Handling 5xx Webhook Failures with a Dead Letter Queue in Genesys Cloud
  • A Python microservice that ingests Genesys Cloud webhooks, handles transient 5xx failures from your downstream system, and persists failed payloads to a Dead Letter Queue (DLQ) for later retry or analysis.
  • This implementation uses the Genesys Cloud Webhooks API to configure the endpoint and the Python requests library to handle the ingestion logic.
  • The tutorial covers Python 3.9+ with fastapi for the webhook receiver and boto3 for Amazon SQS as the DLQ provider.
  • OAuth Client Type: Confidential Client (Client Credentials Grant) for API configuration; Public or Confidential for testing.
  • Required Scopes:
    • webhooks:webhook:create (to register the webhook)
    • webhooks:webhook:view (to verify configuration)
  • SDK/API Version: Genesys Cloud API v2.
  • Language/Runtime: Python 3.9+.
  • External Dependencies:
    • fastapi (Web framework)
    • uvicorn (ASGI server)
    • boto3 (AWS SDK for SQS DLQ)
    • pydantic (Data validation)
    • requests (HTTP client for internal retries)
    • tenacity (Retry logic library)
To interact with the Genesys Cloud API for configuration, you must implement the Client Credentials Grant flow. This flow is suitable for server-to-server communication where no user context is required.
Python OAuth Token Helper
This helper handles token acquisition and caching to avoid unnecessary requests to the authorization server.
import requests
from typing import Optional
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
        self.base_url = base_url.rstrip('/')
        self.token_expiry: float = 0
    def get_token(self) -> str:
        if self.token and time.time() < self.token_expiry:
            return self.token
        auth_url = f"{self.base_url}/oauth/token"
        headers = {
        data = {
            "client_id": self.client_id,
            response = requests.post(auth_url, headers=headers, data=data)
            response.raise_for_status()
            token_data = response.json()
            self.token = token_data["access_token"]
            # Subtract 60 seconds to provide a buffer for expiration
            self.token_expiry = time.time() + token_data["expires_in"] - 60
            return self.token
            raise Exception(f"Failed to acquire OAuth token: {e.response.text}") from e
            raise Exception(f"Unexpected error during OAuth token acquisition: {str(e)}") from e
Step 1: Configure the Genesys Cloud Webhook
Before building the receiver, you must register a webhook in Genesys Cloud. This example registers a webhook that triggers on conversation:analytics:summary events.
Required Scope: webhooks:webhook:create
import json
from purecloudplatformclientv2 import WebhooksApi, WebhookCreateRequest, PlatformClientConfiguration
def register_webhook(auth: GenesysAuth):
    Registers a new webhook in Genesys Cloud using the official SDK.
    # Initialize the SDK client
    config = PlatformClientConfiguration()
    config.host = "api.mypurecloud.com"
    config.access_token = auth.get_token()
    webhooks_api = WebhooksApi(config)
    # Define the webhook configuration
    webhook_body = WebhookCreateRequest(
        name="DLQ Webhook Receiver",
        description="Webhook for testing 5xx handling and DLQ",
        enabled=True,
        event="conversation:analytics:summary",
        url="https://your-domain.com/webhooks/genesys", # Your FastAPI endpoint
        # Optional: Add retry settings if supported by your specific use case,
        # but typically you handle retries server-side for granular control.
        response = webhooks_api.post_webhooks(body=webhook_body)
        print(f"Webhook created successfully. ID: {response.id}")
        return response.id
        print(f"Error creating webhook: {e}")
        raise e
Step 2: Build the Webhook Receiver with DLQ Logic
The core of this tutorial is the FastAPI application. It must:
  1. Accept the webhook payload.
  2. Attempt to process it (simulated here as an HTTP POST to a downstream service).
  3. If the downstream service returns a 5xx error, retry immediately a few times.
  4. If all retries fail, push the payload to an SQS Dead Letter Queue.
Note: Genesys Cloud expects a 200 OK response within 15 seconds. If you do not return 200, Genesys will retry the webhook. For this DLQ pattern, we want to acknowledge receipt immediately (200) even if downstream processing fails, shifting the burden of reliability to our internal DLQ system.
from fastapi import FastAPI, Request, HTTPException
from fastapi.responses import JSONResponse
import boto3
import logging
from typing import Any
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import requests as http_requests
# Configure logging
# Initialize FastAPI app
app = FastAPI(title="Genesys Webhook DLQ Handler")
# Initialize AWS SQS Client (DLQ)
sqs_client = boto3.client('sqs', region_name='us-east-1')
DLQ_URL = "https://sqs.us-east-1.amazonaws.com/123456789012/genesys-webhook-dlq"
# Downstream service URL for simulation
DOWNSTREAM_URL = "https://your-downstream-api.com/process-conversation"
@app.post("/webhooks/genesys")
async def receive_webhook(request: Request):
    Receives webhook from Genesys Cloud.
