Handling Genesys Cloud Webhook 5xx Failures with a Dead Letter Queue
- This tutorial builds a Python service that intercepts failed Genesys Cloud webhooks (HTTP 5xx responses) and routes them to a persistent dead letter queue for manual inspection and retry.
- The solution uses the Genesys Cloud REST API to verify webhook configuration and the
requestslibrary to simulate the receiving endpoint behavior. - The implementation is written in Python 3.9+ using
httpxfor asynchronous HTTP handling andpymongofor the dead letter storage.
- OAuth Client Type: Service Account (Confidential Client).
- Required Scopes:
webhook:read(to inspect webhook definitions),webhook:write(if updating status programmatically, though this tutorial focuses on the receiver side). - SDK/API Version: Genesys Cloud API v2.
- Language/Runtime: Python 3.9 or higher.
- External Dependencies:
httpx: For async HTTP client and server simulation.pymongo: For dead letter queue storage.fastapianduvicorn: To create the webhook receiver endpoint.python-dotenv: For managing credentials.
Install the dependencies:
pip install httpx pymongo fastapi uvicorn python-dotenv
Genesys Cloud uses OAuth 2.0 for API access. For a backend service processing webhooks, a Service Account is the standard authentication method. You must obtain a client ID and client secret from the Genesys Cloud Admin Console under Developers > Applications.
The following code demonstrates how to acquire an access token. In a production environment, you should cache this token and refresh it before expiration.
import httpx
import os
load_dotenv()
GENESYS_CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
GENESYS_CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
GENESYS_REGION = os.getenv("GENESYS_REGION", "my.genesyscloud.com")
async def get_access_token() -> str:
Acquires an OAuth2 access token from Genesys Cloud.
auth_url = f"https://{GENESYS_REGION}/oauth/token"
headers = {
data = {
"client_id": GENESYS_CLIENT_ID,
"client_secret": GENESYS_CLIENT_SECRET
async with httpx.AsyncClient() as client:
response = await client.post(auth_url, headers=headers, data=data)
response.raise_for_status()
token_data = response.json()
return token_data["access_token"]
raise Exception(f"Authentication failed: {e.response.status_code} - {e.response.text}") from e
Step 1: Define the Dead Letter Queue Schema and Storage
Before handling the webhook, you need a place to store the failed payloads. A dead letter queue (DLQ) captures messages that could not be processed or delivered successfully. For this tutorial, we use MongoDB as the DLQ backend because it handles JSON-like documents natively and provides durability.
Define the schema for a failed webhook entry. This schema captures the original payload, the error response from your receiver, and metadata for retry logic.
from datetime import datetime
from typing import Optional, Dict, Any
from bson import ObjectId
class WebhookFailureRecord:
def __init__(
self,
id: Optional[str] = None,
original_payload: Dict[str, Any] = None,
error_status_code: int = 0,
error_body: str = "",
headers: Dict[str, str] = None,
timestamp: str = None,
retry_count: int = 0,
max_retries: int = 3
self.id = id or str(ObjectId())
self.original_payload = original_payload or {}
self.error_status_code = error_status_code
self.error_body = error_body
self.headers = headers or {}
self.timestamp = timestamp or datetime.utcnow().isoformat()
self.retry_count = retry_count
self.max_retries = max_retries
def to_dict(self) -> Dict[str, Any]:
"_id": self.id,
"original_payload": self.original_payload,
"error_status_code": self.error_status_code,
"error_body": self.error_body,
"headers": self.headers,
"timestamp": self.timestamp,
"retry_count": self.retry_count,
"max_retries": self.max_retries
Next, implement the storage layer. This class connects to MongoDB and provides methods to insert failed records and retrieve them for retry.
from pymongo import MongoClient
from pymongo.errors import ConnectionFailure
class DeadLetterQueue:
def __init__(self, mongo_uri: str, db_name: str = "genesys_daq", collection_name: str = "failed_webhooks"):
self.client = MongoClient(mongo_uri)
self.db = self.client[db_name]
self.collection = self.db[collection_name]
# Create index for efficient querying by retry count
self.collection.create_index("retry_count")
self.collection.create_index("timestamp")
def save_failure(self, record: WebhookFailureRecord) -> str:
Saves a failed webhook to the DLQ.
