Handling Disconnects and Session Resumption in Genesys Web Messaging
This guide establishes a resilient architecture for detecting client-side network interruptions, validating conversation state server-side, and resuming Genesys Web Messaging sessions without context loss or duplicate routing. You will implement a production-ready pattern combining widget callback interception, middleware session validation, and Architect flow logic that restores transcript continuity and maintains agent-customer alignment across browser refreshes or network drops.
- Licensing Tier: Genesys Cloud CX 2 or higher. CX 1 includes baseline web messaging, but enterprise resumption patterns require CX 2 for advanced Architect routing, conversation metadata manipulation, and API-driven session management.
- IAM Permissions:
Messaging:Conversation:Read,Messaging:Conversation:Write,Messaging:Channel:Edit,Architect:Flow:Edit,User:Read - OAuth Scopes:
conversation:view,conversation:write,message:write,user:read - External Dependencies: Custom middleware application (Node.js, Python, or Java), HTTPS endpoint for webhook callbacks, Genesys Web Messaging widget version 1.8 or higher, Architect flow with
Get Conversation,Condition,Send Message, andQueueblocks. - Cross-Reference Requirement: If your environment correlates digital transcripts with workforce optimization metrics, review the WFM Integration for Digital Channels guide to ensure resumption events do not trigger duplicate wrap-up codes or skew handle time calculations.
1. Configuring Widget Disconnect & Reconnect Callbacks
The Genesys Web Messaging widget maintains an internal WebSocket connection to the messaging gateway. When the network drops, the browser tab loses focus, or the user navigates away, the widget emits state transition events. We intercept these events to capture authoritative session identifiers before the client loses context.
Initialize the widget with explicit callback handlers that capture conversationId, participantId, and sessionToken. Do not rely on browser-level beforeunload or visibilitychange events. Those events fire asynchronously and frequently miss the precise moment the Genesys gateway marks the connection as stale.
const widget = new GenesysCloudWebMessagingWidget({
orgId: "YOUR_ORG_ID",
deploymentId: "YOUR_DEPLOYMENT_ID",
siteName: "YOUR_SITE_NAME",
callbacks: {
onDisconnect: (data) => {
console.log("Widget disconnected. Capturing session state.");
sessionManager.captureState({
conversationId: data.conversationId,
participantId: data.participantId,
disconnectReason: data.reason,
timestamp: Date.now()
onReconnect: (data) => {
console.log("Widget reconnecting. Initiating resumption handshake.");
sessionManager.requestResumption({
onConversationUpdated: (data) => {
console.log("Conversation state changed:", data.status);
sessionManager.syncServerState(data);
The Trap: Developers frequently attempt to rebuild the transcript client-side by storing messages in localStorage or IndexedDB during the disconnect window. This approach creates immediate synchronization drift. When the widget reconnects, it pulls the authoritative transcript from Genesys Cloud. If the local cache contains messages that failed to reach the gateway, the client displays duplicate or orphaned messages. The Genesys gateway does not guarantee message ordering across fragmented WebSocket sessions. Client-side caching must be read-only and cleared on successful onReconnect.
Architectural Reasoning: We use the widget’s native callback system because it provides deterministic state transitions aligned with the Genesys messaging gateway lifecycle. The onDisconnect callback triggers a server-side heartbeat validation rather than immediately assuming session termination. This decouples client network volatility from conversation state management. The middleware receives the conversationId and participantId, then queries the Genesys REST API to determine if the conversation remains routable. This pattern prevents the common failure mode where users refresh the browser and receive a new queue position instead of resuming their active conversation.
2. Implementing Server-Side Session Validation
Client-side disconnect events are unreliable indicators of conversation death. The Genesys platform marks a conversation as DISCONNECTED after network loss or inactivity, but the conversation object remains active and routable until the autoClose threshold expires or an explicit termination occurs. We implement a middleware validation endpoint that receives resumption requests and queries the Genesys Conversations API to determine the authoritative state.
Create an HTTPS endpoint that accepts POST requests containing conversationId and participantId. The middleware authenticates using OAuth 2.0 client credentials, retrieves the conversation object, and evaluates three critical fields: status, updatedTime, and participants.