    Returns 200 immediately to acknowledge receipt, then processes asynchronously.
        body = await request.json()
        # 1. Acknowledge receipt to Genesys Cloud immediately
        # This prevents Genesys from retrying this specific webhook delivery.
        # The reliability is now handled by our DLQ system.
        # 2. Process asynchronously (in a real app, use asyncio.create_task or a message queue)
        # For this tutorial, we simulate synchronous processing for clarity.
        process_payload(body)
        return JSONResponse(content={"status": "accepted"}, status_code=200)
        logger.error(f"Failed to parse request: {e}")
        return JSONResponse(content={"error": "Internal Server Error"}, status_code=500)
def process_payload(payload: dict):
    Attempts to send payload to downstream service.
    Implements retry logic and DLQ fallback.
    headers = {
        "Accept": "application/json"
    # Define retry strategy:
    # - Retry only on 5xx errors or connection errors
    # - Exponential backoff (1s, 2s, 4s)
    # - Max 3 attempts
    @retry(
        stop=stop_after_attempt(3),
        wait=wait_exponential(multiplier=1, min=1, max=10),
        retry=retry_if_exception_type((http_requests.exceptions.ConnectionError, http_requests.exceptions.Timeout))
    def send_to_downstream():
        response = http_requests.post(
            DOWNSTREAM_URL,
            json=payload,
            headers=headers,
            timeout=5
        # Check for 5xx errors manually for retry logic if tenacity doesn't catch them
        if response.status_code >= 500:
            # Raise an exception to trigger tenacity retry
            raise http_requests.exceptions.HTTPError(f"Server Error: {response.status_code}")
        # If 4xx error, do not retry (bad request, auth error, etc.)
        return response.json()
        result = send_to_downstream()
        logger.info(f"Successfully processed webhook for conversation {payload.get('conversationId', 'unknown')}")
        logger.error(f"All retries failed for webhook. Sending to DLQ. Error: {e}")
        send_to_dlq(payload, str(e))
def send_to_dlq(payload: dict, error_message: str):
    Sends the failed payload and error context to the SQS Dead Letter Queue.
    dlq_message = {
        "original_payload": payload,
        "error": error_message,
        "timestamp": __import__('datetime').datetime.utcnow().isoformat()
        sqs_client.send_message(
            QueueUrl=DLQ_URL,
            MessageBody=__import__('json').dumps(dlq_message)
        logger.info("Failed webhook payload successfully sent to DLQ.")
        logger.critical(f"CRITICAL: Failed to send message to DLQ. Data loss risk. Error: {e}")
        # In production, you might alert here (PagerDuty, Slack, etc.)
Step 3: Processing Results from the DLQ
The DLQ is not a black hole. You need a mechanism to inspect and retry failed messages. This script polls the SQS queue, processes the messages, and deletes them upon success.
import json
import boto3
class DLQProcessor:
    def __init__(self, dlq_url: str, downstream_url: str):
        self.sqs_client = boto3.client('sqs', region_name='us-east-1')
        self.dlq_url = dlq_url
        self.downstream_url = downstream_url
        self.headers = {
    def process_queue(self, max_iterations: int = 10):
        Polls the DLQ and attempts to process messages.
        iteration = 0
        while iteration < max_iterations:
            iteration += 1
            # Poll for messages
            response = self.sqs_client.receive_message(
                QueueUrl=self.dlq_url,
                MaxNumberOfMessages=10,
                WaitTimeSeconds=5  # Long polling
            messages = response.get('Messages', [])
            if not messages:
                logger.info("No messages in DLQ. Exiting.")
