Handling Genesys Cloud Webhook Failures with a Python Dead Letter Queue
- A Python service that intercepts failed Genesys Cloud webhooks, stores them in a durable queue, and retries delivery with exponential backoff.
- This solution uses the Genesys Cloud Platform API to verify webhook health and standard HTTP libraries for the retry logic.
- The tutorial covers Python 3.9+ using
httpxfor async HTTP handling andsqlite3as a simple persistent dead letter store.
- OAuth Client: A Genesys Cloud OAuth Client with
webhooks:readandwebhooks:writescopes. - SDK/API Version: Genesys Cloud API v2.
- Language/Runtime: Python 3.9 or higher.
- External Dependencies:
httpxfor asynchronous HTTP requests.aiohttp(optional, for the local webhook receiver).pydanticfor data validation.
Install dependencies:
pip install httpx pydantic aiohttp
Genesys Cloud uses OAuth 2.0 for API access. For a background service handling retries, the Client Credentials flow is the most robust pattern because it does not require user interaction and tokens can be refreshed programmatically.
You must store your client_id and client_secret securely. In production, use environment variables or a secrets manager.
Python OAuth Token Manager
This class handles fetching and caching the access token. It automatically handles the expiration logic, ensuring your retry service never sends requests with an expired token.
import os
import httpx
from typing import Optional
class GenesysOAuthManager:
def __init__(self, client_id: str, client_secret: str, region: str = "us-east-1"):
self.client_id = client_id
# Determine the base URL based on region
if region == "us-east-1":
self.base_url = "https://api.mypurecloud.com"
elif region == "eu-west-1":
self.base_url = "https://api.eu.mypurecloud.com"
else:
raise ValueError(f"Unsupported region: {region}")
self.token_expiry: float = 0
self.client = httpx.AsyncClient()
Returns a valid access token. Fetches a new one if expired or missing.
now = time.time()
# Refresh if token is missing or expired (buffer of 60 seconds)
if not self.access_token or now >= (self.token_expiry - 60):
await self._refresh_token()
return self.access_token
async def _refresh_token(self):
Performs the OAuth Client Credentials grant.
url = f"{self.base_url}/oauth/token"
headers = {
data = {
"client_id": self.client_id,
response = await self.client.post(url, headers=headers, data=data)
response.raise_for_status()
token_data = response.json()
# expires_in is in seconds
self.token_expiry = now + token_data["expires_in"]
# Handle 401 Unauthorized (invalid credentials) or 400 Bad Request
raise Exception(f"OAuth Token Refresh Failed: {e.response.status_code} - {e.response.text}") from e
Step 1: Define the Dead Letter Queue Structure
When a webhook delivery fails (5xx error from the target endpoint), Genesys Cloud may retry a few times before marking the webhook as failed. If you are building a custom ingestion service that acts as the webhook receiver, you need to handle these failures locally before they reach Genesys.
We will use a lightweight SQLite database to store failed payloads. This ensures durability if the process restarts.
import sqlite3
import json
import asyncio
from dataclasses import dataclass, asdict
@dataclass
class WebhookPayload:
webhook_id: str
event_type: str
payload: Dict[str, Any]
timestamp: float
retry_count: int = 0
last_error: Optional[str] = None
class DeadLetterQueue:
def __init__(self, db_path: str = "dlq.db"):
self.db_path = db_path
self._init_db()
def _init_db(self):
with sqlite3.connect(self.db_path) as conn:
cursor = conn.cursor()
cursor.execute('''
CREATE TABLE IF NOT EXISTS failed_webhooks (
id INTEGER PRIMARY KEY AUTOINCREMENT,
webhook_id TEXT NOT NULL,
event_type TEXT NOT NULL,
payload TEXT NOT NULL,
timestamp REAL NOT NULL,
retry_count INTEGER DEFAULT 0,
last_error TEXT,
status TEXT DEFAULT 'pending'
conn.commit()
def add_failure(self, payload: WebhookPayload):
"""Insert a failed webhook into the DLQ."""
cursor.execute('''
INSERT INTO failed_webhooks
(webhook_id, event_type, payload, timestamp, retry_count, last_error, status)
VALUES (?, ?, ?, ?, ?, ?, 'pending')
payload.webhook_id,
payload.event_type,
json.dumps(payload.payload),
payload.timestamp,
payload.retry_count,
payload.last_error
conn.commit()
async def get_pending_batch(self, batch_size: int = 10) -> List[WebhookPayload]:
"""Retrieve pending webhooks for retry processing."""
conn.row_factory = sqlite3.Row
cursor.execute('''
SELECT * FROM failed_webhooks
WHERE status = 'pending'
ORDER BY timestamp ASC
LIMIT ?
