Handling NICE Cognigy.AI Webhook Timeouts with Python: Resilient Payload Construction, Circuit Breakers, and Latency Governance
  • A FastAPI webhook service that receives Cognigy.AI dialogue triggers, validates payloads against strict latency and schema constraints, and returns correlation-tracked responses with retry directives.
  • An integrated circuit breaker, atomic acknowledgment pipeline, and audit logging system that prevents dialogue stalls during platform scaling.
  • Python code using FastAPI, httpx, pydantic, and structlog to enforce timeout recovery, track latency metrics, and synchronize with external error tracking services.
  • Python 3.10 or higher
  • fastapi, uvicorn, httpx, pydantic, structlog, pydantic-settings
  • Cognigy.AI platform trigger configured to POST to your public endpoint
  • No OAuth scopes required for inbound Cognigy.AI webhooks. Inbound authentication uses HMAC signature verification or IP allowlisting.
  • External error tracking endpoint (e.g., Datadog, Sentry, or internal metrics API) for callback synchronization
Cognigy.AI does not use OAuth for inbound webhook delivery. The platform authenticates requests using a shared secret HMAC signature or IP allowlisting. The following code implements HMAC-SHA256 signature verification to guarantee payload integrity before processing.
import hashlib
import hmac
from typing import Optional
from fastapi import FastAPI, Request, HTTPException, Header
import structlog
# Shared secret configured in Cognigy.AI trigger settings
WEBHOOK_SECRET = "your-cognigy-shared-secret-hex"
def verify_hmac_signature(payload: bytes, signature: str, timestamp: Optional[str] = None) -> bool:
    """Validate HMAC signature against shared secret. Rejects stale requests older than 300 seconds."""
    if not signature:
        return False
    expected = hmac.new(WEBHOOK_SECRET.encode(), payload, hashlib.sha256).hexdigest()
    if not hmac.compare_digest(expected, signature):
        return False
    if timestamp:
        request_age = time.time() - int(timestamp)
        if request_age > 300:
            return False
    return True
Step 1: Define Request/Response Schemas and Latency Constraints
Cognigy.AI expects a response within five seconds. You must validate the incoming payload structure, enforce a maximum processing latency, and return a strictly typed response. The following Pydantic models define the inbound trigger, outbound acknowledgment, and retry directive.
from datetime import datetime
class CognigyTriggerPayload(BaseModel):
    conversationId: str
    sessionId: str
    trigger: str
    data: Dict[str, Any]
    timestamp: int
    correlationId: Optional[str] = None
class RetryDirective(BaseModel):
    retry: bool
    retryAfterSeconds: int
    reason: str
class WebhookResponse(BaseModel):
    correlationId: str
    status: str
    timestamp: datetime
    retry: Optional[RetryDirective] = None
    latencyMs: float
class TimeoutRecoveryPayload(BaseModel):
    acknowledged: bool
    correlationId: str
    recoveryQueueId: str
    status: str
The timeout engine constraint requires rejecting payloads that exceed a defined latency threshold before processing. The validation pipeline checks serialization integrity and connection pool health before accepting the request.
Step 2: Build the Circuit Breaker and Connection Pool Verification Pipeline
You must prevent cascade failures when downstream systems degrade. The following circuit breaker implementation tracks consecutive failures, open state duration, and half-open probing. The connection pool verification ensures httpx clients remain healthy before outbound calls.
import httpx
import threading
from enum import Enum
class CircuitState(Enum):
    CLOSED = "closed"
    OPEN = "open"
    HALF_OPEN = "half_open"
class CircuitBreaker:
    def __init__(self, failure_threshold: int = 5, recovery_timeout: float = 30.0):
        self.state = CircuitState.CLOSED
        self.failure_count = 0
        self.failure_threshold = failure_threshold
        self.recovery_timeout = recovery_timeout
        self.last_failure_time = 0.0
        self.lock = threading.Lock()
        self.success_count_half_open = 0
    def can_execute(self) -> bool:
        with self.lock:
            if self.state == CircuitState.CLOSED:
                return True
            if self.state == CircuitState.OPEN:
                if time.time() - self.last_failure_time >= self.recovery_timeout:
                    self.state = CircuitState.HALF_OPEN
                    return True
                return False
            if self.state == CircuitState.HALF_OPEN:
                return True
        return False
    def record_success(self) -> None:
        with self.lock:
                self.success_count_half_open += 1
                if self.success_count_half_open >= 3:
            else:
    def record_failure(self) -> None:
        with self.lock:
            self.failure_count += 1
            self.last_failure_time = time.time()
                self.state = CircuitState.OPEN
            elif self.failure_count >= self.failure_threshold:
class ConnectionPoolVerifier:
    def __init__(self, client: httpx.AsyncClient):
        self.client = client
        self.health_endpoint = "https://httpbin.org/status/200"
    async def verify_pool(self) -> bool:
            resp = await self.client.get(self.health_endpoint, timeout=2.0)
            return resp.status_code == 200
        except Exception:
            return False
Step 3: Implement the Webhook Handler with Timeout Recovery and Audit Logging
The core endpoint validates the signature, checks the circuit breaker, measures latency, and returns a structured response. If processing exceeds the maximum latency limit, the handler switches to an atomic acknowledgment pattern, queues the payload for async recovery, and returns a retry directive. External error tracking callbacks are synchronized via httpx.
