Handling NICE CXone Pure Connect IVR DTMF Collection Timeouts via Pure Connect APIs with Node.js
- A Node.js module that programmatically configures DTMF collection timeout behavior, reset directives, and fallback routing in CXone IVR flows.
- Uses the CXone Flows API and OAuth 2.0 Client Credentials flow.
- Covers JavaScript/Node.js with explicit HTTP request/response cycles, schema validation, atomic updates, and webhook synchronization.
- CXone OAuth Client configured for Confidential/Client Credentials flow
- Required OAuth scopes:
flow:read flow:write webhook:read webhook:write analytics:read - CXone API Base URL:
https://api-us-02.nice-incontact.com(adjust for your region) - Runtime: Node.js 18 LTS or higher
- Dependencies:
axios,dotenv,uuid
CXone requires OAuth 2.0 Client Credentials authentication. The following module handles token acquisition, caching, and automatic refresh before expiration.
// auth.js
import axios from 'axios';
import dotenv from 'dotenv';
dotenv.config();
const CXONE_BASE = process.env.CXONE_BASE_URL || 'https://api-us-02.nice-incontact.com';
const CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
let cachedToken = null;
let tokenExpiryTimestamp = 0;
* Acquires an OAuth 2.0 access token with required scopes.
* Implements in-memory caching and early refresh to prevent mid-request 401 errors.
export async function getAccessToken() {
if (cachedToken && Date.now() < tokenExpiryTimestamp) {
return cachedToken;
const oauthResponse = await axios.post(`${CXONE_BASE}/oauth2/token`, null, {
params: {
client_id: CLIENT_ID,
client_secret: CLIENT_SECRET,
scope: 'flow:read flow:write webhook:read webhook:write analytics:read'
headers: {
'Content-Type': 'application/x-www-form-urlencoded'
cachedToken = oauthResponse.data.access_token;
// Refresh 120 seconds before actual expiry to account for clock drift
tokenExpiryTimestamp = Date.now() + (oauthResponse.data.expires_in * 1000) - 120000;
return cachedToken;
Step 1: Initialize SDK and Fetch Target Flow
Retrieve the current IVR flow to establish a baseline for modification. The platformClient SDK handles initialization, but raw axios calls expose the full HTTP cycle required for debugging.
// flow-fetch.js
import { getAccessToken } from './auth.js';
* Fetches a CXone IVR flow by ID.
* Required Scope: flow:read
export async function fetchFlow(flowId) {
const token = await getAccessToken();
const url = `${process.env.CXONE_BASE_URL}/api/v2/flows/${flowId}`;
const response = await axios.get(url, {
headers: {
'Accept': 'application/json'
// HTTP Response Cycle
// Method: GET
// Path: /api/v2/flows/{flowId}
// Headers: Authorization: Bearer <token>, Accept: application/json
// Status: 200 OK
// Body: { id: "...", version: 42, blocks: { ... }, startNodeId: "start" }
return response.data;
} catch (error) {
if (error.response) {
switch (error.response.status) {
case 401:
throw new Error('Authentication failed. Verify client credentials and token expiration.');
case 403:
throw new Error('Forbidden. Ensure the OAuth client has flow:read scope.');
case 404:
throw new Error(`Flow with ID ${flowId} not found.`);
default:
throw new Error(`CXone API Error ${error.response.status}: ${error.response.data.message}`);
throw error;
Step 2: Construct Handling Payloads with Timeout Matrix and Reset Directives
DTMF collection blocks require explicit timeout configuration, reset behavior, and fallback routing. The payload must reference existing audio prompts and define a timeout matrix that scales with input length.
// payload-builder.js
* Constructs a DTMF collection block configuration with timeout matrix, reset directive,
* audio pausing, and fallback routing.
export function buildDtmfCollectionBlock(blockId, promptId, maxDigits, timeoutMs, fallbackNodeId) {
const timeoutMatrix = [];
// Build progressive timeout matrix: base timeout increases by 500ms per expected digit
for (let i = 1; i <= maxDigits; i++) {
timeoutMatrix.push({
digitCount: i,
timeout: timeoutMs + (i * 500)
type: 'CollectInput',
properties: {
dtmfInput: {
maxDigits: maxDigits,
minDigits: 1,
validDigits: '0123456789#*',
resetOnTimeout: true,
resetOnInvalid: false,
timeoutMatrix: timeoutMatrix,
audioPrompt: {
playOnReset: true,
pauseAudioOnInput: true
fallback: {
onTimeout: fallbackNodeId,
onInvalid: fallbackNodeId,
onMaxDigits: 'processInputNode'
echoSuppression: {
enabled: true,
carrierMode: 'adaptive',
suppressionThresholdDb: 20
digitValidation: {
regex: '^[0-9]{1,16}$',
strictMode: true
Step 3: Validate Schemas Against Telephony Constraints and Buffer Limits
Telephony gateways enforce strict DTMF buffer limits. The validation pipeline checks buffer capacity, echo suppression configuration, and digit regex compliance before submission.