Returns the ID of the saved record.
result = self.collection.insert_one(record.to_dict())
return result.inserted_id
except ConnectionFailure as e:
raise Exception(f"Failed to connect to MongoDB: {e}") from e
def get_failed_records(self, limit: int = 10) -> list:
Retrieves failed records that have not exceeded max retries.
cursor = self.collection.find({
"retry_count": {"$lt": self.collection.find_one()["max_retries"] if self.collection.find_one() else 3}
}).sort("timestamp", 1).limit(limit)
return list(cursor)
raise Exception(f"Failed to retrieve records from DLQ: {e}") from e
def update_retry_count(self, record_id: str, new_count: int) -> bool:
Updates the retry count for a specific record.
result = self.collection.update_one(
{"_id": record_id},
{"$set": {"retry_count": new_count}}
return result.modified_count > 0
raise Exception(f"Failed to update record in DLQ: {e}") from e
Step 2: Implement the Webhook Receiver with 5xx Handling
This is the core component. You will create a FastAPI endpoint that acts as the webhook receiver. When Genesys Cloud sends a POST request, this endpoint will simulate a 5xx error to demonstrate the failure handling logic. In a real scenario, your business logic might fail, or an external dependency might be down, causing your service to return 500.
Crucially, when your service returns a 5xx status code, Genesys Cloud will retry the delivery. However, if the failure is persistent, you need to capture the payload locally before the retry window expires or to analyze why the 5xx occurred.
from fastapi import FastAPI, Request, HTTPException
from fastapi.responses import JSONResponse
import json
import asyncio
app = FastAPI()
dlq = DeadLetterQueue(mongo_uri=os.getenv("MONGO_URI", "mongodb://localhost:27017"))
@app.post("/webhook/receiver")
async def receive_webhook(request: Request):
Receives webhooks from Genesys Cloud.
Simulates a 5xx error to trigger DLQ storage.
# Parse the incoming payload
body = await request.json()
headers = dict(request.headers)
# Simulate a business logic failure or downstream dependency error
# In production, this is where your actual processing happens.
# If processing fails, you might raise an exception that results in 500.
# For demonstration, we force a 500 error to test the DLQ mechanism
# Note: Genesys Cloud retries 5xx errors. We capture the payload here
# so we do not lose it if the retry also fails or if we need to audit.
raise Exception("Simulated downstream database connection failure")
# Capture the failure details
error_message = str(e)
# Create the failure record
failure_record = WebhookFailureRecord(
original_payload=body,
error_status_code=500,
error_body=error_message,
headers=headers
# Save to DLQ asynchronously to avoid blocking the HTTP response
# We use asyncio.create_task to fire and forget, ensuring the HTTP response
# is sent quickly to Genesys Cloud, satisfying their timeout requirements.
asyncio.create_task(save_to_dlq(failure_record))
# Return 500 to Genesys Cloud
# Genesys will retry this request according to its retry policy
raise HTTPException(status_code=500, detail="Internal Server Error")
async def save_to_dlq(record: WebhookFailureRecord):
Async wrapper to save to DLQ without blocking the main thread.
dlq.save_failure(record)
# Log critical error if DLQ save fails
print(f"CRITICAL: Failed to save to DLQ: {e}")
Why Async DLQ Storage?
Genesys Cloud expects a response within a specific timeout window (typically 10-30 seconds). If your DLQ write is slow, it delays the response to Genesys, potentially causing a timeout on their end. By using asyncio.create_task, you offload the database write to a background task, ensuring the HTTP 500 response is sent immediately to Genesys Cloud, triggering their retry mechanism while preserving the data locally.