import asyncio
import uuid
from fastapi.responses import JSONResponse
import httpx
import structlog
app = FastAPI(title="Cognigy.AI Webhook Timeout Handler")
# Configuration constants
MAX_LATENCY_MS = 4500.0
CIRCUIT_BREAKER = CircuitBreaker(failure_threshold=4, recovery_timeout=25.0)
ERROR_TRACKING_URL = "https://metrics.internal/api/v1/ingest"
# Metrics tracking
latency_metrics: Dict[str, list] = {"request_ms": [], "recovery_success": 0, "recovery_total": 0}
async def send_error_callback(payload: Dict[str, Any]) -> None:
    """Synchronize handling events with external error tracking services."""
    async with httpx.AsyncClient(timeout=3.0) as client:
            await client.post(ERROR_TRACKING_URL, json=payload)
            logger.error("error_callback_failed", error=str(e))
async def process_payload_async(payload: CognigyTriggerPayload) -> None:
    """Simulate downstream processing that may exceed timeout constraints."""
    await asyncio.sleep(0.5)
    logger.info("payload_processed", correlationId=payload.correlationId, sessionId=payload.sessionId)
@app.post("/webhook/cognigy")
async def handle_cognigy_webhook(
    request: Request,
    x_hmac_signature: Optional[str] = Header(None),
    x_request_timestamp: Optional[str] = Header(None)
    start_time = time.time()
    raw_body = await request.body()
    # Authentication verification
    if not verify_hmac_signature(raw_body, x_hmac_signature or "", x_request_timestamp):
        raise HTTPException(status_code=401, detail="Invalid HMAC signature or stale request")
    # Payload serialization checking
        trigger = CognigyTriggerPayload(**raw_body.decode("utf-8"))
        logger.warning("schema_validation_failed", error=str(e))
        return JSONResponse(status_code=400, content={"status": "invalid_schema", "error": str(e)})
    correlation_id = trigger.correlationId or str(uuid.uuid4())
    # Circuit breaker evaluation
    if not CIRCUIT_BREAKER.can_execute():
            status_code=503,
            content={
                "correlationId": correlation_id,
                "status": "circuit_breaker_open",
                "retry": {"retry": True, "retryAfterSeconds": int(CIRCUIT_BREAKER.recovery_timeout), "reason": "downstream_degraded"}
    # Connection pool verification pipeline
    pool_verifier = ConnectionPoolVerifier(httpx.AsyncClient())
    if not await pool_verifier.verify_pool():
        CIRCUIT_BREAKER.record_failure()
        return JSONResponse(status_code=503, content={"status": "connection_pool_unhealthy", "correlationId": correlation_id})
    # Latency enforcement and timeout recovery
    processing_time_ms = (time.time() - start_time) * 1000
    if processing_time_ms > MAX_LATENCY_MS:
        latency_metrics["recovery_total"] += 1
        recovery_id = str(uuid.uuid4())
        # Atomic acknowledgment operation
        ack_payload = TimeoutRecoveryPayload(acknowledged=True, correlationId=correlation_id, recoveryQueueId=recovery_id, status="timeout_recovered")
        latency_metrics["recovery_success"] += 1
        # Synchronize with external tracking
        await send_error_callback({"type": "timeout_recovery", "correlationId": correlation_id, "recoveryId": recovery_id, "latencyMs": processing_time_ms})
            status_code=202,
            content={
                "status": "acknowledged_async",
                "timestamp": datetime.utcnow().isoformat(),
                "retry": {"retry": False, "retryAfterSeconds": 0, "reason": "async_recovery_queued"},
                "latencyMs": round(processing_time_ms, 2)
    # Normal execution path
        await process_payload_async(trigger)
        CIRCUIT_BREAKER.record_success()
        logger.error("processing_failed", correlationId=correlation_id, error=str(e))
        await send_error_callback({"type": "processing_failure", "correlationId": correlation_id, "error": str(e)})
            status_code=500,
            content={"correlationId": correlation_id, "status": "processing_error", "retry": {"retry": True, "retryAfterSeconds": 5, "reason": "internal_error"}}
    final_latency = (time.time() - start_time) * 1000
    latency_metrics["request_ms"].append(final_latency)
    # Audit log generation
    logger.info(
        "webhook_handled",
        sessionId=trigger.sessionId,
        status="success",
        latencyMs=round(final_latency, 2),
        circuitState=CIRCUIT_BREAKER.state.value
        status_code=200,
        content={
            "status": "success",
            "latencyMs": round(final_latency, 2)
The following script combines authentication, schema validation, circuit breaking, latency governance, and audit logging into a single deployable module. Run it with uvicorn main:app --host 0.0.0.0 --port 8000.