POST /api/v2/conversations/messaging/{conversationId}
Authorization: Bearer <ACCESS_TOKEN>
Accept: application/json
Response payload evaluation logic:
"type": "messaging",
"status": "DISCONNECTED",
"updatedTime": "2024-05-15T14:32:10.000Z",
"participants": [
"id": "customer-participant-id",
"role": "CUSTOMER",
"id": "agent-participant-id",
"role": "AGENT",
"status": "ACTIVE",
"updatedTime": "2024-05-15T14:30:00.000Z"
The middleware calculates the delta between updatedTime and the current timestamp. If the delta falls within a configurable window (typically 300 seconds for web messaging), the endpoint returns a RESUMABLE flag along with the original agentId and queueId. If the delta exceeds the window, or if the status is TERMINATED, the endpoint returns NEW_ROUTING_REQUIRED.
The Trap: Teams often treat DISCONNECTED as a terminal state and immediately route the customer to the front of the queue. This causes duplicate agent assignments, transcript fragmentation, and WFM handle time inflation. Genesys retains the conversation object in DISCONNECTED state to allow for exactly this resumption pattern. Routing a resumed conversation through the standard queue block resets the wait time, triggers a new greeting, and breaks the continuity required for compliance auditing.
Architectural Reasoning: Server-side validation centralizes state authority. The Genesys gateway does not expose a direct resume endpoint; it expects the client to reattach to the existing conversation object using the original conversationId. By validating the updatedTime delta, we differentiate between a soft disconnect (network blip, tab switch) and a hard disconnect (user abandoned, browser closed). The middleware returns a structured response that instructs the widget to either reattach to the existing session or initiate a new routing request. This pattern eliminates race conditions where multiple reconnect attempts compete for queue placement. It also ensures that WEM and WFM systems receive consistent wrap-up triggers, as referenced in the WFM Integration for Digital Channels guide.
3. Architect Flow Design for Resumption Routing
The Architect flow must handle both initial routing and resumption logic without duplicating qualification blocks. We design a single entry flow that accepts an inbound resume flag from the middleware or widget. The flow uses a Condition block to branch between new routing and resumption handling.
Configure the Start block to accept custom data attributes: resume=true, conversationId, participantId, and agentId. The first block after Start is a Condition block evaluating data.resume == true.
If resume equals true, the flow executes a Get Conversation block using the provided conversationId. The flow then evaluates the conversation status. If the status is ACTIVE or DISCONNECTED with a recent timestamp, the flow bypasses the Queue block entirely. Instead, it executes a Send Message block to inject a system message indicating resumption, then attaches the customer to the original agent using the Add Participant block with role: CUSTOMER and agentId from the original session.
If resume equals false, the flow proceeds through standard qualification blocks, gathers initial intent, and routes to the appropriate Queue block.
The Trap: Architects frequently place the Get Conversation block after the Queue block, assuming the queue will handle resumption automatically. The Genesys queue system does not recognize resumed sessions. It treats every inbound request as a new interaction, assigns a new queue position, and triggers the initial greeting block. This causes customers to wait in line while their original agent remains idle, or worse, gets assigned a second customer simultaneously. Queue bypass logic must exist before any routing decision.
Architectural Reasoning: Resumption routing requires deterministic path separation. By evaluating the resume flag immediately after the Start block, we prevent resumption traffic from entering the qualification funnel. This preserves wait time metrics, prevents duplicate IVR prompts, and maintains transcript continuity. The Send Message block injects a system message using type: "system" and authorId: "system". This message appears in the agent desktop as a contextual marker, not a customer utterance. The Add Participant block reattaches the customer to the original conversation object. We use the conversationId from the middleware validation to ensure idempotent attachment. This pattern aligns with Genesys best practices for digital channel resilience and prevents queue congestion during network volatility events.
4. API-Driven Context Restoration
After the Architect flow reattaches the customer to the original conversation, the widget must restore the transcript. The Genesys widget automatically pulls the message history via the Conversations API when the session reconnects. We do not push history client-side. Instead, we ensure the conversation object contains complete metadata and that the message stream remains intact.
Use the POST /api/v2/conversations/messaging/{conversationId}/messages endpoint to inject resumption markers or missing messages that failed during the disconnect window. The payload must include the authorId of the customer participant, type: "customer", and text content.
POST /api/v2/conversations/messaging/a1b2c3d4-e5f6-7890-abcd-ef1234567890/messages
"authorId": "customer-participant-id",
"type": "customer",
"text": "[System: Session resumed after network interruption]",
"to": ["agent-participant-id"]
Update conversation metadata via PATCH /api/v2/conversations/messaging/{conversationId} to store lastResumptionTimestamp and resumptionCount. This metadata supports audit trails and WFM reporting.
