx.HTTPStatusError(
            "Rate limit exceeded. Implement retry logic at the caller level.",
            request=response.request,
            response=response
    if response.status_code not in (200, 207):
            f"SCIM bulk request failed with {response.status_code}",
            response=response
    return response.json()
HTTP Request Cycle Example:
POST /api/v2/scim/v2/Bulk HTTP/1.1
Host: api.mypurecloud.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
Content-Type: application/json; charset=utf-8
Accept: application/json
  "Operations": [
      "method": "POST",
      "path": "/Users",
      "bulkId": "create_user_001",
      "data": {
        "schemas": ["urn:ietf:params:scim:schemas:core:2.0:User"],
        "userName": "jane.doe@example.com",
        "name": { "givenName": "Jane", "familyName": "Doe" },
        "active": true,
        "emails": [{ "value": "jane.doe@example.com", "primary": true }]
HTTP Response Cycle Example:
HTTP/1.1 207 Multi-Status
Cache-Control: no-store
  "Operations": [
      "location": "https://api.mypurecloud.com/api/v2/scim/v2/Users/a1b2c3d4-e5f6-7890-abcd-ef1234567890",
      "status": "409",
      "response": "Conflict",
The 409 Conflict status indicates that a user with the same userName already exists. SCIM does not automatically overwrite existing records during bulk POST operations. You must implement a merge strategy.
Step 2: Implement Retry-and-Merge Logic for Conflicts
When a 409 occurs, you must fetch the existing user, apply the requested changes, and submit an UPDATE operation instead of POST. The merge strategy preserves existing attributes that are not present in the incoming payload.
def fetch_existing_user(client: ScimApi, user_id: str) -> Dict[str, Any]:
    """Retrieve the current state of a SCIM user by ID."""
    url = f"{client._base_url}/api/v2/scim/v2/Users/{user_id}"
    headers = {
    with httpx.Client(timeout=15.0) as session:
        response = session.get(url, headers=headers)
    if response.status_code == 404:
        raise ValueError(f"User {user_id} not found. Conflict resolution cannot proceed.")
    if response.status_code != 200:
            f"Failed to fetch user {user_id}",
            response=response
def merge_scim_user(current: Dict[str, Any], incoming: Dict[str, Any]) -> Dict[str, Any]:
    """Merge incoming SCIM attributes into the current user state.
    Preserves existing fields that are not overwritten.
    Maintains required SCIM schemas and removes internal Genesys fields.
    merged = current.copy()
    incoming_data = incoming.get("data", incoming)
    # Preserve required schemas
    merged["schemas"] = incoming_data.get("schemas", current.get("schemas"))
    # Merge core attributes
    for key in ("userName", "active", "name", "emails", "phoneNumbers", "addresses"):
        if key in incoming_data:
            merged[key] = incoming_data[key]
    # Remove internal Genesys Cloud fields that cannot be written
    for protected_field in ("id", "meta", "externalId", "manager"):
        merged.pop(protected_field, None)
    return merged
def build_update_operation(bulk_id: str, user_id: str, merged_data: Dict[str, Any]) -> Dict[str, Any]:
    """Construct a SCIM UPDATE operation for retry."""
        "method": "PUT",
        "path": f"/Users/{user_id}",
        "bulkId": f"{bulk_id}_retry",
        "data": merged_data
The merge function intentionally excludes externalId and manager because Genesys Cloud restricts direct writes to those fields during bulk provisioning. Attempting to include them triggers a 400 Bad Request response. The PUT method replaces the entire resource representation, so you must return the complete merged object.