import uuid
import asyncio
import hashlib
import hmac
from typing import Dict, Optional
import httpx
import structlog
# Logging configuration
structlog.configure(
    processors=[
        structlog.stdlib.filter_by_level,
        structlog.stdlib.add_logger_name,
        structlog.stdlib.add_log_level,
        structlog.stdlib.PositionalArgumentsFormatter(),
        structlog.processors.TimeStamper(fmt="iso"),
        structlog.processors.StackInfoRenderer(),
        structlog.processors.format_exc_info,
        structlog.processors.JSONRenderer()
    context_class=dict,
    logger_factory=structlog.stdlib.LoggerFactory(),
    wrapper_class=structlog.stdlib.BoundLogger,
    cache_logger_on_first_use=True,
# Configuration
    conversationId: str
    sessionId: str
    trigger: str
    data: dict
    timestamp: int
    CLOSED = "closed"
    OPEN = "open"
        self.lock = asyncio.Lock()
    async def can_execute(self) -> bool:
        async with self.lock:
                return True
                    return True
                return False
            return self.state == CircuitState.HALF_OPEN
    async def record_success(self) -> None:
            else:
    async def record_failure(self) -> None:
CIRCUIT_BREAKER = CircuitBreaker()
    if not signature:
        return False
        return False
    if timestamp:
            return False
    return True
async def send_error_callback(payload: dict) -> None:
    await asyncio.sleep(0.2)
    request: Request,
    if not await CIRCUIT_BREAKER.can_execute():
            status_code=503,
            content={
            status_code=202,
            content={
        await CIRCUIT_BREAKER.record_success()
        await CIRCUIT_BREAKER.record_failure()
            status_code=500,
    logger.info("webhook_handled", correlationId=correlation_id, sessionId=trigger.sessionId, status="success", latencyMs=round(final_latency, 2), circuitState=CIRCUIT_BREAKER.state.value)
        status_code=200,
        content={
Error: 401 Unauthorized / Invalid HMAC Signature
  • What causes it: The x-hmac-signature header does not match the SHA256 digest of the payload combined with your shared secret, or the request timestamp exceeds the 300-second tolerance window.
  • How to fix it: Verify the shared secret in the Cognigy.AI trigger configuration matches WEBHOOK_SECRET in your code. Ensure the client sends the exact raw body bytes used for signature generation.
  • Code showing the fix: The verify_hmac_signature function rejects mismatched signatures and stale timestamps before schema parsing.
Error: 408 Request Timeout / 504 Gateway Timeout
  • What causes it: Downstream processing exceeds Cognigy.AI platform timeout constraints. The platform drops the connection before receiving a valid HTTP response.
  • How to fix it: Return a 202 Accepted response immediately upon schema validation. Queue the payload for asynchronous processing. The implementation switches to atomic acknowledgment when processing_time_ms exceeds MAX_LATENCY_MS.
  • Code showing the fix: The latency check triggers the 202 response path with a retry directive and recovery queue ID.
Error: 503 Service Unavailable (Circuit Breaker Open)
  • What causes it: Consecutive failures or high latency trip the circuit breaker to the OPEN state. The endpoint refuses new requests to prevent cascade failure.
  • How to fix it: Wait for the recovery_timeout period. The breaker transitions to HALF_OPEN and allows probe requests. Successful probes close the circuit.
  • Code showing the fix: CircuitBreaker.can_execute() enforces state transitions. The response includes retryAfterSeconds to guide the caller.
Error: 400 Bad Request / Schema Validation Failed
  • What causes it: The incoming JSON does not match the CognigyTriggerPayload model. Missing required fields or incorrect types trigger Pydantic validation errors.
  • How to fix it: Inspect the raw request body in Cognigy.AI trigger logs. Ensure all required fields (conversationId, sessionId, trigger, data, timestamp) are present and correctly typed.
  • Code showing the fix: The try/except block around CognigyTriggerPayload(**raw_body.decode("utf-8")) catches serialization errors and returns a structured 400 response.
