Handling ASR Confidence Thresholds in NICE Cognigy Voice Flows with a Go Webhook
- A Go HTTP server that receives voice flow webhook payloads from NICE Cognigy, evaluates Automatic Speech Recognition confidence scores against a dynamic threshold, routes low-confidence utterances to clarification dialogs via the Cognigy REST API, and persists acoustic metadata for model retraining datasets.
- This tutorial uses the Cognigy Webhook API and the Cognigy REST API (
/api/v1/flows/{flowId}/sessions/{sessionId}/messages). - The implementation is written in Go 1.21+ using only the standard library.
- Cognigy tenant with API access enabled and webhook nodes configured in a voice flow
- API Key with
flow:executeandsession:managescopes - Go 1.21 or later installed
- Environment variables:
COGNIGY_API_KEY,COGNIGY_TENANT_URL,ASR_THRESHOLD - No external dependencies required
Cognigy authenticates REST API requests using an API Key passed in the X-Cognigy-API-Key header. Webhook requests from the platform include the tenant API key in the request headers for validation. The following code initializes a secure HTTP client and validates incoming webhook requests.
package main
import (
"context"
"crypto/hmac"
"crypto/sha256"
"encoding/json"
"fmt"
"io"
"log"
"math"
"net/http"
"os"
"strconv"
"time"
const (
maxRetries = 3
baseDelay = 100 * time.Millisecond
// CognigyClient wraps the REST API client with authentication and retry logic
type CognigyClient struct {
BaseURL string
APIKey string
HTTP *http.Client
// NewCognigyClient initializes the client with a configured timeout
func NewCognigyClient(tenantURL, apiKey string) *CognigyClient {
return &CognigyClient{
BaseURL: tenantURL,
APIKey: apiKey,
HTTP: &http.Client{
Timeout: 10 * time.Second,
// DoRequest executes an HTTP request with automatic retry on 429 and 5xx responses
func (c *CognigyClient) DoRequest(ctx context.Context, method, path string, body io.Reader) (*http.Response, error) {
var lastErr error
for attempt := 0; attempt <= maxRetries; attempt++ {
req, err := http.NewRequestWithContext(ctx, method, fmt.Sprintf("%s%s", c.BaseURL, path), body)
if err != nil {
return nil, fmt.Errorf("failed to create request: %w", err)
req.Header.Set("X-Cognigy-API-Key", c.APIKey)
resp, err := c.HTTP.Do(req)
if err != nil {
lastErr = fmt.Errorf("network error: %w", err)
// Retry on rate limit or server errors
if resp.StatusCode == http.StatusTooManyRequests || (resp.StatusCode >= 500 && resp.StatusCode < 600) {
lastErr = fmt.Errorf("retryable error: status %d", resp.StatusCode)
resp.Body.Close()
if attempt < maxRetries {
backoff := time.Duration(math.Pow(2, float64(attempt))) * baseDelay
log.Printf("Received %d, retrying in %v...", resp.StatusCode, backoff)
time.Sleep(backoff)
// Parse error body for 4xx responses
if resp.StatusCode >= 400 && resp.StatusCode < 500 {
errBody, _ := io.ReadAll(resp.Body)
resp.Body.Close()
return resp, fmt.Errorf("client error %d: %s", resp.StatusCode, string(errBody))
return resp, nil
return nil, fmt.Errorf("max retries exceeded: %w", lastErr)
The client enforces a 10-second timeout, attaches the API key to every request, and implements exponential backoff for 429 Too Many Requests and 5xx server errors. This prevents cascade failures during high-volume voice traffic.
Step 1: Webhook Handler and Payload Validation
Cognigy sends a JSON payload to your webhook endpoint when a voice node triggers. The payload contains session metadata, the recognized utterance, ASR confidence, and audio features. The handler validates the request, parses the JSON, and extracts the confidence score.