''', (batch_size,))
rows = cursor.fetchall()
results = []
for row in rows:
results.append(WebhookPayload(
webhook_id=row['webhook_id'],
event_type=row['event_type'],
payload=json.loads(row['payload']),
timestamp=row['timestamp'],
retry_count=row['retry_count'],
last_error=row['last_error']
return results
def mark_successful(self, webhook_id: str):
"""Mark a webhook as successfully processed after retry."""
cursor.execute('''
UPDATE failed_webhooks
SET status = 'success'
WHERE webhook_id = ? AND status = 'pending'
''', (webhook_id,))
conn.commit()
def update_failure(self, webhook_id: str, error: str, retry_count: int):
"""Update a webhook that failed again during retry."""
cursor.execute('''
SET last_error = ?, retry_count = ?, status = 'pending'
''', (error, retry_count, webhook_id))
conn.commit()
Step 2: Implement Exponential Backoff Retry Logic
The core of the solution is the retry loop. When a webhook fails, you should not retry immediately. Use exponential backoff with jitter to prevent thundering herd problems and to give the downstream service time to recover.
The formula for delay is: base_delay * (2 ^ retry_count) + random_jitter.
import random
async def retry_webhook_delivery(
dlq: DeadLetterQueue,
payload: WebhookPayload,
target_url: str,
max_retries: int = 5
Attempts to redeliver a failed webhook with exponential backoff.
current_retry = payload.retry_count
if current_retry >= max_retries:
print(f"Max retries ({max_retries}) exceeded for webhook {payload.webhook_id}. Moving to permanent failure.")
dlq.update_failure(payload.webhook_id, "Max retries exceeded", current_retry)
return
# Calculate backoff delay
# Base delay of 1 second, doubling each time
base_delay = 1
delay = base_delay * (2 ** current_retry)
# Add jitter (0 to 1 second) to prevent synchronized retries
jitter = random.uniform(0, 1)
total_delay = delay + jitter
print(f"Retrying webhook {payload.webhook_id} (Attempt {current_retry + 1}/{max_retries}). Waiting {total_delay:.2f}s...")
await asyncio.sleep(total_delay)
# Perform the retry
async with httpx.AsyncClient() as client:
response = await client.post(
target_url,
json=payload.payload,
headers={"Content-Type": "application/json"},
timeout=10.0
if 200 <= response.status_code < 300:
print(f"Retry successful for webhook {payload.webhook_id}.")
dlq.mark_successful(payload.webhook_id)
else:
# If it fails again, update the DLQ with the new error
error_msg = f"HTTP {response.status_code}: {response.text[:100]}"
dlq.update_failure(payload.webhook_id, error_msg, current_retry + 1)
print(f"Retry failed for webhook {payload.webhook_id}: {error_msg}")
# Network error, timeout, etc.
error_msg = f"Connection error: {str(e)}"
print(f"Network error during retry for webhook {payload.webhook_id}: {error_msg}")
Step 3: The Webhook Ingestion Receiver
This component listens for incoming webhooks from Genesys Cloud. If the downstream consumer (your business logic) fails, this receiver catches the exception and pushes the payload to the Dead Letter Queue instead of returning a 5xx to Genesys.
Returning a 200 OK to Genesys immediately acknowledges receipt. This shifts the responsibility of reliability from Genesys Cloud to your local service. This is a critical pattern for high-throughput systems.
from aiohttp import web
import json
async def webhook_receiver(request: web.Request, dlq: DeadLetterQueue):
Receives webhooks from Genesys Cloud.
Always returns 200 OK to acknowledge receipt to Genesys.
Processes the payload asynchronously or pushes to DLQ if processing fails.
body = await request.json()
# Extract metadata from Genesys Cloud webhook envelope
# Note: Structure depends on the specific webhook type (e.g., Routing, Conversations)
webhook_id = body.get("webhookId", "unknown")
event_type = body.get("eventType", "unknown")
payload_obj = WebhookPayload(
webhook_id=webhook_id,
event_type=event_type,
payload=body,
timestamp=time.time()
# Simulate downstream processing
# In a real app, this might call a database or another microservice
await process_business_logic(payload_obj)
return web.Response(status=200, text="OK")
# Processing failed. Do NOT return 5xx to Genesys.
# Instead, save to DLQ for later retry.
print(f"Downstream processing failed: {str(e)}")
webhook_id=body.get("webhookId", "unknown"),
event_type=body.get("eventType", "unknown"),
payload=body,
timestamp=time.time(),
last_error=str(e)
dlq.add_failure(payload_obj)
# Return 200 to Genesys so it stops retrying
async def process_business_logic(payload: WebhookPayload):
Simulates business logic that might fail.