Step 3: Exponential Backoff with Jitter and Retry Orchestration
Linear retries cause thundering herd problems when multiple provisioning jobs hit the same conflict window. Exponential backoff with jitter spreads retry requests across time. The formula is delay = min(max_delay, base_delay * (2 ** attempt)) + random.uniform(0, jitter_range).
import random
from typing import Optional
def calculate_backoff_delay(
    attempt: int,
    base_delay: float = 1.0,
    max_delay: float = 60.0,
    jitter_range: float = 2.0
) -> float:
    """Calculate exponential backoff delay with full jitter."""
    exponential = base_delay * (2 ** attempt)
    clamped = min(exponential, max_delay)
    jitter = random.uniform(0, jitter_range)
    return clamped + jitter
def process_bulk_conflicts(
    client: ScimApi,
    bulk_response: Dict[str, Any],
    max_retries: int = 3
    """Resolve 409 conflicts using retry-and-merge with exponential backoff."""
    operations = bulk_response.get("Operations", [])
    retry_operations: List[Dict[str, Any]] = []
    for op_result in operations:
        status = op_result.get("status", "")
        bulk_id = op_result.get("bulkId", "")
        if status == "409":
            # Extract user ID from the original operation or location header
            location = op_result.get("location", "")
            user_id = location.split("/")[-1] if location else ""
            if not user_id:
                print(f"Skipping conflict resolution for {bulk_id}: missing user ID")
                    time.sleep(calculate_backoff_delay(attempt))
                    current_user = fetch_existing_user(client, user_id)
                    # Retrieve original incoming data from the request builder
                    # In production, store incoming payloads in a lookup dictionary
                    incoming_data = {
                        "name": {"givenName": "Jane", "familyName": "Doe"},
                        "active": True
                    merged = merge_scim_user(current_user, incoming_data)
                    update_op = build_update_operation(bulk_id, user_id, merged)
                    retry_operations.append(update_op)
                    # Break on successful merge preparation
                    break
                    if attempt == max_retries - 1:
                        print(f"Failed to resolve conflict for {bulk_id}: {e}")
                    else:
                        print(f"Retry {attempt + 1} failed for {bulk_id}. Backing off.")
    return {"Operations": retry_operations}
The backoff calculation applies a full jitter range to prevent synchronized retries across distributed workers. The max_retries parameter caps the loop to avoid infinite execution. You must store the original incoming payloads in a dictionary keyed by bulkId so the merge function can access them during retry.
The following script combines authentication, bulk submission, conflict resolution, and retry orchestration into a single runnable module. Replace the environment variables with your Genesys Cloud credentials.
import os
import httpx
import random
def initialize_client() -> ScimApi:
        base_url=os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com"),
        client_id=os.getenv("GENESYS_CLIENT_ID"),
        client_secret=os.getenv("GENESYS_CLIENT_SECRET")
    auth.login()
def submit_bulk(client: ScimApi, operations: List[Dict[str, Any]]) -> Dict[str, Any]:
    headers = {
        response = session.post(url, headers=headers, json={"Operations": operations})
        raise httpx.HTTPStatusError("Rate limited", request=response.request, response=response)
        raise httpx.HTTPStatusError(f"SCIM bulk failed: {response.status_code}", request=response.request, response=response)
def fetch_user(client: ScimApi, user_id: str) -> Dict[str, Any]:
    headers = {"Authorization": f"Bearer {client._auth.get_access_token()}", "Accept": "application/json"}
        res = session.get(url, headers=headers)
    if res.status_code == 404:
        raise ValueError(f"User {user_id} not found")
    if res.status_code != 200:
        raise httpx.HTTPStatusError("Fetch failed", request=res.request, response=res)
    return res.json()
def merge_user(current: Dict[str, Any], incoming: Dict[str, Any]) -> Dict[str, Any]:
    merged["schemas"] = data.get("schemas", current.get("schemas"))
    for k in ("userName", "active", "name", "emails"):
        if k in data:
            merged[k] = data[k]
    for k in ("id", "meta", "externalId", "manager"):
        merged.pop(k, None)
    return merged
def backoff_delay(attempt: int, base: float = 1.0, max_d: float = 60.0, jitter: float = 2.0) -> float:
    return min(base * (2 ** attempt), max_d) + random.uniform(0, jitter)
def main():
    client = initialize_client()
    initial_ops = [
            "method": "POST",
            "path": "/Users",
            "bulkId": "user_001",
            "data": {
                "active": True,
                "emails": [{"value": "jane.doe@example.com", "primary": True}]
        response = submit_bulk(client, initial_ops)
        print(f"Initial bulk response: {response}")
        conflicts = [op for op in response.get("Operations", []) if op.get("status") == "409"]
        if not conflicts:
            print("No conflicts detected. Provisioning complete.")