// WebhookPayload matches the Cognigy voice flow webhook structure
type WebhookPayload struct {
SessionID string `json:"sessionId"`
FlowID string `json:"flowId"`
NodeID string `json:"nodeId"`
Utterance string `json:"utterance"`
ASR struct {
Confidence float64 `json:"confidence"`
Text string `json:"text"`
} `json:"asr"`
Audio struct {
DurationMs int `json:"durationMs"`
SampleRate int `json:"sampleRate"`
Features string `json:"features"` // Base64 encoded acoustic features
} `json:"audio"`
// WebhookResponse dictates the next routing step for the Cognigy engine
type WebhookResponse struct {
NextFlow string `json:"nextFlow,omitempty"`
NextNode string `json:"nextNode,omitempty"`
Message string `json:"message,omitempty"`
func handleWebhook(client *CognigyClient, threshold float64) http.HandlerFunc {
return func(w http.ResponseWriter, r *http.Request) {
if r.Method != http.MethodPost {
http.Error(w, "Method not allowed", http.StatusMethodNotAllowed)
return
// Validate API key from request header
incomingKey := r.Header.Get("X-Cognigy-API-Key")
if incomingKey == "" || incomingKey != client.APIKey {
http.Error(w, "Unauthorized", http.StatusUnauthorized)
return
body, err := io.ReadAll(r.Body)
if err != nil {
http.Error(w, "Failed to read request body", http.StatusBadRequest)
return
defer r.Body.Close()
var payload WebhookPayload
if err := json.Unmarshal(body, &payload); err != nil {
http.Error(w, "Invalid JSON payload", http.StatusBadRequest)
return
// Validate required fields
if payload.ASR.Confidence == 0 || payload.SessionID == "" || payload.FlowID == "" {
http.Error(w, "Missing confidence or session identifiers", http.StatusBadRequest)
return
// Log acoustic features for retraining
logAcousticFeatures(payload)
// Route based on confidence threshold
if payload.ASR.Confidence < threshold {
triggerClarification(client, payload)
json.NewEncoder(w).Encode(WebhookResponse{
Message: "low_confidence_routed",
return
// Default pass-through response
NextNode: payload.NodeID,
The handler validates the X-Cognigy-API-Key header to prevent unauthorized invocations. It parses the JSON payload, verifies that asr.confidence and session identifiers exist, logs acoustic metadata, and branches logic based on the threshold comparison. The response JSON controls Cognigy routing: an empty nextFlow/nextNode with a message tells the engine to pause while the REST API call handles clarification.
Step 2: Dynamic Threshold Evaluation and Clarification Routing
When the ASR confidence falls below the dynamic threshold, the webhook calls the Cognigy REST API to inject a clarification message into the active session. This forces the voice flow to enter a clarification dialog node. The threshold is read from the environment at startup, allowing runtime adjustment without redeployment.
// ClarificationPayload pushes a synthetic message to trigger the clarification node
type ClarificationPayload struct {
Message string `json:"message"`
Source string `json:"source"`
// triggerClarification calls the Cognigy REST API to route low-confidence utterances
func triggerClarification(client *CognigyClient, payload WebhookPayload) {
clarifyMsg := ClarificationPayload{
Message: "repeat",
Source: "asr_webhook",
jsonBody, err := json.Marshal(clarifyMsg)
if err != nil {
log.Printf("Failed to marshal clarification payload: %v", err)
return
path := fmt.Sprintf("/api/v1/flows/%s/sessions/%s/messages", payload.FlowID, payload.SessionID)
resp, err := client.DoRequest(context.Background(), http.MethodPost, path, io.NopCloser(strings.NewReader(string(jsonBody))))
if err != nil {
log.Printf("Failed to trigger clarification: %v", err)
return
defer resp.Body.Close()
if resp.StatusCode != http.StatusOK && resp.StatusCode != http.StatusCreated {
log.Printf("Clarification request failed with status %d", resp.StatusCode)
The REST endpoint /api/v1/flows/{flowId}/sessions/{sessionId}/messages accepts a JSON body containing a message field. Cognigy treats this as a new user utterance, which routes to the clarification node if the flow is configured to listen for repeat or clarify intents. The DoRequest method handles 429 rate limits and 5xx server errors with exponential backoff, ensuring reliable delivery during peak call volumes.
Step 3: Acoustic Feature Logging and Retry Logic
Model retraining requires structured logging of acoustic features, confidence scores, and recognized text. The following function writes JSONL records to standard output, which can be redirected to a file or forwarded to a logging pipeline. The retry logic from Step 2 ensures that transient network failures do not drop clarification triggers.
// AcousticLogRecord structures data for ASR model retraining
type AcousticLogRecord struct {
RawFeatures string `json:"rawFeatures"`
BelowThreshold bool `json:"belowThreshold"`
// logAcousticFeatures writes structured JSONL to stdout for dataset collection
func logAcousticFeatures(payload WebhookPayload) {
record := AcousticLogRecord{
Timestamp: time.Now().UTC(),
SessionID: payload.SessionID,
FlowID: payload.FlowID,
Utterance: payload.ASR.Text,
Confidence: payload.ASR.Confidence,
DurationMs: payload.Audio.DurationMs,
SampleRate: payload.Audio.SampleRate,
RawFeatures: payload.Audio.Features,
BelowThreshold: payload.ASR.Confidence < threshold,
jsonData, err := json.Marshal(record)
if err != nil {
log.Printf("Failed to marshal acoustic log: %v", err)
return
log.Printf("ASR_LOG: %s", string(jsonData))
The logging function captures the exact timestamp, session context, confidence score, audio duration, sample rate, and base64-encoded acoustic features. The BelowThreshold flag enables quick filtering during dataset curation. In production, replace log.Printf with a structured logger that writes to a file or forwards to a message queue. The retry logic in DoRequest uses exponential backoff starting at 100 milliseconds, capping at three attempts. This prevents thundering herd scenarios when the Cognigy API returns 429 during high-traffic periods.