// validator.js
const MAX_DTMF_BUFFER = 16;
const VALID_DIGIT_CHARS = /^[0-9#*]+$/;
* Validates a DTMF collection block against CXone telephony constraints.
export function validateDtmfBlock(block) {
const props = block.properties.dtmfInput;
const errors = [];
// Buffer limit validation
if (props.maxDigits > MAX_DTMF_BUFFER) {
errors.push(`DTMF buffer limit exceeded. Maximum allowed is ${MAX_DTMF_BUFFER} digits. Requested: ${props.maxDigits}.`);
// Digit validation pipeline
if (!VALID_DIGIT_CHARS.test(props.validDigits)) {
errors.push('Invalid character set in validDigits. Only 0-9, #, and * are permitted.');
// Echo suppression verification
if (props.echoSuppression.enabled && !props.echoSuppression.carrierMode) {
errors.push('Carrier echo suppression is enabled but carrierMode is not specified.');
// Timeout matrix integrity
if (!Array.isArray(props.timeoutMatrix) || props.timeoutMatrix.length === 0) {
errors.push('Timeout matrix must be a non-empty array.');
// Regex validation
new RegExp(props.digitValidation.regex);
} catch {
errors.push('Digit validation regex is malformed.');
if (errors.length > 0) {
throw new Error('Schema validation failed:\n' + errors.join('\n'));
return true;
Step 4: Execute Atomic PUT Operations with Retry and Format Verification
CXone requires optimistic locking via the If-Match header. The update function implements exponential backoff for 429 rate limits and verifies the response format before proceeding.
// flow-updater.js
* Updates a flow with exponential backoff retry logic for 429 responses.
* Required Scope: flow:write
export async function updateFlowAtomically(flowId, flowPayload, maxRetries = 3) {
const currentVersion = flowPayload.version;
for (let attempt = 1; attempt <= maxRetries; attempt++) {
const response = await axios.put(url, flowPayload, {
headers: {
'If-Match': `"${currentVersion}"`,
// Format verification
if (!response.data.id || !response.data.version) {
throw new Error('Response format verification failed. Missing id or version in payload.');
} catch (error) {
if (error.response.status === 429) {
const retryAfter = error.response.headers['retry-after'] || Math.pow(2, attempt);
console.warn(`Rate limited (429). Retrying in ${retryAfter}s (Attempt ${attempt}/${maxRetries})`);
await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
continue;
if (error.response.status === 412) {
throw new Error('Precondition failed. Flow version mismatch. Fetch latest version and retry.');
if (error.response.status === 409) {
throw new Error('Conflict. Another process modified the flow. Retry with latest version.');
throw error;
throw new Error('Max retries exceeded for flow update.');
Step 5: Synchronize Handling Events via Webhooks and Track Latency
External analytics systems require event synchronization. The webhook registration captures timeout events, while a metrics collector tracks latency and reset success rates.
// webhook-sync.js
* Registers a webhook for DTMF timeout events.
* Required Scope: webhook:write
export async function registerTimeoutWebhook(targetUrl) {
const url = `${process.env.CXONE_BASE_URL}/api/v2/webhooks`;
const webhookPayload = {
type: 'post',
targetUrl: targetUrl,
authentication: {
type: 'none'
events: [
'flow:node:timeout',
'flow:node:reset',
'flow:input:invalid'
filter: {
expression: 'event.type == "flow:node:timeout" && event.blockType == "CollectInput"'
enabled: true
const response = await axios.post(url, webhookPayload, {
headers: {
* Tracks handling latency and reset success rates.
export class HandlingMetricsTracker {
constructor() {
this.latencies = [];
this.resets = { success: 0, failure: 0 };
recordLatency(durationMs) {
this.latencies.push(durationMs);
if (this.latencies.length > 1000) {
this.latencies.shift(); // Maintain rolling window
recordReset(success) {
if (success) this.resets.success++;
else this.resets.failure++;
getStats() {
const avgLatency = this.latencies.length > 0
? this.latencies.reduce((a, b) => a + b, 0) / this.latencies.length
: 0;
const successRate = this.resets.success + this.resets.failure > 0
? (this.resets.success / (this.resets.success + this.resets.failure)) * 100
: 0;
averageLatencyMs: parseFloat(avgLatency.toFixed(2)),
resetSuccessRate: parseFloat(successRate.toFixed(2)),
totalResets: this.resets.success + this.resets.failure
Step 6: Generate Audit Logs and Expose Timeout Handler
Governance requires immutable audit trails. The handler exports a unified function that orchestrates validation, update, webhook registration, and audit logging.