            return
        retry_ops = []
        for conflict in conflicts:
            loc = conflict.get("location", "")
            user_id = loc.split("/")[-1] if loc else ""
            if not user_id:
            for attempt in range(3):
                    time.sleep(backoff_delay(attempt))
                    current = fetch_user(client, user_id)
                    incoming = initial_ops[0]
                    merged = merge_user(current, incoming)
                    retry_ops.append({
                        "method": "PUT",
                        "bulkId": f"{conflict['bulkId']}_retry",
                        "data": merged
                    print(f"Conflict resolved for {user_id} on attempt {attempt + 1}")
                    break
                    if attempt == 2:
                        print(f"Failed to resolve {user_id}: {e}")
                    else:
                        print(f"Retry {attempt + 1} failed. Backing off.")
        if retry_ops:
            final_response = submit_bulk(client, retry_ops)
            print(f"Retry bulk response: {final_response}")
        print(f"HTTP Error: {e.response.status_code} - {e.response.text}")
        print(f"Unexpected error: {e}")
    main()
The script handles the complete lifecycle: authentication, initial bulk submission, conflict detection, merge preparation, backoff delays, and retry submission. It catches 429 rate limits and raises them for external retry orchestration. It catches 404 during fetch to prevent merging against deleted resources.
Error: 409 Conflict with missing location header
  • What causes it: The SCIM bulk response omits the location field when the conflict occurs during a POST that cannot resolve the target resource ID.
  • How to fix it: Query the user by userName using the SCIM filter endpoint before attempting the merge.
  • Code showing the fix:
def resolve_user_id_by_username(client: ScimApi, username: str) -> str:
    url = f"{client._base_url}/api/v2/scim/v2/Users"
    params = {"filter": f"userName eq \"{username}\"", "count": "1"}
        res = session.get(url, headers=headers, params=params)
        raise httpx.HTTPStatusError("Username lookup failed", request=res.request, response=res)
    resources = res.json().get("Resources", [])
    if not resources:
        raise ValueError(f"User {username} not found in directory")
    return resources[0]["id"]
Error: 400 Bad Request during PUT retry
  • What causes it: The merged payload includes read-only fields like id, meta, or externalId. Genesys Cloud rejects bulk PUT operations that attempt to modify immutable attributes.
  • How to fix it: Strip all protected fields before constructing the retry operation. The merge_user function in Step 2 demonstrates this pattern.
  • Code showing the fix: Refer to the merge_scim_user function in Step 2. It explicitly removes id, meta, externalId, and manager before submission.
Error: 429 Too Many Requests during retry cascade
  • What causes it: Multiple workers retry conflicts simultaneously without jitter, exceeding the SCIM bulk rate limit of 10 requests per second per client ID.
  • How to fix it: Increase the base_delay parameter and widen the jitter_range. Implement a circuit breaker that pauses all retries when consecutive 429 responses occur.
def circuit_breaker_backoff(attempt: int, consecutive_429s: int) -> float:
    """Dramatically increase delay when 429s cascade."""
    base = 1.0 if consecutive_429s < 2 else 10.0
    return min(base * (2 ** attempt), 120.0) + random.uniform(0, 5.0)
Error: 401 Unauthorized after token expiration
  • What causes it: The SDK cache expires during a long retry loop. The httpx client does not automatically refresh tokens.
  • How to fix it: Call client._auth.login() before each retry batch, or wrap the HTTP calls in a token refresh decorator. The SDK’s ClientCredentialsAuth handles sliding refresh when you call get_access_token(), but explicit re-authentication guarantees validity.
  • Code showing the fix: Add client._auth.login() at the start of the retry loop in process_bulk_conflicts.