The following script combines authentication, webhook handling, threshold evaluation, REST API routing, and acoustic logging into a single runnable module. Replace COGNIGY_API_KEY and COGNIGY_TENANT_URL with your tenant credentials before execution.
package main
import (
"context"
"encoding/json"
"fmt"
"io"
"log"
"math"
"net/http"
"os"
"strconv"
"strings"
"time"
const (
maxRetries = 3
BaseURL string
APIKey string
HTTP *http.Client
ASR struct {
} `json:"asr"`
Audio struct {
} `json:"audio"`
var threshold float64
BaseURL: tenantURL,
APIKey: apiKey,
HTTP: &http.Client{
var lastErr error
if err != nil {
lastErr = fmt.Errorf("failed to create request: %w", err)
if err != nil {
resp.Body.Close()
time.Sleep(backoff)
resp.Body.Close()
return resp, nil
if err != nil {
return
Message: "repeat",
if err != nil {
return
if err != nil {
return
func handleWebhook(client *CognigyClient) http.HandlerFunc {
return
return
if err != nil {
return
return
return
json.NewEncoder(w).Encode(WebhookResponse{Message: "low_confidence_routed"})
return
json.NewEncoder(w).Encode(WebhookResponse{NextNode: payload.NodeID})
func main() {
apiKey := os.Getenv("COGNIGY_API_KEY")
tenantURL := os.Getenv("COGNIGY_TENANT_URL")
port := os.Getenv("PORT")
if port == "" {
port = "8080"
if apiKey == "" || tenantURL == "" {
log.Fatal("COGNIGY_API_KEY and COGNIGY_TENANT_URL environment variables are required")
thresholdStr := os.Getenv("ASR_THRESHOLD")
if thresholdStr == "" {
threshold = 0.75
} else {
var err error
threshold, err = strconv.ParseFloat(thresholdStr, 64)
if err != nil || threshold < 0 || threshold > 1 {
log.Printf("Invalid ASR_THRESHOLD %s, defaulting to 0.75", thresholdStr)
threshold = 0.75
client := NewCognigyClient(tenantURL, apiKey)
http.HandleFunc("/webhook", handleWebhook(client))
log.Printf("Cognigy ASR Webhook listening on :%s with threshold %.2f", port, threshold)
if err := http.ListenAndServe(":"+port, nil); err != nil {
log.Fatalf("Server failed: %v", err)
Run the script with go run main.go or compile it with go build -o asr-webhook. The server exposes /webhook on the configured port. Cognigy must be configured to call this endpoint from a voice flow node. The dynamic threshold defaults to 0.75 but can be overridden via the ASR_THRESHOLD environment variable.
- Cause: The
X-Cognigy-API-Keyheader is missing, malformed, or lacks the requiredflow:executeandsession:managescopes. - Fix: Verify the API key in your Cognigy tenant settings. Ensure the key is passed exactly as generated. Check that the webhook request includes the header. The handler returns
401immediately if validation fails. - Code Fix: Confirm environment variable
COGNIGY_API_KEYmatches the tenant key. Add logging to inspectincomingKeyduring development.
- Cause: The Cognigy REST API enforces rate limits per tenant. High call volumes trigger throttling.
- Fix: The
DoRequestmethod implements exponential backoff with three retries. If failures persist, increasemaxRetriesor distribute traffic across multiple webhook instances. Monitor theRetry-Afterheader if returned by the API. - Code Fix: Adjust
baseDelayandmaxRetriesconstants. The current implementation sleeps for 100ms, 200ms, and 400ms before giving up.
Error: 400 Bad Request
- Cause: The webhook payload lacks
asr.confidence,sessionId, orflowId. Cognigy may send empty payloads during flow initialization or testing. - Fix: Add a guard clause in your Cognigy flow to ensure ASR data is populated before triggering the webhook. The handler returns
400with a descriptive message when required fields are missing. - Code Fix: Validate
payload.ASR.Confidence > 0andpayload.SessionID != ""before processing. Log the raw body for debugging malformed requests.
Error: 502 Bad Gateway
- Cause: The webhook server is unreachable from the Cognigy platform due to firewall rules, missing HTTPS, or DNS misconfiguration.
- Fix: Deploy the Go server behind a reverse proxy with valid TLS certificates. Cognigy requires
https://endpoints for production webhooks. Ensure the port is publicly accessible and not blocked by network security groups. - Code Fix: Use
http.ListenAndServeTLSin production with valid certificate paths. The example useshttp.ListenAndServefor local testing.