// audit-logger.js
import fs from 'fs/promises';
import path from 'path';
import { fileURLToPath } from 'url';
const __dirname = path.dirname(fileURLToPath(import.meta.url));
const AUDIT_LOG_PATH = path.join(__dirname, 'dtmf-handling-audit.log');
export async function appendAuditLog(action, flowId, details) {
const timestamp = new Date().toISOString();
const logEntry = `[${timestamp}] ACTION: ${action} | FLOW: ${flowId} | DETAILS: ${JSON.stringify(details)}\n`;
await fs.appendFile(AUDIT_LOG_PATH, logEntry, 'utf8');
The following module integrates all components into a single executable handler. Replace environment variables with your CXone credentials.
// dtmf-timeout-handler.js
dotenv.config();
import { fetchFlow } from './flow-fetch.js';
import { buildDtmfCollectionBlock } from './payload-builder.js';
import { validateDtmfBlock } from './validator.js';
import { updateFlowAtomically } from './flow-updater.js';
import { registerTimeoutWebhook, HandlingMetricsTracker } from './webhook-sync.js';
import { appendAuditLog } from './audit-logger.js';
const FLOW_ID = process.env.CXONE_FLOW_ID;
const WEBHOOK_URL = process.env.EXTERNAL_ANALYTICS_URL;
* Main handler for automated NICE CXone DTMF timeout management.
* Validates, updates, registers webhooks, and generates audit logs.
export async function handleDtmfTimeoutConfiguration() {
const metrics = new HandlingMetricsTracker();
const startTime = Date.now();
// Step 1: Fetch current flow
console.log('Fetching flow...');
const flow = await fetchFlow(FLOW_ID);
await appendAuditLog('FETCH_FLOW', FLOW_ID, { version: flow.version });
// Step 2: Construct handling payload
console.log('Constructing DTMF collection block...');
const dtmfBlock = buildDtmfCollectionBlock(
'dtmf_collection_001',
'prompt_enter_extension',
8,
3000,
'fallback_to_agent'
// Step 3: Validate against telephony constraints
console.log('Validating schema...');
validateDtmfBlock(dtmfBlock);
// Step 4: Merge block into flow and execute atomic PUT
console.log('Updating flow atomically...');
flow.blocks[dtmfBlock.id] = dtmfBlock;
flow.version = flow.version + 1; // Increment version for optimistic locking
const updatedFlow = await updateFlowAtomically(FLOW_ID, flow);
const updateLatency = Date.now() - startTime;
metrics.recordLatency(updateLatency);
metrics.recordReset(true);
await appendAuditLog('UPDATE_FLOW', FLOW_ID, {
newVersion: updatedFlow.version,
latencyMs: updateLatency
// Step 5: Register webhook for external analytics sync
console.log('Registering timeout webhook...');
const webhook = await registerTimeoutWebhook(WEBHOOK_URL);
await appendAuditLog('REGISTER_WEBHOOK', FLOW_ID, { webhookId: webhook.id });
console.log('Configuration complete.');
console.log('Metrics:', metrics.getStats());
return { success: true, flow: updatedFlow, webhook };
} catch (error) {
const failureLatency = Date.now() - startTime;
metrics.recordLatency(failureLatency);
metrics.recordReset(false);
await appendAuditLog('HANDLER_FAILURE', FLOW_ID, {
error: error.message,
latencyMs: failureLatency
throw error;
// Execute when run directly
if (import.meta.url === `file://${process.argv[1]}`) {
handleDtmfTimeoutConfiguration().catch(err => {
console.error('Handler failed:', err);
process.exit(1);
- What causes it: Expired OAuth token, invalid client credentials, or missing
flow:writescope. - How to fix it: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETmatch the registered OAuth client. Ensure the token cache refreshes 120 seconds before expiration. Revoke and regenerate client secrets if rotated. - Code showing the fix: The
getAccessTokenfunction implements early refresh. If authentication fails during a PUT, the error handler throws a descriptive message prompting credential verification.
Error: 412 Precondition Failed
- What causes it: Version mismatch during atomic update. Another process modified the flow between fetch and update.
- How to fix it: Fetch the latest flow version, reapply the DTMF block configuration, and retry the PUT with the updated
If-Matchheader. - Code showing the fix: Implement a retry wrapper that calls
fetchFlow(FLOW_ID)again when status 412 is received, then recalculatesflow.versionbefore the next PUT attempt.
- What causes it: Rate limit cascade across CXone microservices.
- How to fix it: Implement exponential backoff with jitter. Respect the
Retry-Afterheader if present. - Code showing the fix: The
updateFlowAtomicallyfunction catches 429 status codes, calculates backoff duration usingMath.pow(2, attempt), and retries up tomaxRetriestimes before failing.
Error: Schema Validation Failed (Buffer Limit)
- What causes it:
maxDigitsexceeds the telephony gateway limit of 16. - How to fix it: Reduce
maxDigitsto 16 or implement progressive collection with multiple nodes. - Code showing the fix: The
validateDtmfBlockfunction explicitly checksprops.maxDigits > MAX_DTMF_BUFFERand throws a structured error before any API call.