# Example: Simulate a random failure for demonstration
if random.random() < 0.3:
raise Exception("Simulated downstream database timeout")
# Normal processing
print(f"Processed event: {payload.event_type}")
Combine the components into a single runnable script. This script starts an HTTP server to receive webhooks and runs a background task that periodically checks the Dead Letter Queue and retries failed deliveries.
import asyncio
import os
import sys
# Import classes defined in previous steps
# In a real project, these would be in separate modules
# from auth import GenesysOAuthManager
# from dlq import DeadLetterQueue, WebhookPayload
# from retry import retry_webhook_delivery
# from receiver import webhook_receiver
# --- Consolidated Code for Copy-Pasteability ---
# [Insert GenesysOAuthManager class here]
# [Insert DeadLetterQueue class here]
# [Insert WebhookPayload dataclass here]
# [Insert retry_webhook_delivery function here]
# [Insert webhook_receiver function here]
# [Insert process_business_logic function here]
async def dlq_worker(dlq: DeadLetterQueue, target_url: str):
Background worker that polls the DLQ and retries failed webhooks.
while True:
pending = await dlq.get_pending_batch(batch_size=5)
for payload in pending:
await retry_webhook_delivery(dlq, payload, target_url)
# Wait before next poll
await asyncio.sleep(10)
print(f"DLQ Worker error: {e}")
await asyncio.sleep(5)
async def main():
# Configuration
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
REGION = os.getenv("GENESYS_REGION", "us-east-1")
TARGET_URL = os.getenv("WEBHOOK_TARGET_URL", "http://localhost:8081/api/v1/events")
if not CLIENT_ID or not CLIENT_SECRET:
print("Error: GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables are required.")
sys.exit(1)
# Initialize components
oauth = GenesysOAuthManager(CLIENT_ID, CLIENT_SECRET, REGION)
dlq = DeadLetterQueue("dlq.db")
# Verify OAuth connectivity
token = await oauth.get_token()
print("OAuth connection established.")
print(f"Failed to establish OAuth connection: {e}")
sys.exit(1)
# Setup AIOHTTP Application
app = web.Application()
app.router.add_post('/webhook', lambda req: webhook_receiver(req, dlq))
# Start the DLQ worker in the background
worker_task = asyncio.create_task(dlq_worker(dlq, TARGET_URL))
# Start the HTTP Server
runner = web.AppRunner(app)
await runner.setup()
site = web.TCPSite(runner, 'localhost', 8080)
print("Webhook Receiver started on http://localhost:8080/webhook")
print("DLQ Worker started, polling every 10 seconds.")
await site.start()
# Keep the application running
await asyncio.Event().wait()
except KeyboardInterrupt:
print("Shutting down...")
worker_task.cancel()
await runner.cleanup()
asyncio.run(main())
Error: 401 Unauthorized during OAuth Refresh
- Cause: The
client_idorclient_secretis incorrect, or the OAuth client is disabled in the Genesys Cloud Admin Portal. - Fix: Verify the credentials in the Admin Portal under Admin > Platform > OAuth Clients. Ensure the client is Active. Check that the
client_secrethas not been rotated.
- Cause: Your retry logic is sending requests too quickly, or the Genesys Cloud API is rate-limiting your OAuth token requests.
- Fix: Increase the
base_delayin theretry_webhook_deliveryfunction. For Genesys Cloud API calls, always respect theRetry-Afterheader if present. In theGenesysOAuthManager, ensure you are not refreshing the token more frequently than necessary.
Error: SQLite Database is Locked
- Cause: Concurrent writes to the SQLite database from multiple async tasks.
- Fix: SQLite handles concurrent reads well but struggles with concurrent writes. In the
DeadLetterQueueclass, ensure all database operations are serialized. The provided code uses synchronoussqlite3calls within an async loop, which blocks the event loop. For high-throughput production systems, switch toaiosqliteor use a dedicated message queue like RabbitMQ or AWS SQS.
Error: Payload Too Large
- Cause: Genesys Cloud webhooks can contain large payloads (e.g., conversation details with transcripts).
- Fix: Increase the
max_content_lengthin theaiohttpapplication setup.app = web.Application(client_max_size=1024*1024*10) # 10MB