Step 3: Implement the Retry Logic
Storing the failed message is only half the solution. You need a process to attempt re-processing these messages. This service runs independently of the webhook receiver. It polls the DLQ, attempts to process the payload again, and marks it as successful or increments the retry count.
async def retry_failed_webhooks():
Background task to retry failed webhooks from the DLQ.
while True:
# Get failed records with retry_count < max_retries
failed_records = dlq.get_failed_records(limit=5)
if not failed_records:
await asyncio.sleep(10) # No failures, wait before polling again
for record in failed_records:
record_id = record["_id"]
payload = record["original_payload"]
current_retries = record["retry_count"]
max_retries = record["max_retries"]
if current_retries >= max_retries:
print(f"Retrying record {record_id} (Attempt {current_retries + 1}/{max_retries})")
# Simulate processing the payload again
# Replace this with your actual business logic
await process_payload(payload)
# If successful, remove from DLQ or mark as processed
# For simplicity, we just increment retry count here to demonstrate flow
# In production, you would delete the record or set a 'status' field
dlq.update_retry_count(record_id, current_retries + 1)
print(f"Successfully processed record {record_id}")
# Processing failed again
print(f"Retry failed for record {record_id}: {e}")
print(f"Error in retry loop: {e}")
await asyncio.sleep(30) # Wait longer on error
await asyncio.sleep(10) # Poll interval
async def process_payload(payload: Dict[str, Any]):
Simulates business logic processing.
# Add your actual processing logic here
await asyncio.sleep(1) # Simulate work
# Simulate occasional success after retries
if "simulated_success" in str(payload):
pass
else:
raise Exception("Processing still failing")
The following script combines the authentication, DLQ setup, webhook receiver, and retry logic into a single runnable application. It uses uvicorn to serve the FastAPI app and asyncio to run the retry loop in the background.
import os
import asyncio
import httpx
load_dotenv()
# Configuration
MONGO_URI = os.getenv("MONGO_URI", "mongodb://localhost:27017")
# --- DLQ Classes ---
def __init__(
self,
"_id": self.id,
# Find records where retry_count is less than max_retries
# We use a simple aggregation or filter. For robustness, check max_retries per doc.
cursor = self.collection.find().sort("timestamp", 1).limit(limit)
return list(cursor)
{"_id": record_id},
# --- App Setup ---
app = FastAPI()
dlq = DeadLetterQueue(mongo_uri=MONGO_URI)
# Simulate 5xx error
error_body=str(e),
headers=headers
# Fire and forget DLQ save
while True:
# --- Entry Point ---
import uvicorn
# Start the retry loop in the background
asyncio.create_task(retry_failed_webhooks())
# Start the web server
uvicorn.run(app, host="0.0.0.0", port=8000)
What causes it:
If your retry logic runs too frequently or processes too many records at once, you might hit Genesys Cloud API rate limits if you are calling Genesys APIs during the retry process. Even if you are just processing data, ensure your DLQ polling does not overwhelm your local database.
How to fix it:
Implement exponential backoff in your retry logic. Instead of a fixed 10-second poll, increase the delay between retries for the same record.
def calculate_backoff(retry_count: int, base_delay: float = 5.0, max_delay: float = 60.0) -> float:
Calculates exponential backoff delay.
delay = base_delay * (2 ** retry_count)
return min(delay, max_delay)
What causes it:
This occurs if your OAuth token expires before the webhook processing completes or if the Service Account lacks the necessary scopes. While webhooks do not require authentication from Genesys Cloud to your receiver, if your receiver calls back to Genesys Cloud APIs using a token, that token might be stale.
How to fix it:
Ensure your token refresh logic is robust. Check the expires_in field in the OAuth response and refresh the token 60 seconds before expiration.
class TokenManager:
def __init__(self):
self.token = None
self.expiry_time = 0
async def get_valid_token(self) -> str:
if not self.token or time.time() >= self.expiry_time - 60:
self.token, self.expiry_time = await self.refresh_token()
return self.token
async def refresh_token(self) -> tuple:
# Implementation of get_access_token here
pass
Error: MongoDB Connection Failure
What causes it:
The DLQ storage layer fails to connect to MongoDB, causing the save_to_dlq task to fail silently or raise an exception.
How to fix it:
Wrap the MongoDB operations in try-except blocks and implement a fallback mechanism, such as writing to a local file or sending an alert via email/Slack if the database is unreachable.
import json
import os
def fallback_to_file(record: WebhookFailureRecord):
Fallback mechanism to save failed webhooks to a local file if MongoDB is down.
filename = f"failed_webhooks_{datetime.utcnow().strftime('%Y%m%d')}.jsonl"
with open(filename, "a") as f:
f.write(json.dumps(record.to_dict()) + "\n")