                break
            for message in messages:
                receipt_handle = message['ReceiptHandle']
                body = json.loads(message['Body'])
                logger.info(f"Processing DLQ message: {body.get('timestamp')}")
                    # Retry logic for DLQ processing
                    self._retry_downstream(body['original_payload'])
                    # Success: Delete from queue
                    self.sqs_client.delete_message(
                        ReceiptHandle=receipt_handle
                    logger.info("Message processed and deleted from DLQ.")
                    logger.error(f"Failed to process DLQ message: {e}")
                    # Optional: Re-queue or move to a secondary error queue
                    # For now, we leave it in the queue for the next poll cycle
        logger.info("DLQ Processing cycle complete.")
    def _retry_downstream(self, payload: dict):
        Attempts to send payload to downstream service with retries.
        for attempt in range(3):
                    self.downstream_url,
                    json=payload,
                    headers=self.headers,
                    timeout=5
            except http_requests.exceptions.HTTPError as e:
                    logger.warning(f"Attempt {attempt + 1} failed with 5xx. Retrying...")
                    time.sleep(2 ** attempt) # Exponential backoff
                else:
                    raise e
                logger.error(f"Unexpected error: {e}")
                raise
        raise Exception("Max retries exceeded for DLQ message.")
# Usage
    processor = DLQProcessor(DLQ_URL, DOWNSTREAM_URL)
    processor.process_queue()
Below is the consolidated main.py file for the FastAPI webhook receiver.
import json
import logging
from datetime import datetime
import boto3
import requests
# --- Configuration ---
GENESYS_CLIENT_ID = "YOUR_CLIENT_ID"
GENESYS_CLIENT_SECRET = "YOUR_CLIENT_SECRET"
AWS_REGION = "us-east-1"
# --- Logging ---
# --- AWS SQS Client ---
sqs_client = boto3.client('sqs', region_name=AWS_REGION)
# --- Genesys Auth Helper ---
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str):
            return self.token
        auth_url = "https://api.mypurecloud.com/oauth/token"
        data = {
        return self.token
# --- FastAPI App ---
        # Acknowledge receipt immediately
        # Genesys Cloud expects 200 OK within 15s.
        # We return 200 to stop Genesys retries, shifting reliability to our DLQ.
        # Process in background or synchronously for this example
    headers = {"Content-Type": "application/json", "Accept": "application/json"}
    @retry(
        retry=retry_if_exception_type((requests.exceptions.ConnectionError, requests.exceptions.Timeout))
            DOWNSTREAM_URL,
            json=payload,
            headers=headers,
            timeout=5
            raise requests.exceptions.HTTPError(f"Server Error: {response.status_code}")
        logger.error(f"All retries failed. Sending to DLQ. Error: {e}")
    dlq_message = {
        "timestamp": datetime.utcnow().isoformat()
            QueueUrl=DLQ_URL,
            MessageBody=json.dumps(dlq_message)
        logger.info("Failed webhook payload sent to DLQ.")
        logger.critical(f"CRITICAL: Failed to send message to DLQ. Error: {e}")
# --- Main Entry Point for Testing ---
    import uvicorn
    uvicorn.run(app, host="0.0.0.0", port=8000)
  • Cause: Genesys Cloud rate limits webhook registrations or your downstream service is overwhelmed.
  • Fix: Implement exponential backoff in your retry logic. For Genesys API calls, check the Retry-After header.
  • Code: The tenacity library in the example handles backoff. Ensure your downstream service also respects rate limits.
  • Cause: OAuth token expired or invalid client credentials.
  • Fix: Ensure the GenesysAuth class is used to fetch a fresh token before API calls. Check that the client ID and secret are correct.
  • Code: Verify the get_token method is called before post_webhooks.
Error: 500 Internal Server Error (Genesys Webhook)
  • Cause: Your endpoint returned a non-2xx status or timed out.
  • Fix: Ensure your FastAPI endpoint returns 200 OK quickly. Do not block the request thread on long-running downstream processing. Use background tasks or message queues.
  • Code: The receive_webhook function returns 200 immediately after calling process_payload. If process_payload is slow, move it to a background task using asyncio.create_task.
Error: SQS Queue Not Found
  • Cause: Incorrect DLQ_URL or AWS credentials not configured.
  • Fix: Verify the SQS queue exists in the specified region. Ensure the IAM role or user has sqs:SendMessage permissions.
  • Code: Check the DLQ_URL variable in the configuration section.