PATCH /api/v2/conversations/messaging/a1b2c3d4-e5f6-7890-abcd-ef1234567890
"customAttributes": {
"lastResumptionTimestamp": "2024-05-15T14:35:22.000Z",
"resumptionCount": "2"
The Trap: Engineers often attempt to restore context by sending messages to a conversation that has entered QUEUE or REROUTE state. The Genesys gateway rejects messages to conversations that are not in ACTIVE or DISCONNECTED state. This causes HTTP 409 Conflict responses and breaks transcript continuity in the agent desktop. Message injection must only occur after the Architect flow confirms the conversation is reattached to an agent or system participant.
Architectural Reasoning: Context restoration relies on Genesys message streaming architecture. The widget subscribes to the conversation message stream via WebSocket. When the session reconnects, the gateway pushes all messages published after the last acknowledged sequence number. By injecting a system marker via the REST API, we provide a visible boundary in the transcript without disrupting the message sequence. The PATCH operation updates conversation-level metadata without altering participant states. This metadata persists across resumption cycles and supports downstream analytics, including the Speech Analytics for Transcript Correlation guide, which relies on consistent conversation boundaries for NLP processing. We avoid client-side transcript rebuilding because the Genesys gateway maintains the authoritative message order. This pattern ensures idempotent context restoration, prevents duplicate message rendering, and maintains compliance with audit requirements.
Edge Case 1: Stale Token Replay After Browser Cache Flush
- The failure condition: The user clears browser cache or uses an incognito session after a disconnect. The widget attempts to resume using a cached
conversationIdandparticipantId, but the Genesys gateway rejects the request with a 401 Unauthorized or 403 Forbidden response. - The root cause: The OAuth access token embedded in the widget configuration expires or becomes invalid when the session storage is purged. The middleware receives the resumption request but fails to authenticate the API call. The conversation remains in
DISCONNECTEDstate, and the customer receives a generic error instead of a routing prompt. - The solution: Implement token refresh logic in the middleware before querying the Genesys API. Use the OAuth 2.0 client credentials flow to obtain a fresh access token on every resumption request. If the widget lacks a valid token, the middleware returns
NEW_ROUTING_REQUIREDand the widget initiates a fresh authentication handshake. Never cache OAuth tokens inlocalStorage. Use secure, HttpOnly cookies or server-side token storage with short TTLs.
Edge Case 2: Concurrent Reconnection Attempts from Multiple Tabs
- The failure condition: The user has the web messaging widget open in three browser tabs. The network drops, then restores. All three tabs trigger
onReconnectsimultaneously. The middleware receives three resumption requests for the sameconversationId. Two requests succeed, one fails with a 409 Conflict. The agent desktop shows duplicate participant attachments and fragmented message streams. - The root cause: The Genesys gateway enforces a single active customer participant per conversation. Concurrent
Add Participantor message injection requests race against each other. The first request succeeds, subsequent requests fail because the participant role is already assigned. - The solution: Implement idempotency keys in the middleware. Generate a UUID for each resumption handshake and store it in a distributed cache (Redis or DynamoDB) with a 60-second TTL. If the same
conversationIdandparticipantIdpair arrives within the TTL window, return the cached response instead of querying Genesys. The widget should implement exponential backoff with jitter when retrying failed resumption requests. Only one tab should maintain the active WebSocket connection; others should enter a suspended state until the user closes them.
Edge Case 3: Agent-Side Disconnect During Active Transfer
- The failure condition: The customer experiences a network drop while the conversation is being transferred to a specialist queue. The agent initiates a transfer, the network drops, and the customer reconnects. The widget attempts to resume, but the conversation is in
TRANSFERstate. The resumption logic fails, and the customer is routed to the original queue instead of the specialist. - The root cause: The Genesys gateway marks conversations as
TRANSFERduring active handoff. Resumption logic that only checksACTIVEandDISCONNECTEDstates misses this transitional state. The middleware returnsNEW_ROUTING_REQUIRED, breaking the transfer intent. - The solution: Expand the middleware validation to recognize
TRANSFERandQUEUEstates. If the conversation is inTRANSFER, the middleware returnsRESUMABLEwith thetargetQueueIdandtransferReason. The Architect flow uses this data to route directly to the specialist queue without re-entering the initial qualification funnel. Update theConditionblock to evaluatedata.conversationStatus == "TRANSFER"and bypass the standard queue block. This preserves transfer intent and prevents customer frustration during network volatility.
